Isuzu Owners Maintenance and Repair
1565759616265
  • n9pugn9pug Member Posts: 3
    thanks for the reply, the 4700 ohm resistor makes it think it is about 62 degrees outside, so I dont think I am running it too lean. Also, what about mileage? I am getting about 16mpg combined mileage. I have read where the NEW mileage was 13.8, so am I above average? I would like to try to squeeze 20 mpg out of it, think thats possible? .....greg
  • santroopersantrooper Member Posts: 4
    my trooper is running well and but i have few problems at the moment. at times ReABS indicators pops up, especially after driving and in a major impact/vibration. i thought it is in the Fuse in the front fuse box but very difficult to rule it out. secondly the Engine Oil pressure indicator is not working, but temperature and other relevent indicators are fine.any body can help me in this issue.
    i had the same issue and did not take care it properrly. i was spraying belt dressings but one day knew it is from water fan. but it was too late. i had to replace water fan,radiator, tentioner,hoses etc. take care.
  • green11green11 Member Posts: 22
    Thanks for the advice. I was beginning to think my post would not get a response. I am definitely not doing the flush, but will strongly consider your recommendations.
    i had my starter motor replaced by a mechanic and he took almost 45 min. he took out the exhast manifold and replaced the motor easily. you can do that on the ground.
  • troop2shostroop2shos Member Posts: 235
    What most people refer to a flush is really a fluid exchange using the transmission to draw / pump new fluid in. There are all sorts of stories that putting new fluid in will remove the varnish holding seals & tranny parts together in a neglected transmission causing a failure. The detergent properties in the new fluid will keep particulates in suspension. Personally, if the fluid smells burnt or is brown from heavy particulate contamination, I would change out the fluid. Continuing to run contaminated fluid will only promote more internal wear. Draining the fluid & pulling the pan for an inspection (including checking the screen) may be prudent then properly filling with ATF before the complete fluid exchange later is another option to insure the system is clean.
  • timber2timber2 Member Posts: 1
    I have a leak that sounds the same as yours. What year is your Trooper. I have purchased the replacement line but have not had a chance to install as of yet.
    I had a 1995 Trooper with a tiny power steering leak. The line with the leak is a sharp bend and it is known to fail after 120K miles or so. Expensive little hose to replace.
  • russlarussla Member Posts: 74
    TOD essentially locks when there is a speed difference sensed between the front driveshaft and rear drive shaft.
    So there could be a sensor issue, or you could have under/over ,between front and rear, inflated tires that cause enough difference to trigger the locking
    I would ensure that the speed sensors are well connected.
  • bock1bock1 Member Posts: 1
    I have a 1999 trooper that the engine races at 2000-3000 rpms. I have spent over $1300.00 at Isuzu dealers only to give up! It will race sometimes for the whole day or just a couple of hours. The dealer checked the cables and installed sensors but nothing works. Can anyone help me.
  • daztrooperdaztrooper Member Posts: 2
    Firstly i live in ireland and 12 months ago bought what i taught was a clean jeep a 1995 trooper no major problems bar a clutch fluid leek.
    3 months ago the turbo blew which is look of the draw all the same cost 1400 dollars fitted.
    The problem im having at the moment has me broke and my mechanic lost. sent the jeep in to get belts fan,alternator etc tightened and a new back box fitted a few other bits and pieces which came to 900 dollars.
    since i took it back it cuts out as you take your foot of the gas and will not idle sometimes it will but eventually dies. duz any one have any advice. PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1 :sick:
    Is the idle problem only when the diesel engine is warmed up?
    NO the engine is very hard to start in the mornings is turning over but takes ages to fire the engine will sometimes idle but at some stage rpm just drops and engine dies. so i am pumping the rpm up with the throttle control knob keep in mind this is only an issue since the visit to the macanicks and before this i never had to touch the throttle control and it always started perfect even wen cold
  • dand1dand1 Member Posts: 1
    I have oil leaking into the spark plugs,all six plugs will be covered with oil.any ideas.
    now blows black smoke and fuel mileage cut in half and the gas has small explosions you can feel and hear
  • greybeard49greybeard49 Member Posts: 1
    The 4wd shifter on my 86 Trooper shed it's 4wd shifter ball pattern decal about 15 years ago, the drivers manual doesn't have a good photo of it, and the sunvisor drawings have faded into oblivion over the years.
    I'd appreciate it if someone would draw the relative positions of NEUTRAL LOW and HIGH ranges for me. I've rarely used 4wd except when I'm in the mud behind the barn, and it pulls pretty good in first gear in whatever range I'm in.
    This thing is no spring chicken anymore - the clutch was last changed in 1994 but the AC works and it's still pretty tight after 275,000 miles. This March, I'm getting a "new" daily driver - an '87 with only 42,000 original miles that has most likely never been in 4wd or even driven across a lawn. My "Big Blue Bus" will have it's top cut off and an awning fitted, and it will live its days out in our horse pastures and fire roads hauling feed and hay and farm wagons. Other folks with little or no experience will be using it, so I'd much rather know for certain that it's in low range.
  • skill124skill124 Member Posts: 5
    Please all - I need suggestions. Someone close to me idled my 2002 Trooper in a closed garaged for about 3 hours - at best guess.. - assume the worst just please don't don't ask for specifics. Back from the police - here's whats wrong: TOD check light on - feels like 4wd is engaged. Check engine light on, lots of connectors on the left side (exhaust side) melted. I think is the rustproofing on the bottom is fried and just flakes off. The parking brake is stuck on - handle just flops up and down, a friend yanked something underneath and it went off, but pulling it up again got it stuck and flopping again. It has 52000, so its still under the extended warranty. What should I do??? Take it straight to the dealer - they'd tell me it was abused and not cover anything right? All it did was idle and get very very hot - so hot some of the plastic rivets in the fender melted into stringy stuff. Does anyone know what can really be affected by this and how best to get into selling shape? I personally can never drive again - so its a matter of paying off the loan balance - fixing for as cheap as I can - and selling it. Can I fix some stuff so the dealer will check the major stuff under warranty??? I just confused - need help. Any thing would be appreciated.
    skill1234
    Sorry to hear about your loss.
    Here's some food for thought.
    I would check on what your comprehensive insurance will cover, so call your auto insurance company, also call the friend's, if they had a policy, to see what they're liability or comp covers.
    I suspect Isuzu will deny any claims, because when it got hot, it wasn't turned off, the trouble lights were essentially ignored so that is abuse from there POV
    The parts that put the parking brake on, have to be metal, so it works in an emergency, but the parts that release it, don't, so since it was so hot that it was melting plastic parts in the enginebay,it could have melted something above the TC too. I also suspect that the heat burnt up a few electric parts, this may also be the cause of the TOD issue, as the sensors could be fried.
    If you get no assistance from insurance, you'll have to start fixing on your own, so...
    Because it got so hot, I would change the TOD fluid, and the tranny fluid too, and it wouldn't hurt to add a cleaner to the oil and change it out.
    Lastly, and this is the probably last thing on your mind, if the worst happened, one might claim against the estate if they really were burdened by the $$ damage to the rig.
    Best Regards
  • jgarsjgars Member Posts: 1
    I have a 99 Trooper S w/auto trans. The car has 78k miles. In November I took the car to have a 60k mile service done which hadnt been done and the car had 75k miles at the time. They did the job. Last week i had been driving and noticed that the oil light was lit so i took the car to the dealer and they said that the problem was that the car was using more oil than before and that all i needed to do was to check the oil level. Today i was driving and i began to hear a "clunk" noise from the engine or from where i believe the noise is coming from. The noise got worse and luckily i was close to my house. Does anyone know what the problem can be. I feel that the service rep. was full of bs.
  • tabitha_btabitha_b Member Posts: 1
    This may sound ridiculous, but i just got a new motor put in my '01 Trooper by the dealer near me. When i got it back, the dealer told me that for the first 1000 miles i shouldn't drive the car over 60mph. This seemed very weird to me and i was just wondering if this is legit or if i should just consider the guy out of his right mind.
    That was how the engines were years ago, the "break-in period" (below 55mph and variable speeds not all break-in miles at one engine speed or load) is meant to allow the piston rings and other parts to mesh together and wear down a little so the piston rings seal up as best they can. An improperly broken-in engine long ago, would tend to burn oil through its whole life. I'd follow that restriction and look up more about break in procedures on line and send an email to Isuzu to ask if this applies to your engine. I think most newer engines get some break-in hours in the factory. Johnson outboard motors use a different piston and cylinder technology that have very tight tolerances and they sell not needing a break-in period as an advantage over otehr engine makers.
    1000 miles will go by very quickly, I drove over 2000 just last week.
  • atfdmikeatfdmike Member Posts: 414
    Not a ridiculous question at all. As Boxtrooper says, it is unusual in this day and age to have special break in for newer motors. It is common practice, except in high performance engines, to use non-synthetic oil before the first oil change and to vary the RPM's of the motor for several hundred miles of driving before hitting a freeway on a long trip. The tolerances are so tight now on motor construction now that the dealers advice won't hurt, but you should consult Isuzu for a definitive answer.
  • sinfulkittensinfulkitten Member Posts: 2
    Hi I have a 88' trooper that will not start and won't do anything, the radio won't even come on, no power what so ever. We just put a new batt. and starter in it but still no power. Anyone have any advice or anything to help us out??? :sick:
    Will any of the lights come on (head lights brake lights dome lights)?
    I would have a look at the fuse box and then the ignition switch, there might be a relay after the ignition switch to enable all the stuff that comes on when the ignition switch is turned on.
    Have a look at your battery cables. Put one probe from your volt meter on battery positive termial and the other on battery negative terminal, write down that voltage. Leave the positive battery terminal connected to your volt meter and move the other voltmeter lead to an exposed metal part of the engine, if you can't get the same voltage as before then you might have broken or corroded inside battery cables.
    Keep posting results I like a puzzle.
    We have already checked all that stuff, theres no relay after the ignition, we took the dash apart and looked. And the battery cables are brand new, as is the battery. No lights come on at all not even the inside light, theres nothing. Anything else you can think of though will be very helpful. We're at our wits end on this!! :confuse:
  • 89trooper89trooper Member Posts: 8
    :cry: OK i've been thru H*** and bach with this car we tracked it to the ECM bought an ECM thru someone we found online well the first they sent didn't at all so they sent us another one which did work but only for 2 days(In the ECM there is a Memory Calibrator(Smaller Chip) Unit and a Prm Unit(bigger chip)that you are suppose to pull out and replace with your car original ones which we did with the first ECM that didn't work.. with the second we changed both out then on the off chance just changed the Prom Unit and used the Memory Calibrator that was sent in the box and for some odd reason it ran. We were of course happy but like i said only ran for 2 days... in th middle of all of that i sent my original memory calibrator back to the company in one of the ECM's(core price) which didn't work anyhow..anyhow brings me up to date with the company having just sent me another ECM and aaarrrrgghhhh my car is still not running any help at all??? by the wat not even a chech engine light :cry: thanx Lisa
  • 94trooper5spd94trooper5spd Member Posts: 1
    My 94 Trooper overall is a great truck! It's been a great vehicle to own the past few months. The truck runs great when it is cold but does not when the temperature is above 40 degrees outside. Yesterday after driving 17 miles on the highway from the burbs to the city, the vehicle got very sluggest once I jump off the highway. I had to rev the engine to around 4000-5000 rpm to get it to move. I thought the clutch was failing. A few block later and three traffic lights the truck would not move forward at all. Reverse barely worked too. So I call a AAA. After waiting 40 minutes for AAA, I decided to try driving again. The truck began to drive like nothing was ever wrong. The clutch felt okay. The rpm was normal. So is it really the clutch at fault or is it something else?
    Dave
  • dangnojekdangnojek Member Posts: 2
    I was looking at putting slightly bigger tires on my 2000 trooper. I wanted to know if anyone out there knew how big I could go before I have to start lifting it and cutting up wheel wells and fenders.
    I have heard of a few people having a problem with the 3.5L engine in their 99 or early 2000 troopers. When it would get to 60 or 70k miles it would break down, and isuzu fixed this in the later 2000 troopers.
  • jacqui1jacqui1 Member Posts: 1
    hi all - sorry but i need a little help i have a isuzu rodeo which i really like but me being me i checked the oil and it is a little low but i cant find anywhere to fill it up, where is my little plastic cap??? that says oil here!!!(all my other previous cars had one -made life a lot easier) please if any one can tell me i have looked hard under the bonnet but cant find anything and i really dont want to go to the garage just to top up my oil many thanks
    Jacqui xx :):)
  • df2000df2000 Member Posts: 60
    It is black screw in cap on driver side valve cover, have no marking, assummed you have v6 engine. Or stop by in any Pepboys or alike and look in the book(Haynes).
  • westernwestern Member Posts: 1
    92' 3.2L 5-speed manual Trooper (131,000 miles). It wouldn't start 1 morning & has been flaky thereafter.
    The last 2 years (maybe 2 or 3 month intervals?), the engine might quit while starting up from stoplight (1st gear), but would restart easily or revive if I hit the gas quickly. Also, something (fuel pump??) makes noticeble mid to high (whine?) noise 1-2 minutes after engine is turned off.
    Starting last summer, speedometer needle would drop suddenly to pin while driving, but then suddenly work again during driving: maybe down 3 days+. Operational since September, it quit 1/2 day in Jan or Feb.
    Got a tank of bad gas approx. 2 weeks before car died & car bucked/jerked really hard all day. Ran down tank & filled with fuel w/out water & car ran about a week. Thought maybe fuel pump or inline fuel pump, but rough to access. Mechanic replaced fuel pump relay and car ran several days w/some stalling, but re-started well. Appeared car ran/re-started until engine got hot after 1 hour driving - then wouldn't restart. Would restart after sitting 10/20 minutes intervals, but now the engine just turns over. Had replaced air filter/fuel filter/& cleaned pvc valve around time of bad gas. Isuzu dealer said sparks/wires/& fuel injector flush would solve stalling, so installed new spark plugs/wires/& ran heet-type stuff, then fuel injector cleaner through tank. Since outside temp's, been down to 15F or high as 32F, I poured 1 bottle iso-heet in tank to rid of possible water, but I'm back to poss. fuel pump or fuel pump regulator or mayber something els.....???
    Suggestions?
    Thx,
    western: maybe your problem is like this one: I had a problem with my 2001 Trooper where it was idling rough sometimes and had little torque at just off idle, but with more open throttle it ran great. That turned out to be the EGR (Exhaust Gas Recirculation valve) going bad by sticking open I think. The replacement of the valve actuator is easy except that the valve body must be cleaned thorougly of the carbon buildup which is tedius, so the labor will cost as much as the valve if you have a mechanic do it for you.
    I also have a very slight knock at the moment because it has a tank full of 87 Octane but the engine computer is used to 89 or 93 Octane, so I will get a bottle of injector cleaner (I am partial to the valvoline Synpower brand) which will eliminate the slight knock for this tank full and clean the injectors at the same time. I like to use higher octane fuel because it allows the engine computer to adjust the timing a more advanced which gives quicker throttle response, and the pre-ignition knock however slight and probably completely normal, bugs me, makes me think I am treating my engine poorly.
  • idiot2idiot2 Member Posts: 1
    like an idoit that i am i put the battery in wrong way round and now nothing comes on i believe i could of blown a fuse but cant find it. Any help would b much appreciated.
    :confuse:
    You might have blown a "fusible link" which is basically a big fuse hidden in the main lead off the positive battery cable. Some FLs are replaced by splicing them into the wire and some are plug ins. You might need to consult a repair guide or ask a mechanic where this fusible link is on yourcar.
    Reversing polarity may be a lot more damaging than merely blowing a fuse. I'd get it checked out ASAP.
  • pv10chagpv10chag Member Posts: 2
    I spent the last weekend going through literally every post trying to find something that might give me an answer to my problem. Since I have to drive from Mexico back to Ohio in about a month, now I gotta ask.....
    96 Trooper LS, 187k miles. The problem now - intermittently flashing check engine light. It seems to happen just before the shifts between the lower gears or when the engine is under stress, like going up a steep grade. I step on the gas, feels like nothing happens, then suddenly the light starts flashing, the RPMs jump, I accelerate and then everything goes back to normal and the light stops after a few seconds.
    After the trip FROM Ohio to Mexico, I had to have the tranny rebuilt but not real confident in the work by the Mexican mechanic... it took him 7 tries, with various leaks and slippage, before he finally went to "the big city" to get NEW parts. At least he knew it was a GM tranny when I brought it in and he has honored his "warranty". And although it seems to "jerk" right now, I think it is more to do with what is going on with the Check engine light and the acceleration problem. However, I didn't have this problem before I had him work on the tranny....
    I read about the "disconnecting the battery" thing to reset the sensors/computer because I did have it fueled up with the key in the "on" position, but that didn't help.
    Before I left Ohio, I told the mechanic to spend whatever time he needed and do ANYTHING that he thought would/could cause problems on the trip down here. Things done recently, back in the USA at 183.8k miles:
    New shocks all around
    New fan clutch
    New wheel seals
    New radiator hoses
    Air and fuel filter
    pcv valve
    spark plugs
    1/2 shaft
    Tie rod end
    Idler Arm
    Oil change/filter
    V belt
    EGR valve
    Coolant fill and bleed
    Drain and refill axles
    Clean/repack front wheel bearings
    Replace Power steering belt and pulley
    Drain/Fill transfer case
    lube cables and linkage
    Had the water pump replaced at 170k and since they were in there, had them do the timing belt also.
    Am I looking at a possible O2 sensor or something more sinister? I love my girl, got her brand new and would really like to keep her around for another 50k or so... I know she can do it. All I want is for her to get me back to the border where I can take her to a dealer, if I have to...
    Help!
    pv10chag
  • wells3wells3 Member Posts: 2
    Someone help me please......okay here is the deal, I broke a wrist pin, after i called around for estimates to rebuild the 3.2L v6, it was cheaper for me to buy a new motor, now that i have it installed i'm having more trouble, when i picked the RODEO up they told me I had a converter clogged on the drivers side,and when he stuck the o2 sensor back in, the truck would cut out like it was out of time.I drove the truck to a well trusted muffler shop, they ran test and said the converter was good, but the number 2 cylinder was misfiring but not enough to pin point the exact problem, then they said it could be the mass air flow,then a friend said no it could actually be a exhaust problem, then i read on here and someone said something about high performace plugs....i need some rodeo advice....
    james
    I think the spark plug issues that have drifted past here are two types:
    1.) what are the best plugs
    2.) why can't my engine use anything but the original plug?
    Question 1.) The 3.2L engines that have spark plug wires can use any spark plug that fits. And if desired might benefit from the full ignition kit available from http://www.directhits.com.
    Question 2.) Some newer engines with coil over spark plug measure some sort of feedback from the coil over plug unit, and changing the spark plugs away from the original type can change the feedback measurement enough to confuse the engine computer.
    If you think you might be having ignition troubles, don't forget to check the plug wires and ignition coils also.
  • 3blkcats3blkcats Member Posts: 1
    Hello, Just found this forum, and saw this post. Where could I find more information on the timing belt tensioner problem that you mention? I have a 92 Trooper with the 3.2 DOHC engine. It makes a knocking noise after slowing down from extending interstate driving, and seems to go away after a few seconds of idling. The t/belt, tensioner and hydraulic lash adjusters were replaced about 20k miles ago, and the noise doesn't happen as often, yet it still occurs randomly. Thanks for your help.
    thanks boxtrooper,
    but heres a question what is the standard issue of plugs for a 1998 isuzu rodeo LS 3.2L V6 w/coil package?
    And one other thing, should i start with the plugs? My Rodeo right now has now power what so ever, i had to leave it in first gear just to get it to climb a small incline to bring it home.But if i take out the O2 sensor on the drivers side it runs like a champ but its real loud because there is a hole in the exhaust, can you give me an idea of where to start? much appreciated!
    james
  • bahmedbahmed Member Posts: 66
    I recently changed the spark plugs on my 1998 Rodeo, V6, 3.2L and Had the same question, I did the extensive research and when I took the old plugs out, they were Champion Double Platinum RC10PYP4, stock No: 7346, they come pre-gapped at 0.044. They are available at AutoZone, ORiely Auto Parts Stores, just ask for Champion Double Platinum, Stock No : 7346, they were i believe $5 a piece. The later model Rodeo, V6 engines were changed to Denso Spark Plugs as they come with a new Ion Sensing Emission Systems etc. 1998 Rodeo, V6 suppose to work with any Platinum plugs, at least this is what I read on most of the posts.
  • setiansetian Member Posts: 1
    There is a serious problem with the http://setian3.smugmug.com/gallery/1320127. The alternator has ripped the block that holds it in place. I basically need a new engine block. The insurance company says they will not cover it because they believe it is due to previous improper repairs (e.g., Someone did not tighten one or more of the bolts securely enough. This led to the alternator ripping out of the remaining bolts). Has anyone ever had this happen to them?
    I'm having trouble with your link; looks like this is it though.
  • hbfuseblowerhbfuseblower Member Posts: 1
    Check engine light refers to oxygen sensors. Sensors have a lifetime of 70K-100K miles. I believe there are four individual sensors. Oxygen sensors operate at very high temperatures and thus wear out. When they become intermittent the car can perform badly. Any reasonable mechanic can find the bad one and replace it. I replaced one of the sensors in 2000, cost $110 then.
    Good Luck.
    Howard
    Thanks Howard...
    Had another friend tell me the same thing. Also said that with the recent transmission work, could be a problem with linkage out of alignment... Gonna have both things checked.
    Thanks again!
    pv10chag
  • predatorpredator Member Posts: 3
    Hi to all Trooper owners out there. How's things your side of the big pond?
    PREDATOR
  • highjumper25highjumper25 Member Posts: 3
    i wanted to see if someone could help me with my problem that I have with my 2000 Rodeo. I have oil getting into my 1 and 3 sparkplug wells. I had this problem for 2 years. Everytime I bring it to a mechanic they say it is the valve cover gaskets, they have been changed 3 times and i still have the problem, can someone please help me!
  • my914my914 Member Posts: 1
    Hi my 94 trooper will only run when I spray gas in the throttle body but will not run on its own,fuel injectors have no fire when tested,Is this a ECM problem or just bad wiring or injectors.Thanks
    I think the spark plug wells are press fit at the bottom, and may leak a little when temerature is changing. I had a half teaspoon of oil in the spark plug wells on my 3.2L 1995 Trooper, it did not cause trouble. Maybe head bolts need re-torquing?
  • cumberlandcumberland Member Posts: 1
    Help,... Anyone... My 1994 Rodeo 4WD LS 3.2 Liter will leak
    a full radiator within 50 miles. It never leaks when the engine is cold and stopped. Nobody can find the leak..! but everyone agrees it's between the rear of the engine and
    the firewall, and there is only about two inches between the two and you can't see where it's leaking from. Does anyone know where the leak is from...?
    There is NO water in the oil.
