Visitor Agreement.
My Axiom (4x4) has had no such problems.
-mike
TOD should provide a maximum of 50/50 depending on slippage and Low should provide a locked 50/50 front/rear.
If your fronts were spinning, yet you weren't moving that sounds strange? That would mean all power was going to the front without traction?
In theory 4 low should be 2/3 wheel drive at a minimum. In a very low traction situation, like ice, only one front wheel will spin (due to open differential) and both rears should spin or alternate power to each other (LSD functionality). The LSD in the Isuzu's is geared more for road travel so I have seen situations where only 1 front and 1 rear is getting power due to slippage, but never only front/rear. That would be a 0/100, 50/50, 100/0 setup?
Don't forget that we have automatic transmissions on these vehicles. You don't necessarily have to have the wheels spinning to dissipate the energy, you can have the torque converter sucking up that energy.
-mike
It's not very noticeable, but it does seem to occur when stopping (from 10mph to stop) and starting from a stop. At first I thought it was something with the brakes but then I did a little test and now I am inclined to think it is drive train related.
I ran the Ax in both normal and power modes and it seems more noticeable in power mode. Let me also say that it only happens sporadically...so it's not something that seems like a big problem.
Anyway, I was just curious what 'mode' those folks that are experiencing this problem usually drive in? You would think if it was a breaking issue it would be consistent, regardless of the power/non power mode. And if it were drive train related, you would think it would be more noticeable in power mode, right?
I need to stress again that it does not happen often with my vehicle...but it does happen.
Let me know what you think...thanks...
-mike
Check out the 4x4wire trailriding section for more details or post up here.
-mike
I did notice my brakes are slightly more travel than my subarus. But stopping hasn't been a problem, just took a 1000 miles to get used to
-mike
I definitely think I am experiencing something "somewhat" different than you are.
I don't really sense a vibration as I am braking, I sense a "hop" (for lack of a better word) that occurs occasionally just before the vehicle comes to a stop. And then almost the exact same thing when moving from a stop.
If I were to describe what seems to happen when moving from a stop (assuming it is brake related)...it's almost as if there is a delay from the time you take your foot off of the brake pedal and the actual separation of the pad...in that small span of time, the car starts to move forward but the brake has not released yet. That's the best I can do to explain it...
The only thing that doesn't make sense is why it would happen during breaking...assuming it is break related...
That's why I started to believe it it the drive train...there could be a small amount of "play" between parts that is noticeable at times...
It sounds crazy to me if it does...but you never know...
-mike
The problem is now in the hands of the Regional Customer Service Mgr.
They have one more chance to get it right. If not, it's history. (And now the perforated panel insets on the front passenger doors are separating!!!)
All this at about 8500 miles! I had a '92 Rodeo for 10 years and it was super. Our Axiom is a big disappointment.
Spell it LEMON.
In all seriousness, it's probably something rather simple to fix, your particular dealer is probably just not the best. I know I had to try 3 different dealers to get my mirror fixed on my trooper.
-mike
We live in the Bay area of SF, CA and own this Axiom 2WD for 18 months now. Since I have been driving front wheel drive for 18 years and this is my first time driving a rear wheel drive vehicle, I am not sure whether this has anything to deal with rear wheel drive in particular.
What bothering me is that we had 2 incidents of "fish tailing" in the last week alone. By the way, including these 2, we had total of 4 times in the past 18 mo! First, I suspected maybe related to those 18K miles old tires. But since the first occurance happened when the car was 2 weeks new, most likely that's not the case.
3 out of 4 occurances were very similar:
1. completely stopped at stop light,
2. started left turning at green light,
3. by the time almost finishing the turn, the rear of the Axiom started spinning to the right,
4. I needed to keep steeling left & right 3 to 4 times before it started going straight again.
By the way, the road condition was wet for all four incidents.
Any ideas / suggestion that you can share? Thx.
-mike
Yes, I do know that claiming LEMON can be an arduous process. Fortunately, we live in Georgia where we have one of the strongest LEMON LAWS.
If they can fix it, great.
I've had a lot of cars, and even raced a couple, none of them behaved like this one.
We have the first meet next Friday.....I'll let you know how it goes:)
Bob
Thanks for your input.
By the way, regarding what you said on #1614, we also experienced that kind of "issue". Now it sounds like it's a "feature" instead of an "issue". Is that correct?
Joe
Now, whenever the roads are wet or anything less than dry, I switch to TOD.
Go and read some reviews on these tires and you will see the terrible ratings they get.
-mike
lou
The problem is that Isuzu and other manufactures compromise load carrying ability for a softer ride. Kia, GM, and Toyota offer similar systems on their SUVs as options for this very reason. It would be nice if Isuzu did as well, but considering you can buy the springs for less than $100 dollars and compressors for around $100, it is a cheap aftermarket upgrade.
I just wish there was away to increase the stiffness of the front suspension in a similar fasion without raising the front end.
-mike
-mike
-mike
In 2 wheel drive the Axiom is definitely squirrely in the rain, definitely a trait of RWD vehicles with lots of power, but not nearly as squirrely as my 1970 chev truck with a 350. Probably due to the limited slip on the Axiom.
Installation is quite easy. Here is an explaination of T-bars on my webpage:
http://isuzu-suvs.com/howto/torsionbarsexplained.html
and step by step instructions
http://isuzu-suvs.com/howto/torsionbarupgrade.html
-mike
Thanks, Bob
-mike
Bob
PS Iksuzu Zone Mgr visited with my Ax on Fiday..."....we are effecting repairs....." No word as yet as to whether they have cured the braking problem!
BUT, since I know what you meant, that's good to hear! My clunk/hop has been minimal, but it's nice to know it can be remedied without much effort.
Thanks for the feedback...
-mike
Keeping our fingers crossed. We still have 1,ooo miles to go until LL expiration.
I must say that all the personnel, both Isuzu and the dealer, Lou Sobh, were courteous, helpful and got the job done!
Bob
