You should consider installing the HID headlights. They are like streetlights ... People notice you on the interstate in the day and will generally change lanes to let you pass. ... I got mine clearanced for about $250, but have seen new kits (in July) for as little as $450, which is great for HID lights.
Greetings to you in Tokyo! Hope you are enjoying it there so far.
Do people swear at you as they move over to let you pass with these lights of yours. :-)
I was hoping to spend somewhat less on lights than the cost of an HID kit. The stock lights are great for my driving needs (mostly urban daytime) and based on the cars I had in the past, they are the best so far even for driving in the boonies at night with moose on the road.
I was looking for light bulbs as bright as stock, with the same wattage so I don't have to worry about new wiring, and with a cooler colour temperature. I guess I will have to keep looking since the Eurolites I bought only fit 2 of the 3 criteria.
Thanks for the suggestion, though.
Fuel economy - Good. Averaging about 28.5 mpg in mixed driving with moderate a/c use. The GT performs as advertised in this department.
Problems - Hardly any. I purchased the car on 6/15/01. Since then I have had to re-set the "check engine" lamp once (covered under warranty) and replace the left lo-beam headlamp (did this myself - $14.83 part from Auto Zone). We did have to replace the oil pan (not the car's fault - part damaged during oil change) and one tire (wife popped the sidewall while parallel parking).
Service/Fuel Costs - Total for all service from date of purchase is $453.80. This includes oil changes. I fill the tank about once every 8 days at a cost of roughly $17. My estimated fuel costs since 6/2001 have been $901.
Overall Appearance - we don't have a garage, so the GT sleeps under the stars. After 14 months the car still looks very good. No scratches, scuffs, dents or cracks to mar my baby's finish. There is only a ding on the hood courtesy of a HUGE falling acorn. The interior still looks new. The leather holds up well and is softening nicely. No squeaks or rattles from the interior.
General Impressions - Incredible car for the money spent ($14,500). I'd never owned a Korean car before we bought the GT last year. Now I don't know if we'll ever buy another brand. We are seriously impressed with the Elantra GT. We really can't think of enough good things to say. On our advice, friends of ours purchased an Elantra GLS several months ago and are reporting similar impressions.
To anyone reading this thread and considering purchasing an Elantra, take it from a *very* satisfied customer: driving is believing!
Adios! Will update again after 30,000 mile service.
pw_eastside
Thanks for the suggestion about the seats, I'll give it a try but it really does sound like something in the hatch, but you never know.
jofficer-
My gt is only a few weeks old and the a/c has always made a hissing noise periodically while it's on. It doesn't seem to affect cooling as my pump cold are pretty well. My wife's 1990 mazda protege also does the same thing so I'm not too worried about it.
Has anyone experienced a "clanging" noise coming from either the rear hatch or suspension when going over large bumps or expansion joints.
The noise is likely coming from the spare wheel.
I had a similar noise and traced it to the spare wheel being improperly placed over the rubberized foam pads at the bottom of the spare wheel well. When you go over a bump the rim would hit the bottom of the well and make the noise.
Cure -- reposition the wheel and tighten the retainer firmly. Better yet (and I am yet to do this) is to get some more material and add more pads. In my case, I suspect the pads are not optimally placed.
thanks for the ideas, I'll check the spare tire this weekend for sure. I'm hoping to figure it out myself since I'd rather not go back to my dealer and mess around with them.
other than that though I've been very impressed with my car so far. I'm still under 1000 miles but I'm already getting 29.1 mpg with mostly freeway driving. I was able to go almost 400 miles between fill-ups on my last tank of gas which I was pleasantly suprised about.
pw_eastside
5port - I had the same noise on mine - only once in awhile when going over bumps like those you described. I have heard that it is either the spare wheel well or a loose strut in the back end. Either way, check for a loose spare or have the dealer inspect the rear end suspension at your next oil change - the noise on my 2002 w/4500 miles on it is not normal but did not occur very often at all. The dealer inspected and tightened the rear suspension and the noise has not recurred.
My noise disappears completely when I put the rear seatbacks down so I know it is coming from them. Also when its cold outside there is no noise and when hot I hear it. If it is the rear seats I say its the leather being stiff in cold and plyable when hot. Thanks for the tip on the strut and I may mention it at my next service.
I get someone to drive over roads I know the noise is usually heard on while I'm trying to locate the source of the noise - usually I'll be in the back. I figure seeing I'm used to it I have the best chance of finding it and by not driving I can devote all my attention to finding it.
I also had to drive 55mph all the way back because since most of the engine is new parts, I have to go through the break-in process again. We did manage 33.4 mpg on the way back though.
It's nice to have my car back again. Right now I can't say that I would buy another one, but I'll have to see if there's any more major problems during the life of the car.
It was closerthanthis between the GT and the Suzuki Aerio - I was going schizoid trying to decide, but finally opted for the GT, having been so pleased with my Accent and the dealer. 6 months after I got my Accent, hubby bought a 98 used Accent Sport (he's still in love with it!).
So Wednesday, I drove home in my gorgeous new GT! Here in Canada, they call the colour Prime Beige (what a boring name for a lovely colour) but I guess in the States it's called Champagne. Anyway, she's beeeyooootiful!! 5 speed, totally loaded with everything but the moon roof, leather seats and ABS. They come as a full package here. I would have liked the moon roof, but hubby hates - I repeat HATES - leather seats. He sweats like a pig, even in winter, so I guess I understand. *wink*
And the best part? There are hardly any of them on the road! I feel so unique!
My favorite thing? I'm so odd - I'm in love with the little tweeter speakers! *LOL*
Came out of the showroom for under 20K in a car that looks and drives like at least 30K! Am I happy? You betcha!!
From what I've seen the US seems to have unique names for most of the colours
A couple of weeks ago I visited my brother in Tonawanda, NY. On our way to Pilot Field (aka Dunn Tire Park), to enjoy a Buffalo Bisons game, we passed the local Dunlop Tire plant. There were at least a dozen Hyundai boxcars lined-up on the siding, which I thought was odd, since most, if not all, U.S. Hyundais are shod with Michelins. What's up with that? Are Canadian Hyundais equipped with Dunlops? Are Santa Fes?
Returning home via the NYS Thruway, I set the cruise at 78, and but for a few slowdowns involving 18-wheelers, radar traps, the occasional arrogant morons in SUVs clogging the passing lane, and a 10 to 15 minute "comfort"/lunch stop, I made Lanesborough, MA in just 5 hours (approx. 320 miles). At 78 mph in 5th gear, the engine turns about 3200 rpm, so it accelerates up to 90, 95, effortessly when needed. No wind noise, no buffeting, no a/c noise, no hatch noise, no strut noise; the car is rock-solid, and rides like a mid-sized sedan. I commuted back and forth to work, and elsewhere, the rest of the week, on the same tank of gas, averaging 31 mpg with the a/c on the majority of the time.
Last weekend, I drove down to Long Island, via NY-22 much of the way. NY-22 is, for the most part, a combination of very straight and very winding 55 mph one-lane road, but goes through a number of villages and hamlets where speed limits drop to 35 mph or below. On the 55 mph sections, I usually set the cruise at 60, but one is hard-pressed to maintain that speed on most stretches because of the plethora of aggravating slowpokes doing 40 to 50. The Elantra quickly gets to 70 or 80, so time spent passing in the oncoming lane is minimal.
Starting the trip home, I pulled up next to an Audi A4 1.8T (probably a 150 hp version with a slushbox) at a stop light; he was in the left lane, I was in the right lane, and we were both turning left onto the westbound L.I.E. service road. When the light changed, the Audi immediately turned and put the pedal to the metal, whereas I held back slightly to ensure there was no late cross-traffic. The entrance to the L.I.E. was a few hundred yards up the road on the left; I not only caught him, but passed him and beat him to the entrance. Hopefully, for his self-esteem, he thought it was a Saab. For the entire round-trip, about 300 miles, plus local mileage, I averaged 30 mpg, again, with the a/c on most of the time.
Over the years, I've owned a couple of Toyotas, a '79 Subaru (a *very* nasty piece of crap), and a couple of Mazdas, all new, all manuals; and a gently used '97 base Tiburon 5-spd, which I traded-in for the GT last year. With the exception of the Tib, the Elantra GT has by far the best handling and acceleration of the lot, is the most fun to drive, and is close enough performance-wise and has so many more amenities than the Tib -- it was dark purple with no a/c, which would have been really unbearable with the unrelentingly brutal heat and humidity in the northeast this summer -- that I don't regret the replacement. All in all, this is one great "little" car.
You and I are sooooooo in agreement over left-lane cloggers. Here in West Michigan, not only is the lane inhabited by these cretins, some have the nerve to try motioning ME to their right, even though they are not in the correct lane. Add to this exits and entrances on the left of the freeway, where people are nowhere near the speed of the rest of traffic. Add to this the fact that not only is there no sense of urgency, there isn't even a HINT of a sense of urgency. Some of us like to travel at reasonable speeds, not below the speed suggestion. As a Detroit transplant, I yearn for the insane (but in-synch) driving of Detroit or Chicago drivers.
Now, back to the GT. My dealer has a "sold" Pewter GT in their lot, driven up from a Michigan City, IN, dealer. It is a stick, with moonroof and ABS, and even though I really dislike add-ons, the slim black spoiler is very nice. Just over $16K on the sticker. A steal.
http://www.auto.com/reviews/ulrich29_20020829.htm
Took the 'Princess' for a drive yesterday afternoon on some windy county roads. My Goodness!! She certainly holds the road nicely! I love this car more each day!
MontrealGT: Leather is usually chosen for easy-to-clean properties (esp. dog hair which brushes off and drool which wipes off), however I must admit that my last car's partial leather (w/cloth) was still enough for me to lay a towel on it to prevent my summer legs from sticking. Interesting note on beige v. grey cloth; ours are the same pattern and texture. Are Canadian cloth seats two different patterns? I really think the GT interior should offer a cloth like that in the Tiburon. I would definitely consider that over leather. (P.S. I thought dogs and teenagers get tossed into the hatch)
goby2000: There might be posts in the Accessories and Modifications thread for people who have done plugs, filters, etc.
I just purchased a K&N highflow stock filter replacement and it seems to have improved the performance slightly. I am also thinking about changing the plugs to Bosch Platinum+4 and maybe wires. I don't want to do anything crazy with the car (like throttle body change, etc) just simple cheap mods. Anybody out there wanting to do the same thing or has done and has some advice to give?
My site Drivers & Believers is a good source of information on modest add-ons to this car.
I installed Bosch Plus 4s in mine and I think it resulted in slightly improved pickup. I don't believe that it did anything for the mileage though.
"The GT isn't the best in its class (never
saying what is or why) but has great handling, power, brakes, style, warranty, content, etc."
What more do they want, a great price?
From what I can tell, the GT only comes with the cloth that is a dark grey with almost a denimy feel to it (aside from the leather that is). The beige almost veloury is only in the sedans, I think, and as I remember, it wasn't the same pattern at all - didn't have the Hyundai freckles.
And now that you mention it, the hatch in this baby is so big that I probably can fit the teenager and the dog in it! And it's kinda nice to know that when hubby and I head down to CT in a couple of weeks, I won't see a single car like mine! I'll tell you, the Champagne (I will not call it boring Beige!) gets prettier every day - very classy looking if I do say so myself.
Hopefully, when the 2003's arrive, there will be a little more choice in packages and available colours. I have to think that the popularity of this car has taken Hyundai by surprise this year, much as the '99 Accent GSi's did - at least in this part of the world.
Have you checked out the Australian or Swiss or Italian sites? Boy, does Hyundai have interesting models on other continents! And the plethora of colours! That Lavita or Matrix (I wonder who used the name first?) is pretty nifty looking. And the itty-bitty Atos is kinda cool - probably wouldn't fly here in North America though, we like our cars bigger, don't we? Still, imagine the mileage!
The web sites are NOT a good representation of the colours in general. The Lavita is an interesting car, built on the Elantra platfrom but actually shorter than an Accent, it is quite high so easy to get into and out of.
Australia has adopted smaller cars in a big way since petrol prices skyrocked in the 70's, although the micros are not accepted well here, the accent has done particularly well here.
And look! It shows a beeeyoootiful Prime Beige (sigh) GT just like mine!
Oh, and remember...the prices quoted are all Canadian $$.
it works out to about 26-27mpg for the trip... average speed on the highways outside queens was 80 topped out at barely triple digits...in queens average was 50... hit 2 huge craters on the way back on the GWB... thought and felt like rims were cracked or bent but upon initial inspection no damage to my 205/45/17 babies... (my coworkers say i ride on rubber bands... thats how thin my sidewall is...)im going to have my tire guy take off teh tires and wheels and inspect them separately for damage inside out this weekend... i was even looking out for potholes the whole way... the damn things streched across the Cross bronx center lane where i hit both of em on my way back..
powerful enough to keep with v-8's but needed to drop down a gear to speed up on those nasty long climbs
If memory serves they used an Aluminum pan on the elantra not the normal pressed steel and thread insert others use. This change would have been done for rigidity and noise issues I would think
I worked part-time at a Wally world auto center, and most of the staff was/is kids without a clue. Even with the training video's, WHT bought 4 engines in 11 months I worked there (not because of me
Changing oil is so easy I'm surprised more people don't do their own. If you choose to have it done, go to someone who knows what they're doing (pay the extra $5). I don't know what Hyundai charges, but if they strip it... they'll fix it!
