As far as fixing the paint, the dealer can't fix it like it came from the factory. The sooner you get it fixed the easier it is to match the paint. Reason they can't match the factory is they can't bake it on like they do at the factory because the factory has just a bare body with nothing that will melt due to the heat. They should still be able to make it so you will never know. As far as fixing it, is it something that no one else will ever notice? If it is I would leave well enough alone. Granted you know it's there and it will always stick out like a sore thumb but if you can put it out of your mind, forget it. Maybe you can get the dealer to throw in something instead of fixing it. I got a half doz. free oil changes on a car once for the same thing.
We got stuck with a lemon and it's been a real headache. We are happy with the MPV, especially with the folding rear set. It is smaller, but it works well and we will probably never purchase a Toyota again.
One old story related - a friend of my father's had purchased a brand new '55 Chevy. A persistant rattle from the rear could never be found on four visits to the dealer. They isolated it to one area of the trunk or fender - cut into it with shears - found a small metal box spot welded to the body (somewhere) - found a coke bottle inside with a note: "Loud, wasn't it"?
Anyone have a rattle?
I'm pretty sure that in most cases it's simply a matter of probabilities. Each part of a car has some chance of failing. In most cases, only a few fail, because the chance of any particular one failing is relatively small. But build enough vehicles, say 200K to several million, and probability-wise there will be some small number of them that will have a lot of failures. Those are the "lemons". Obviously, the more reliable a vehicle model is in the first place, the smaller the number of "lemons".
"One old story related - a friend of my father's had purchased a brand new '55 Chevy. ..."
This is a story that has been repeated in lots of variations for many years. I'm sure that it happened more than once, but my suspicion is that most iterations of it are in the category of "urban legend"
Maybe in a few years we will be Sienna owners again...
If all mini-vans were the same we would be back to the Model T days when you could have any color you want as long as it was black.
It's great to have so many choices, as we drive a mini-van but are older and don't have kids at all. We were so dumb that after the lease was up on our 99 Seville STS we got a mini-van. I got sick and tired of having to rent a truck to bring home plywood etc. from the store. Why don't I have a truck? Because we have a 36' motorhome and needed a small vehicle to tow (GEO Tracker) so a truck was out.
http://www.ottawacitizen.com/columnists/cote/prev_stories.html
Chk out Dec 21 & 27 '2000
deepan
It looks completely closed but you know it isn't when it rattles while driving. If you pull the inside handle, there is play and if you push on the door from the outside it moves in considerably. I've compared it to the drivers side and there is definately a difference.
I'm scheduled to bring it to the dealer tomorrow, and am keeping my fingers crossed that they can do something. I wouldn't care much but it's a really annoying sound and the van is not quite 3 weeks old.
I believe the torque converter problem was localized to Sienna's that were manufactured in the May-June-July 2000 timeframe. You can figure out when you're was made by looking at the sticker on the inside of your driver's door (by the latch).
Scott
I think I read one, possibly two, posts here from people who had the tranny go out. Seems rare... probably the unfortunate case of bad luck.
Sorry to hear about your wrecked vacation.
initial fiddling with it, I realized that the
JBL Radio system is not able to
tune to any AM stations (while my neighbour's
LE can tune to without any problems). Took it to the dealer. The technician swapped my radio system with a working system from another van. Result:
No Reception!
The technician swore that he had never seen this
problem before (yeah!). He then got on the phone
with Toyota. Toyota thinks that the antenna
assembly might have some problem. 2001 vans have
the "in-glass" antenna technology. Toyota is sending down a bunch of parts (new windshield etc. etc.) for the dealer to swap out on the van.
Has anyone seen this problem before? I am kind of reluctant for the dealer to start screwing around with the windshield and every other part that the radio antena touches.
V
It looks like there were some that had problems but as a whole Sienna have gotten praises for power and reliability.
mmeskal you have good dependable van and based on the number of toyotas you've owned choke this up as a bad luck but now you have new tranny that will last as long as the rest of the van.
What you describe is exactly the same thing that every Camry, Sienna and Avalon has and has had since I began selling cars in '94. You will have a difficult time in arbitration since this is a very normal characteristic of the vans. It is not symptomatic of any problem.
The van makes an abnormal noise, period. That is what is "wrong", period.
"What you describe is exactly the same thing that every Camry, Sienna and Avalon has and has had since I began selling cars in '94. "
I drove two Siennas while I was looking at vans and am now driving a third one (the one I just bought). NONE of them make the noise you claim is "normal".
Your primary purpose here appears to be to jump on any comment that is not positive to Toyota. Who are you and what, precisely, do you do ????
I just spent 40 minutes with Toyota's help desk - two separate calls - and was told that the Sienna 2001 Class II hitch is 2 1/4". I asked her to confirm it, she went off for 5 minutes and came back to say that that is what it is. I was also told not to worry about a weight distribution device because "the brake system in the 2001 Sienna takes care of it" and that there is no relationship between sway control and weight distribution units.
Is all this just a temporary fix? What exactly is happening with the power steering? Many are having rack and pinion replacements. Why is the power steering so noisy on this van?
Please write about your consistent pulling problems and the resolutions, if any, attempted.
I am not here to jump on anybody for anything. I have helped a number of participants with a variety of issues and have learned a number of things myself along the way.
Now, on to your two specific issues. First, noise level is a very subjective matter. Couple this with the extreme level of insulation inside the vehicle and many people may not consider the whine an issue. I can categorically tell you that if you lift the hood on ANY Camry, Avalon or Sienna with the engine running, you will hear a fairly loud whine at idle. It is normal and indicates no mechanical problem at all.
It is possible that yours is more loud than others. This may or may not be symptomatic of other problems. Sound itself is not a problem.
Now, as for the hitch, the customer service people misinformed you. You are correct that the "load leveling" device has nothing to do with the brakes. I am not a big believer in load levelers and I don't think you need them. The owners manual tells you that you need it but that book was written by paranoid lawyers.
The brake distribution system only serves to keep proper braking pressure on the rear brakes when you are towing or are loaded down. This is the system the customer service person mentioned.
As to the hitch measurements, it is 2". That is the standard hitch size for class III and IV plus certain class II hitches.
Thanks for the information about the hitch. As far as the recommendation of load-leveling being a function of "paranoid lawyers", thatdepends: I've towed with several front-drive vehicles which would not have done well without one, while another did just fine. I guess I won't really know until I try it.
Some owners have indicated that tires have been replaced more than once at low mileage. I am wondering if this is some sort of "quick fix" for the pulling problem? Does the problem recur after 5-7,500 miles?
You are not the only one that has been told there is no pull problem. Would such documentation result in a possible government investigation? Have others been told that the problem is "unable to duplicate?"
Please post your pulling issues and/or the methods used to correct them, even if temporary. Thanks.
My Sienna does whine/whistle when running; but so what? The engine is smooth and the van runs fine. I must admit that the van does seem to drift on the highway, especially when windy or a truck passes me. I just figure it was due to the van design (height). I have always had lower to the ground vehicles. Cliffy - any comment on this drifting?
