A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Just give me a martini, the Times (Financial or NY), and a sunny day at the pool and I'll be fine. Thanks for caring. Your concern is touching!
By the way, could you please cite for us the source who has confided the development schedule of the GM inline 4/5/6 program to you?
So the V engines aren't perfect but the straight six is!
One other point. Besides the tweaky Honda four-cylinders, do any other engines make as much power per pound and specific output as the current M3 engine? It must not have a big intake manifold problem, and it by no means looks like a "bundle of snakes" on a V-6.
Articles discuss how this was the first high performance I-6 since the Hudson Hornet. Calls it a "satisfying" engine. Excerpt: "... in Sprint form with Rochester Quadra-Jet carburetor, hotter valve timing, and double valve springs. The crankshaft had seven main bearings; the camshaft was driven by a fiberglass-reinforced notched belt rather than conventional chain or gear drive. The optional four-speed transmission, clean styling, and interior that featured bucket seats and console gave the Sprint the look and feel of a true grand touring car."
Stan, why don't you read a REAL book on the subject yourself, instead of depending on the bits and pieces offered up by rag writers and dabblers.
Actually, according to the (engineering) books I've read, the only truly balanced 6 is the horizontally opposed (flat) 6 ala Porsche. All the rest (including the I6) generate couples which must be dealt with somehow.
Buy the book, "Advanced Engine Technology" by Heinz Heisler, at the SAE.org or Amazon.com website and read it. When done, fire up your barbecue grill, get a "6 pack" (pun intended), and enjoy all the steaks which get carved out of your favorite sacred cow.
That's it for me, I'm tired of typing.
It should be obvious to everyone that nobody here is changing their opinion, so why bother arguing about it? I used to get caught up in arguments like this until I realized 2 things:
1 - If you've made your case and the others still disagree, nothing you say is going to change the other person's opinion. So why keep trying?
2 - In the big picture of life, what difference does it really make? And why waste your time and effort (and high blood pressure) on it?
My approach now is to make my case, argue once if necessary and then just drop it. If the others don't agree then either you're wrong (hard to accept but possible), the other person is wrong but is convinced they're right, or you're dealing with a troll who's doing it for sport (I think all of us fall in the first two just for clarification). In all 3 cases there's absolutely nothing more you can do, so why waste your time.
(Geez, you even got Brian riled up, and that's hard to do!)
As for the comment about nothing to read....the previous "discussions" (whining's in my opinion) about more HP, performance issues, LM's direction, etc. (ad nauseum), are MY idea of nothing to read.
But, like you mentioned, everyone is entitled to their own opinion, although engineering matters, (as pertains to physical phenomena) are generally based on facts, and are not open to interpretation by "opinion".
I don't think it does any good to attack sources. Asking for a citation on some info or background info is one thing, but to blanketly attack or denigrate a source to prove a point is not worthy of an open and honest or full and fair discussion. That includes attacking the automotive press in toto.
As for engineers and "facts", I constantly chuckle at and periodically chide the group of DOT engineers I work with when they discuss roads, bridges, setting speed limits, the color of signs, safety strategies, etc. There are about a dozen of them. All licensed, skilled, and experienced engineers in their fields. I have never seen them all agree on anything. Heck, they can't agree that the new high visibility puke yellow/green signs are "better" than the former color they replaced. Nor can they agree on whether using asphalt or concrete is appropriate in a lot of cases. Or the exact mix of materials. Engineers are as bad as economists. You put a dozen in a room and you get anywhere from 6 to 18 opinions! On darn near any subject.
Stanny: Read my previous post! with split crackshaft rod journals you can have any angle V engine and still get a even firing order.
ezairconj4c: You left off a very important qualifier in my post "given the same displacement"
For all those with fond memories with the Pontiac I6 from the 60's you must have been fortunate enough to unload them before all the problems surfaced, rocker arms, lifters, cam drive, distributor etc. They ran good when new & in tune but time & miles significantly degraded their performance. Given the small numbers of the Pontiac I6 that were manufactured the shop I worked at made a lot of money fixing them! Comversely, other than occasional timing chain problems I can argue that the Chevy small block V8 and the Pontiac mid-block V8 were comparatively bullit proof.
I pray GM won't build an I-5. Didn't Acura use something like that in their mediocre Viagra (oops Vigor)? Don't remember anyone praising that motor.
Guessing we might all agree on one thing. Engines should have an even number of cylinders. Five cylinders bad; six (or eight or twelve) cylinders good!
I'm not familiar with that term, however if it is an insult, then....SAME TO YOU BUDDY!
Think basketball.
I'm 6 ft 2 inches. About 185 pounds. Scrawny and caucasian. Been a while since I played b-ball. I can jump but not dunk the ball.
gschwartz: Nice attempt a levity. A commodity in short supply around here at times. I'm much better at sarcasm and satire. Do they count as humor?
j-man: To show you how experts in a field rarely agree, just try linguistics and the English language. How do I spell labor/labour or humor/humour? Theatre or theater? Can I pronounce the "n-word" for atomic energy "nu-cu-ler" or "nu-cle-er"? I prefer the midwestern variant. How 'bout we settle our differences with a spelling bee? Geography test? History quiz? Geo-politics test? Economics? (Notice how I try to choose areas I think I might do well in.)
With apologies to Swift: A modest proposal. We settle all strongly held disagreements in a dignified, professional, gentlemanly way... drinking contest. I'll start stacking up my Guiness Stout, Newcastle Brown ale, single malt scotch, and gin...
Personally I prefer a discussion that's fun, engaging, and cool..real cool. I believe you are correct slunar, The 60s Pontiac I6 did develop problems with age which was another reason they didn't survive. Luckily the Air Forces' SEA plans for me forced me to sell the Tempest before any engine aggravation. Aah, my misspent youth.
Thanks for bringing up a topic that I have vast yet subjective experience in.
Tom....
No offense (as if that were possible here), but I spend most of my day refereeing debates of this sort in a company that needs to deliver complex mechanical products on time while making a profit. The products are competitive in nature, though produced in much smaller quantities than in the auto industry.
Point being, reading magazines & books can be good, but what works and lasts is usually what matters. People who write articles may or may not have produced products that have withstood the test of time. I owned a 240-Z that had an absolutely bulletproof engine. Won't trouble you with the configuration. Those who care, know, and those who don't, don't care.
We can throw quotes back and forth until the world looks level, but in the end, the customer will call the shots. If the LS proves to be a competitive "luxury" sedan over the next 10 years, we'll all appear to have been experts. If not. . .most of you will turn in your lease cars and go on to the next flavour of the month.
Others of us will be somewhat more disappointed.
What we got was about a 3-5 hp increase once the readings were corrected for temperature and humidity.
I am going to swap out the GMS sensor and put back the stock sensor and try to get the car dyno'ed again next week to isolate where the discrepancy is.
While I know that the Borla exhaust is not as free-flowing as the Magnaflow prototype that we tested several months ago, I still expected to see more of an increase. The prototype system gave us a 12 hp increase. I would expect the Borla since it is a bit quieter to bring about 5-8 hp.
So currently LLSOC can't recommend getting a GMS mass air flow sensor at this time. It doesn't appear to contribute an increase and may possibly be taking some away. For $360 I would expect to see a better result. To be fair to GMS we will test it again on the dyno next week swapping it with the stock one on the same day to see the results.
I'll keep everyone posted.
http://auto.com/industry/nissan15_20010815.htm
I love my car but i really hate driving around with duct tape holding the window up..
maybe if I had a car without duct tape I would give a da%m$n about V6 vs V8.,
0-60 times, manual vs auto, endless discussions about engineering stats and who found them..
I just want to talk about the Lincoln LS and what we can do to fix the problems... not how to make the car a "Dream machine" for a select few...
The forum is called Lincoln LS not "wanna be experts and how they know more than anyone else and if you don't believe me I will talk you into oblivion"
Ok I've vented.... thanks
Kevin
The installation was easier than anticipated, and I did it alone. The stock system is "one-piece", and after loosening the two clamps (15mm six-point deep socket) up near the front, removing the "safety" cross bracket under the resonators (two 8mm bolts) and removing the two hangers from the rubber "donuts" (a little WD-40 helps here), the whole stock system literally drops out. Compared to the Borla, the stock system weighs a ton has 1.75 diameter pipes versus Borla's 2.25.
The V-6 has smaller stock pipes than the V-8, but the Borla system is the same for both engines, so the Borla really benefits the V-6 more. The Borla system comes in three "sections" . The easiest way to set it up is to attach the two pipes of the middle section to the one piece resonator/X-pipe section and then install the whole thing at once - just shove the resonator pipes into the original header pipes and attach the two middle rubber donut hangers. Six clamps are provided, and these are industial-strength wide babies which have to go on before you mate the pipes. Tighten the two front clamps and you are ready to fit the muffler/tip sections in. Just shove the pipes in and do the donut hanger trip again. Now it's all "well-hung" and you are ready for the most time-consuming and critical operation which we will call "adjustment for optimum looks". After tightening the four clamps "finger-tight" which requires the 15mm deep socket on a 3/8" ratchet handle, pretend you are driving the car behind yours in the Jack-in-the Box line and eyeball the chrome tips. By moving the pipes around you can control the angle and protrusion of the tips to a limited degree. Like tire pressure, you want some similarity between the sides so you don't look like one of those retards with the ill-fitting mufflers on a Honda Civic or Integra. After tightening the clamps, you are ready to let the neighbors know that, yes, the neighbor who is pushing middle-age is indeed having his second childhood/male-menopause period.
I did resist the urge to start the cars sans exhaust system but I don't know why.
With the Borla, I won't be taking crap from the Civic/Integra/Eclipse crowd anymore. Amen
I would like to put some emphasis on one thing I said last night. None of you are obligated to respond to any post that gets under your skin. If you can keep that in mind, it might be helpful to your blood pressure, and very likely would be helpful to keeping the discussion helpful, useful and on track . As we all know, sometimes posts are made for the sole purpose of riling others - if the bait is not taken, there is no reward for that sort of post to continue.
Meanwhile, please do feel free to drop me an email if you need to call my attention to a post or for any reason at all.
Thanks - you folks really have created one of the finer discussions that I read.
Pat
Sedans Message Board
So all of you posting about your window problems, hope you know you have some of us living in constant fear! I'll just have to keep saying "It can't happen to me." Over and over. (Please let us know when the parts shortage is over and the engineering fix solved.)
j-man: Putting on your engineering hat, what do you attribute the window problem to? Poor engineering? Bad supplier? Cost cutting run amok?
Borla System -- Thanks very much Stan, for the detailed installation recap. Keep us posted as to your longer-term impressions.
Mods in General -- Don't be surprised if the "obvious improvements" put forward by aftermarket suppliers don't pan out. Ya think maybe the FoMoCo engineers may have known what they were doing in the first place? Just a thought.
Drive on!
Seems like too many aftermarket products are hype over substance. Many don't lead to improvements. Many also lead to degradations in areas like noise, fuel economy, durability, driveability. Or jeopardize warranty. If you want an LS to perform like something like an M3 or M5, installing gads of aftermarket parts likely won't do it. Just buy a used M3 or M5 instead?
Kevin
"saws" the material. I also did not spot any mechanism for tensioning the cable to compensate for age, temperature, stretch and physical wear.
Once that cable gets off track, the inside of the door resembles an explosion in a speghetti factory. This mechanism seems just as problem prone as the old "gear and scissors" system used for decades.
Folks, we have got to get back on the subject and stop talking about each other.
Pat
I think the horsepower letdown on the project car is from choosing an exhaust system that restricts flow too dramatically. You should probably look into an exhaust system similar to the one below.
http://www.beaterz.com/reviews/0300/p49.htm
As an added benefit, I believe the unit is much less expensive than the Borla -or- the Magnaflow.
-Matt
I agree with cdnpinhead and giowa with regards to casting an extremely jaundiced eye toward aftermarket vendors. Can you imagine someone spending $360 if the advertising read "And look, you can get 3 hp more!". What I really find hysterical is that you never see a part offered that produces under 10 additional horsepower.
Yes, I am, and have been for over 26 years, an electronics design engineer in the field of electronic power conversion, where I hold 6 US patents. The products I work with are motor drives, UPS systems and power supplies in the range of a few watts up to 2MVA (that's Megawatts buddy). In addition to the electronics design portion I routinely design the packaging/heatsinking to house, mount, and cool the electronics portion of my designs, some of which have been the size of a car. I guess this gives me a mechanical background also? I've been a "gearhead" since my early youth, have done all the hotrodder stuff from bolt-ons to porting & cc'ing heads. My brother and I even had our own auto repair for several years while I went to college nights. And oh yeah, I know my way around a machine shop (tool & die) just fine thank you.
Oh yeah, I'm also a member of the AARP.
I'm supposing here, but I think the problem is multi-pronged.
1. The supplier made a inferior part.
2. Ford may have squeezed the supplier on price to where the supplier cut a few corners.
3. The part may not have been designed properly.
4. The dealers aren't being told what to do with the problem. Not securing the window in the up position is pretty customer service poor. Expecting owners to drive around with the windows taped up on a $35,000 car is really idiotic.
5. The parts from the new supplier isn't being put into the service channel quickly enough to satisfy the demand.
Whatever the reason for the problem, it is obvious that it is a customer service nightmare. As you all know, I don't generally advocate recalling things, but this appears to be widespread enough and unpredictable enough that it may warrant it.
