Maybe if you drove all the way into the drift the car would have performed better?
If you start at the beginning of this topic there is a good description on how torsion works.
I prefer to be able to lock diffs as needed. I had a 4runner a year ago, and was in Vermont for the winter. I was able to get out of every mess I got myself into by locking the center diff and on rare occasion, the rear as well.
At any rate, snow tires make huge difference.
As for the false sense of security with 4wd, I agree. I drove up to Vermont one weekend last year in my 4runner through a snow storm. On the shoulder of the freeway, was a tipped over SUV.
4WD does not equate to invulnerability. That said, I would take a 4wd with snow tires over a 2wd with snow tires any day. Theres is no doupt that 4 is better then 2, but that does not make up for reclace driving.
Ken
-juice
Ken
I believe that the order of diff locking on the Audi's is torsen first then EDL. But I am not sure. I do recall reading somewhere that EDL is fifty % more effeicent when used in conjunction with a torsen center. I think it was an article about the Mercedes SUV's.
-juice
Don't quote me on that, it has been a while.
I did a lot of reading back in May/June when I was shopping for a new SUV. I came across this article when investigating the pros and cons of EDL.
I believe the efficiency comes from using the torsen first, thereby saving wear and tear on the brakes.
Coupled with T/C, when the torsen fails you have the brakes to manage wheelspin. A good combo.
In fact, Subaru mentions that in their VDC model they tuned the traction control to allow the VTD AWD systems to act first.
-juice
-mike
-mike
BTW, if one suddenly appears in the next day or two, you'll know it was a Troll! ;-)
Which models are you looking at? There are several systems:
Manual tranny, VC
Manual tranny, VC + rear LSD
Manual tranny, VTD + rear LSD
Auto tranny, VTD + traction/stability control
Auto tranny, auto AWD
Auto tranny, auto AWD + rear LSD
All are effective, but each works in a different way. Some come only on certain models (VDC, WRX). Which models are you interested in?
-juice
I know with the viscous-coupling you have to maintain the tire diameters within tolerances and change the fluids regularly.
Also, there are no fluids to replace with the VC system. In fact, there are no maintenance items for it that I know of.
Ken
But both are effective, so let your tranny preference decide. If you do a lot of bumper-to-bumper drives, and auto may be better. I prefer manuals myself.
Ken is right, the VC is sealed and maintenance-free.
Trying to justify the H6? Reasons would include more relaxed power delivery, good torque, still good fuel efficiency, and 3 years of free maintenance (Bean models only). If you like the wood/leather steering wheel and the two-tone leather, even better.
-juice
There are several ways to categorize AWD systems on the market today. One way is full vs. part time. The other proactive and reactive.
Without argument, full-time proactive systems are the best. One such system is the VTD system found in the Subaru VDC wagon and Impreza WRX (A/T). These systems have the least tendency to slip in the first place since they are continuously managing torque distribution. These systems not only help you in snow and ice, but also improve dry road handling as well.
The least effective systems are part-time reactive such as Honda's Real Time 4WD (CR-V) and the system found in the Saturn VUE. These systems are designed to just give your vehicle a "push" when the front tires get stuck. The downside to these systems is that you can get a herky-jerky motion as the system kicks in and out in slippery conditions. Also, these systems do not let you take advantage of the handling benefits of AWD.
Here are some good links that explain the above in more detail:
http://makeashorterlink.com/?W2A32166
http://www.4x4abc.com/4WD101/need.html
http://makeashorterlink.com/?A2935366
Ken
If you decide to "move", look first at the ML320 or the X5.
2 hi, 4 hi (open center diff), 4 hi (locked), 4 lo {also locked)
Quaratrac:
4 hi is AWD or more appropriately termed automatic 4WD. Rear axle is the primary drive. With rear slip, a hydro-mechanical "gerodisc" at the transfer case reactively distributes some of the power to the front. 4lo will have locked front to rear connection (?). New hardware and lots of bugs, lots of unsatisfied owners.
-mike
-mike
-mike
-mike
-mike
Since about February 2001, guess who has been working out of the Muncie plant, none other than Borg Warner. I haven't been able to find anything directly linking the Smarttrak to Borg Warner, but since it's still coming from Muncie, and that's who is operating out of that plant, I'm guessing that's who is manufacturing the new system. The sad thing is... since Olds is on the way out the door, We'll most likely never see a lo-range like the TOD on the Trooper.
-mike
Thanks in advance.
-mike
Smarttrack (Oldsmobile)
VC (Denali/Escalade)
Autotrack (Yukon/Envoy/TB/Taho/Suburban/Pickups)
-mike
in order of fastest/best/on-road.
I state that because the system in the Denali/Escalade provides a minimum 38/62% split in torque between the front and rear axles all of the time, therefore traction from the front tires is instaneous since power is provided permanently to the front end.
Power is then transferred as needed through the center viscous coupling between the front and rear above the minimum as needed based on rear slippage. Likewise this system provides a limited slip rear differential which also transfers power from left to right in the rear based on whichever tire has better traction.
IMO this is a substantially better 4wd system for on-road purposes than either Smarttrack or auto-trac, however the absence of a 4wd-lo would make the Auto-trak setup preferable for off-road purposes.
-mike
Even the Smarttrack system has some minimal delay in transfer since it starts with 0 power to the front axle. An AWD system such as the Denali's will be preferable in adverse on-road conditions. Its my belief that eventually most suvs purchased with minimal intention of off-roading will likely come with systems more like the Denali and Audi Quattro in the future.
-mike
I think most would agree that having the traction to start with is better than waiting for it to be transferred regardless of how fast it can be moved up front.
