I would strongly recommend (as I did)that you purchase the "wiring kit" from Toyota. It provides proper snap-on terminals and complete instructions. It is high priced but worth it!
Good Luck!
Do you notice a noisy power steering? Have you repaired any part of the power steering?
Have you seen increasing white smoke on start up? Are you noticing any strong gasoline smells from the front end?
Have you had any ABS peculiarities? Or, clunking with backing up and brake use?
Have you had lots of creaking in the interior, especially around the sliding doors? Is the ride not as smooth as you had expected?
I do appreciate your feedback. This van is very comfortable but recurring problems are not acceptable.
INKY
There is a little info at the www.yotarepair.com site (under Sienna then transmissions) that would indicate your replacement would hopefully be fine. I don't know if your problem is the one he's talking about, having to do with Toyota identifying "that the spacer for the drive pinion was not to correct thickness specification."
It supposedly affected VIN's before 4T3*F1*C*WU043545. However, I think this is for pre-2000 Siennas and he mentions that 2000 Siennas in the west are showing up with problems - he doesn't know any more.
Please keep us posted if your dealer has more info - especially if a TSB exists. I'm keeping my eye on this...I have a 2000 with almost 10k miles!
If there is a problem, is it as simple a replacing a spacer before a transmission failure? Is there or should there be a recall?
Besides smfran's questions, I would like to know from people who have had the transmission break, what was the cause, assuming the dealer/service dept. could tell them.
By the way, the easy fix for the washer fluid drip on the back window didn't show up when he checked for my VIN...so TSBs may not be the only source to check.
There are less than a third of the posts that there were for the torque converter problem regarding this sort of transmission failure. I think it may be too early for Toyota to know whether there is a failure somewhere, VINs affected, etc. And the timeframe is wide open, again, unlike the T/C problem that popped up within a span of 3 months or so. I'm still hoping this may be simply that things occasionally go wrong and not a systemic problem in any way. Although, the comment over at www.yotarepair.com regarding one dealership seeing "a bunch" out west doesn't bode well!
Again, the best thing would be for the people affected to get back to this site with the info they receive from their personal experience.
As for the TSB route, our system does not list all TSBs by model. My service department keys you VIN into the system to see what it comes back with.
If anecdotal information means anything (and since you posted this, I assume that you believe it does), then you are showing a transmission failure rate close to 1%. That is very high.
At first, I thought it was just the American vans. Then, I bought a Sienna. Now, I know it is not just the "Big Three." Some owners are angry enough to do a protest. I see one woman is doing just that in my area at a local Ford dealership. It may be time to join her...make it an effort on behalf of owners of other makes with significant, premature problems and costly repair bills...not to mention safety issues.
Yes, I might just see what can do to assist this person. Why, *everyone* knows how bad the GM head gaskets are, too! The problem seems to be epidemic in all GM models.
Sad to say that Toyota is following suit. The number of occurrences of major failures is appalling and totally unacceptable, IMO. Something must be done...and SOON!
I would be curious to know the justification for this suggestion, particularly in light of the comment "The number of occurrences of major failures is appalling--etc." Truth is, there seems to be no evidence of major failures in epidemic numbers, nor has any clear evidence that warranties are not being honored been shown.
So why are we being asked to believe otherwise? Especially in the face of what are essentially inferences and suppositions put forth by a well known consumer advocate?
Manufacturers have warranties for failures, etc. That in itself indicates they know something "might" go wrong. That's what warranties are for. Has Toyota refused to fix anyone's transmission out there? Do you really expect a perfect car or whatever you purchase? My 27" TV has lasted 10 years with no problems. My last can opener died three weeks after purchase! We are not perfect people living in a perfect world. There are no perfect cars. Some may be better than others but they're not perfect either.
"Things" happen (had to clean that one up...
I usually expect something, somewhere, to go wrong - when it doesn't, I'm happy.
No, this is NOT epidemic. And to the guy who said minivans in general are declining in quality based on the Edmunds posts he's read - where are you coming from, dude? Before you take time off of work to protest your Toyota dealer, better jog your memory about what this forum is for, and that is maily people with problems trying to get answers. SOME problems are large, most are not. Don't construe the existence of these problems here to mean the auto industry has gone to pot! It hasn't. When asked about the industry as a whole, most experts say cars are of the highest quality ever.
We can't be so quick to jump on the consumer rights bandwagon ESPECIALLY when problems get fixed under warranty! No, service is not always perfect. Is it anywhere? Subway got my order wrong again today. I asked for harvest wheat bread, not plain wheat. Perhaps I should have thrown my meal in the face of the "sandwich artist" that made it and spent the rest of the afternoon in front of the store with a bullhorn shouting how Subway doesn't care about the customer!
Before we all march upon our local car dealer with banners and placards, it's a good idea to put things in perspective, and your comments do that very nicely.
INKY
I too have the feeling that this is probably an all or nothing defect and it will either show up early or you'll drive it for 200K and never have a problem. So far, Stanger Toyota in St. George has been very pleasant to work with, Toyota has agreed to cover the expenses regarding my repairs (towing, rental, etc.) and the tranny is obviously covered under warranty, so its not like they aren't doing everything they can to fix my van. However, it still feels like they probably know more than they are telling and it seems that other owners should have a right to know if there is something they can do to prevent a similar catastrophic failure.
I'm certainly not in this to promote any kind of consumer revolt, I basically just want my van to perform like one expects a Toyota to perform and have the peace of mind to drive it anywhere I want with my family. That would certainly be much easier to do if Toyota would 'fess up to the reason for the failure and what is being done to assure that it will not happen again.
Cliffy: Is this transmission unique to the Sienna?
My 2000 hasn't had any problems but then again I barely have over 6000 miles on it.
My rear windshield wiper rubber insert tore two or three months ago and I thought the dealer was going to fall on the sword over that. I received two letters and a phone call after that from Fred Haas Toyota (Houston) apologizing for my "problem". If my transmission fails I suspect they will commit mass suicide......
I'm glad you have such a responsive dealer. If you ever do have a problem, it is nice to know you have the right guys to take it to.
I'll see if I can find anything loose under the hood. I don't want the shop tearing into the dash unless they have to.
-Greg
I don't know that this will fix your problem, but it is worth a try.
Let me know what your dealer says. I noticed that sound myself last night, for the first time. I doublechecked that the windows were shut, and I tried the recirculate setting. It was a soft whoosh, although I had the radio on and could still hear it. I expect it's just that way! But let me know if you find out anything.
I'll see my dealer when I bring it in for it's first oil change. It really does sound like the two front doors or windows are not quite shut. Especially in wet weather I can hear everything zoom by. I hope it's just a matter of weather stripping.
Rear heater - how do I get them to work?? No matter what I set the tempurature knobs at, I get no air/heat out of those two vents under the front seats that are supposed to heat the second row! Are mine somehow disconnected??
I love my van and just need to work out a few kinks!
We love our Sienna but this is the first time we've had a vehicle that needed brake work this early in ownership.
-Greg
Steve
I also have a severe rattle in the door somewhere, close to the latch/handle area. I don't think the two are realted. I've had this rattle longer than the broken handle. Now my question:
When I get the handle replaced, should I have them investigate the rattle? Will they have to remove the inside panel to replace the handle? If not is this something I could fix myself. I have removed several dashes and door panels over the years but never a van sliding door one. Does anyone have a quesstimate for the handle replacement cost? Thanks All
Does anyone out there find the interior of a Sienna surprising prone to rattles? My driver's side sun visor rattles, driver's side window pops and buzzes if the window is opened an inch or so, the passenger side middle captain's chair squeeks, the power door creaks when I accelerate or brake, and there's an assortment of noises that seem to come and go from the rear.
If I had bought a Chevy Venture for about 10k less, I might think "you get what you pay for". But, h___, I thought I was buying the famous, standard of the world, bullet-proof, untouchable high-holy of personal tranportation. I thought that extra 5k-for-the-very-same-stuff Toyota requires you to cough up to get into one of their cars guaranteed something mighty close to perfection.
All that said, I have never driven anything with a better engine/power-train. It is absolutely wonderful. The switches and buttons have a quality feel that rival the best. It is totally easy, comfortable, smooth, quick, and well thought out in every detail. So what happened? This rattle-prone interior is shameful on a car that is otherwise, close to perfection.
-Greg
-Greg
Arrrgh!
