Great to be back on here hope all is well with all of you.
Any help is appreciated!!
jmaldo68@gmail.com
No drain plugs on the block.
BTW.. 2003+ have to disconnect the lower hose to drain the radiator.
Doe's this model have synthetic fluid, will it be OK to replace with syn.? Planning on having coolant flush done at a local shop, plan on doing the BF change myself.
Thanks...Bill
Reused the brake pads which were still very good.
Completely fixed problem.
That was 9 months ago. I will turn in lease at 48K in the next 3 months.
I had my front drive shaft, drivers side, throw grease out of the boot all over the frame and the dealer fixed it under warranty a year or two ago. Now the one on my right front is doing the same thing. Any tackled this? Is it just a matter of taking off the boot and replacing the seal assembly that is in there?
If I have to replace boot and bushing I might replace axle because have almost 80K on vehicle and 80k wear on existing axle. Need special tool to replace swage clamp on shaft side of boot if only replacing boot. Do not have the tool. Not sure I want to buy the tool. Keeping close eye on leak for now then decide later what I'm going to do to fix.
HALFSHAFT, FRONT DRIVE - FRONT - LEFT - R&R
Not very useful information but thought I'd share it anyway. I have the 2002 TB LTZ factory service manual, 2 volumes, and I'll look tonight for the procedure and tool number. If the tool is needed and expensive I'd be willing to do some sort of purchase/share deal with you. What vehicle and year do you have?
Found it http://www.autozone.com/in_our_stores/loan_a_tool/loan_a_tool.htm
They have a CV boot driver in the loan program. Removes and installs all boots on GM constant velocity joints with stamped retaining rings.
OEM27052
They also have several other tools for CV replacement. I'm assuming they might want you to purchase parts from them to get the loaner tools, but it won't hurt to ask them for the details.
If you don't have AutoZone in your area, check some of the local parts places to see if they have a similar program.
On the brakes,when I do mine, I'm going to use whatever the OEM pads are. I have 75K and still have the original pads. I don't baby this truck by any means. I will say, however, that I do have a slight pulsation in the brakes.
Just checking.
Now if you are not low on fluid and still slip then get ready for a major transmission overhaul. Take it to the transmission shop and let them diagnose the problem. They should do it for free if not take it somewhere else. What is the mileage on your Buick?
Also would you consider having one of those quick lube joints doing the work?
amigo_john, "Isuzu Trooper" #8070, 30 Jun 2003 7:46 am
I know I have not provided a lot of info. But your thoughts and ideas would be a great place to start.
Thanks in advance.
Bill in KC
Thanks for the info. so far...was away on holidays last couple of days.
Current mileage on Buick Rainier is 55000 miles. The more I listened during a family trip, the more I think that it feels like a transfer case issue and not transmission...not sure if that makes any sense.
I called it slipping before, but it is best described as a 'bumping' feeling somewhere in the driveline while in 2nd gear between 15-40 mph.
I had the tranny serviced just after I bought the vehicle at 50k, and I'm wondering if I should have the transfer case serviced as well (change fluid, etc.)
Any more thoughts are welcome....thanks again!
60,000 flushed at the dealer--$125.00. filter change and flush at 120,000 dealer--$200.00. Flush at 180,000..dealer--have 196,000 and still going--shifts a little slower into OD but who the heck cares at this point it's still shifting!!!!
Can't thank you enough for the info. on my driveline 'bumping' problem with my 04 Buick Rainier. I went to the dealership and had them check for transmission/transfer case computer updates. They 're-flashed' the computer module in the transmission with updates to 'improve performance and driveability' and they worked. Thanks again!!!
I have the same problem - the dealer in Santa Clara CA quote about $900 for the repair, including $490 for the part (gmpartsdirect.com price is $195 including shipping/handling!).
I am getting it fixed at an independent whose labor rate is about 25% cheaper.
My 2002 GMC Envoy XL SLT has about 55K miles on it.
There is also a part in the AWD system called the encoder motor that I had to have replaced to stop crow hopping, which was due to the front wheel drive engaging during sharp turns. Just giving you a heads up in case you have this issue.
Recently, I started getting a rattle in the left front suspension and found that the left strut had become loose and the rubber on the top got pulverized. So I took this opportunity to have the the Bilsteins installed. My old dealership closed down so I found another that did the whole job for $250.00.
Wow, does this truck handle better. Much less body roll around corners and no see-sawing from front to back. GM put very soft shocks on the Bravadas to give it a smoother ride I suppose, but driving it was like steering a ship on the ocean. Much more fun now.
Sits just a tad higher in the back but doesn't look jacked up.
I
I've seen mixed reviews in this forum on the advisability of installing the Hotchkiss rear anti-sway bar. But, since it appears that the larger GM anti-sway bar that was used on later model TB/Envoy/Rainier isn't adaptable to the earlier models, it seems to be the only solution to the body roll on twistee roads.
General Likes:
1. Seat heaters work very well
2. Decent towing performance
3. Nice ride on the highway
4. Air suspension works well
5. Oil Life % readout
6. Third row seats good for short trips
General Gripes:
1. Bose Radio - Volume control "steps" are too big. Not enough resolution in the volume control.
2. Need more cup holders up front
3. Bose Radio - 6 disc changer is okay, would like the option to repeat a single disc or random a single disc
4. Bose Radio - Auto volume control - over compensates for ambient noise, would like high/medium/low setting
5. DVD player - Cannot pipe audio through the sound system, have resorted to a battery powered computer speaker (headsets not small child friendly)
6. DVD player - Does not play DVD-R's
7. Auto-wipers do not work very well in heavy rain or snow, ok in light rain
8. Changing the air filter takes about 1 hour
9. No aux input on the stereo
Warranty Work:
1. Air Leaks - driver door, passenger door, and both rear windows
2. Rear license plate well seal (replaced gasket)
3. Rear spoiler - detached itself
4. Failed ignition relay - stranded 6 hours from home
5. Rear Wiper arm replacement (replaced 4 times)
6. Rear drivers side door handle
7. Driver Memory Seat Buttons broken - Driver 1/2 (Replaced)
8. Loose shifter knob
9. Squeal at 1000 RPM - Demonstrated and acknowledged by dealer, unable to fix
10. Suspension Noise from bumpy road (replaced sway bar end links front and back)
11. Rear drivers side door panel (interior plastic molding fell off)
12. Replaced serpentine belt
13. Replaced both backup lights (seal failed - lights were full of water)
14. LH Rear door panel pulling apart (replaced)
15. 4WD service light on, 4WD did not work (replaced module, updated software)
16. Rear visor on top of rear window peeled off (replaced)
17. Right Rear backup light inoperative (replaced socket)
18. Rust in rear gate area (repainted hinges)
19. LH Rear door trim loose (reglued trim)
20. LH Rear door hard to open (re-aligned & lubed)
21. Rear air deflector loose (replaced)
22. LH Rear door panel problem (replaced)
Post-Warranty Work:
1. Fuel Pressure Regulator failure - difficult to start, ran poorly (38,600 miles, $295)
2. Blower Control Module - blower would not shut off even though engine was off and key out of ignition, drained battery overnight (43000 miles, $325).
3. Front Air Conditioner (needs service - currently only working intermittently)
4. Sounds like it might need a brake job soon.
Recall Work:
1. Replaced tail lamp circuit boards
2. Rear side door closure
Summary:
The Envoy is a nice looking vehicle with some decent features but based on my experience is poorly made and assembled with substandard parts. It appears that some maintenance-friendly features were designed in (easy to change the oil), but others were completely forgotten about (must remove metric and english bolts from the same cross-bar when changing the air filter).
The engine has been good so far but there have been three instances where I have been stranded or nearly stranded due to component failures. I have driven GM vehicles all of my life and this one by far has had the most issues. It is obvious to me that "GMC Professional Grade" is no more than a marketing slogan. This is the last GM vehicle that I ever plan to purchase (and I have family that works for GM!).
Glubash
Did you ever get the problem fixed regarding the air suspension problem you were having and how much did it cost (if you don't mind me asking)? I have a 2002 Envoy SLT and I've noticed over the past couple of weeks that the rear suspension becomes deflated after the truck sits for over 24 hrs.
Our 2001 AWD Safari van is getting near its "end of ownership" time period. Within the next year (or so), we'll be selling this beast and replacing her with something that is simular (or close to it). Time to move to better technology and something different - that can still tow under 3,500 lbs (loaded utility trailer with full electric brakes) and still have 3 rows of seats.
I read the above post "18089 2003 GMC Envoy XL V8 - 50,000 Mile Report by glubash Sep 29, 2007 (11:52 am)" and found it very informative. Thank you for taking the time to post it. Well worth reading - especially being in bullet form.
Due to my small weight towing and 3 rows of seats needs, my wife is targetting the Envoy XL I6 version. And, we'll go with the 2WD version - instead of our current "gas hog" AWD version. Having AWD/4WD in my area isn't worth it - for me.
With all this in mind, just wondering how many folks have gone from a Safari/Astro van to an Envoy XL I6 engine replacement? Pros / Cons, would you do it again? ETC. ETC.
BTW: I do plan to read the many Envoy XL I6 reviews on this forum. If you've gone from Safari/Astro to Envoy XL I6 replacement, just wondering about your "transition / comparison" feedback. This type of feedback isn't usually found in individual User Review feedback.
Many thanks.
RWD I6 gets maybe 18 mpg around town in mixed driving. Hwy cruising tops out at 21-22 in the 70-75 mph range.
Thanks for your feedback. Yes. We are looking at 3 year old used vehicles. We bought "new" many years ago and soon after, we discovered it was a lemon. Besides that, we lost tons of dollars on its initial deprecision fall. By doing research and looking for "patterns" (both good and bad) in this forum, we'll be able to determine if a 3 year old vehcile (like the Envoy XL with I6 engine) is a good replacement - for our current 2001 van. Thanks for feedback on your 2004 Envoy XL model. Sounds like a 2004/2005 is worth focusing on. thanks.
