I also recently tried my varied "grade" of fuel test. A tank of 91 octane to compare to the usual 87 octane I use. There was no improvement in mileage during this tank of fuel. Supports what you read about pouring money down the tank on higher octane fuel, unless of course, you're getting "pinging" with the lower octane.
bsmart
Therefore to finally answer your question, I do also grease these fittings every 3rd oil change.
Isuzu Japan it is rumored that they will be converting all thier plants in japan over to med duty and bus assembly. The 2003 Trooper *may* and I stress *may* be produced in IN where they make the rodeo and Axiom now.
-mike
http://www.asahi-net.or.jp/~uw7a-mrn/top/bighorn/fig6/fig805.htm
Translation for each pic:
1. On universal joint between rear differential and drive shaft.
2. Between rear shaft and transfer.
3. On universal joint between transfer and front shaft.
4. Between front shaft and differential.
...Eiji...
-mike
-mike
http://isuzu-suvs.com
-mike
The [minuet] was performed by one couple at a time, with the order based on social hierarchy, while others watched and waited their turn.
So, it would seem that your clock thinks it holds a higher position than you in the social hierarchy, and that's why you have to manually set it back. You need to have a long talk with that clock and explain to it that YOU are the top dog, and that YOU go first, and that THE CLOCK should beep on the hour.
Now, does that help?
- Sue, who's just pulling your leg, and who has no idea if her clock beeps or not because the radio is ALWAYS on.
My truck's clock doesn't beep. Now if yours beeps consistently no matter 11:57, 12:00 or 12:03 on the trucks setting, it really sounds like you might have a digital watch in the glove box or ash tray?
The beeping IMHO is a watch under the seat, or in the glovebox, etc. Change the clock so that it reads 3 minutes earlier. If it beeps on the hour, then it's a different clock, not the one in the dash.
-mike
As far as the beeping clock goes, I checked mine last night on the way home from work and it did not beep. Just curious though does the person who posted the beep messsage have an aftermarket stereo. There are some car stereos that will beep on the hour. If not there definately has to be a watch lost somewhere in the car.
-mike
-mike
-mike
Here we were all consumed for a day or 2 about a beeping watch! Those are the type of problems that make me happy I have an Isuzu.
-mike
-mike
-mike
Charlie
-mike
I full throttle the gas pedal while the truck is either standing still or moving as long as it's still moving in first gear. As my truck attempts to change between 1st and 2nd gear (while maintaining the full throttle) I get this massive vibration, jerking and banging sound coming from the rear as if the trans is slipping in and out of 2nd gear. It's actually sort of scary. It does this both with TOD on and off.
I need to take it back to dealer for this one. I noticed this the first time I drove the truck home and did the full throttle thing. Foolishly, I never did anything about it.. like took the troop back to the dealer. I actually forgot about it until a few days ago when I did the full throttle thing again. Now..... it aggravates me.
Has anyone tried this? Has anyone had this type problem?
Steve P.
David
I had a bunch of deck lattice in the vehicle with me, and had NO mirror visibility. (If Isuzu would put a freakin' rack on the roof, this wouldn't have happened...) Stupid me. Anyway, backing out REALLY slowly, there was a BUMP, so I jumped out and I had hit a Honda CRV. It had a grapefruit sized dent in the corner of it's bumper (black plastic, NOT painted thank goodness). Trooper: No damage visible! I was really surprised, as I haven't heard too many positive things about the stock bumpers. No scratch, ding, dent or warp. There must be metal frame behind the plastic trooper bumper, because the CRV's internal frame was about 5 inches away from the bumper material, allowing it to dent. We were able to pop out his dent right there, with virtually no residual damage.
I guess this is a credit to the Trooper (2000 Ltd 2WD), that their bumpers aren't total crap after all. If I had one of those extra protective bars installed, it probabably would have cut into or done more damage to the CRV. Just a thought.
Trooper Wins!
Andy
Nashville
