I beg to differ. Using synthetic is better than using dyno and thinking that changing the oil more often will make up for it. Synthetic oil is simply a lot better at lubrication and flows better during cold starts.
You may have fresh conventional oil in there all the time, but it's still inferior to synthetic and will allow more engine wear.
Search the web and you will find and number of tests of synthetics vs. conventional oils. Engine wear is a measurable thing.
http://www.csaa.com/global/faqdetail/0,8054,1004010401%257C220,00- .html
Also doesn't a 5W-30 "dino" flow the same as a 5W-30 synth at 0°F? They should if they are both "5W". "W" is the Winter viscosity. Of course if you live in Siberia, maybe you need an oil that won't congeal at 50 below!
Most folks will never realize a benefit from synth, they don't keep a vehicle more than 100k miles, at most, there might be a difference at 250-300k, but how many keep a rig that long? Most do not.
I'm not most folks. I'll be keeping my Trailblazer forever. I do agree that most folks sell cars long before the engines give out. If they're that concerned about oil, I thank them for saving their engines for the next owners.
I've seen plenty of high mileage engines out there, but it's not enough to just make it that high. If you would subject them to compression tests, you'd most likely find a decrease in compression due to engine wear. Yeah, they sound fine, but do they perform like when they were brand new? Nope.
As for "buying into the hype", obviously we have to make decisions about who to believe, but to me hype is when Jiffy Lube tells you to change oil every 3000 miles. When you buy a new motorcycle and it says not to break the engine in on synthetic motor oil because it is too slippery, I gotta ask "why would they lie?"
Also doesn't a 5W-30 "dino" flow the same as a 5W-30 synth at 0°F? That's what the "5W" part means. Of course if you live in Siberia, maybe you need oil that won't congeal at -50 below!
I don't know. If I lived in Texas I guess I wouldn't be concerned about that.
What an awesome car! I could put that as my dream car in the profile....and you got rid of one! I hope you kick yourself regularly for that. Got any vintage Camero SS in your backyard t-blazed?
But I digress. All that's distilled down now to an '88 S-10 and an '02 Trailblazer.
If I lived in Colorado I wouldn't be too concerned about oil at 50 below either- it doesn't get that cold up there does it??
Here's a good link that explains what that "W" designation means among other oil facts.
More Than You Ever Wanted to Know About Motor Oil
I will be glad to give you my email address if you prefer communicating that way.
Bert Mandeville
http://www.cs.wisc.edu/~lists/archive/vfr/199707/msg02380.html
Bert M.
FYI - '02 Envoy XL SLT 4X4 - loaded with everything but the DVD.
Allen
Found a pic of one I had seen before that does have a fan, this from a '99 S-10. The inset is a front view. This is an older radio.
I'm not an audiofile, but after seeing your post and doing a little research, is it possible to use the Soundgate product you mentioned and hook up a Pioneer XM antenna to a Pioneer XM tuner and then to an '02 TB LS radio (no cassette or video)without an FM modulator or that funny little external XM display box? Will the sound travel to the GM radio via wires and not FM, and it looks like all displays and buttons go through the '02 GM radio? (of course with a XM subscription...)
From my understanding, Soundgate developed a new interface Part# PIOGM1 (for Pioneer [XM Radio])& Part # KNGM1 (for Kenwood [sirus radio] that will interface with the some of the late model Delphi Bose Radios. This interface tricks the Delphi radio into revealing the satellite reading onto your radio display. NO FM modulation or the funky little display required!. You will also need to purchase the tuner for XM or Sirus.
the link to soundgate is http://www.soundgate.com/ Tweeter stores can order this interface for $130.00 - $140 or you can order directly from soundgate for $149
I just haven't decided if I want to go with Sirus or XM Radio? Any suggestions.
Estimated costs:
tuner $150
interface $149
antenna $40
= $339 plus and installation (or do it yourself)
Oh yes, XM or Sirus subscription required!
At 31K, I still love my Envoy XL SLT. No rattles, squeaks, everything still tight. That hydroforming really has made it a tight machine.
Chris
Thanks for the info. How many miles do you go between oil changes with the Mobil 1 and what type of driving do you do?
Todd
Todd,
Sorry for taking so long in replying but I was up north for the holiday.
I generally go between 5000 and 8000 miles between oil changes on my 02Envoy. The wifes car (01 Alero) I generally go between 4000 and 6000 miles. I do 95% of my driving on the freeway, my wife does 50%-50% highway/city. Her change oil light activates a lot faster than mine. Just for my peace of mind I send a sample to Blackstone after every oil change (mostly because of the potential piston slap issue on the Envoy).
Jim
Frank
(without the drain plug) to get the last 1/2 quart out. Suffice to say they said the idiot light was made just for him! Can you believe it..........
GAM
'02 Envoy XL SLT, 32K.
Chris
However, what would cause the head gaskets on a vehicle to dry out and need replacing? This happened on both the Saab and the Monte Carlo. Because of my trades, I never made the repairs but the dealers in both cases said the gaskets were beginning to leak.
How can I prevent this in my Envoy? Is the answer synthetic oil?
Chris
Other causes can include faulty gaskets either through manufacture or design, as well as impropper installation. In other instances the warping of a head can result in the gasket leaking, overheating an engine and thin cylinder wall designs requiring very narrow gaskets tend to burn through more quickly under constant heavy load. Much of just how long an engine survives before developing those types of leaks is strictly a design and assembly issue. In short, there isn't a whole lot we can do to prevent a head gasket leak from eventually. - Yes there are basic things, like ensuring we don't overheat the engine or constantly accelerate by flooring the throttle (high cylinder pressure) but beyond that generally not a whole lot and the type of oil isn't going to be a factor. (Basically the oil doesn't come into contact with the areas of a head gasket which tends to leak - usually a combustion or coolant leak).
Ray
I'd post a pic if I knew how.
I got mine off Ebay from Mr. Motorsports. Considerable savings from x3racing price.
the last visit!!! They had told me it was in spec. but changed it anyway! Its very annoying especially when its cold out side, The shaft was actually within GM specified tolerance but was sending out a vibe between 45-60MPH HMMMMM, slight vibe on feet. GOOD LUCK!!!
Chris
Chris
Any thoughts out there?
Chris
Could the dealer meant manifold gasket rather than head gasket? This family of engines used in the Monte Carlo, namely the 60deg V6, have a history of manifold gasket failures. Just replaced them on a 93K mile 98 Pontiac van w/3.4L engine. I've also replaced the manifold gasket on a 4.3L S10. In both case a coolant leak was evident.
As an added comment, I had previously changed the Dexcool (extended life anti-freeze) in the van at about 2.5 yrs even though the recommended interval was 5yrs/150000miles. Again I put in fresh Dexcool when I replaced the manifold gasket. While the engine was apart I checked the coolant passages for any evidence of corrosion and changed the water pump. (easier to replace at this time) For all practical purposes, there wasn't any and the water pump looked as good as the new.... so I intend to change the Envoy's coolant before 5 yrs.
