Visitor Agreement.
Where in the world is Doc? We're all dying to know if you were able to inspect your air filter. We've given you a ton of hints! Did any of them help?
;-))) Inquiring minds want to know!
fastdriver
http://www.shutterfly.com/my/osi.jsp?i=67b0de21b318b0a9a425
I have received pictures from 4 of the attendee's: George, Vincent, Tony and Robert. I'm waiting for a couple of pictures that I shot, and will be putting them up when I get them. To whomever is co-ordinating the 'Arizona Meet', feel free to borrow the code and layout for pictures/mini-Arizona website you may create.
Link to the Wall Event mini-website:
http://www.300mclub.org/wallEventHome.htm
Doc
I have some pinstripes on my M. They were dealer add-ons. They are very thin gray ones that run just above the accent ridge at the top part of the sides. My wife didn't really like them when we first looked at the car, I could care less about them. I thought of pulling them off, but she said don't worry about it. I don't notice them much at all. I like the chrome around the windows. I think it sets off the lines of the car.
Forrest
Doc - got your IM after you logged off - site looks great. Nice work!
Exhaust - ok, now the bad part, since the mechanic yesterday was on about how it's no big deal to swap the exhaust, even though it's a lease, now I want to
Also, I know that a lot of people prefer the hujo duals design, but mine's a lease and I can't cut into the rear to put the other tips in
Anyone? TIA
(also posted at 300mclub board in case you notice the dupe)
http://www.exhaustproslinc.com/index.html
They have it for about $600 shipped. Or so they say they do
Tempted to check the so-cal speedshop. They did an M modded car, but they don't list the parts online and I haven't gotten around to calling them yet. If someone does, please ask about shipping since I'm on the right coast.
Check out the Hugo design diagram at http://albums.photopoint.com/j/ViewPhoto?u=1620463&a=12630411&p=46814953&f=0 Dynomax has a SuperTurbo model 17786 that could be put in place of the 17739 that I used in my installation. The 17786 has a 2 1/2 inch input on one side (which matches the stock intermediate pipe dimensions) and two 2 1/4 inch outputs on the other side. The input comes from the passenger side through the existing pipe, and the two pipe output would be on the drivers side. You would just have to add mandrel bent 2 1/4 inch pipes (can be bought at JC Whitney or customized by any muffler shop) that go to the existing cutout, and find some tips you like to put on the end. Viola. Dual exhaust that can be removed. Here is a PDF of the dynomax mufflers.
http://www.dynomax.com/documents/super_turbo_specs.pdf
pics are small filesize....now just working with a rotozip to get the tv flush in there, and then doing vents on the two sides. will be sanded down to original texture, so it doesnt have that cheap glossy look. and of course painted.
muhaahahahahah
As for the fuel consumption, I think I actually get few mpg's now than I originally did. The reason is when you hear what it sounds like you are going to wanna hear that baby rev a little bit more than you used to... Sounds so sweet... but you pay for making it do that... Otherwise I think I probably got a couple of mpgs better...
Was looking on the web for the parts - looks very doable...
Im looking for a cool looking switch, lighted, that would match the guages at night... Have any ideas ?
I've got a 2000 Intrepid R/T with the 3.5 liter. There seems to be confusion over whether this drivetrain needs the differential fluid changed at 15,000 miles. It is separate from the transmission, correct? What type of fluid is used in the differential, ATF+4 just like the tranny?
You can get the Dunomax 17786 from carshopinc.com for $66, the Magnaflow 12258 front collector from bestautopartsonline.com for $83, 90 degree stainless mandrel bent pipes from JC Whitney for about $30 each (need two, and could save money if you don't use stainless), and borla or monza pacesetter single tips for about $30 each, also from JC Whitney. You'll use the existing stainless intermediate pipe from the magnaflow to the dynomax so you don't need that part. I come up with a rough parts total of under $300 including some brackets and maybe some short 2 1/4 exhaust pipe pieces to run from the stainless mandrel pipes back to the tips. If your muffler guy will do a good job for $100 I think you've got a nice system for a nice price.
One word of caution though. Make sure they weld the parts together and not just clamp them. Too much opportunity for leaking. Also make sure you let them know just how far and in what position you want the rear tips. Mine are staggered and follow the line of the bumper, which I think is a classy touch.
The bad part is I live in Ohio(used to live 20 miles away from Summit Racing too) and have to pay sales tax, yuck! But it is still by far the best deal. One plus is I've delt with Summit Racing before and have had good experiences.
ok, I take a look in the manual - read what it says, in Canada (since they only sell them there standard) it says when the car is on and the Emergency Break is OFF they will run. Duh! I plug it in, turn on the car, take off the break. Voila! works like a charm
On the exhaust side - which do you think (cost aside) between the borla and a dual with the magnaflow/dynamax, but two pipes on the same side (so it will look the same as it does now) would perform better?
boy I seem to be posting a lot here today - maybe they should give me something to do at work. I've already asked
Dr Pixel........my M has pin stripes down the sides, also just above the accent "groove". The stripes are black on my silver car.....looks good. Mine are hand painted, not tape or something.
I like the way they look, but my car is about to go into the body shop to repair the damage done when the bike rack in my own garage fell on it. They have to replace the right front fender and straighten the right front door and, of course, repaint both those panels plus the hood. I'm very concerned that the stripes will not be redone as well as they were done originally.
I'm keeping my fingers crossed!
Lynn Flowers
McKinney, Texas
I forget, is the borla exhaust a two or three muffler system? If it's three, it might be more restrictive than the other approach. Also, I echo Roger's comment about the resonation. I think we all get a little resonation around 2k RPM, but reports are that the borla is obnoxious.
With the other single side system, I can foresee a possible alignment problem with using two 2-1/2 inch mandrel bent elbows side by side, since they would both be bent on the same radius. If you have them custom bent, unless you have a mandrel bender at your disposal (very few muffler shops do), you're talking about big bucks. The alternative is fairly sharp bends made without benefit of a mandrel bender, which probably means some kinking of the pipes. Now that might reduce your performance.
Requires another set of holes as well. Unavoidable!
i went to my new dealer the other day (these guys really are 5 star still cant believe the diff in service quality over my other dealer) to have a bunch of service done, including transmission service... They told me that the fluid in the car was ATF +4 and that it was permanent and did not need changing at all. I asked them if not changing it would void my warranty and they even put in writing that it would not affect the warranty... They said they would do it if I wanted, but in their opinion it was a waste of money... Whats the deal ? Anyone else ever heard of ATF +4 being permanent ?
Proof of 5 Star: I overheard them tell and old lady that she didnt need a tune up yet, and the day after I picked up my car they called me to tell me they would pay for my rental since it was in 2 days... Im not used to this kind of treatment ! LOL
My 1999 300M manual called for a trans fluid change at 15K.
The eagle finals seem very appropriate now!
http://albums.photopoint.com/j/ViewPhoto?u=1501794&a=11408326&p=40150653&f=0
on the 300 M. But as an former member of the "SHO REGISTRY" and owner of a "91 SHO, the company claimed up to a 20 - 25 hp gain with their cat back systems. This claim was verified on "their" dyno machine.
However, a indedepent company performed the same test (with a '93 SHO), and hp gains were a modest
2 - 4hp.
At that time Borla was charging $800 for this system, alot of money for such little horsepower.
sdmike2-
Ahhhhhhhh.......ONE of my favorite pics! No scratches, no dents! ;-))
fastdriver
Is this S&B air filter sold by it's self away from the Borla kit? And if so, by whom?
Plus any new info on the S&B vs the K&N air filter?
