and you use the anti-seize on the threads, and the di-electric grease on the connector to the wires?
oh yeah, i'm using OEM NGK plugs, straight from the dealer ;-)
psst...
you can get the same plugs at a parts store for a little bit cheaper.
Man, all the difference in the world at 80 this morning.
LIKE BUTTAH!!!
Meade
Viz. you set the trip meter to zero when the fuel light comes on, fill it up and take the reading when the fuel light comes on once again.
As you receive answers to your question about how many miles people are getting on a tankful, remember the P5s (and the '01 on Protege sedans too, maybe?) have larger gas tanks than the '99s and '00s.
My '00 ES 5-speed, with a mix of city and highway driving, usually goes about 310 to 320 miles between fill-ups. On an extended highway trip last weekend, I set a record and went 345 miles between fill-ups.
Meade
GO WILD GO!
Dinu
PS: The PRO is doing great BTW
Also, I can drive at least 50 miles after the low fuel light comes on. I think that it comes on when there is about 2 gallons of gas left in the tank.
Or is it?
I have pumped half a gallon after the autoshutoff, and because of a fear of overflow, I stop.
So what should I believe?
Manavi, 400miles to a tankful?(how many gallons?)
What is ur driving mix?
I think my low fuel light comes on at a bit over 2 gals left. I don't want to overheat the pump though, so I usually don't let it get to this point.
You'll find the autoshutoff at pumps vary by the pump. I've actually had one that was too insensitive and spit out some fuel. Nasty poorly maintained pump at some run-down station. I avoided that stop on the return trip. I try to listen at the fuel inlet for sounds of fuel gurgling up into the inlet pipe. When the frequency goes up, I ease off the trigger, which gives the autoshutoff (I think most work by sensing a change in air pressure due to the outlet tip being "under water") more reaction time. I probably look awful silly with my head down by the fuel door, but I don't want to repeat the spilled fuel fiasco. I'd rather underfill than overfill my tank so I don't saturate the charcoal canister.
2. Fill up the gas till it auto shuts off
3. Reset the trip odo to 0.00
4. Start driving
5. Head to your regular gas station once more
6. Fill up the tank again. Note the gallons that it took in before autoshutoff.
7. Divide the trip odo reading with the numbers of gallons it took in.
Voila! you have ur mileage
8.Repeat steps 1 thru 7 for 5 times to get a good average of the mileage(????)
Right?
Note: isn't the term "mileage" supposed to represent an average reading in the first place?
I get around 29 or 30 miles per gallon. It usually takes about 13 gallons when I fill up. Hence, 400 miles per tank is not unusual. Just depends how close I am to one of the gas stations in town that has cheap gas.
Also, I can put at least one more gallon of gas into the tank after the auto-shutoff. I've overflowed twice in 2 years. Oops! But, I like being able to drive as far as possible without having to stop again to put gas.
Of course, the real winner here is the Protege! (whew, I worked it in).
Now where is that rally duck?
ps
Did you get my e-mail?
I did notice that if you use your AC a lot and drive around 85mph you get closer to 22mpg.
I average 28-29mpg on 70/30 city/hwy driving, unless I'm feeling frisky and accelerate hard. Then I manage to make it dip to 24-26mpg. :P
those things are complete badass!!!
4. Start driving
5. Head to your regular gas station once more AND
to the same pump. Pumps can vary at the same station.
Voila! you have ur mileage!
The only long trip I took in my 01 Pro LX, last year, I got 36mpg. The roundtrip mileage was 427. Most of the highways were through hilly and mountainous country with some driving over rolling hill country in Central Virginia.
For those driving in mountainous country for the first time, one of the best routes is U.S.220 from Roanoke, Virginia to the North Carolina state line. It's four lane with roller coaster dips and sweaping curves. Traveling north on 220 there is one hill, which gives you a panaramic view of the mountains 30 miles away, just before you plunge down a straight stretch for 3/4ths of a mile with a 90-degree right turn at the bottom. Lots of flashing lights warning truckers to slow down and torn up median grass where many did not.
The Pro takes 220 like it's on rails.
Hank: Did you see C&D TV on TNN this afternoon? They showed a test drive of two, red RX-7's. Said they really needed more power. Ha, don't all cars?
On ESPN, they had the International New York Auto Show the following hour. Everything on wheels seems to be either silver or dark grey metallic. That Toyota Scion makes a Jeep Cherokee look downright streamlined. Definition of the Scion: A Wells-Fargo truck in drag.
fowler3
yeah i saw it, doesn't that look fun :-D
I just changed it today, my god how the old plugs look all beat up and stuff after only 32k.
now I feel much better with fresh plugs :-D
I would never, ever, leave spark plugs in for 100,000 miles. I don't care what they're made of.
Ted--After reading that C&D article, I think it's obvious that the Mazda 2.0L isn't a tuner motor. Mazda had to do TONS of work to get 240 hp out of the 2.0L and it isn't even a reliable 240 hp. It's too bad they couldn't call Honda up and just borrow their naturally aspirtated 240 hp 2.0L from the S2000. I have a feeling that the 2.3L will be much better also.
"Some people wouldn't leave thier oil in for 10,000 miles or more. But some models allow it."
Isn't it funny how the oil change intervals got more relaxed as some manufacturers started offering free scheduled maintenance? MB and VW come to mind.
Meade
P.S. NO POSTS AT ALL YESTERDAY??? Do I really hafta come in here and stir up another debate among you guys???
Today I drove 6.5 miles to daycare and work and in that time I saw:
3 ES
1 LX
1 DX
3 P5
TONS, literally TONS of Proteges of all ages running around.
I guess having 4 Mazda dealerships within a 20 mile radius has something to do with the abundance of Proteges, Miatas, and 626s :-D
and Mazda6's!!!
No, I haven't found out about cargo tray fitment yet. Frankly, I probably won't be buying one since I'll be trading my Protege for a Jetta 1.8T this weekend.
Meade
http://home.attbi.com/~bernhard36/honda-ad.html
Meade
