Visitor Agreement.
http://www.mpt.org/motorweek/reviews/rt2030.shtml
-mike
Isuzu V8 DOHC
3 Rows std.
Longer, wider, still boxy
Axiom dash-like compnents.
-mike
-mike
http://www.autonews.com/html/main/stories/gm405.htm
2002 Trooper; A redesign is on the books for the Trooper, due to keep its body-on-frame Isuzu roots and some of the looks of the SUV concept car shown at the '97 Tokyo Show.
Does anyone recall what it looked like? I thought that was the Axiom?
http://www.edmunds.com/reviews/futuretelling/articles/44810/page017.html
The remake won't be til 03 or 04MY.
-mike
Although, Isuzu will be making the future Trooper in Japan.
Thanks for the info.
-mike
-mike
-mike
The same drivetrain may just mean the same technology? I have been wrong before...so I have tomorrow off and will stop by and verify. I also plan on a test drive.
On another note, we were out walking Sunday morning thru a neighborhood we normally don't visit (part of the March of Dimes Walkathon) and I saw an Axiom parked in a driveway. Still had the temporary tags on it. I expect it's a solid vehicle, but the styling didn't do anything for me. It was my first face-to-face with one, and it was even smaller than I had expected. I guess it really does fit a niche, just not mine.
Charlie
1) 3 rows of seats
2) Longer, wider, slightly curvier (not sure if that is overall or just the front)
3) Isuzu Built V8 power
4) Built in Japan
5) Model Year '03 launching next spring/summer
Those are the solid details which isn't much. Also check http://isuzu-suvs.com as we'll post up details there as well.
-mike
-mike
-mike
I'd love to see the duramax diesel in the next trooper but I wouldn't count on it.
-mike
-mike
BTW--the running boards on the SR5 would be destroyed in a real offroad scenario.
-mike
The 4WD Hi system on the 2001 sequoia, land cruiser, and new 4runner are apparently identical--3 open differentials (front, rear, and center)--and the same system is also used in the Mercedes SUV. This allows dry driving conditions but it seems to me that would result in power going to predominantly one wheel? When slip is encountered the brake counteracts that slip at one wheel sending torque to the other 3 wheels. Also has a 4WD Lo with standard 50:50 split. The VSC in combination with that open diff system supposedly works very well. I just wonder about the use of the brake on a 4WD system--although I am sure it works.
-mike
I like the TOD for the fact that if you are spinning both axles, it will remove power from the front axle and then re-apply it giving the front wheels a chance to grab, whereas the 4wd Lo will keep 50/50 power not allowing the front wheels to grab.
-mike
-mike
Oh, BTW I read something interesting pertaining to oil consumption in the sequoia manual. It says its from oil slipping past the piston rings or valves during deceleration, due to the sucking effect. I wonder if gearing your vehicle down alot increases that. Also, it said that around town driving can make it look like you're burning no oil due to fuel and moisture not be burned out of the oil. After that if you do hgy driving, the oil looks to go down alot. This was sort of what happened to me on my trooper.
Nighter, I did get the cloth in gray. The truck is Marlin blue metallic with gray trim + bumpers. The seat seem good to me. They are wider, but thats fine with me.
-mike
-mike
-mike
-mike
