"confuses" the engine til you turn it off , at which time the computer resets and adjust to the mixture.. I'd say when they change the spark plugs, removing the manifold to do this..that this condition will be fixed.. I'd bet money.. Good luck, I loved mine..now proud owner of a LR3 Rover..
Daniel
http://www.cargurus.com/Cars/l-Used-2002-Jaguar-X-Type-c5617
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
jeaniedel
I plan on keeping mine for many years to come.
Hope that helps.
I find that the controls are very well positioned for ease of use on steering wheel - cruise control at right hand, radio left hand.
Setting the clock is a little kludgey and not intuitively obvious. I have to figure it out every time. My clock gains a minute in about a month.
The cruise control is the best I've seen, car gets to that speed gradually instead of downshifting. When it approaches speed it eases up so it does not go over more than maybe 1-2mph. It is very consistent. The cancel is like hitting the brake. Resume just gets you back. I am on my second set of brakes at 134k, will probably renew soon to my third set.
At your miles it is not inconceivable for your engine light to come on at some point. It is a common thing with these cars. It is generally not an emergency, most times indicating an air leak of some sort in the intake system. It could be a hose or requiring renewal of upper/lower intake gaskets, about $600 at the dealer. You may also see "cruise not available". That happens because of the intake business. When that happens you cannot get the engine to rev beyond 3000rpm. Just keep it below that and you can drive to wherever. It's happened to me and went away after I sprayed an manifold air pressure sensor with CRC, a very simple operation, 5 minutes.
Have fun with your car.
