Visitor Agreement.
Also, just because the oil mfr says you can go longer doesn't mean you shouldn't change the filter. Either find a larger-capacity filter or change at the regular intervals.
For me, I pay more for the raw materials because I prefer the way my engine sounds and runs with synthetic. Since I do the work myself, it costs me roughly $15 (v. $6)in oil and oil filter, plus about 30 minutes of my time (including prep and clean-up work).
Regarding seal materials, I can't vouch for all makes, but most materials used these days shouldn't swell when exposed to synthetic oils. This was a much bigger problem when everything was made from butyl rubber.
I'm switching to Valvoline Synthetic BLEND for my Protege. I want somehting a bit "better" then regular dino for better cold startups and longer drain intervals. But I don't think that full Synth is necessary in this low compression, N.A. engine.
So I split the difference! :-)
Sytnh
Blend
Dino
false alarm (with "recirculation exhaust" EGR code)
So before I take it to the shop, I would like to reset it and see
if it turns back on any time soon.
So how do I reset it ? Will it automatically reset
itself based on X times cold start etc.
(In some posts I have seen people mentioning drive for a
week and it will shut itself off. But no specific criteria)
Synth: about $4-4.50
Blend: anywhere from $2-3
Dino: about $1-1.30
I use either Mobil1 or Valvoline full synthetic.
I learned this trick and became quite accustomed to it with my POS 1994 Mazda B2300 pickup. (Hey, I know ... Ford through and through.)
Meade
You might want to find an independent garage or mechanic who has more pride in their work.
"Within specifications" is an excuse used by lazy/non-caring people.
The filter was a bear to get off and my filter wrench was too big. The oil drain bolt is the obvious one on the bottom, back of the black oil pan. The manual says it's on the front.
I used the Bosch filter and 5W-30 Valvoline Synthetic Blend oil. It took about 3.5 quarts. I'm at 4400 miles and intend to change around every 5k as recommended in the manual. I'd love to find a bigger filter.
At this mileage, I have no problems to report. The engine has really loosened up and revs smoothly and sweetly to redline without much prodding. The interior is quiet except for one small rattle/buzz coming from the glove-box. I need to empty it and see if my wife can track it down on our commute. I'm not really worried about it.
Does anyone have tourqe specs for the lug nuts? I need to switch over to mywinter wheels/tires soon and want to get it right.
znole
Protege Newbie
yeah, i hate that air wrench gun for lug nuts. i bought myself a torque wrench (a nice one with case) and a deep socket, and do it myself. squarely mounting on the wheel is to do a star pattern at 30-lbs and then 60-lbs and then finally 85-lbs. note, during torqueing, wheels must be off the ground not resting. the manual stated 80-lbs (if you look in the flat tire section), but i put a little into it, 85-lbs. when i mounted my wheels this way, all the vibrations and shutters are gone (yeah, squarely mounted).
btw, over torque may cause breakage in nuts, bolts, threads, etc..
http://www.protegeclub.com/forum/showthread.php?s=&threadid=722
I hope my torque wrench goes up to 80 ft. lbs.
You can definitely strip threads or break off studs by over-tightening.
People using powered drivers can easily cross-thread, which ruins the nut for sure and can damage the stud enough to warrant replacement (about $50US). After losing two to careless mechanics, I do all my tire rotations myself. While they're off, you can inspect your brake pads and rotors. Drums in the rear usually don't wear out before front disc pads do, so I wouldn't bother checking them until you replace the front pads. When I inspected the ones on my '89 323, they still had about 75% of their original specified thickness when I replaced my front pads.
BTW...the wrench cost $70 - 10% ($7) = $63 + tax. My brother (an engineer who has designed MANY tools) says it's one of the best torque wrenches out there for under $500. He's never steered me wrong.
Pete
Anyone familiar with Sear's policy on that?
9.95 dollars and 19.95 dollars, respectively. Yes, the wrench with a case is 9.95 dollars that was a sale price. It goes up to 100 ft/lb. I used it to put on a hitch bar onto my Honda Odyssey, and it worked nicely. I'll find the mail-order catalog if you want to order one. Before the wrench was on sale, it was 19.95 dollars.
If it's Pittsburg brand it came from: http://www.harborfreight.com
Many cheap Chinese tools there, but for some of the stuff, who cares.
$19 with shipping. That's half the price of having a shop switch my wheels just once.
Pete
Most diagrams show that range the most. I'd like the in/lb too, but there are more pressing stuff for the 5-80 range.
Plus the handle was longer on the 1/2" one, requiring less effort at higher torque settings on my part. (Bum shoulder necessitates this).
Pete
I've read that some people avoid coin-operated car washes in the winter due to the water being recycled (thus containing salt from previous car washings). Is this a legitimate concern??
Your help is appreciated.
Try these web sites. These are my top secret places to learn about car care. Enjoy!
http://www.autopia-forums.com/
Respectfully,
Larry
-Larry
What is their retail store like? BTW, check out the Wax Test Web Site, if you have not alreadt done so! Verrry cool!
-Larry
Has anyone else tried to clean the REALLY stuck on brake dust from the INSIDE of the rim? Is there a way to do it without destroying the finish? I tried a little Brasso on the inside of one of the spokes and it worked pretty well but after reading the bottle it says not to use on aluminum. Our rims are cast aluminum...right?
Any suggestions?
Pete
my 2000 pro is set for a 15000 mile service in 2 days time. i do not know much about car maintenance. would you please let me know what kinds of service/maintenance issues i am to be aware of before i step into the dealership. what consists of a normal 15K service and how much (approx) would it cost ?
just for info, i am in central NJ and my dealer is Route1 Automall, Woodbridge.
thanks a lot.
I called one time to get something over Labor Day but they were closed. They said they aren't really a retail shop like a PepBOys is, however if I wanted to pick something up I ordered I could..
BTW.. who was it that ordered the Klasse system? was it you? I was reading that Wax Test and it seems to do pretty good...
-Larry
The manual also says that if fuel-filler cap is missing or not tightened securely the "check engine light" may come on.
In some previous Edmunds Pro posting it was said that if the "check engine light" comes on it means the dealer is required to turn the light off. But, another posting said that simply disconnecting the negative battery lead (and reconnecting it several minutes later) would allow the computer to re-set itself, and no trip to the dealer is needed. This sounds plausible to me. Can anyone confirm this?
If not, try some bug & tar remover, that stuff removes bad stuff really well.
Mequire's, Mothers, Griot's Garage.. nearly all the big companies make it.
Pete
