Visitor Agreement.
thanks, rob
http://www.spoilers4less.com/bcusstylrear6.html
Shawn
Your dealer is solely responsible for that option.
"Winter Start" on the sticker is refering to the transmission being able to start in 3rd gear rather than 1st so that you don't slip your wheels.
-mike
-mike
Get some good AT tires on your Axioms and you'll not regret it.
-mike
The Axiom has excellent reliability because it's basically a Rodeo frame + Trooper drivetrain. Both of which have been around for at least 5 years.
-mike
He can get you rodeo stuff which will work on the axiom.
-mike
One part of the shock swap that I do not have info on is the ISC disable. How do I keep the computer from seeing a fault from the wiring harness? Anyone have a schematic?
Your reviews of the Isuzu Axiom and Rodeo are horrendous. "The Axiom is little more than a rehashed Rodeo wearing nice duds and a Halloween mask for effect." "Pick the Rodeo only if you have a soft spot in your heart for Isuzu."
First of all, the Axiom's interior is much more luxurious and has more features than a Rodeo. The interior feels and is roomier. The engine is from the Trooper, not the Rodeo. Why don't you mention similar "Halloween mask" comments on vehicles such as the Toyota Highlander and Lexus RX300. The RX300 is more luxurious but it is nearly identical to the Highlander and it evens looks a lot more similar than the Rodeo and Axiom.
There are plenty of reasons to buy a Rodeo. Exclusitivity, off-road ability, sporty styling, and a roomy interior are a few. It may be a wee bit outdated, but so is the similar Pathfinder and neither has a redesign in sight. Personally I prefer the Explorer, Axiom, and 4Runner, but to say only Isuzu lovers should buy it is horrible. You ought to be ashamed of yourselves.
After the lift! http://gallery.consumerreview.com/webcrossing/images/AXafterlift.- jpg
I'll get a write up out this week sometime. Hardest part of the lift was bolting the top of the rear shocks into place. Getting the springs in and out was 2nd on the list.
Right now I have the Ranchos set to 2 in the front and 3 in the rear and it seems to ride like the sport setting. Great around town but on the Los Angeles freeways it may be a bit too hard.
-mike
Still trying to get a link up to the write up and pictures.
What did your lift kit consist of?
When I put the switch in 2H position, I could barely move forward with some serious fish-tailing. I was very impressed with the Winter Mode. In 2H and Winter Mode engaged, I was able to move forward without wheels spinning and fish-tailing. If you use Winter Mode in 4x4 setting, it's almost like moving on dry pavement.
-mike
Pictures of the lift are at the link below. The bro and I enjoyed tearing the Axiom apart! Good thing it was in his driveway.
One thing I didn't mention was the use of a spring compressor was necessary for the lift. The gas tank was in the way when we tried to lower the axle down far enough to push the new springs in.
One other tid bit. The bolts on the top of the rear shock is a ball buster to tighten. 1/8 of a turn at a time holding the flat section above the nut at the same time.
http://www.imagestation.com/album/?id=4290583687&code=4753752- - &mode=invite
Larger tires and possibly different rims when my wife's back is turned! Looking at the Bridgestone Dueler A/T Revo 265/70 17s. $123/tire at tire rack. Just Tires said they'd match the per tire cost plus the shipping charges.
Over on the Vehicross VMag forum superchargers are $2,800 and will fit our engines. How does close to 300 horses sound?
Also a PowerVault catback exhaust system is available for around $360.
Locker for the rear. I haven't decided between a locker or something like power trax. Still being reseached.
In the most likely order, my next mods will be the tires, then the exhaust, then the rear diff. The SC will have to wait!
-mike
-mike
Amazing!! How badly is the axiom selling?
