Isuzu Axiom
1242527293049
  • jamesjajamesja Member Posts: 15
    I've got about 25k on my 2002, and I'm in "Sport" mode everywhere but the freeway. "Comfort" mode (a/k/a "mother-in-law" mode) for the freeway. -jj-
  • usg8110usg8110 Member Posts: 6
    I have 2000 miles on my Axiom and I have detected
    some inconsistencies in my ISC suspension. I use
    the Comfort Mode primarily and find that harshness of the ride changes from day to day on the same highways.
  • twocartwocar Member Posts: 95
    Has anyone noticed a not-so-smooth starting condition? I wouldn't call it "hard starting" but it doesn't sound just right. Plus it appears the Ax has the type of starter that doesn't disengage itself until the engine is running even after you release the key so I have noted the engine taking a few more seconds than usual. I have 18k on my 2002 Ax. Anyone else around that mileage with this condition observed?
  • axiomloveraxiomlover Member Posts: 216
    I also noticed that suspension gets harsher the longer the trip (shocks warm-up). I usually keep it in Comfort mode.
    Starting is never really difficult on my Ax (7,500 miles), but I do notice that usually only three or four cylinders kick in before the rest fires up. When the engine is warm, it starts right up. If it doesn't start at the first attempt, the second usually takes longer and sometimes cranks for 3 seconds (by itself).
  • cmunizcmuniz Member Posts: 604
    Just completed the 15,000 service on my Axiom. Have never had a problem with starting. The only thing I have noticed is that when it is cool outside (not cold) the idle right after starting is a little rough, but it only lasts a very short while. Had a similar problem with the 2000 Trooper.
    By the way, my local trusted mechanic who works on a lot of 4WD vehicles charged me $95 for the 15,000 service which included oil/filter change, new air cleaner, tire rotation, chassis lubrication and changing the differentials and transfer box oils. His one comment was that the lack of drain plugs made the gear box changes a little harder.
  • sowrsowr Member Posts: 69
    It makes sense that the ride would be harsher in cold ambient conditions. The hydraulic fluid viscosity would be quite high (thicker fluid) until the hydraulic sub-system had reached its operating range - after which, the suspension would operate at its default hardness setting.
    I would not expect a harsher ride in hot ambient conditions, I can't imagine an existant sub-system that would preclude suspension performance by allowing the interference of mechanical components due to dimensioanl heat-expansion.
  • cptsessocptsesso Member Posts: 116
    I have 3000 miles on my Axiom and just had the starting situation "twocar" previously reported happen to me tonight. I got in and turned the key. The engine began to turn over and start like normal, so I let the key go, but the engine did not fire up like normal and the starter still continued to crank until it finally started after several seconds. It seemed really strange for the starter to continue to crank even though the key was released. This was the first time it did not start with one or two turns of the engine. Has anyone else experienced this? I have never had a vehicle where the starter continued to turn over even after releasing the key. This is my first Isuzu (really love it) and was wondering if this is normal?
  • libertycatlibertycat Member Posts: 593
    I heard Isuzu may be going out of business in a few years. That is sad, but I never see Axioms and my dealer has 4 in stock.
  • icedog97icedog97 Member Posts: 141
    I also just had the starter situation occur. It seemed to dis-engage a second or two after the car had/should have started.
    Thanks for the feedback on the suspension. It seems like a few folks have encountered similar situations. It has only happened once or twice and I thought it was more related to the mechanism that controls the ride rather than the actual suspension. The next time it happens, I will try switching the ride mode to see if there is a difference.
    Try this guys...
    Turn the key to the "on" position for 10 seconds before starting when it's cold. This will pump fuel from the fuel pump/tank up into the fuel injectors. The engine will turn over right away after that.
    -mike
    Paisan is right. It should help in starting the engine when you build up fuel pressure by holding the ignition key in 'on' position for a few seconds before starting.
    The continuous starting is a feature described in the manual under "starting." Unless the engine starts within 1.5 seconds, the automatic feature kicks in. If you think it cranks for too long on its own, just turn the ignition off.
    I am noticing that my Axiom is smoother and smoother the more miles I put on it. The engine starts easier and is not as rough-running when cold, it is more quiet and economical, idle is lower when motor is hot (sometimes as low as 750 rpm) and acceleration is lightning.
    How is oil consumption?
    Thanks guys. I guess I must have missed the continuous starting feature while reading the manual. I will try Paisan's suggestion in the future.
    I was away for work/vacation in Arizona two weeks ago. Stayed in Scottsdale, Sedona, and the Grand Canyon. I had a Ford Escape XLT as a rental. It wasn't a terribly bad vehicle. Interior was very cheap and I had mistaken the column mounted windshield wiper lever for the shifter many times. They are very close to each other. A real pain, but I guess I always had a nice clean windshield. I also did not like the loudness of the horn when engaging the security system. People tended to look our way a lot.
    Anyway, there were more Isuzu's than I have ever seen on the roads. I would have to guess about 10 to 15% of the SUV's I saw in Scottsdale were Troopers and Rodeos. I only saw 1 Axiom. This was the first time I have ever seen one on the road. I also saw many Isuzu commercials on tv. In Arizona, Isuzu offers 0% financing for 7 years. Maybe this, in combination with the advertising, is why I saw so many. Who knows.
    I was in Miami Beach for 5 days and saw a TON of Axioms. At least saw 6-10 during my stay. I was glad to see that. Rented a Mustang Convertible. I quickly missed my Japanese vehicles (SVX and Trooper) the build quality was horrible on the stang.
    -mike
    The vehicle I traded in on my Ax was a 2001 Ford Escape XLT 4x4. Good vehicle, but doesn't come close to the functionality of the Ax.
    Thanks for the info Paisan...I guess some of us should read our manuals...(I am referring to myself!!!)
    I saw some pictures of the XSF on the web and liked the grille inserts that they used. Does anyone know if there is a vendor that makes these for the Axiom? I looked around a little without much success so I figured I'd check here to see what people knew.
    I have read just about every on-line review of the Axiom that I can find. I noticed that many reviewers seem to be confused... and a lot of that has to do with the fact that the styling of the Axiom suggests car/wagon but it's really a true SUV. I think that is why some folks rate it negatively... they expect the ride of a luxury car but it's not quite exactly that. I also think that some of the earlier reviewers might have had vehicles that did not have all of the kinks worked out. Some of the harsh ride characteristics they mention seem impossible. I can honestly say that our Ax rides very nicely with the exception of the occasional jittery ride on rough roads...and I live in Pittsburgh...our roads are notoriously bad. Anyway I just wanted to throw that in...
    BTW...this vehicle would be perfect if it got about 5 mpg better fuel efficiency and some type of adjustment could be made to control the jitters a little bit better. Even so...we still love ours...like I said earlier it rides very much the same as our 98 Camry.
  • k2rmk2rm Member Posts: 205
    Monitor ebay for grill inserts. Someone is custom making them for the Axioms and listing them every few days.
  • cdfaulkcdfaulk Member Posts: 5
    Does anyone know what the 2003 Axioms are going to offer? I heard there will be some interior changes, but cant confirm. Rear air? Steering wheel controls for stereo. New dashboard color selections besides black? Maybe a trip computer or color screen for the console?
    I doubt anymore content will added to Axiom anytime soon due to the poor sales. The only thing I have heard about the 2003 models is the addition of a base model with less content to lower costs.
    I found the grill kit and bought it...I'll let you know how it turns out.
    I have been trying over the past months to review all I can about the Ax. I own one and am amazed at the misinformation provided by some reviewers. Edmunds even says it has an armrest in the back. Maybe that's only a leather option. Anyway, many reviewers hate the ride and handling...others love it. This one just really ticked me off though...it comes from virtualroadtest.com. They claim there is no 4x4 Low on the Ax. Huh? I don't think so. Read for yourself:
    Serious off-roaders will note that there is no high-low transfer case to give the Axiom serious capabilities when crossing rugged terrain. The Axiom's system is ideal for suburbanites who want the added traction and safety of all-wheel drive for bad weather, but off-road the lack of a low-speed transfer ratio makes this a suburban SUV, not a serious off-roader.
    - Do these people really drive these vehicles or just look at the brochure and form an opinion. I think it is ridiculous.
    Yup, I have read alot of misinformation about the Axiom as well out there. The Edmunds review is probably the worst I have read, but usually it seems that some of the more car focused reviewers don't like it because they are expecting a car, they seem to forget that it is actually a truck. The Edmunds review was just plain ridiculous, especially about this statement:
    "If you own an Axiom, or plan to buy one no matter what we say, do your neighbors a favor and drive down residential streets in Sport mode. You never know when a kid might chase an errant soccer ball and land right in your path."
    Talk about a completely misleading statement. This statement was made after they complained about the axiom stopping significantly longer from 60-0 in comfort mode (which I don't believe from real world experience). Well, I don't recommend driving 60 miles an hour down any residential street in any car.
    Its pretty obvious the reviewer wanted to spin everything into a negative with this review. I am not saying the Axiom is perfect, but I expect reviews that come from such reputable sources such as Edmunds to be at least impartial.
    I to often wonder if these so called "expert reviewers" even see the vehicles they review. I remember reading the reviews you guys pointed out and thought they were talking about a totally different vehicle. I especially like the one about the rear armrest. The Axiom, in any model, does not even have one. It would be nice if it did though. Probably the only thing that most of them got right was the lack of up and down on the power drivers seat.
    I bet that if we slapped a Toyota or Honda logo on the grill, the review would all of a sudden turn 180 degrees. I even wrote to Edmunds.com and expressed my disapointment in lack of independent opinion and bashing Axiom for the wrong reasons. For instance, Toyota Highlander gets much better reviews than Ax, but when I looked at it (before I bought Ax), it looked ugly inside and the outside shape is simply dull. People are like rats or cows. They are afraid to try new, unchallenged waters and buy whatever their neighbors buy (high Toyota and Honda sales). If you don't know anything about cars and trucks, you will be happy in whatever gets you from point A to B. I have read reviews that complained about Ax's poor quality of interior plastics. Well, I have sat in many cars and trucks and Ax has one of the best interior finishes on the comparable market. Go figure!
    Well, the Highlander is a little dull, but it is a well put together car and does deserve the reviews it gets. I test drove the Highlander and it does ride better than the Axiom, but, when the going or towing gets tough, the Axiom is a far better choice. Not to mention Axiom has so much more personality.
    "The high quality craftsmanship was abound in Toyotas new SUV. The fit and finish was by far the best this reviewer has ever seen. From its silky smooth, yet power full V6 to its fine crafted, hand stitched, Corinthian leather interior, the Toyota Axiom is aimed to please even the most finicky drivers. I feel blessed to have been given the privilege to review such a fine piece of art."
    Meanwhile, back at the office. Now Mr. Toyota, how many advertising dollars will you be spending with our company this year?
    If anyone else would like to comment to the editors, here's the link:
    Feedback Form
    Or you can send a "Letter to the Editors" to editor@edmunds.com.
    Well, the Highlander may ride better but the ride you get...is the ride you get. With the Ax you can at least manipulate the ride (which I do from time to time) to make me appreciate it that much more.
    I also remember comments like 'wind noise' and 'tire roar'. And another one that mentioned the Axiom gets blown around in cross winds (these may all be from the same review).
    I haven't really experienced any of those to a such negative degree...has anyone else?
    I had a 97 CRV which was rated highly by many reviewers and we really liked it for what it was. But I can honestly say it was louder in the cabin than my Ax and it got blown all over the place in crosswinds...you actually had to counter steer...
    The other comment that I saw more than I could believe was that the Axiom was not fast enough or did not have strong acceleration. Please!!! Are you pressing on the accelerator? Is the car started? OK...it's not a Corvette but the acceleration is more than acceptable.
    For a really good laugh read this review from Consumer Guide...it has the comments I mentioned above...
    http://auto.consumerguide.com/auto/new/reviews/full/index.cfm/id/20532.htm
    It just seemed like this reviewer was in a bad mood...the Ax is average at worst...
    I think Isuzu would have been much better off if they never let folks know it was a mix between the Rodeo and Trooper...truck based SUVs get bashed all of the time now...
    Yeah, I love how that reviewer their says the Axiom has less utility than its car based competitors. They obviously don't have a clue.
  • sveltaxsveltax Member Posts: 72
    Excelleration: Fairly Spirited.
    http://auto.consumerguide.com/auto/new/reviews/full/index.cfm/id/20839.htm
    At 9.3 it is well behind the AX yet gets Fairly Spirited. Must be a Honda.
  • axaholicaxaholic Member Posts: 8
    My name is John and I am an AXaholic!
    If you are still in the shopping mode my feedback might help you.
    I had a '95 Grand Cherokee which was reliable but started needed expensive repairs.
    Almost a grand for a cat converter, and $1,100 to fix the antilock brakes which I didn't and on and on.
    It had 88,000 miles. Even the radio completely quit shortly after the extended warranty ran out.
    I just had a gut feeling the ac or something else would go out so I was ready to trade.
    I wanted to pay in the low 20's for a new suv. Not much these days. I was considering several vehicles that would do but I wasn't really that excited about.
    I thought about the Hyundai Santa Fe, Saturn Vue, Isuzu Rodeo, PT Curiser Ford Escape or an entry level Grand Cherokee or Highlander. Even these models
    can add up fast with a few options.
    I grew up in a little town in the 60's and 70's and one of the hight points of the fall was going to the car dealers, get free donuts and see the nice new cars
    with some Style. It was nice to look but we could never afford one. I say this because most of the suv's these days all look alike to me and are Boring.
    I had seen the Axiom on a dealers lot driving by but figured it was too much. When I discovered there was a $4,000 rebate the price became in range. The
    best thing is even the base model I got has many near luxury options that would add thousands more to the price of the ho-hum other vehicles. To top it off,
    driving the Axiom makes me feel like I am driving something a lot more expensive, way above the impression I have of the other vehicles I looked at.
    I re-read the reviews after I bought the Ax and thought maybe I made a mistake. But I still like driving it and have decided I am an AXaholic.
    I would buy it again. Some of the reviews remind me of the concert reviews in the Dallas Morning News. They send a 50 year old guy out to review an 'nsync
    concert. Surprise . . . they get a negative review. Likewise, send a car-loving, suv hater out to review a Real Truck (Axiom)and . . . Surprise . . . they hate the
    truck but love the Cars that Look like a Truck (Highlander and Rx300). I would have given the Highlander more of a consideration if it wasn't such a bland
    design. I don't go off road and just need something to bring my stuff home from Home Depot so a car-based SUV would do. I do think a truck base will be
    more durable just driving over nasty potholes and rough RR tracks.
    The cross wind and road noise complaints are a joke. The wind was very strong the other day and handling was no worse than any vehicle with a higher
    profile. Road noise is much less than the Jeep I had and better than many midsize cars I have driven.
    Plusses included even in basic trim level.
    Climate Control that "controls" better than the one I had in my Lincoln Mark VII.
    Cutting Edge Unique Styling (I have only seen six others on the road in Dallas in 4 months. If you want to blend in the crowd, don't buy this)(If you want to be
    like six others at the stop light, buy a Grand Cherokee.)
    Classy looking two tone interior.
    CD changer and very good but not superb stereo
    Peppy get up and go power. More than you need.
    Compass, Trip Computer, Outside Temperature, Home Link
    Color Keyed Bumpers ( a major upgrade on some other models)
    Adjustable ride suspension.
    Power Seat WIth Lumbar Support
    Power Mirrors, Dimming Mirror, Remote Locks, Alarm More|
    Locking Allow Wheels
    Extra lighter socket in cabin and rear for accessories.
    After 4 months and 2200 miles - no rattles, trim or other problems.
    I bought from Hiley Isuzu in Mesquite. Their follow up After the sale was impressive, more like I would expect buying a Lexus or something, even a
    Christmas card. ( I didn't hear anything after the sale from the Jeep Dealer)
    Awesome warranty, I got the extended for a reasonable amount. Now I have Bumper to Bumper coverage and roadside assistance for 10 years or 120,000
    miles. Beat that.
    I wash my own car. There are no ruberized bumpers, side moldings, mirrors or roof racks which get faded and are hard to keep looking good. No small
    crevices in wheels or grill.
    A few negatives.
    Prop rod to hold up hood with no insulation.
    It would be hard to upgrade or replace the stereo because of the integration with the all in one display.
    No Locking Gas Cap
    No Height Adjustment on Seat in base model.
    Non padded dash in some areas.
    Non-plush carpet and headliner.
    Non retracting antenna (becoming more common on other models including Grand Cherokee)
    The Suspension is a little rough in sport mode and bouncy in normal mode on some roads. The Jeep service dept. started inflating my tires to the
    recommended level on the Grand Cherokee after the explorer roll-overs. Talk about a buckboard ride. The Ax is a Limo ride by comparison.(My biggest
    complaint but not a deal breaker)
    There is some talk about Isuzu's future. Even if they cease making suv's they are not closing down. They have major large truck and other operations in
    many countries. They will honor any warranties and will not simply disappear like some Korean brands might.
    In summary, if you want a real truck based suv with unique cutting edge looks, a great warranty, well equiped and at a reasonable price the Axiom is a no
    brainer.
    Go Farther.
    Very nice review. Good luck with your Ax. Which model and what color did you get?
    I got the basic 2wd but with all the standard features, its hardly basic. The blue was a nice medium unusual shade which I like real well.
    California and Oregon have virtually none on the road. You drive and drive for miles and miles and keep your eyes peeled but you almost never see any. I still have only seen three since they were introduced. I haven't seen ones for months. Has anyone else heard that Isuzu might go out of business in a few years? That would be terrible! Also I have decided to shop for a used Axiom in Blond Gray with the tan interior. Does anyone know when they introduced gray and stopped offering Blond Gray with the tan interior. IMO, that was a big mistake. Don't they realize people might want a gold exterior with a tan interior? Wow!
    Also vote for the Mazda MPV-minivan, Volvo V70-luxury car under $40,000, Jeep Liberty-small SUV, Dodge Ram-pickup. Thanks!
    (host-if this is against the rules for any reason please don't delete this message; e-mail me so I can fix it)
    Why the Volvo V70? I'd vote for the VDC over the V70. Liberty isn't small, it's in the same class as the Axiom.
    -mike
    according to Automobile. Don't you agree the V70 is nicely styled?
    So long as it performs :)
    Not sure why the VDC is in a different class or the liberty for that matter. Then again who knows, what is in these magazine's heads...
    -mike
    Just saw this today. Good deal if you are looking for fog lights:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33709&item=1875723942
  • Is it true all the Axiom owners in the world are in this forum :)
    I still like the Axiom's styling the best out of any suv I have seen. Even though I eventually bought an MDX I am keeping my eye on this vehicle. Only have seen one Ax on the road and one on a billboard.
    I haven't seen a single one. New Jersey must have more Isuzu buyers than Oregon or California (don't ask me why). Slocko, vote for the Axiom at automobilemag.com.
    No offense to anyone who owns one but it is so ugly! It looks exactly every Honda CR-V interior. The CR-V isn't even available with leather and with that ugly interior and kinda blaw exterior I would never consider buying one. The interiors have a flowery design or something and the doors have some of it on them too.
    You forgot to add "in my opinion" to your statement about the Axiom interior being ugly.
    Use of the word "ugly" obviously implies opinion. I think they're kind of neat - in my opinion! :-)
    Hey!!! I have one of those Axioms with the ugly cloth interior!!!
    Honestly, my first impression was exactly this..."Wow, that's awful looking!" It was almost a deal breaker. The wife and I took the car home for a couple of days and realized that we really didn't care one way or the other. Now we don't even talk about it anymore.
    I will say this, the pattern they use is definitely not for everyone, and if I ever find myself with about 2k to blow (ha, ha, ha), I would consider having leather installed.
    My experience was exactly like Icedog97, except that I'm definitely not spending any money to get leather. The first time I saw the car I thought it looked like somebody had spilled pumpkin pie all over the inside. Now it looks quite normal and I think it adds to the uniqueness of the vehicle. A man stopped dead in his tracks at a ski slope parking lot last week to take a second look at my blond grey Axiom. He was right in front of me so I talked to him for a while. He was very impressed with both the exterior and interior of the vehicle. That doesn't happen too often with other look-alike vehicles.
  • beachednkc8beachednkc8 Member Posts: 3
    Looking at the Axiom XS, but we don't feel the fuel mileage will be enough. We need a vehicle for sales work, lots of highway miles and working out of the back. Need a vehicle with dependability, and comfort. Can anyone respond to the gas mileage and the dependability of the Axiom. We will be driving it about 50,000 per year.
    Have the base model 4x4 and it got 22.8 on the highway over the holidays in 2WD. Usually average between 18-20 in town. Think you would be happy with the build quality. Have 18+K on mine and am still very pleased with it.
