Chrysler 300M
1250251253255256507
  • sdmike2sdmike2 Member Posts: 2,909
    I ordered the shirts and SWEATSHIRTS today. I'll email you once I get a final cost and due date. Also, saw some nice nylon brief cases that can be had for under $30 including embroidery.
  • 99_300m_ric_va99_300m_ric_va Member Posts: 377
    Order Part 05080982AA, 4 of them to fix both seats, 2 if only wish to fix drivers seat.
    It's a 20min fix, you need a 15mm socket and rachet to remove the seat and a T-50 Torx bit to remove and replace the bolts. Do it yourself and save yourself a lot of grief.
    Steps are simple as follows:
    Remove the seat as usual, 2 bolts in front, 2 bolts in rear.
    Unplug one small and one large electrical connector.
    Remove seat and look for two large T50 Torx head bolts.
    Remove and replace with new bolts.
    Reinstall seat.
    Pics:
    http://photos.yahoo.com/bc/rpowelljr300n/vwp?.dir=/My+Photos/Seat+Movement+Fix
    For those @Home users getting switched to your cable provider's own high speed internet (@Home is bankrupt and AT&T declined purchase)
    Since I'm posting this I'm back on the net. I got switched today from Comcast@Home to Comcast High Speed Internet. I was down this morning, but found that I'm back on tonight. Speed seems about the same.
  • easyrider300measyrider300m Member Posts: 1,116
    what is the problem with the old bolt? are the heads too small---will the problem get worse or dangerous if you leave old bolts in? I had a slight problem but havent noticed it lately---mentioned to dealer--said he couldnt duplicate--if you sit in seat and shift your weight forward and back with your legs, you can feel some slight movement---I even mentioned TSB and they said it didnt apply my Y2K vehicle
  • hayneldanhayneldan Member Posts: 657
    The list of contributors posted originally by me (although I was not the originator) was dated no later than 9/15 /01. The Scopes site data, updated as of 18 Jan 02 now lists Contributions of vehicles equipment and dollars by some Manufacturers since the original internet posting. The DC contribution is real and can be verified at Carandtrucknews.com
  • 300michael300michael Member Posts: 1,815
    Carlsbad sounds good to me, as long as it is in March (not Feburary). Good luck with the dealers, they sited liably clauses for not wanting to have the meet at the Phoenix dealerships. I agree Torry Pines is a great photo op place. I hope to see a lot of LA Mer's there too (My old stomping grounds).
    The first time I complaned about it, I too got the could not dupicate it. Give them a ride, I am sure they will feel it, then. I am still waiting for my bolts to come in.
  • russklassrussklass Member Posts: 389
    TSB stands for "Technical Service Bulletin."
    These are issued by the manufacturer when the same complaint is receives often enough to prompt a suggested fix. They save the dealer time diagnosing the problem, and instruct on the repair proceedure. They are not a recall, which is issued for safety-related problems.
    A dealer will usually perform a TSB fix at no charge if a customer requests it.
    A dealer who says he doesn't know what a TSB is should immediatly lose his 5* rating!
    Question is the service better elsewhere? Generaly yes, but you pay dearly for it. Go to a BMW and have a 24K mile service and do the same at a Chrysler dealer, the BMW will probably cost about 3 times as much. I do wish that the service (I made a funny) department would take more care of our cars though. Most of the damage to my car was caused by them (the four door panels I am have replaced) by over tightening. Luckly that is the reason I do most of the work myself. My old motto is " If I break it I pay for it, if they break it I pay for it". I may as well get the pleasure.
  • beach15beach15 Member Posts: 1,305
    Just a quick question, the car goes in tomorrow.
    How long should it take for the side windows to clear off when they're wet and you can't see through them in the morning from the overnight moisture? Our car sits outside all the time, and even though we let it warm up a good 10-15 minutes before going anywhere in the morning, the windows have never once cleared properly like the windshield and rear window do in just a minute or two. This morning for intstance, started the car at 7:15 and while sitting in the car at 7:40, all the side windows were still covered and we couldn't see through. This was 35 minutes, even after having it the blower on high. Tried to roll the windows down which should clear like it does on any other car we've been in, but that doesn't clear them either.
    So, on average, how long should it be taking to de-fog the side windows? Our Voyager did it quickly just like the windshield and the Bu-rod LeSabre too just a few seconds for all the windows. So, what's up?
    Also, we've had trouble defogging any of the windows, including the windshield, if they fog up inside from temp. changes. We'd vary the temp, max the blower, but nothing. Should the HVAC system be working like this?
    Shouldn't the windows clear off too?
    I got one the other day on eBay, and all I can say is WOW! The local ace hardware has plastic handle ones (the better ones have wooden handles) for under $14.
    Check your calendars. I'm shooting for March 16th. More information to come later.
  • massivslinkymassivslinky Member Posts: 13
    That sounds way too long. I've always had a quick defog. Usually 5 minutes max. Few possibilities: You mentioned that the car was exposed to the elements. Is it possible the interior is retaining moisture? Is the condensation pan (for the air conditioner) clear and empty. My scirrocco routinely had a problem with condensation drainage which would actually act as a humidifier when I would turn on the blower. Does the problem get worse when you turn on the blower? Either way, something's not right. Both my 300M and Town & Country clear the windows in minutes.
    Unless things have changed, BMW gives your "free" maintenance for 4 years 50,000 whichever comes first. They'll even replace the clutch if you torch it. I think they just charge twice what it costs to build the car so they factor in a worst case of replacing everything at least once ;).
  • achanceachance Member Posts: 106
    Juneau, AK has two kinds of weather: cold and raining and cold and snowing - defroster gets a workout. If I put it on manual defrost, it clears pretty quickly - the 300 is a coldblooded beast compared to my wife's Sebring and the Turbo LeBaron I had before. Side windows are slower than windshied, but not a real hassle. If it is on blended heat and defrost, it takes a good long while, say 15 - 20 minutes in 30 - 40 F temps. I'd have the dealer check to see that the A/C is coming on with the defroster and that it is using outside air on defrost.
    Have plenty of Green Beer and a Birthday cake ready then (March 17th).
  • ruskiruski Member Posts: 1,566
    sounds like it's from a spy movie -
    "was snookered by my source-my corporate executive wife sent it to me, so I thought it was genuine information"
    Yeah, I have noticed too.
    First some guy came in and said that he had test drivena Special 300M which did not have dual exhaust... then a few other new people complaining about stuff.
    I picked that weekend because my in-laws will be in town and I'll be able to ditch them for a day. lol! Maybe we'll have dinner at Jose O'Reilly's...green beer and mexican food.
    Easy,
    The bolts look the same to me except for the rubber washer. I guess it's intended to keep it from comming loose, although one would think a lock washer would do that. There is also some dried red "loc-tite" on the new bolts. I put my new bolts in and really tightened them down and the rubber virtually squeezed out. Maybe that's too tight, but it doesn't move anymore, so I'm happy.
    Pics:
    It's been 25 degs here lately and some mornings I have to scrape the glass, others not at all. Depends on the dewpoint I guess. Anyway, I was scraping yesterday morning in the dark and had the driver door open so the interior lights would be on. This caused all the interior windows to fog on the inside. The rear window did not fog as I had the rear electric defrost on. It had to wait for the car to warmup some while watching the front windshield slowly unfog. I had it on full front defrost and put the system in manual to boost the fan speed. The front windshield was clear in about 3-5 mins since the air was still warming up. The side windows took quite a bit longer, 15 full mins before the rear side windows were clear, about 10 mins for the fronts. There is very little air blown on the side windows. Normally when the air is warm, any fog on the inside is cleared within a few seconds. It's just those cold mornings and cold defrost air that makes it difficult.
    Hope this helps.
    Yesterday, I bought the Michelin Pilot Sport A/S tire. They are a perfect balance between high peformance Z rated and excellent all weather traction. In a 300M with the Performance Suspension, they corner like it's on rails. Hasn't rained yet, so can't comment yet, but Michelin gives them their highest rating for Wet, Snow and Ice, and Dry Traction. They are a little firmer than the Michelin XGTV4s I had before, but ride is still good and they are about the same on road noise, which is way better than Goodyear equiped LH sedans.
  • bigmike5bigmike5 Member Posts: 960
    The part numbers for the molded splashguards, no logo, are: 82203657 & 82203658. I assume they are generic to all the current Ms.
  • bobhex40bobhex40 Member Posts: 63
    I brought my 2000 300M in to get the seat fixed and told them of the TSB and they responded "what is a TSB?"
  • pjyoungpjyoung Member Posts: 885
    Turn the AC compressor on manually, then turn the fan speed up to full. Your windows will defog in no time.
  • rogor2krogor2k Member Posts: 385
    These guys are either clueless or are jerking you around. In either case, I wouldn't expect a good outcome.
  • mboomgardenmboomgarden Member Posts: 39
    I've posted a poll on the 300M Enthusiasts Club Message Board at http://pub88.ezboard.com/f300menthusiastsclubfrm1.showMessage?topicID=158.topic . I'm interested in getting your honest input, whether positive or negative. If there are enough responses to lend some validity to the poll, I'll report the results here and forward them to Chrysler.
    I spent 9 months in Juneau on a project for the DOTPF. I loved it up there. Heading north out of town along the water on the dirt roads gives you some of the world's most beautiful views.
  • cbwonguscbwongus Member Posts: 40
    Can the wings on the grill be removed cleanly and easily?
  • blondablonda Member Posts: 542
    When I took my car in for the seat movement I offered to give the TSB# to Service Manager but he said "that's okay..we'll look it up." My service receipt doesn't reference a TSB, but describes it as "replacing the seat drive block bolts per Recall."
    I have noticed some movement only in one corner of the seat about 3 times since. It could be one of the bolts has loosened. I'm going to have them check it out if I EVER get the call that both my window bezels have arrived for replacement. (He told me the rest of the parts would arrive in about 3 days -- this was 3 weeks ago). 'Bout time for me to give him another call!
  • scotianscotian Member Posts: 1,064
    I assume that the actual wing trim is glued or riveted onto the plastic grille and can be removed, but there will still be a flat wing-shaped part molded into the grille to deal with. You might be able to paint the whole thing black, which might turn out pretty good (just the "shadow of the wing" left). Something to consider.
    If you want no wing in the middle, get the 2002 grille which probably swaps right in. I myself do not like the wing eblem as part of a larger chrome piece as it is on the 2002 300M and the back of some minivans.
    This is across the road from the Doubletree Resort right?
    Can you buy the 2002 grill?
  • glennbpglennbp Member Posts: 327
    Yes, that's the place. I'll see ya there! (If I'm late it's because I'm standing in line at Starbucks. I can't come within a mile of one without stopping. I'm so addicted!)
    See you at the starbucks counter. I have the same problem. ;)
    Eventually. I'm thinking of buying a pair of Special HIDs some day.
  • mykemmykem Member Posts: 203
    I've been in hiding since the beginning of the year (some 595 posts!) but now I'm back...
    btw... anyone hiring in the Chicagoland area? :(
    -m
  • triffnertriffner Member Posts: 31
    I am shocked by your comments. When I wrote that check on 1/15/2000 for $32,000.00 I too thought I was buying possibly the best car on the road. It was shortly after that I realized I had not. My problems started a short 10 months later. If it hadnt been for this forum I would still be being stroked by this supposed 5* dealer. Telling me nothing is wrong with my car, cant duplicate, never heard of this problem, yack, yack, yack! But due to the problems (YES THE PROBLEMS) that ALOT OF US ARE HAVING! this car is finally being fixed. You see this 5* dealer was hiding the problems from me. It was HERE I was told of them.
    I went through arbitration on ths car and WON!
    So to end my ravings I will say to you I am so glad that you bought a good 300m, and I'm sorry to say I DID NOT!
  • laurasdadalaurasdada Member Posts: 5,293
    I've been posting here since mid '99 (I bought my '99M 6/99). You should compare notes with Fastdriver who may have had the worst 300M ever built! Mine has been reliable, but not perfect. I have no complaints.
    I think most M owners here are pleased, but we all know that there are ALWAYS a few bad apples in every bunch.... It is a shame that your M wasn't up to snuff. It really is a marvelous car. Congrats on winning arbitration.
    Geez, and auto dealers wonder why the public has such a low opinion of them. We just bought the evil wife a Lexus RX300 and in limited dealings with the Lexus dealser so far, much different level of service. I may get spoiled! Although I have no real complaints about my ?* dealer.
  • fastdriverfastdriver Member Posts: 2,273
    triffner-
    CONGRATULATIONS!! You saved yourself YEARS of aggravation, excuses and wasted time in dealing with incompetent, uncaring, we have ALL the answer "5-STAR" dealers! What a JOKE.
    fastdriver
    Don't say congrats yet, mine is in the shop as we speak hopefully being fixed. They were ordered to fix it. We'll see. What finally happened to yours?
    Undo the nut in the center and then there are four fingers that secure it. It is the one I used for the back.
    I too have been very happy with my 99 300M. Just a few minor problems, which were taken care of. Having 20/20 hind site I would do it all over again. The only thing I would do differently would not to purchase the extended warranty. But at least the car is covered for another four years.
    Triffner and fastdriver, I'm now starting to see all the crap you guys have gone through!
    The car was to go in today for a few very minor fixes.
    1) Fix the broken passenger seat with a new motor.
    2) Put a new steering coulmn cover on
    3) Fix the wipers that don't work
    4) Just a few notes: check the defogger system and see if they can fix the rattle behind the gauges yet
    So, what do you think they did!! Nothing!! Oh, well, yeah, they snapped a new plastic steering coulmn cover on (we think!) and supposedly fixed "a loose wire" with the wipers. The seat, well you guessed it! The car went in New Year's Eve. They ordered the seat part. They called last week to say the column cover and seat part were in. Well, this morning they called with the usual. "Oh, we're sorry, we must have ordered the wrong part for the seat. We opened the box and it was for the driver's seat." Oh great, the wonderful 5* screwed up again! They did the same thing last summer for the steering wheel when they forgot to order it, not once, but twice!
    So, what did we get? A car with a new steering coulmn cover (never looked to be sure yet) and supposedly a fixed wire for the wipers (who knows?!). Oh yeah, and now, even though they never bothered to check it, the rattle has gotten worse and there's a new one in the driver's door. Now, something is so loose behind the gauges that it even rattles with slight engine vibes when the car is idling! And, the driver's door now has (or had) something vibrating in it that was buzzing about. Such a nice car, but why is it built so poorly?
    I know, I know, you say, go to a different dealer. Believe me, if we could, we would! The problem is, the non-5* we bought the car from is 45 minutes away and couldn't fix anything before, and the onle other dealer within driving distance is another 45 minutes in the other direction. This dealer is also large and a supposed 5*, but they happen to have once of the worst ratings as far as service and sales go in the state. So, these are the only two, and we won't go to either.
    The dealer that has been working on the car is only 10 minutes up the road and a 5* (supposedly). When we had something for them to fix on the Voyager, they were very nice and did what needed to be done, no questions asked. Now, we've been there I don't know how many times with our supposed "32 grand luxury car" and have had nothing but trouble.
    When my mother went to pick the car up again this afternoon, she was not at all happy. And when she isn't happy, you know it! She told them off with the manager standing there and made them aware that she was not pleased with the service. Now, when she was done, the main guy at the desk, Tracy is his name, walked her to her car, appologizing several times. But it didn't work, she told them that she will be contacting DaimlerChrysler regardless of the apologies.
    So, I need to know, who's the best to contact to get such issues resolved? This is just one headache after another, and all we want is the car fixed properly and completely for once and all this nonsense to stop!
    Triffner and fastdriver, who do we contact?
  • sirharpersirharper Member Posts: 112
    Sorry to hear about all the problems with your M. I can certainly understand how frustrated you must be. Personally, I am a life-long exclusive Mopar owner and have never had any issues resembilant of yours. Luck? Maybe the first few times but not after 11 of them (including the parents and wife). I can say that along with my Neon this 2 year old M has been the best of the group. ABSOLUTELY no unscheduled maintenance.
    You must fully understand that the purchase of ANY new car is a proverbial roll of the dice as to it's individual build quality and NO make or model is immune to this. Can't you imagine how surprised owners of the Benz M-class must be? I am sure many bought them fully expecting the brand's legendary service record and they got something very different.
    I am not here to say that 5 star service is perfect, they aren't. Here the adage "you get what you pay for" seems to be the rule. I don't get greeted by a service advisor that opens the door for me like my neighbor with a BMW does. I also don't pay $90 for an oil change ($150 with a new filter) or $800 for a brake job either.
    My bottom line is this...the service record of the M might not be better than some makes people like to associate with high quality, but if certainly is no worse. I assure you there is a Lexis owner out there that is just as unhappy with the build quality of his particular vehicle as you are with your M.
  • mboomgarden1mboomgarden1 Member Posts: 49
    I've just gotta open my big mouth here. First, I need to admit I've had limited experience with my dealer's service department--I've only had it in twice for minor warranty issues, but on both occasions, I felt I've been treated with indifference and have received service that was marginal, at best. I'm willing to give them another shot (hey, they still have to fix the things they didn't get on the first go-around).
    However, my qualm with what's being written here is with the notion that you only have the right to expect outstanding service if you buy a "premium" brand like BMW or Mercedes. I've owned both and, yes, you do pay more. But, truthfully, not a lot more. I've also owned Toyotas and Volkswagens (two of each brand) and I received highly attentive and professional service when I went to the respective dealerships. So, at least in my experience, it's clearly not solely an issue of price, but one of corporate culture (incidentally, at $33K +, I don't consider my 300M a stripped econobox). If much of what I've read on this board is true, then shame on Chrysler. The management and control systems clearly exist for manufacturers at all levels to ensure high levels of customer service. If they don't deliver, the brand will perish.
    Mercedes-Benz, Chrysler's big brother, knows how to do this. Hopefully the Daimler/Mercedes influence will ultimately have a positive effect. There's no excuse for shabby customer service at any price point.
    My boss HATES the service he gets from the dealer on his new Mercedes.
  • kosh_2258kosh_2258 Member Posts: 338
    I've owned 2 Volkswagens and 2 BMW's in my past. All were bought from the same dealer and frankly I was never impressed with their service. They were a purely German store selling Benz, BMW, Audi and Volks so you would have expected them to be better, but no.
    I think the defining moment was with my second BMW. The clearcoat finish literally peeled off the bottom half of the door in a car wash. I took the car in to have it looked at. The service manager motions me over and tells me the clearcoat had come off, then just silence.
    I look at him and say "and?". Another pregnant silence from him so finally I have ask him what are you going to do about it? He answers "it has to be repainted" (clearcoated). I look at him and say I figured that part out already so are we going to make an appointment with the body shop to get this done? Ah, oh, yeah, yeah.
    My experience with that dealer went down from there. It was the last car I bought from them.
    So far the service from current Chrysler dealer has been pretty good, not exceptional, but competent. I confident that if I take something in to get fixed it will get done.
    I just wish that road along the water went further. It is hard to get a 300 to stretch its legs with only 38 miles of road. I am happy to report that the 300 is quite happy at 100 on curves the DOT posts at 35. Come back when you get a chance
    I have 23K on a 99M. It has been to the dealer twice; once just because I thought it was noisy on a cold start when it was new and once when I had a noise in the center A/C vents. The noise I've learned is part of the package, the Borla drowned it out anyway. The noise comes from fan cavitation if the heater is on low and the sunroof is open to the vent setting - I smoke sometimes. It probably shouldn't do that, but it isn't something to get exercised about. I really can't find anything to complain about. Sometimes I think I should be taking it in, but there's nothing wrong with it. I live in a small town by most of your standards and probably paid more for mine than you would in a big Lower 48 city, but my dealer would kiss my behind on the courthouse steps and give me a week to draw a crowd. If I complain, they get busy! Great car, good dealer, no problem!
