Visitor Agreement.
I can get at the headlight, but not that little light!
Darn, there is a pipe in front of it too!
Any ideas are welcome! If I disconnect the battery, I'll need to reprogram the radio, clock, etc....is there anything else that could get screwed up too? I'd rather not remove the battery if at all possible.
Thanks, Tom
That's a lot of money for just changing oil and rotating tires and changing a belt.
Please respond; anyone who has gone thru this period.
Thank you. TCC
-Brian
I have a Toyota that requires it every 60K and so I wanted to be sure. I called my local friendly dealer who did not disclose the fact that it is a CHAIN vs. a belt...how nice.
He just said it was over 400 dollars for the service and come on in with open arms!! Truthfully, if you have your tranny flushed, antifreeze flushed, oil changed, and tires rotated under a tire warranty, I can break it down to be much less than that amount elsewhere and that is what they basically do at 60K at my friendly open arms dealer!
Mazda should change them for free labor. POOR design for sure. You need to remove the battery and a air housing to get at the drivers side one!!! Engineers are great with cad, but not with hands on!!
-Brian
How does one go about adjusting the 'height' of the headlights?? I don't see an adjusting screw and the manual has nothing on this!
They show a diagram on how to change the headlight bulb - which is a joke since they show a large space between the battery and the socket area for the drivers side bulb - NOT! It cost me $25 to have the dealer replace that little parking light and he was cussing it...which the manual actually states to 'see dealer for replacing parking lights'!
Sorry for the continued ranting on this vehicle, but it is not 'user-friendly for working on the simple things!
Again; how does one adjust the headlights?
Thanks, TCC
Have you had to change a tire yet - in the rain?
There's nothing like getting close to nature being on your knees in a pool of water cursing the engineer who designed the infamous "hidden spare tire".
It's obvious that they only design things on a CAD drawing and NEVER try it for real! But they get paid the big bucks and we pay the big bucks for a unit that is worthless in less than 5 years!
Still no one has replied as to how to adjust the headlights; maybe no one cares about having lights out of line!!
I have not lost a turn signal light YET, but I'm sure that will come next. I've replaced nearly every external bulb on this thing in 3 years! About 30% of them I've been able to do my self....!! What kills me is that the unit has so much potential, but between the tranny issues (mine seems good now) and all the other nit-picking things, it is a nuisance vehicle! I'm really worried about what it will be like after 5 years of ownership. It may just start falling apart as I drive it and all the lights will be burnt out too:-O!
I have 92.5K on my flaming red '01 MPV. It has honestly been the most trouble free automobile I have ever owned. I change the oil at 3~4K intervals, add fluids every once in a while but that's about it. It's beating the two Honda's I have owned. Now, if it breaks down in the next two weeks or so I'm blaming you guys -
So, besides the spare tire and the tiny little ashtray (always my personal joke) it's been a very good van.
Even my TOYOTA Camry has had brake issues and oil leaks in the cylinders!
So, you have not had to replace any of these darn light bulbs yet? WOW! Take a walk around your vehicle to be sure they are all working first....:-) I actually think the earlier models of the MPV were better although you had that smaller engine though....
BTW, I wish that I could have gotten a red MPV in 03 but they didn't offer it anymore after 2001!.
I also have a 2000 Sienna which has been pretty good too - some little nit-pickin' things but generally satisfactory. I prefer the MPV for in town travel and the Sienna for long trips.
I mentioned this a while back; the Sienna is the long range bomber and the MPV is the fighter. I wouldn't trade either one right now.
As far as your "lucky" comment - it's about time! I've owned too many Fords and Chevy's in the past - Ha.
Since the maintenance page is so rarely visited, I thought I would post the question here.
I bought an in-cabin air filter replacement element for my wife's MPV. I looked under the glove box to see where it would fit.
After toying around and removing a few clips and screws, I couldn't figure out how to remove the piece on the left that looked like to most likely place to put it.
How does one replace the filter element? :confuse:
The funny thing is that I asked the parts guy if the filter was behind the glove box (like on my Infiniti). He said it was below the glove box, so it wasn't necessary to pull the glove box out. He should have just said he didn't know.
Now, if you have never had the coolant flushed or transmission fluid flushed, I could understand why the service writer recommended those services on a 3-year-old van with 42k miles. But $620 still seems high even with those services added.
No, it's not. Routine maintenance is following the service intervals outlined in your owners manual. i.e Coolant replacement (yellow) at 100,000 miles. No recommended interval for transmission fluid unless you tow or are under "heavy usage" conditions.
At only 42k miles I think you would be wasting your money. Some people get carried away with frequent oil, transmission, coolant & brake fluid changes. It's really not needed and is bad for the environment. You can wait until at least 60k. Also, most dealerships charge 30-50% more than an independant garage would for similar services, so they will advise you need it irreguardless.
Do it yourself and save 80%
Also noticing the center tray that flips up and down is chipping.
How is everyone elses vans as far as interior and exterior durablilty and finish?
Any informtaion on other vans would be great.
I really like the van so far rides great and is very quite. I picked it over the honda and toyota.
Oh also today went to have some added dealer items put on to the van that was promised when i bought it. I bought mine at a toyota / Mazda dealer. I asked the guy if he sees allot of them come in for serivce. He said no he sees alot of the Mazda 6 but get this he turned to me and said but the toyota vans are much better. but you get what you pay for and you have to buy what your budget allows. Again I picked it over the honda and the toyota. It wasnt a budget issue. I was floored. I didn't say a word but was amdazed he woudl say that to a Mazda MPV owner let alone a customer.
The Odyssey and Sienna should be better than the MPV--the MPV's design dates from the late '90s, and the powertrain is basically unchanged since it was introduced for the 2002 MY. Also I doubt you can get a new Odyssey or Sienna for under $17k, which is possible with the MPV.
I bought the Mazda OEM door edge guard that you were referring to. Though I didn't have any problems with door edge chips, bought mainly as a preventative. I took it back to the dealership because installing the guard required using a cutting tool on the edge of the door to properly install it.
I don't see how the center tray could chip as it is made of plastic?
That was pretty stupid of the service guy saying the Toyota van was better and you get what you pay for. My opinion is that the Mazda MPV is a better van, because for my needs it was. I didn't need a overpriced/oversized minivan (with questionable styling), when I can have one that is a size that is easy to handle and park, is attractive and sporty looking in both interior and exterior, has excellent quality and fit and finish, and is thousands less.
edited: If you don't think that door paint is holding up like it should, you may want to have the dealership look at it. They'll blame you more than likely, but as you have recently purchased the van, they may take it more seriously.
Shattered both passenger side lamps in snow storm. Plenty of sites that sell them at a discount (about $200 for both), but wondering if they're difficult to change, as I know the fog lights are a real hastle to replace? Any advice? Thanks!
expires? The car seems to drive well, but I want to make sure that there are no underlying issues that need attention. Any advice would be greatly appreciated.
Anyway, just wondering if anyone else has had this happen... recently first thing in the morning my brakes are VERY stiff.. with a little pumping they seem ok. Took it first to my local garage.. they flushed lines, checked fluids and verified brakes were ok. Still had problem so took it to the dealer.First said something about brake lines decaying and needed to replace them and rotors..that was NOT under warranty..cost about $300.00. I wouldn't have minded IF it fixed the problem.. but it didn't..seemed only marginally better so I took it back and now they are saying I need the idle air control valve replaced. That is under warranty at least. Anyone else have this happen to them?
Also had trouble with over revving and feeling like the engine was jerking.. they replaced a valve..didn't fix the problem (covered under extended warranty though).. now they are saying transmission has to be replaced, plus front wheel bearings and oil pan all need to be replaced. Now I am not complaining as all under warranty.. and they are giving me a loaner for free BUT I am concerned as this seems like a lot of stuff to go wrong. I hate to get rid of the car (first as a single mom.. money is tight..second as overall I like the car). Anyone else have this type of thing happen..once fixed will it all be ok or is this the start of MAJOR problems (I only have 1500k left before warranty expires so if I get rid of the car it would be soon)...just wondering what anyone else had experienced along these lines.
At what point does it make sense (cost, aggravation etc..) to say enough? I don't think my mileage is that high and I do get it serviced regularly..fedd back is appreicated!
If you have faith in this dealership, I'd go ahead and have them fix everything under warranty. Then drive it for another 500 miles left on warranty and see how it does, leave 1000 miles in case you decide to sell.
This is a tough call. I think it just depends on how well your dealership can diagnose and repair properly. If they install your trans. properly... you should be good to go for another 50k. If you continue to have problems after the trans. and other repairs, then I'd take it to another Mazda dealership if possible, then look into selling if repair bills become to frequent or unreasonable.
I had told them stiff brakes so they replaced front brake pads and rotos.. the rotos were replaced under DSA warranty and they flushed the brake system..total charged $622.36 and warranty covered 299.50..so my actual cost was $322.86.. is that a easonable price for what they did?
Then as I said above... the problems weren't resolved...took it back and now the items that they are doing are: replacing the transmission, replacing the oil pan, replacing the front whee bearings and the idle air control valve. Not complaining as they said all under the warranty. But I am concerned as why didn't they see all these things the first time I brought it in? (They are saying that replacing the idle air control valve is what will fix my stiff brakes...does that make sense? They are stiff first thing in the am or if the car has sat for a while.. and they are so stiff I could stand on them before they work.. but if I pump them a little for a few minutes they all of a sdden will click in and work fine and I have no other problems that day (assuming no long sit period...)
Anyway.. I have idea if the dealer is being fair and straight forward with me or not..so I appreciate any and all help/comments. The one thing he did say that I appreciated was that the reason they hadn't done the transmission first off is that they have to first replace the switch and see if that solves the problem.. if it doesn't then they move to the transmission. That actually made sense.. I understand eliminating the simple first. I am just shaking my head about everything else.
Since my receipt says parts and labor warranted for 12 months or 12k miles.. does that mean I am covered in case their repairs are falty? What about being covered for mis diagnosis? I amgetting sick of bringing it in and having a repair done and the problem is still not fixed...
Oh the other continuing problem is that I hear this continuing click sound when I drive.. they said the replacement of the front wheel bearings will cver that.. anyone else have this problem? I have been trying to get that problem fixed for going on a year now... they keep claiming it is something else...
Please advise,
Dave
I called the Mazda dealership and they said they could order a kit, which included clips, metal brackets and the 3m tape for $34. That's right... $34 for about 30 cents worth of plastic clips. Anywho, I went to an auto parts store(Autozone)and bought a variety pack of clips for a couple bucks... you may get lucky and find the exact size. The closest clip to fitting was just a couple hairs to big. So, I drilled out a slightly larger hole in the metal bracket and it worked fine. No problems in the 2 years since I installed it.
Thanks again for your help!
I got some surface scratches the other day when I backed the Buick against our hedges. :sick: They came out fairly easily though.
