Any thoughts what could be causing this? I am sitting on the fence whether I should get the tires and exhaust work done, but will probably get rid of the car if this most recent noise is something serious. My dealer told me not to worry about the coolant leak or knock sensor; just to use 89 octane gas and keep an eye on the coolant level.
Any thoughts about the noise and the wisdom of hanging on to this vehicle greatly appreciated.
I have a 199 SE Pathfinder. When I drive on the highway and the car shifts at about 45 a screeching sound (not a belt sound) comes out from under the car and then goes away as the car accelerates to 50 and beyond..Has anyone ever had a such a thing. My mechanic mentioned some cap on the undercarriage?
Thanks for any help.
Tim
I don't even know how to describe it, but it actually made our ears hurt. Once we opened another window it stopped. Has anyone else had this experience? And does anyone know what causes it?
At lower speeds where drag isn't a as much of a factor (ie. below 40mph) the opposite may be true. At higher speeds, the power loss due to the AC compressor is less than the drag created by the open windows. Then again, sometimes having the window open for "fresh air" is just nicer than AC, and maximum fuel economy isn't as important.
Hoping someone can help me out here? What is a New Jersey New Car Dealer Sticker? Is it just a sticker that you get when you purchase the car in New Jersey, or is it the sticker that you get when you register it in New Jersey?
Any ideas would be apprecieated.
I have a 1995 Pathfinder and this morning began experiencing the exact same problem. If you receive some suggestions please let me know. Short term I'll be taking the vehicle to our mechanic for some ideas. I'll let you know what he tells me.
Tom
Thanks for your help! :sick:
Have the Service Engine Soon (MIL) computer code read by a local Autozone or Advance Auto Parts. It could also be the throttle position sensor.
In short, the problem was the electronic throttle and it had to be replaced. I was out of warranty and for some reason (to avoid a recall?) they paid for a rental car for me for a week, did the repair free of charge and paid the towing bill.
Make sure you get it fixed properly. There appears to be no quick fix and it will leave you stranded somewhere if it is not repaired properly. Also, depending on your warranty status, if you raise the issue you should be able to get it fixed free of charge. They did that for me and I was expecting to pay for the repair.
plz help
This is my first time with a Unibody vehicle and I'm wondering it I am just a little more sensitve to the typical noises associated with this style of frame. Any help would be much appreciated, thanks.
and this could be the cause. try searching some of the dedicated nissan forums.
I also have a 2005 pathfinder SE with a rattle coming from the passenger side. I posted in the regular nissan pathfinder forum & two other people replied with the same problem. While my dealer has been unable to fix the rattle, they said their dealers diagnosed the problem by using a special microphone system which localized the rattle to a point where the firewall meets up with two other panels. The went on to say that the only way to get at the rattle (according to the dealer) would be to drill open the welds. Both are refusing this d/t safety concerns. They said there are nissan engineers working on the problem. As for me, I still have this terribly annoying rattle which comes from the passenger side (sounds like a tapping noise) it gets worse the longer you drive the truck. Strangely, it is absent until you have driven for about 15-20 minutes. After this I also have the added bonus of a constant squeaking noise coming from somewhere under the front of the truck. After my third visit to the dealer (who has been very friendly so far) a tech rode with me and heard both noises but could offer no suggestions as to what might be causing them.. I have yet another appointment next week. Will keep you posted. Good luck!
Request advice.
You can access Pathy Technical Service Bulletins for free at this site:
http://www.nissanhelp.com/Index.htm
I believe there is a TSB for 02's on "bottoming out". You may want to have a look at it.
Good luck
my pathfinder wen i start it sometimes hesitates for 2-3 seconds before it finally kicks in and starts up, it sounds like its trying to crank during those 2-3 seconds
but this only happens 4 out of 10 times , its been hot out here in NY so its nothing to do with cold, my warranty is going to expire in 15 days and the stupid nissan service guys said they cant find nothing wrong with car, i think they just saying that to make me wait till it gets worse n loose out on my warranty , i just bought the truck n dont know bout its past history, bought it from a nissan dealer , now it has 40k
please if anyone could help me out i would appreciate it , thanks
sal
