Subaru Impreza WRX
I also like the light weight of the superlegs, about 15.8 lbs, I believe.
Ryan: No...I know that tall drivers can get comfortable in the WRX...but, as you said the wagon more than the sedan. I believe the wagon has the edge in front headroom and, definitely rear headroom. I was repeating what I had read over at i-club for the poster commenting about tall people having trouble getting comfortable.
Stephen
However, having just heard the really disturbing metallic rattle in the 3-4,000rpm
range with the engine braking, I am kinda sure it's a rattle of a shield or something.
Tinny metal on metal. (I've heard a similiar sound, under same conditions from my
Pathfinder, and it was diagnosed/fixed as a rattling heat shield).
It took 35,000 miles for the Pathy heat shield to rattle, so I'm a little disappointed
with Subaru at this point.
Is it at all possible to find and fix?
Hell, at this point, I settle for $1K over. I just went to Pine Belt and they tried telling me $2K OVER STICKER!! But, of course, because I was a repeat customer (got my wife's Forester there), that I could get the "special deal" of MSRP. AVOID PINE BELT IN LAKEWOOD, NJ!!
Anyway, ANY suggestions would be appreciated.
thanks,
rob
Anyway, I'm a devout stick shift driver, but with 2 sport car sticks in the household, having at least one auto vehicle around is a begrudging compromise that I felt I had to make. Still, I had my reservations about the WRX. While the unprepped car wasn't slow on my test-drive (yes, they did let me test-drive w/o any flack or melodrama), it certainly was no road-burner. What a difference some dealer tuning prep makes. The car really moves. Don't believe some of the hype that you read about WRX auto performance. From a rolling 5mph start, the WRX 5 speed would be hard pressed to keep up even in the hands of a highly proficient driver (from a standing start, if you did a 5000 rpm launch with the stick, you'd probably gain a car length at the outset over the auo, but you'd lose ground by the 1/2 shift). The auto holds gear as long as you want it to (it's easy to modulate gear change with the throttle), has firm quick shifts, a lower final drive ratio (4.111 vs. 3.9 on the stick) and excellent gear spacing. I've driven and owned so many sports cars in my life that I can unequivocally say that the auto would have no problem bettering 15 sec for the quarter mile even w/o power braking the transmission. Once it's broken in, 14.7 seems quite plausible. More important than the #s, despite it being an auto it's still a fun car.
Other myths -- (1) the wagon needs a thicker sway bar. The suspension rides pleasantly firm, but has a good deal of travel which was presumably designed into it for second-rate roads (that rally image). A thicker sway bar wouldn't make a difference with this much suspension travel. The car isn't going to handle like a Miata. The only way to come close is either dropping the suspension 1 1/2 inches or keeping the ride height but with competition firm springs and shock rates. If the car is for street use, think long and hard about the wisdom of either move. You could do far worse than this stock suspension. A major suspension change like that requires a good deal of fine tuning (wait a few months for the tuners to spend their $$ experimenting of springs and shock rates, sway bar, tire and drop kit combos). More often than not what you'll get on the first or second shot is extremely darty and buckboard harsh over any road irregularity.
Myth (2) -- the tires are way too soft and must immediately go. The softer tires provide additional dampening for a firm suspension over rough roads. Switch to significantly firmer tires, and there goes your extra dampening, along with the "pleasant" in pleasantly firm. If you're going to drop the suspension and switch to something like Koni or Bilstein shocks with Eiback springs, you're thowing your money away without switching to firmer 45 series tires (plus one upgrade). If you're enough happy with a ride that's pleasantly firm, keep the Bridgestones until they wear out and replace with a set of high-performance all season Pirelli P7000 Supersports (or something better perhaps by that time).
See this post at i-club:
http://www.i-club.com/ubb-files/Forum30/HTML/000009.html
trent4: Sounds like a seal of approval to me. I'm really getting WRX envy and you've got the car with the specs I'd want - black wagon w/auto. I think I'd have the dealer keep the RE92s, put winter rubber on the 16" wheels and get a nice set of 17" OZ P1s with summer rubber. I really like my Forester and I've had it only since January 2000 but sometimes I wish I'd tried to wring another year out of its predecessor. I guess I'll have time to see how the Forester's and WRX's long-term reliability works out. Maybe by then the WRX furor will have died down a bit and I'll also know whether I can stay with a small wagon or have to start thinking Legacy GT.
Congrats on the purchase - enjoy the ride and keep us posted.
Ed
The 6-speed tranny in the STi (according to the New Zealand Subaru site) is built in-house, and Subaru is swamped with back orders. NZ is getting only 15 STis for the whole year (of which 3 are dedicated race vehicles), starting this June. So until Subaru can start producing decent quantities of 6-speeds, it will be a while...
Bob
By the way, I just checked my tire pressure today for the first time since getting it from the dealership. They were way past recommended pressure! The dealer inflated them to the max psi level printed on the sidewall (44psi) instead of the recommended psi (32 front, 29 rear). I haven't taken the car out again, but I wonder if this isn't the reason the tires slipped a bit on hard turns.
haven't had the displeasure of driving a car with RE92s, but from what I heard they aren't all that impressive, even on an AWD car.
Curious as to what your real-world results hold with reduced pressure.
Since I won't be anywhere near an autocross course with my new car (will be happy to drive one with yours!) I won't be following suit with your advice on tire pressure.
--jeff
2002 WRX
5MT, WR Blue
Try running the RE 92's at around 36 PSI. That's what I use on my Legacy GT and it is a nice compromise between wet/dry handling and comfort.
Cheers,
-wdb
It is astounding how sloppy dealers are when prepping cars for delivery. There have been serveral reports of cars delivered with blinking check engine lights indicating that they didn't even do a cursory look over. The car I ordered (but didn't buy) had plastic sheets, discarded boxes (I think from the installation of the alarm at the port), and other trash in the car when I came by to test drive it and presumably take delivery. Another car I bought a few years back had some minor body damage.
When you drive a car home, you really need to do your own PDI - look the car over carefully and take notes. Check all the fluid levels, pressures, etc.
- Mark
-juice
-Beanboy
The test drive on Saturday clinched the deal. I had ordered the car subject to a drive about 2 weeks ago. It is fast and fun, and rides great, and with nobody from the dealership along for the ride, we didn't worry about the 4,000 RPM rule - after all it was a demo car not the one I was getting. I still think the car is a little weird looking, and as I am about 20 years older than the target market hope I don't feel uncomfortable in it - but it is all about the performance. I hope to get my car in about 3 weeks.
Stephen
I think of the WRX more of as the "A-10 Warthog" of the Automotive industry
Negative press? Don't believe the hype. To borrow a phrase from another car brand: "Own one and you'll know!"
Stephen: only 400miles on your WRX? You're going to have to try harder!
-Colin
Yes, as lark6 mentioned it's Flemington. They don't have that deal any longer but are still selling under MSRP. The contact is Alex Leist at
Flemington Subaru, 908-782-2025, Leista@riisc.com
They don't have any WRX's in stock right now because the first allotment sold out. They'll probably give you the best deal in NJ though. Tell him bluesubie (Dennis) sent you.
trent4 - Thanks for that review. I'm considering an auto in my next Sube purchase in another year or so. Especially if they have the sport-shift "pretend" manual.
-Eric
2002 Blue Ridge Pearl Impreza 2.5RS
-juice
I don't know what size your stock bar is-- crawl under there and measure it yourself-- but I do know that the rear sway bars between 93-01 Imprezas (and 02+ wagons) are *not* compatible with a MY02 sedan.
If you don't have a 20mm rear bar then you could order one since they're original equipment on the WRX. You can get the part number and a great price from Ryan Cavalier @ Irvine Subaru-- his email is scoobyparts@hotmail.com .
Have fun.
Stephen
I will look into ordering a 20mm WRX bar.
-Eric
-juice
Stephen
By the by, I let a friend drive around in my WRX for a bit this evening. He has an '87 Mustang SVO modified up the wazoo. At 3000 RPMs he let the clutch drop and got the tires to spin for a split second to my horror! Poor pup! Oops, there's that dog thing again! Sorry Vanex.
I've heard people say-- a.k.a hearsay or RUMOR-- that the 2002 RS has the same suspension including swaybars as the WRX. I don't consider it proof yet, since SOA hasn't affirmed it...
-Colin
-Eric
13mm seems like a coat hanger next to even an 18mm bar.
-juice
I came across an interesting graph that one of the members supplied in this topic:
They were trying to see what combination of VW engines, chassis and drivetrains could compete with the WRX!
Ken
I run 225/50-16 on my 99RS, and the tires rubbed the rear fender lip a bit before I relieved them.
-Colin
thanks for your help on this - it has been a long wait but this weekend i'll be booting around (under 4000 of course) in my silver wrx - with some good toyo rubber
That graph is interesting, but you have to account for weight and gearing to get the full picture.
-juice
The S4 does not fall anywhere near the others in terms of price. Performance? Definitely!
VW will strike back, though. That 1.8T makes 225hp in the TT, why not bring a little more power to the Golf or Jetta with 4Motion to take on the WRX?
-juice
