Visitor Agreement.
The closest competitors to the Axiom:
Sorento
Montero Sport
Liberty
X-terrible (maybe)
-mike
Thanks in advance
Ithan
http://www.google.com/search?hl=en&lr=&ie=ISO-8859-1&- - q=limited+slip+differential+dana+power+trax&btnG=Google+Searc- - h
Here is another article about lockers, LSD and other types of devices.
http://www.nagca.com/grandtech/carrierslockersandmore.htm
The LSD is nice cause it's "always enganged" Basically the LSD will help on and off road. A Locker is better for offroad but it has no "give" so you can break a driveline component and you can't use it on-road.
-mike
I just put mine on this weekend and wanted to pass along a few comments...
First off, it took about 2 hours from start to finish. It might take you less time, I had a 5 and 2 year old watching and asking questions the whole time.
The small screws and washers are tough to handle at times...washers that are a little bigger will definitely work better.
Be careful when making your pilot holes if you use a drill. I used a 1/16 inch bit and that seemed to work fine. I caution you because the areas where the screws need to go have varying thicknesses. It is possible to accidentially drill through the front end (yikes...I did this once...luckily it's in an unnoticeable spot!!!).
The other thing is that I think it helps to bend the excess grill material around the lip of the wholes that you are covering. This adds some strength to the material itself...it makes it stronger from the front side if you press on it...I did this because when wshing the vehicle, it will help if the grill pieces offer some resistance...
Anyway, that's about it...not a bad process overall...BUT as others have mentioned, I think you can buy the same material yourself for less money...
BTW...I have yet to see the 7th piece of the kit...has anyone received one yet?
Shawn
How does everyone like their Axiom? I understand it is based on the Rodeo, which from what I understand isn't the BEST thing in the world. However, a friend of mine has a Passport with over $100k miles, not a single problem. So, I guess I am asking, do you feel that the Axiom is good for the long haul - compared to a Pathfinder or 4Runner? Does it tow jet-skis with no problem? Any unscheduled trips to the dealer? Interiors (leather) hold up well?
I hate the new 4Runner looks wise, already had a Pathfinder (transmission problems), so the Axiom is the only REAL SUV left in the price range, except the tiny XL-7...
I have loved every minute in the vehicle. No big problems (did have a loose fan at about 23k, but that is a fairly "minor" issue)
Mine is the 4x4 with the two tone tan and black interior and is the Dark Gray Metallic. I, too, have received more positive comments on this car than any I have ever had. I would higly recommend this vehicle to anybody. Seats are a bit different position, but I'm 6'3" and about 275 and they are great for me.
I would recommend planning on changing the tires. I hated the stock and replaced them with Mich. SUV which have been wonderful. Worst winter here in Indiana in a long time and the vehicle was wonderful in all the snow.
The above link has grill guards, step bars and tail light protectors for the Axiom.
The steps connect to the body it looks like so that won't help with rocker protection.
-mike
-mike
-mike
Could you please report on your Axiom's oil consumption. For instance, how many miles before the indicator on oil dipstick goes from max to min. Or, how many quarts of oil per certain number of miles. I think it would be good to know where we all stand.
They showed a black ax with the vapor chrome wheels...
The trailor hitch is very easy to install, about 1/2 hour. For the wiring, you just have to pop a grommet off the floor and run the wiring cable throug it, find the wiring harness inside of the jack compartment and plug it in. Simple.
-mike
http://club.vmag.com/ubb/Forum13/HTML/000137.html
I was suprised by how well my 2wd AX performed. We went just about everywhere. In the sand, up and down a few rocky trails, up a few MX hill climb areas, the rancho 9000s and the lift work very well together. I had the shocks set on full plush and it was plush! We encountered a number of ify situations and the AX pulled through in all but one instance. In that instance I was able to back out of the obtacle. The rear locker is definitely my next mod!
Hungry Valley has an offroad center but it was closed for a group event. Looked like it would give me a much better idea of how the AX would handle without placing the truck in a dangerous situation.
Anyone in the area want to go on May 9th? Email me and we can hook up. I'll be out of town until the evening of the 8th so email me, I'll answer on Wednesday evening, going on a two week vacation starting Thursday.
Hope everyone had a great weekend!
The second time around (same complaint) they found the front rotors "out of spec" and machined them. Better. But a long way from acceptable....even for a Yugo!
Has anyone out there experienced a similar problem? If so, I'd appreciate hearing from you.
bob
-mike
-mike
