Visitor Agreement.
Con
-mike
FYI I have a 99 Trooper...
They have another base kit which provides additional base position at the front (above front window area). It is for installing full size roof rack.
Paisan is doing great job by locating suppliers in Australia. I'm sure price would be lower from AU than from Japan.
Paisan: The dealer I got the kit from enclosed a catalog of Bighorn accessories. Can I send it to you? Besides price, it even shows required installation time.
...Eiji...
-mike
To route the wires I used an existing hole in the firewall that was located at the extreme left side of the footwell. There was a large rubber grommet in the hole already holding wires passing out to the engine compartment. I just threaded the additional wires thru the grommet.
Good luck, Marty
95 Trooper LS
-mike
Con
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=592128066
Thanks. Troopin.
Any info appreciated!
Rick
...Eiji...
Cheers,
Con
-mike
http://www.thule.com/English/welcome.htm
I would love to have a set of these, or even better yet, a set of the roof rails. Has anyone come up with an overseas contact yet?
Thanks - and thanks to everyone for the interesting messages day after day.
Koert
-mike
The front suspension "lift" with the OME rear coils does not change the suspension travel at all, merely repositions the equilibrium point an inch or two higher, by adjusting the torsion bars. So, I don't think the lift would affect how high you have to jack it to clear the ground.
The bigger tires, however, WILL increase the necessary jacking height. My 265/75R16s should need about another inch to clear...can the supplied jack do that? I don't know, but I probably should give it a try one of these days.
-mike
-mike
As for Tire rotaion, I don't know about you but I have my shop rotate them when they do the oil change. I have not taken my new Trooper to anyone yet so I am going to try the Dealer first and see how their service is(I normally went to the local shop for work). When I use to do the work myself(Yes I am too lazy), I used the spare to rotate the tires or even easier, use a 2 ton jack and the factory jack so you don't have to use the spare(more dangerous as two wheels are off the ground though).
Cheers,
Con
Now that I have an aluminum wheel for my spare, I am going to do a 5-wheel rotation, so I'll be able to just swap the tires at each corner as I go around...
-mike
The only thing I can think of is if the spare is different size because it hasn't been used (and therefore has more tread left and a slightly larger circumference)...
Seems to me there is a 5 wheel rotation mentioned in the owners manual...you've forced me to go out to the parking lot and look!
Well, I'm back and the owners manual for my 99 shows three different rotation patterns: a 4-wheel front/back swap, a 4 wheel "X" pattern, and a 5 wheel rotation. Page 6-11, if you care.
I think the main thing is that you are actually rotating them consistently, more than the pattern you use...
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
My contact is still checking out the side-turn markers that go right in front of the front doors.
-mike
-mike
Re: 3rd Row Seat
It was not listed in the Japanese accessory catalog. I've read somewhere that Trooper models w/o the 3rd row seat do not have mounting hardware and need mod.
...Eiji...
I am considering a highlift jack for off-road? I carry plywood for under the jack, but I also carry "fix-a-flat". I would imagine that is the best way to fix a tire on the road or in woods. If I get hung up on an obstacle though, a highlift would be helpful.
Oh yes that jack is a pain in the #$@. I bought a scissor jack from autozone for about 17 bucks and am carrying it always in my Passport. Also bought a "cross" tire wrench, the flywheel action of the cross makes it a breeze to remove and install the wheel nuts.
Another other problem is Hi Lifts are awkward (like 4 ft long) to haul inside an SUV. They're heavy and have sharp edges which can damage the plastic side panels in the cargo are when you're bouncing around off-road. In this part of the country they're hauled mostly in the back of a pickup or bolted to a front bumper , roll bar, etc.
On repairing a tire when you're off road, you might check out some the 4WD speciality shops. They have a number of tire repair kits that work very well for nail hole type punctures. You can repair the flat in 5 minutes or less with the tire on the vehicle, then air up with a portable 12 volt compressor that works from your battery or cigarette lighter. The 12 volt compressor also works very well for those who like to air down their tires for driving on sand etc., then air them up again for the highway.
-mike
Does anyone have detailed pictures of the 3rd row seats? Like mounting brackets, hinges, etc.
-mike
I have scanned the catalog just in case you need translation. The catalog was slightly larger than my scanner bed, so edges are cut off, but you can see most of pictures and descriptions. I'll email them to you.
...Eiji...
-mike
-mike
Thanks for the tip on the leather seats on e-bay. The auction is really a front for a company at
http://www.autoaccessoriesrusfl.com
They have leather replacement seat covers for $599, which is the best deal I've seen. Has anyone else tried replacing their own seat covers? It looks straightforward enough.
Paison, looking forward to seeing the Japanese catalog on your web site.
Thanks to all, Koert
The lights look cool on the black one but I don't think it will look as good on a lighter color.
Cool pics though.
Con
-mike
-mike
