BMW 3-Series Maintenance and Repair
17778808283105
    ventureventure Member Posts: 2,883
    Search at www.bimrs.org
    They list 2 in your area.
    2020 Ascent Limited, 2024 Subaru Legacy Sport
    jetzzsjetzzs Member Posts: 64
    Thanks for all the comments and suggestions. The field rep looked into the problem and the BMW dealership called and said that BMW would pay for all but $500. My husband then authorized the repair right away. That is a savings of $900. It seems like this confirms that they know they have an engineering issue with the oil separator. (We have a 2001 330i with about 100k and we just paid it off and got the title in the mail two weeks ago).
    Thanks for all the posts and have a great New Year!
    roadburnerroadburner Member Posts: 17,365
    Sometimes a manufacturer will pick up all or part of some repair costs for loyal customers as well. The oil separator is not a chronic problem but they do fail on older cars at a higher rate. The part itself isn't that expensive, but it is a bit labor-intensive to install.
    Mine: 1995 318ti Club Sport; 2020 C43; 2021 Sahara 4xe 1996 Speed Triple Challenge Cup Replica Wife's: 2015 X1 xDrive28i Son's: 2009 328i; 2018 330i xDrive
    uncletouncleto Member Posts: 45
    need help on finding why the carpet is wet on the driver side mostly after rain. check all the seals on the window and the door, looks fine to me. had suspicion but not sure about it im not losing coolant so i dont think its coming from there. hope anybody out their who had similar prob. will be able to help me. its a 2001 32ix wagon and 60000 miles on it. any imputs will be much appreciated!
    Do you have a sun roof? If so, it could be caused by a plugged drain hole for the sun roof. Good luck!
    gbrostekgbrostek Member Posts: 9
    There is some kind of seal inside teh door, that if leaking can cause this problem
    I had same problem in my 2000 323i on passenger side, and teh dealer replaced some sort of seal inside teh door and problem went away
    This was 2 years ago
    curiously I have water there again and am not sure if it is teh door or something else. I just had the compressor on the A/c replaced, not sure if they are related
    In addition to the windshield seal and the sunroof drains, I'd check the inner door insulator panel; part number 12 in this diagram.
    when you say inner door insulator are you referring to the vapor barrier on the door? some had told me that might be one of the source of the leak.
    Yes thats it the vapor barrier
    Now why should tehy go bad? I have no idea
    Did I EVER have these problems with a US made car? NO
    Did my electric window regulator fail last week when I tried to lower teh winder in teh snow? Yes.
    Do I love driving very fast on dry highways with this car? Yes
    HCM5HCM5 Member Posts: 2
    Did you ever figure out what was wrong? We have a 2004 330xi with just 20,000 miles that has been having the same problem. When you turn the key, the lights go on and there is a soft humming sound, but no engine ignition. Sometimes, if you give a 2nd quick turn of the key, the engine starts up fine. Once the car is "on" it's completely fine. First time was in March 2008. We had it checked at our dealership, everything checked out diagnostically, though they suspected the key could be a problem and then we didn't have any more problems for 9 months. Now, after our first really cold spell, the car is doing it again. We left it alone for a week over Christmas, then it started fine and we got it over to our dealership. They kept it for a week, again found nothing obviously wrong with it, and decided to try replacing our key. We brought the car home and within a few days, we had the same problem. It is now sitting in our garage. We will wait a few days, then try to start it and get it over to our dealership.
    We have a 2004 BMW 330xi with 20,000 miles that is intermittently starting. We turn the key and all the lights go on, but there is no engine ignition or even any sound. Sometimes, if we follow with a quick 2nd turn, the car starts fine. First time in March 2008, had it fully checked at our BMW dealership, only duplicated the episode once and could not find anything obviously wrong, though they mentioned maybe the key was a problem. The car was completely fine for the next 9 months. Then a few weeks ago after our first cold spell, it started again. Same thing, first turn of the key, just the lights and maybe a slight whoosh or humming noise from the engine area. Maybe, will start with the 2nd quick key turn. We again took it to our dealership. They kept the car for a week, ran the same computer diagnostics, could find nothing wrong, and this time replaced the main key. We brought the car home and it started doing the same thing within 2 days. It is now stuck in our garage. We will wait a few days, hopefully it will start and we will take it back to our dealership and try again. Fortunately, we have an extended warranty on this car by having it BMW certified when we transitioned from a lease to a purchase. We decided to purchase this vehicle because we had not a lick of trouble with it for the first 3 1/2 years. Help? Does anyone have any ideas?
    JunkOwnerJunkOwner Member Posts: 2
    Extremely sorry to hear of the problems; I recently bought a 2008 BMW 335i. Here's a list in 5 months:
    1)Bad fuel pump (will cost $2000.00 when out of warranty. Scares me for the 335i, 535i and the 2009 Z4
    2) Two window leaks and faulty operation
    3) Transmission issues
    4) Software issues out the ying-yang. It's been months and they have not fixed it yet. It induces turbo lag; BMW does not care about it because they only look at the future of new cars and not the current customers.
    5) BMWNA does not support in any fashion whatsoever.
    6) Cars are always in the shop and it's extremely crowded.
    7) 8 times in the shop since Sep 2008
    8) Missed time at work due to all the issues
    Now that I have learned my lesson, I would never buy one of these reduced reliability cars; they are extremely poor quality. I do not believe you will make any headway with BMWNA, but I do recommend selling your car when it is feasible. I guarantee you I will do the same. These are just a few problems I noted; there is more....just makes me miss my trusty G35 as I think about it. Good Luck.
    I'd take the above post with about a ten pound grain of salt. Google "stealth marketing" and you'll see what I mean.
    I think taking it with a grain of salt is a good idea too! ;)
    montrealer1montrealer1 Member Posts: 3
    I have a 2001 325i (130K miles). Oil Separator failed and it's going to cost me $1900. Yes, it was cold outside when it occurred. Apparently, the problem arises more often in cold climate areas.
    BMWNA have gotten back to me and told me that there is nothing they can do for me. It's out of warranty. No goodwill, no sharing of costs,"sorry you're on your own".
    I have been researching oil separator and BMW on the internet and apparently this seems to be a very popular reocurring problem.
    Any sugggestions on what my next step should be? I feel that with all of the news around this issue, and what seems to be poorly manufactured/designed part, that something should be done to have BMW take on some responsibility.
    Looking for help.
    Is that the dealer price? Try a good independent BMW tech.
    We had the exact same issue with our 2001 330i (100,000 and out of warranty). Our estimate was $1600 (we live in Omaha, Nebraska).
    I called BMWNA and told them this was a common problem that may be the result of an engineering flaw. The rep said, "these things usually stop here", meaning they would not help me. The next day he called back and said they would look into it and I was very surprised. They covered $1100. (see message 4068, in this message I was the mistaken about how much they covered, it was $1100 and not $900).
    We have had several major repairs done with the dealer and all other repairs but oil changes (that was a bad idea=new oil pan twice, but that is another story). We also bought the car as certified used at the dealer. I am not sure if this had anything to do with the outcome.
    I hope this is of some help and best of luck.
    jonsdadjonsdad Member Posts: 4
    I think the key for you is they treated you well is that you gave BMW (and its dealership) business other than the sale.
    I am not saying you should always use dealership, but when you do and something outside of warranty occurs. Dealership and Manufacturer tend to take care of you.
    qbrozenqbrozen Member Posts: 32,949
    not sure why someone should be so disappointed that they have a major repair on a vehicle with 130K miles. Hell, my '93 mazda developed a cracked head at 118k miles, yet I never complained once about it nor has it soured me on mazdas in the least. I put $4k into repairing my volvo before it reached 115k miles (and that was just parts, as I did the work myself), yet I still love volvos and would buy another one in a heartbeat.
    ya know, there are engines and transmissions out there that don't last 130k miles. Everything fails eventually. Doesn't mean they are poorly manufactured/designed (ok, maybe some), and it certainly doesn't mean the manufacturer should be held liable.
    srs_49srs_49 Member Posts: 1,394
    I disagree that a cracked head at 118k miles is within what would be considered a "normal" repair. A cracked or leaking head gasket - yes, but not a head.
    I had an 82 Mazda '626 that needed a new head gasket every 55,000 miles or so. After letting the stealer do the first one, I did the second myself (actually let my two sons have at it). Yes, that experienced soured me on Mazdas.
    My '87 BMW with 188,000 miles is still on the original clutch and no tranny work. I'll have to check my records (it was bought used with 125,000 miles on it), but I don't think the head has ever been touched. Heck, even my Dodge Caravan went for 174,000 miles without having any major engine problems. That's what I consider the norm for today's engines, not cracked heads at 118,000 miles.
    Actually 80s BMWs were known for cracked heads in the 3 series, so consider yourself fortunate (unless someone put one on before you bought it).
    130K is a lot of miles and may well be beyond any "goodwill" gestures from BMW. I mean, think of all the other parts that might normally fail at 130K on any car in the world. When do we stop our expectations as an owner? 150K? 200K?
    If you were a good customer at one dealership, and if that dealership is a favored one by BMW, and if the dealer has discretionary monies given it by BMW for these goodwill things, well fine.
    But if you are in a situation of having a high mileage car and no particular relationship with a dealer, I don't see where you can expect very much.
    I didn't say it was normal. But I don't consider it unacceptable, either. My personal view on cars is that once I pass 80k miles, all bets are off. Its nice when it goes longer without major repairs, but I certainly don't expect it to.
    zapatista2000zapatista2000 Member Posts: 33
    Hello all,
    Long story, but I'm thinking of trying to swap a 1996 520i Touring five speed for a 1996 320i Touring automatic (both German specs). My biggest concerns are the overall reliability of the automatic versus manual transmission, and the degraded handling/control in the winter as I drive daily through a pass that can get sketchy in the snow (and we take frequent snowboarding trips to Austria).
    Any thoughts on these two issues or other general comparisons would be great.
    Appreciate everyone's comments.
    I guess my frustration stems from the many examples that I am hearing/reading regarding BMW and oil separators. I know wear/tear repairs become prominent as you get beyond the 100K mark. I accept this.
    However, the impression that I have is that there is an issue (again from reading other forums, blogs, etc.)with BMW's oil separator, especially in cold weather climates (regardless of mileage).
    In my particular case, my garage door spring broke, which forced me to park my 325 outside while waiting for the door to get repaired. Over the course of 3 days, the oil separator valve(?) froze from condensation build up (this is what I was told). 5 minutes into my drive, engine started to smoke from oil spraying everywhere.
    Repairs include replace oil separator, dipstick, vavle cover gaskets & seals.
    So, if this is a case of "just an old BMW" wearing. OK, I'll keep quiet and move on. However I will say that I bought a BMW because I thought I would get more than 130K out of my investment.
    But if this failure is becoming prevalent in the BMW community (and is getting more awareness because of the advantages of the internet and sharing like this forum), then I am one more data point that needs to be added to the many, potentially more.
    Thanks again!
    Well I think you have to look at it as something on a continuum...in other words, some oil separators will freeze up and break the valve quite prematurely, some will wait to 130K miles and most will never fail.
    Yes, it's a potential problem but it seems to require a certain set of conditions that don't affect most of the cars.
    I think a "goodwill" gesture from BMW would be quite appropriate and I hope you can wrangle one, but I can't say that BMW "owes" anything legally or morally to a customer after 130K miles. Most cars are junked at 175K miles anyway. (average age of a car on the road in America, about 10-11 years).
    So your car is probably at well over half its natural life at this point anyway. Not sure how much of an "investment" you have left in reality.
    Anyway, I'm definitely on your side about the $$$ to fix this. That's no small change. I wouldn't be happy either and I'd certainly ask for something. No harm in asking and/or firing off a few letters....squeaky wheel and all that. Good luck with it.
    Is it possible that besides the vapor barrier that may cause the wet carpet on the driver side, somebody mentioned about the coil heater that might be another source of it.every now and then im checking my coolant level, the other day i checked and found th expansion tank empty and filled it up. could it be a sign that im leaking thru the coil heater. any imputs will be much appreciated to those experts on 3 series.
    If the heater core is leaking you woud almost certainly have a sweetish smell in the interior.
    So far, the only issue is the condensation of the lower windshiled if the temp. outside is freezing and the carpet is wet, beyond that there is no smell.
    owner6owner6 Member Posts: 89
    What is the current mileage.
    I have a 2006 330i with 70,000 (mostly Highway) miles. I am thinking about keeping it for two or three more years for an additional 66K miles. However I am worried about costly or many less expensive repairs. I am retired and want some reliability. as I travel a lot. My car is garaged kept I am the only driver. rear seat never used. Very clean condition. Only repair was rear brake pads.
    Any comments or suggestions?
    owner6
    lokkilokki Member Posts: 1,200
    Well, the first part of the decision process is simple math:
    If you don't keep the car, what will you buy or lease, and what will the increase in your payments be? If they're the same or lower, then first choice is sell. If they're higher, how much higher?
    Take that difference and set it up as a maintenance fund. Let's say the difference is $100 a month, and you'll keep the car 36 months. Thus: $3600.
    Now: Assuming that you would buy/lease another BMW, you'd get free maintenance, and new tires and brakes. Therefore, in considering keeping your current car, you have to factor those expenses into your $3600. At 70,000 miles, you'll likely be needing both within 5,000 miles. Let's say $1500 between them.
    That leaves you $2100 for routine/non-routine maintenance over 3 years. Of course, I'm just making these numbers up, but I'm guessing that your break even point is one significantly major repair over 3 years. The fact that you're travelling a lot may influence the likelyhood of that occuring.
    Now the serious guessing starts. Looking at this board, I don't think it likely that the car will nickel and dime you - it won't break often, but if it does, it won't break cheap. It's not the window switches that fail, it's the regulator or the motor. It's not the radiator hoses, it's the radiator. What's the cost of an extended warranty from BMW? If it's not outrageously expensive, that would solve your "major illness" worries.
    I personally come down on the side of buying a year-old lease-return CPO BMW warrantied out to 7 years or 100K, rather than keeping your current car. You get most of the warranty, and all the major concerns are covered way out into the future. Your current car is easy enough to sell right now; at 120K miles it will take a bigger hit in depreciation.
    Of course, I just pulled all these numbers out of my coffee cup - your math WILL vary. So, I recommend that you take the course I always do - sit down at the kitchen table with a pencil, pad, and calculator and run the numbers. Then ball it up and go with your heart. You may do something stupid that way, but you'll do it with your eyes open and you'll have no regrets later.
    For what it's worth.
    First question I have is, have you already had REVERSE fail on your transmission? If no, I receomend that you sell teh car, as the 99/2000 and I think 01 323's transmissions fail at 100k or so
    Thanks, many variables.
    To answer your question, I would buy a new 2009 335I @ about $48,500 plus $2,910 tax total $51,400. If I sell mine for $20K in this depressed market that would mean I would write a check for $31,400. No payments on either car.
    I do have the BMW 100,000 mile extended service plan which covers brakes, rotors oil filters belts and such. The only problem I have had so far was the rear brake pads were replaced several months ago.
    jimbresjimbres Member Posts: 2,025
    The mileage on my car is very low - less than 40K - because I've never used it for commuting (relied on public transportation for that until I retired last year) & I rarely drive it during the winter. It's my spring-summer-fall weekend pleasure car. (I've thought about buying snows for it so that I can put more miles on it, but I already have a Honda CR-V.)
    Since the E36 hit the streets in the early 90s, the 3-series has been quite reliable overall. If I owned your car, I'd hang onto it. It's been substantially trouble-free so far, & there's no reason to believe that it will suddenly fall apart now. In time, you will have replace components as they age & wear out, but you're still years away from the point at which the cost of keeping your car roadworthy exceeds the cost of replacing it.
    wzhao68wzhao68 Member Posts: 15
    Hi there,
    I own a 2006 330i, it has almost 49000 miles. I'm thinking about buying either the extended warrant or the extended service maintenance plan, or even both. Where should I get some competitive quotes? I did get some quotes from my BMW dealer, but as always, it's pretty expensive, namely about $2800, and no monthly payment plan. Where else should I look?
    David
    I paid $800 for my extended service (not warranty) 50 to 100K miles. I purchased it about a year ago from my BMW dealer when it hit 49,000 miles. I have 2006 330I.
    kyfdxkyfdx Moderator Posts: 237,266
    Prices have gone up...
    MSRP is $1395 now... Doubt they have more than a couple hundred to play with....
    Hi Host,
    do you have any input on my posting #4095 and 4098?
    Well.. if you've got $31,400 to drop on a new car, then you can certainly "self-insure" against repairs or maintenance on the one you have...
    No matter what issues you might have over the next 66K miles, it will certainly be cheaper to keep running your current car, than to suffer the depreciation on a new one... Even taking into account the further depreciation on the car you have...
    You like it, you know how it's been treated, and you've had pretty good luck with it.... Obviously, a big repair is not going to bankrupt you.. As long as your dealer is good with loaner cars when yours is in the shop, I'd just soldier along.. Any after-market warranty would be fairly expensive at this time, and I doubt it would cover you past 100K, either way...
    But, I might be the wrong person to ask... We lease our BMWs...
    regards,
    kyfdx
    visiting host
    I'm a big believer in self-insurance. Put that $2800 into an online savings account (GMAC Bank is currently paying 3.25%) & then add a couple of hundred per month to your initial deposit. (Sounds like a lot, but it's less than $7/day.) In a year, you'll have more than $5,000 in your emergency repair fund.
    OK... the wife's 98 328i was in the shop yesterday, and they discovered that when she went over a curb (a sad and ugly story I don't want to repeat) a month or so back, the LF control arm was bent..... and additionally the LR shock has started to leak.
    This means replacement struts and shocks since they have to come off anyway to replace the control arm. I'm looking for recommendations on what to have the shop put on as replacements:
    I know of four possibilities (listed below in order of increasing cost guesstimate):
    1. Whatever the shop puts on as OEM replacements, and good enough thank you.
    2. Monroes
    3. Bilsteins
    4. Koni's
    Decision point information:
    The car doesn't have the sport suspension, and my wife is not a performance driver....so lowering the springs and putting on racing Koni's is not in the picture.
    Having said that, her car has low miles for a 98 (53K) and the car is in excellent condition, so we plan on keeping it for some years. She likes the car, and between the few miles she drives it and the condition of the car, it's worth the money to do things right. $100 or $200 dollars extra for better parts now isn't that big a deal in the bigger scheme of things, so if it's worth doing, OK. Still there's no point on putting racing quality parts on a car that generally loafs along on the good roads around here.
    So, what's the best balance of quality and price?
    I'd appreciate any opinions and recommendations about these brands and options.
    Lokki
    I would stay away from the Monroes. I'd put them on wifey's Caravan, but not on my BMW.
    If it were my wife's BMW, I would go with the OEM parts. If it were mine, I would consider the Bilsteins.
    If I recall correctly, the Monroes are made in Europe, and I know some folks on the Yahoo E39 group who have used them with no complaints. The other brand I'd consider would be Sachs/Boge. Bilsteins or Konis would be overkill for your application, I'd think.
    I'll take a look at the Sachs/Boge too. Turns out I can't get the car into the shop till late next week sometime, but I'll come back with a report on what happens.
    Appreciate it.
    Lokki.
    Thanks for your advise.
    If I keep it should I now at 67k miles have the transmission oil (automatic), rear end oil, spark plugs and serpentine belt replaced as a precaution? And anything else you suggest.
    I have been doing an in-between engine oil service at about 9K miles after the Free dealer service which has been recycling at about 18K miles in the service indicator. Last time i paid for an in-between service they charged me $91.95.
    Thanks Owner6
    I'll leave maintenance recommendations to the rest of the board... I haven't had a BMW with over 50K miles since 1990! :surprise:
    $90 is not a bad price for a dealer oil change...
    I'd change the ATF and diff oil, and I'd have the serpentine belt inspected-as well as the belt tensioner and idler pullies. If the car is running fine I'd probably leave the plugs alone, although it wouldn't hurt to change them. Be sure to change the brake fluid at two years from the in-service date and change the coolant at four years.
    Thanks HOST and roadburner.
    I looked over my maintenance records. The brake fluid was changed twice. At 37 and 65 thousand miles. (Now has 67K miles on it). The oil has been changed seven times approximately every 9,500 miles. The BMW guy at 65K miles service said the belt was OK. I have service to 100K miles and the car computer states the transmission and plugs need serviced at 100K. I just thought I pay to have it done now. The car runs fine so the plugs must be OK. I really wanted to get a new 335I however I have read and heard many horror stories about the breakdowns and out of service for weeks at a time. I retired and dont need that at this point in life. Just want to have some reliability.
    Well, just a quick update on my oil separator issue.
    I ended up bringing my 325i to a local mechanic. What started with a $1900 charge from a BMW Dealer ended up costing me $960!! at the local mechanic. What a difference! When you think about, way too much off a difference. Makes you think about the BMW organization and their approach to over the top repair costs.
    Hope the car last for least another year.
    Pays to shop around! Good for you. Good for your mechanic. Good for your car.
    webdriverwebdriver Member Posts: 3
    I recommend OEM. My 99 328i (146K) is starting to show its age, however my independent mechanic tells me all of the original struts/shocks are not leaking (despite a broken right rear spring...most likely from a parking lot curb). I replaced the front control arms at 90K. It will keep going with some more money thrown at it, but I'm looking for a replacement...with a spare tire. Since yours has only 53K, it should have a lot of life left. :)
