There's some great incentives on until Jan. 1 - 6,000 off MSRP on TB with 3 yrs 0 financing, and I'm finding invoice plus $500 on Envoy with 5 years at 0, and 3 mos. no payment.
We're probably going to focus on Envoy, as we're looking to trade a Rendevouz, and the GM dealer we've used for service has been great, as is the vehicle, but the RDV turned out to be way too small in the third row for full size high schoolers I transport.
The one feature that RDV's have that is missing from Envoy/TB is the built in sensor for parking. Has anyone installed these aftermarket? It's a great feature, more useful than I imagined - takes all the stress out of parallel park.
Redline65 - there's alot of 4wd Envoy's out here - don't know if you can dealer trade from Northern CA to Texas - if so, you'll have your choice with the features you mentioned -
Happy Holidays and New Year to everyone!
I just didn't want to go to 100% (about 11,500 miles for me). I change it myself and if I watch for sales it only costs about $12 for a change. Awfully small compared to the price of an engine.
What are you using?
The other thing is that I know we are to use 7 quarts. The Walmart folks swear they put in 6 and that it was full on the dipstick. Perhaps they miscounted the quarts they put in because as I look at the dipstick it is past the stamped F and almost into the little dimple above the F mark. Is it possible that they did only put in 6 and that it registers that high on the stick?
SAFETY INSPECTION: Inspector "buzzed" over the car in just a few minutes, then announced to me that it failed because of headlight alignment. He said, "this is common in new cars (they don't check it) and I can fix it for 6 bucks". No thanks, I'll take it to the dealer. Has anyone else experienced this? Of course, he stated 2 or 3 times what a nice truck it is! and it is!
STEERING: My Envoy has 13,000 miles on it. I've noticed recently that there is a "rubbing" feeling in the front end (steering). Makes you think of a bearing or misalignment of some sort. It is on the driver's side. Has anyone else experienced this? Doesn't seem as smooth straight-away as it did; also noticed a pronounced "bind" when turning.
SUSPENSION: Each time I start the car, the "load leveling suspension" does it's thing (you can hear it and actually see the rear of the car raising). Yes, I know, that's what it's for and it makes for a great ride. But, is this normal (to happen with every start and periodically while I'm driving....conditions unchanged)?
Very happy with my Envoy!
What are you using?"
Another thing I decided long ago and have stuck to is to buy the cheapest oil I can find that meets the latest SAE standard. I would rather have less expensive oil and relatively frequent changes than vice versa. My theory is that blow-by, mechanical particles and other "additions" to the oil occur regardless what oil you're using and a change takes care of that.
You can get into days-long discussions about what oil is best, including the my brother-in-law's cousin's wife's uncle used to work for xyz who found brand x sludging after just y miles, etc. I prefer an objective standard and test such as the SAE rating.
Last quite a few changes (across 4 vehicles) have been Wal-Mart Fram filters at $2.49 and Wal-Mart house brand oil at approximately $11.00 for a half-case of 12. My theory is that Wal-Mart (or other house brands) obviously isn't refining oil so the oil is produced by one of the large oil companies, meets the same standard, and is sold cheaply due to no advertising, volume, etc.
For Oil changes, I've been going about 5000 miles, and I switched to Mobil 1 on the first change (2700 miles). Oil takes exactly 7 quarts, doesn't burn any noticeable amount in 5K, and is dark amber (still transparent) upon drain.
I also swapped out the rear diff. fluid for Mobil 1 when I did my 2nd oil change (8K)to clean out the original metal shavings from the gears settling.
I did the K&N filter mod as well, running a semi modded airbox, similar to what tlauro did, and it definitely makes a difference!
I plan on keeping this vehicle for at least the 5yr/60K bumper to bumper warranty period, but if she holds up as well as she's been doing, I may keep her a lot longer than that!
Do you notice any increase in noise (air induction) running the K&N filter with the modified box? The full kit (open filter) supposedly is quite a bit louder.
I agree 100% with that one!
And for the other post, I assume you meant 1,100 miles, not 11,000 miles; right?
Heck, anything would be dirty after that long. Who cares if the oil itself hasn't broken down, it is dirty and contaminated!!!
The technology this engine uses is really advanced and it will be the basis of a four & five cylinder variations used in the next generation small pickups.
http://media.gm.com/division/powertrain/index.html
Go to this link and look for the 4.2L archived press kit for more info.
Glad to hear that it is covered under warranty. I have to say though, I switch the drls off all the time when I drive. I never leave them on, so I don't knnow if this affects it at all. I thought I read on this board that others do that as well. Kinda bother me though that it's just the right one, and that someone other than me had a problem with the right one as well. Also, it was commented that the dealer repaired 3 of them recently too. Anyne have the left one go out?
Any impact on gas milage??
Any impact on warrantee??
If it is adds so much, why not sell the truck with the engine this way? You would think they could mold the airbox this way for no additional cost plus the filter would be next to a "0" upcharge
(Sounds like a great present to yourselves, redline!)
God Jul is the Swedish for Feliz Navidad or something like that.
P.S. I bet the hosts can point you to that car buying checklist somewhere.
Merry Christmas
Frank
Happy holidays, folks...
brad barber
peace. love. track.
First off, headlamp. I didn't know that you could turn off the DRLS before you put the car in gear. I have been turning them off after putting the car in gear. Thanks for the heads up. Maybe the constant on off had something to do with it?
As for the amp install. I replaced the head unit myself. It's a pain, since you have to take the dash apart, but no where near 4-5 hours. I bet he just wants tweet a little money out of you.
One caveat is that I did not have the bose system, so I don't know what's involved with that. I'm assuming the dash disassembly would be the same. Then you'd just find the speaker wires and hook that up to the inputs from the amp. Hope that helps.
I've notice that you posted this question on the sounddomain forum as well. That's a great place as well. If I can find my notes, I'll post step by step on here. Like I said, it was a pain, but doable.
amp install .... If you have the Bose there is a seperate amplifier mounted elsewhere in the vehicle - not at the head unit.
Can't wait for a thorough review on that Jet chip!
twylie "Jeep Wrangler" Oct 1, 2001 7:26am
billg7 "Honda Odyssey" Feb 8, 2001 7:27pm
The tweeter install is easy. Mid to smaller 3.5" tweeters will easily fit with just a little minor trimming. I have 3.5" coaxals in my front dash.
The only issues we have seen so far was a rattle in the driver door (resolved at first visit to dealer), and one instance of the air bag warning light coming on (this resolved itself after shutting off the engine and restarting).
On the whole, a very nice truck. Hope Im still as happy after the next long trip. In any case, we are going to have to find a way to keep the mileage down - hard to believe we have put on so many miles so fast :-)
Kimodo: If you do have the instuctions, would be helpful, just in case.
M2Iceman@Aol.com
I've had a huge number of cars from GM with very little if any long term care concerns. I'm a little different though as I only really perform the necessary maint when needed. I've never been the 3k oil, 30k tranny or 15k tune up type owner. My last three cars NOT in my possesion are still going strong and have no issues. I maintain contact with the owners who are here locally.
I only know of a few Triplets with over 40k and haven't heard any issues, but that's hardly long term.
My wifes E-320....40k and nothing but oil changes. All is solid as a rock and typical Mercedes quality. We're selling it this week to get something fun for summer.
Good Luck
tim
I bought an '02 Envoy XL SLT because I always wanted an SUV and I thought it would be great to have something that my brother last worked on. Probably sounds corny.
Anyway, I've been very happy with my Envoy and it seems very solid enough to last a long time. The engine seems especially robust, smooth, and quiet. But, since I financed for 5 years I bought an extended and improved warranty so I wouldn't have to pay for an unexpected repair while still making payments.
Chris
I have every option, except the load leveling suspension and DVD. The auto climate works flawlessly. I had a '98 Bravada that had several problems, including the auto climate. GM's not perfect, but I believe they've come a long way since my first one (1975 T/A).
I paid $640 for 5 years, or 60,000 miles. I'm curious to know what employee pricing is. I was first quoted $1K. After convincing the finance guy I didn't want coverage, he showed me what he said was employee cost ($550). He really wanted to sell it, so after some negotiating we settled on $640. I hope I never need it, but I feel more secure that I have it.
However back in August, it started stalling when stopped at traffic lights. The PCM was replaced after an error code was read from the computer. Then just 2 weeks ago it stalled twice, same situation, but no error codes. It's been at the dealer now for over a week waiting for a new throttle body. Service advisor says he hasn't seen any throttle bodies go out before. Hopefully this is just a fluke.
Envoy XL SLT build date 5/02 now with 11K miles is/has been running flawlessly. I ordered because I wanted Polo Green, did not want a sunroof (tired of sunburned head and wife was always annoyed by it anyway), and did not want polished wheels (very pleased with looks of factory aluminum wheels). Other options I got included Bose (like music then get this), air-suspension (have it on our '98 Transport, its fantastic), locking diff, running boards, 1SF.
Chris
Inline means the cylinders are all in line versus the old V configuration used before where three cylinders were located on each side of the engine. This engine has them all in line, thus no V shape. Suppposedly, it can deliver more power and maintain it's low noise level. Others may chime in on the pros and cons.
