Thanks in advance
-Mike
How long did everyone run the factory oil ?
When is it best to start useing synthetic oil ?
Kevin
difficult it is to remove and replace the oil filter on the 3.5...is it done from the top or the
bottom and does the vehicle need to be raised if
it's done from the bottom?...
Sebring LXI
T&C LXI
T&C LX
It's quite difficult to get the filter off, UNLESS you use a plastic/nylon filter removal tool (slips onto the end of the filter, then you put a ratchet on it to turn it and the filter). It's easy with that tool.
I remove the filter from under the car, without raising the car. The oil drain bolt is on the right side of the engine, not far behind the front frame, and it points sideways (toward the leading edge of the right front tire). Some people have had trouble removing the drain bolt, so make sure you use a good-fitting wrench!
Carsdirect.com
http://albums.photopoint.com/j/ViewPhoto?u=1280646&a=12731429&p=47352049&f=0
It's safe on your car's finish, and does a terrific job removing tar spots too.
SO... What do you think a fair price is for a 2001 with the perf. pack, 4 CD (360 watt-11 sp), moonroof, chrome over Al wheels, and side impact bags should be?
The 30k price is OTR price after all taxes, tags and rebates. Please respond soon 'cause I got the buying bug BAD and I might buy at a Memorial Day tent sale .
Tried my chin technique, it did not help either. The remote only worked when I was litterally on top of the car.
I later realized that the M was parked under some high voltage lines (I could hear the "grasshopper sound" coming from the wires).
That probably had something to do with the remote range.
Also, there are two pieces of leather on the driver's seat that have cracking on the entire piece, and I asked this be replaced under warranty. They refused, saying it is normal wear and tear. I say it isn't. (The car is garage kept 100% of the time when not on the road, not even in an office parking lot 8 hours day/5 days week, as I work out of my home.) It is only those two pieces, nowhere else. They said the only thing they could do would be have a Chrysler rep look at it the next time they were in. I said okay, let's do that. He said the visits were never scheduled and that they never knew when one was to be there (did I mention that I purchased the car from this 5* dealer and that it is 50 miles from my home?). Suggestions???
I recall reading that Chrysler now has a new remote, mine is an early 2000 model. The power lines could definetly interfere w/the remote though.
http://www.playingmantis.com/jl/contact_us.php
I used Shoe Goo to attach it. The sucker is on there for good. Plus it gives you time to make adjustments.
Using the spreadsheet you can get at that website I figured that the MSRP on that car you're describing is about $33,400, with an invoice of around $31,000. If you simply took your rebate (assuming it's $2,500 where you are) off their invoice price you'd get down to $28,500. In that scenario the dealer makes their 3% holdback as profit, which is a more-than-fair $1,000. My dealer took a $250 profit because the stars were aligned (and I bought on the last day of the month). Another piece of advice...don't be afraid to walk out if you don't get what you want. Another dealer can usually get the exact same car you're looking at. Also, make sure the price is negotiated before you talk about trade-ins or financing. There's about 4 places they can make a profit, and it's in your best interest to not let them mix things together on you...like "here is what your payments will be", which hides the cost of the car, the trade-in value, and the interest rate into a blob that you can't unravel. Do it all one step at a time.
Oh...another thing I'm glad I did was after getting the lowest cost from dealer #1 I called 3 other dealers and told them if they could beat the cost by $200 on the same car I'd buy it. When nobody would, I knew I was at the bottom.
I hope this was helpful. This is a major purchase, don't go in uninformed and unarmed. Dealers sell cars every day and you're at a disadvantage right out of the blocks unless you do some homework.
Mike
Mike
I picked up some lovers off an old olds, may install them in the hood as an intake, in keeping with my lo profile look. I order some paint to do some touch up work, paint my lovers and a couple of other things I have found. I also have a old Ford Mustang hood scoop that I may try to trim down to fit the hood. My Idea is to use the scoop(s) for air intake and to cool the transmission. I will see which ever one system workes (and looks) the best.
Easyrider
someone mentioned using amsoil synthetic tranny fluid--anyone here use this and are you happy with the shifting--I would think synthetic would hold up to heat better than regular fluid--But I wonder if it could cause leaks--any comments?
Rick
Zaino is great, but it's not a miracle polish. If you've taken your car to car washes, the Z5 may not be enough to hide all those scratches. That's why we all say to use the Zaino from DAY ONE! You may need several coats of Z5 to hide the damage. Then again, you might need the 3M swirl/scratch remover that NAPA store sells. Don't forget those 100%, Made in AMERICA white, cotton towels.
fastdriver
advertising a 300m with sunroof and chrome wheels
for 24490...don't know colors or number of cars
available at that price...
LOL... I have some of those too! I don't think the blue towel makes much difference on red anyway. I just know that my car always looks great with the Zaino on it.
I made a movie of my car yesterday. I'll put the link in my profile if it will work. It's pretty funny. Seems to work better on slower MHz computers because the pics don't fly by so fast.
Have a good weekend. DON'T speed! ;-)))
fastdriver
TJ
As soon as I saw this screen name I KNEW it HAD to be you! LOL... I can't wait to take some new pics so I can make another movie! This weekend I'll do it when I'm in NH. Not supposed to rain there like it has been in CT since Tuesday!
I know I have mentioned this before, but it still amazes me. When I had Christine, IF I saw ONE 300M around here a week, that was a lot. Now I see at least 2-3 a DAY! I STILL stare! ;-))
fastdriver
no handle, muahahaahaha, i should be getting me selanoid kit in soon, but they are real tuff to put it, takes forever...oh yea, no accent line either, filled that in...
CAUTION- Using a transmission fluid other than ATF+4 may cause deterioration in transmission shift quality and/or torque converter shudder. Using a transmission fliud other than ATF+4 will result in more frequent fluid and filter changes."
