-June 2024 Special Lease Deals-
If the person who posted about the 150 yellow p5's could speak up please do so I don't have to check myself into an asylum
I know Mazda has more up their sleeves than just getting their name up on the board at Laguna Seca... The Mazda Raceway at Laguna Seca... And just convenient enough to see the rotary engine return to American shores.
Way to go Chris, good work!
Pat
Sedans and Women's Auto Center Message Boards
hollenhorst2, you don't need no stinking V-6 ;-) Just go to corksport.com click on j-spec engines and buy yourself a fs-ze with 170 horses. It should drop right in, cost very little, and leave you with a brand new emergency back up engine (your old one) AND a stealthy little mustang killer of a car. People won't see you coming but they will see you going.
If you ever affect such a plan please report all results to the group. I for one do not have the intestinal fortitude (or cash) to be the first person to try such a plan.
I hope you get a protege, I'm sure you'd love it.
. . . Lurker mode - ON
Respectfully;
Larry
If Tammy wants a yellow car--get the yellow car. A new mother needs certain things. As a mother of three boys (who are now young men), believe me.
fowler3
http://www.rideanddrive.com/guide/guide.html
fowler3
http://www.cardesignnews.com
Beautifully designed web site with a lot to offer about cars in general.
fowler3
http://biz.yahoo.com/prnews/010430/lam050b.html
unmarkedcar- The owner's manual for all Protege's with the 1.6L, 1.8L, and 2.0L call for 87 octane gas. I have been using 87 octane in my ES for two and a half years now without any problems. Occassionaly, I will run 91 octane to see if there's much of a difference. With the 91, the engine idles just a hair smoother, but other than that, I don't notice any difference. Therefore, I will not spend $2.15/gal for the 91... I will pay the already outrageous $1.89/gal for the 87! Stick with 87 unless your car starts "pinging" (you will know if it does, but the engine computer shouldn't allow it anyways).
What do you mean by "solid response". I counted three responses within four hours of your original post. What more information do you need? No one can tell whether your particular Protege will ping running on 87.
Your original post:
87?
Hey guys....I am currently using 89 octaine gas i my 2001 protege LX 2.0. With gas prices going higher and higher, I do not know if I should start to use 87. I do not know if I will get more engine knock (using lower octaine). Or if higher ocatine is acutually harming more than it is helping. I am getting 27mpg (hwy. will this improve with a lower grade of gas?
The responses:
From hkchan:
Re: Octane
1. Why have been using 89 in the first place?
2. You won't know for sure if your engine will knock on 87 unless you try it. Chances are your won't because most don't.
From vocus:
87 vs. 89...
I have a 2001 ES 2.0 with 4100 miles. I use 89 octane about every 5th tank init, just to make sure the engine is cleaned out inside. But 87 works fine, with no knocking at all. Also, you shouldn't constantly use a higher octane than recommended, because I hear it causes carbon build-up on the internal parts of the engine. And that is not good for the car. Also, why pay extra for 89 when the car only requires 87? BTW, I usually average 24-26 mpg, no matter what kinda gas I use. Drive mostly highway, 70-80 mph.
From maltb:
87 - Always
Never had a problem... The only times I use something different is when I decide to run advanced timing on an older vehicle.
Most new vehicles use a knock sensor to retard the timing when necessary.
Go Figure....
http://www.blueovalnews.com/mazda_02323.htm
In accelerating the tach goes up to 2900rpm and it upshifts, again up to 2900rpm and it upshifts to D3 or D4. At 65mph in D4 the tach shows 2750rpm.
I'm averageing 26mpg around town. No hard and fast starts, no hard braking on stops. I just don't drive that way. This should be a comfortable car on trips.
ibg: I'm not a Pro-ZOOMER, I'm a Pro-MOOZER
fowler3
('01 Pro ES)
Dave
Dave
Oh yeah, and about gas. I heard that Protege's do not have knock sensors so using higher octane fuel will not do anything for gas mileage. I was using 91 octane since I bought the car, I'm trying 87 octane to see if there is a difference in fuel economy. I am not the bigest car brain but I'm not sure how a knock sensor is related to fuel economy, I thought is was used to retard timing. I though the oxygen sensor was what determined fuel/air mixtures. Again, I am not a car wiz here.
Squealing: I have floored my ES AT many times from takeoff, and only spun once, and that was because I was on loose gravel. Of course, I have 4600 miles already, so well broken in.
Octane: Why use more than 87? It's just a waste of money IMO. I have used 87 in this and the last Protege (a DX) since new with no problems. I admit, occasionally I do run a tank of 89 to clean the car out, but only like once a month or something.
http://boostamerica.org/fordgive.htm
I do wish the Protege was offered with traction control. I don't know about the automatics, but when the road is wet I have the hardest time trying to get a smooth, gradual take-off from first. Most of the time, I'll start from second gear to keep the front wheels from spinning. Of course, here in Southern California, when it does rain (very seldom), all of the oil comes up to the surface and stays for quite a while.
However, just to give you an idea what a Protege ES 5-spd can do in terms of spinning the tires, here's an experience from racing an Integra from a light. Dropping the clutch at 4,000rpm from a stand-still produces about 3 seconds of tire spin before they catch. A quick upshift to second at redline produces about a half-second of wheel spin... Upshifting to third gear produces a nice audible chirp. I don't know about the upshift to fourth... the Integra gave up when I was still pulling away from him at 70mph... Zoom Zoom!
Zoom ZOOOOMMMMMM!!!
Meade
I live in the VA/DC area, and after much research, decided on the 2001 Pro ES, 5 speed, with premium package (either emerald or silver). Last weekend, I went back to the dealership where I had test driven, and learned (of course) that they didn't have what I wanted. (They only had one ES, sand, no options. I'm somewhat flexible, but it wasn't for me.) I wasn't prepared for them to tell me that no cars in that configuration were available anywhere on the East coast. Indeed, they claimed the car is so popular, few dealers would trade them if they had them.
I expanded my search on Monday, using online tools to send requests to dealers all over the area. Another area dealership confirmed the claim of the first: none were available in the area. I was told that I could "factory order" one and have it in 6 to 8 weeks.
So, here I am trying to decide how flexible I am, how long I can wait, and what to do next.
Questions:
1. Can anyone else confirm the experience? It appears ES premium packages are rare on the 5 speed and/or in high demand.
2. Should I be wary of the claim that none (or at least very, very few) are available within a thousand miles? I'm willing to expand the search, but don't want to head out on a fool's errand. (I do understand that dealers are interested in selling what's on the lot.)
3. Is there any drawback to making a "special order", other than the wait? I've waited a while to get a car, and a few more weeks won't kill me.
4. Are there any general suggestions on how to proceed or words of encouragement? (I'm not completely inflexible. It's just that I did my homework and figured out what I wanted/needed.)
5. On a side note, I've been out of school for 3 years, one more than the two maximum for the college grad rebate. However, it *is* my first car purchase after college (I've been walking to work) and a local (blue oval) Ford dealership said they might be able to get it for me (back when I was looking at a Focus ). Any thoughts or experiences on the topic? Can the rules be bent a bit? Will dealers be willing?
I do know that some posts way back around #1006 touched on some of the topics, but I thought I would get some fresh perspectives.
Zoom. Zoom. Soon?
