Thanks again.
Seriously though. It is a feature. My 2003 TB and my 2004 Malibu both do this. Reading a bit over on the Bu' forum, I've heard that this is to prevent misreads caused by engine compartment heating. Supposedly getting the vehicle up to speed allows the airflow to blow the warmer air out of the front of the vehicle and away from the outside temperature sensor.
At start up and the car has been parked for more than 2 hours, the display should read real time temp when started.
At start up and the car has been parked less than 2 hours, the display should read the last stored temp.
After starting and the coolant temp is less than 28 degrees centigrade or 50 degrees fahrenheit above the ambient air temp, real time temp should display.
When driving away, and the vehicle speed is above 20 mph for a minimum of 80 seconds, the real time temp should display.
If the vehicle speed is above 45 mph, the real time temp should display.
If the sensor reading is less than the last displayed value, the real time temp should display.
Greetings to all, this is my first post. Just found this forum recently although I've had my 2003 Envoy for a year now. Am extremely pleased with it and have had only one problem--bad A/C cycling switch when I drove it away and went out again about a month ago. Both times fixed immediately.
C.B.
As I read post 14582 it is clear to me that my temp guage should be reading the real temp or at least the last stored temp which has not been 50.
Not sure when I'll get to the dealer as it is not yet enough of an issue for me. I will get it fixed b4 the warrantee expires.
Mcafee1 - If you get yours looked at first, please post the problem and fix
MODERATOR /ADMINISTRATOR
Review your vehicle
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
There are currently (as of today May 21, 2004) 100 TSB's on my 2003 Envoy although only one rang a bell for me and that was the A/C cycling switch problem. If you see one that you would like more info on, there is a way to get it but it looks like a fee for the service. I did not check this out.
When you go to the URL, you can select your vehicle, year, mfg., model, etc.
C.B.
Upon re-entering the atmosphere, I notice that the temperature gauge will not read beyond 999 degrees F! I mean really, how much more could it cost to add another digit to the temp display? Also, I noticed that the paint peels off rapidly when I do this. More poor workmanship! I would think that for $30K GM would at least install ablative heat tiles on my TB!
We are ready to pursue lemon law.
Valid observation on the Envoy's handling. Check my comments and suggestions at posting #14099.
BTW, Bilstein recently came out with HD struts and shocks specifically for the lower, stiffer springs now available. Let me know if anyone wants the part #s.
The dealer checked the freon, searched for any PCM codes and did a software upgrade but found nothing specifically wrong with the A/C. I did have the cycling switch replaced last summer after the A/C failed all together.
Anyone else noticing this problem and/or know of a fix?
I got an '03 Tahoe and now am thinking of downsizing because of fuel costs. I have seen very few posts from Rainier owners. I'm thinking of getting a Rainier.
How is REAL TIME average gas mileage with the V6?
Have the numerous issues with the '02s been pretty much remedied?
If you HAVE a Rainier, how do you like it?
Ok one stupid thing I noticed. You CAN'T get the rainsense wipers on the Rainier. What????
Our envoy felt the same way as you describe staying in the lane. I noticed it more challenging when driving in the back country, driving around the bends... My wife and kids were constantly badgering me to slow it down because they were getting sea sick, but I was at or below speed limit!
So I did a little research and changed out the OEM bilstein shocks and replaced them with NEW aftermarket Bistein's and the problem has ceased. I can now stay in my lane with little to no effort, and as for the back country, no more sea sick kids... I just have slow it down now... I hope this helps...
The Rainier has a V8, not a V6.
Personally, I'd go for the V8 on this because the Buick is a bit heavier due to all the insulation.
In any case, I picked one up yesterday on a 24 hr drive and I can already say that it feels much better than my Bravada. What is GM thinking about the Nav system though? If you want to play a CD you have to take the Nav DVD out and then you can't play a CD and get Nav at the same time. DUMB! And the actual Nav system looks and operates exactly like my Lexus except that it doesn't have a touch screen and you have to enter things from a joystick.
Maybe they realize nav systems are 99% worthless.
Hey, I'm a gadget freak as much as the next guy, but most of the time you're going to work or someplace else you're familiar with. I'd recommend a handheld GPS for the 1% when you're on a road trip. Don't those nav systems cost like 2 grand?
Sounds to me like fuel costs aren't the issue here.
I have the Nav on my Lexus and love it. It works out great when you are going to restaurant in an area of town you are not familiar with and very good at getting you back home.
I'd say that's pretty good unless you want to wait for a GM hybrid.
Huge price difference. You'll pay way below invoice on a GM product too. Basically, you can buy (2) Rainiers for what you'll pay for a Lexus LX470.
So, yeah! The Lexus does have rain sence wipers! It should for $65K!
Obviously the bad messages did not stop us from buying an Envoy! (Being able to knock the price down from $44,400 Canadian to $35,000 Canadian - about $25,000 US- didn't hurt the decision, either)!
Our 2003 Envoy has been trouble free for 14,000 km (about 8,700 miles) except for wind noise and minor problems with the CD player/tape deck.
The wind noise has been greatly reduced by our eager to please dealer's service department, although not totally eliminated. I plan to try some of the "home made" fixes described elsewhere in this forum. The CD player problem (would not eject a CD) has been noted by our dealer, but has not re-occurred so I have not pushed for anything to be done yet.
We are pretty happy with the Envoy, although we probably will turn the vehicle in at the end of the lease and lease another one. After warranty repairs look to break anyone's pocket!
Best mileage so far has been 10 litres/100 km (23 mpg), but that was taking the speed pretty easy- about 60 mph.
Love the power, ride and looks. Hate the cheap looking dash plastic. Miss the cup holders and console area of my '96 Chev Blazer...
By the way, I'm from Calgary, Alberta, Canada, so I have to say;
GO FLAMES GO!
No team from Florida should ever win the Stanley Cup!
Happy motoring all!
You can get the Rainsense wipers on everything from the $30k ES330 on up to the LX470. There is NO defense for Buick opting not to make it available on the Rainier when it is on the other brands.
I would disagree. The RX is really a car. (Very nice vehicle though.) The Buick is built on a truck chassis and will tow a good sized boat, is rear, or AWD and is available with a V8. The RX is a natively front drive vehicle with AWD as an option.
Hardly compairable at all unless you're talking about features like what sort of windshield wipers and leather seats you can get.
Can't get a V8 with the RX either.
What I'm saying about that comparison is, simply, anyone looking at a Rainier is most likely looking for a luxury SUV. The RX is a luxury SUV.
Now if you would have compared a Tahoe to the LX470, I wouldn't have said a word. (Although the Escalade is more of a comparison to the LX.)
Pretty good mpg (kpl?). What's gas running up there?
"GM's current program, for example, includes $1,000 cash back plus zero percent financing on loans of up to five years on models such as the Chevrolet TrailBlazer and GMC Envoy."
Gas prices not hurting U.S. auto sales (Redlands Daily Facts)
I get put off because GM will not offer the V8 engine in the standard wheel base Envoy or TB.
I'd like those Bilstein part numbers, please. Also, "lower, stiffer springs"? Any info on those?
Even though my V8 TB EXt is for towing my track car, I'd like to wack it down a couple of inches.
As in the previous post my temp sensor acts like it should per the programming logic. There was an old post way back had the program logic of the automatic climate control, I’ll see if I can find it.
There are three or four sensors inside the truck that tells the computer what to do, one of those could have gone bad.
No mater what my outside temp reads, the inside controls work fine keeping the temp at what I set it to.
Allen
The Bilstein numbers are:
Front - BE5-A333-HO
Rear - BE5-A335-HO
The springs I put on my Envoy are made by Eibach. I got them from TireRack and they are FANTASTIC! I couldn't believe how much of an improvement they made in the handling. I also put on a Hotchkis rear sway bar and solid bushings on both ends. To round out the package, I went with BFG Comp T/A HR4s. More of a street, performance tire but rated all-season and worked great this past winter even with 2WD.
Go with this set-up and you will not believe how much better these GMs can be. Who needs a Porsche Cayenne?!
I had the problem of the shift not coming out of "Park" Looked in the forums for some answers and looked for the common fixes. No Luck, wires are all in, wasn't torque lock. No matter what I did, wouldn't come out of "Park. Had the recall work done a year ago, so I couldn't use the orange button fix.
Took the TB to the dealer and one of the mechanics says its a solenoid that needs replacing and could cost $350 or so. DAMN! Anyway, anyone have the problem or know someone who has had this problem and had it fixed? I was hoping someone had the answer before I had to drop $400 if it doesnt need to happen. The mechanic stated, without really knowing, that the whole shifter assembly had to be replaced to fix the problem.
Is the mileage you are reporting from the driver's info center or actual tank fills? Generally our DIC numbers will be within a couple tenths but I've heard reports of less accurate results.
Of course fuel economy is highly dependent on how and where you drive. Make sure the emergency brake is fully releasing, tires are right pressure.... and no one is stealing your gas! Keep records of how & where you drive and maybe try another dealer.
Gas in Calgary is about $2.40 US per US gallon (88 cents per litre Canadian).
I don't know if the break in of the engine had anything to do with the good gas mileage- our salesman is a former mechanic, and he gave us a different break-in method.
He said to find a deserted country road, drop the shifter down to second, and gradually bring the RPM's up to about 6,000 or 6,500 and then let it off. He said to do this about 8-10 times, and then just drive normally for the rest of the break-in period.
I did as he asked, and the engine in my Envoy just purrs, gets good gas mileage, but has wonderful acceleration.
Go Flames Go!
Two more wins and the cup is back where it belongs- the frozen north!!
Cheers
David
