Visitor Agreement.
My 2000 S Trooper is two-tone - the lighter silver color with slightly darker trim.
If Jimmy or anyone else is interested, e-mail me at koert@pierpont.com
Koert
Jim
http://www.truckaccessories4less.net/trooper.html
The IPF lights are good, way better than the stock headlights.
Overall I think both were a good investment.
-mike
http://www.itog.com/board/?topic=topic4&msg=1607
http://www.itog.com/board/?topic=topic4&msg=1784
-mike
Time to go back into the Power Generation Industry.
-mike
Though not the competition I went to, the following link is one of their other ones. If anything the event I saw was even more severe and almost all the rigs had a lot more damage than just tire abrasion.
http://www.rockcrawler.org/gallery/gallery_jv_feb2001_d.htm
If, in addition to bigger tires, you crank up the front suspension via the torsion bars, you theoretically could change the camber. However in our experience the small change needed when swapping in the OME springs does not appear to affect the camber.
Now if you were to crank up 3 or 4 inches with custom springs, then you may very well affect the camber and should have it checked...
http://www.edmunds.com/chat/isuzuchat.html
-mike
-mike
Any help is greatly appriciated.
-mike
http://www.discounttire.com/tireSiping.html
Jim
Sent email to the Rancho website, but no return as of yet.
-mike
-mike
http://forums.vmag.com/suvrodeo0300/
Two years ago their favorite shock was Bilstein. I installed Bilstein on my '99 Passport which was great but too firm for long drives and small road irregularities can be felt which is normally ignored by the factory shocks or the Monroe matic.
The Monroe rep. advised Sensatrac over monroe matic but two Rodeo owners who tried both advised Monroe matic over Sensatrac.
I finally replaced the Bilstein with Monore matic plus and I am very very contented with the ride improvement.
My 2 cents.
-mike
Jim
-mike
The 684s are a 106S (112 mph) tire marked on the sidewall.
-mike
BTW, it broke when a 2" round tree lying across the trail spun behind the front tire and snapped the flap off.
that sux.
-mike
...Eiji...
I have Yakima on my '95, works great but there is some wind noise when racks are empty.
I set up my rack for maximum spread between the crossbars - for hauling a canoe. The gunwale bracket set comes with a set of straps to lash your canoe down. After it's assembled / fitted, the rack installs in less than 5 minutes so I leave it stored in the garage most of the time.
-mike
