Visitor Agreement.
Not.
I got a Brand New 2000 Pro and sealed the deal and drove off with it about midnight Friday. Since the dealers cleanup shop was closed, they owe me a detailing which I'll have done this coming Friday. I think I'll have them add-on Flaps and a Cargo Net.
One big suprise was the car did not have a power antenna. Just about everything else was powered. The radio/CD sounds pretty good for standard, but for some odd reason it wan't pickup my favorite station. It's got a weak signal anyway and I guess the FM autosquelcher or what ever justs rejects the less than great signal. At times like this I wish it had a regular VERTICAL antenna.
I plan on doing the front struts this summer.
I was also thinking about Wire Wheel covers. I never did care for that roman chariot spoke look on every other car on the road. Spokes are classic, classy and sporty to my eyes. I'm from those days when any sporting car had wires. Real Wires.
And at 80MPH, you shouldn't have to worry about hot radiator air...
Click on the pic to go to Corksport.com
They also carry one of the most prestigious but elusive brands around: MAZDASPEED. Mazdaspeed was an aftermarket manufacturer until recently when it was absorbed by Mazda. It is now the factory's "tuner" division, much like Ford's SVT or Mercedes's AMG.
Why do they call themselves Corksport?
I already checked the web site and they don't give a reason. I know the answer is out there on the web, but this makes for a good trivia question.
You should post that in the main Protege board and see what kind of response you get. I don't think anyone else but the junkie's like us come into this board very often.
http://auto-stuff.com/mazda.html
http://www.corksport.com
Click on General Parts, and then Decals/Stickers/Emblems.
They also sell J-Spec engines... like this one for $1875.
210hp 1.8L DOHC turbo from the 323 GTR!
It HOPS constantly from 5mph up even to 65mph.
Is there a way to reduce the uncomfortable hopping?
Can the suspension be snubbed down and not put in stiffer shocks? Civics don't have this hop, but the seats are terrible, way too hard. The Pro's seats are as good as in more expensive cars, if it just had a smoother ride it would beat the heck out of Civics.
fowler3
So far the Nitto's have been great. They do "chatter" a bit on painted road surfaces (such as lane lines and stop lines) and they'll squeal a bit in hard corners, but the grip is excellent and road noise is much, much less than the OEM Bridgestone's. Plus, the tread wear has been outstanding for a performance tire. I have 17,000 miles on them and I think I can get another 15,000-20,000 miles on them. I only got 15,000 miles out of the Bridgestone's (of course, I drive my Pro pretty hard). I hope this helps!
fowler3- Unfortunately, the stiffer ride is part of the Protege. The ride is very similar to a German sport sedan. However, with that stiffer ride comes excellent handling. I thought the ride was very bumpy at first, but two years later, I have found I prefer the stiffer ride and the extra control rather than a cushy ride with less control. Everytime I take my Protege into a corner, I smile, and the ride is forgiven.
There is no way to soften the ride. The Protege already wears extremely stiff shocks with fast rebound rates. Also adding to the stiffer ride are the 15" wheels and 55-series tires. The ES gets even stiffer with 16" wheels and 50-series tires. You will get used to the ride pretty quick, and you may begin to appreciate it.
I'd appreciate a response before tomorrow morning
TIA
I have 22% tint on the rear five pieces of glass (the rear doors count as two pieces of glass each). I have 35% tint on the front doors. I don't have a moonroof :-( , so I don't know how much that would be. However, definitely get the 100% fully metallized titanium film for the moonroof at a very dark (10% or lower) tint. It will really reduce the heat generated by the moonroof glass.
kuzma725- Congrats! $100 for the keyless entry is for a factory installed system only. The dealership will charge you an outrageous amount for keyless entry to be installed and it will not be the factory system. They probably could install the factory system, but it will certainly cost you. My experience with dealerships (and I've worked at enough of them) is that their keyless entry and alarm systems are amazingly cheap and of very low quality. I would go to a shop that specializes in automotive security systems (they usually sell audio equipment as well) and have a really good system installed. It will be a much better system, will most likely include an alarm system, and cost less than the dealership's system. Good luck!
For instance, consider the following scenario:
1. Take the remote control and stick it on your key chain
2. Place the door / ignition key on one of those removable key chain accessories
3. Unlcok the doors with the remote
4. Separate the key from your key chain to start the car
5. Lock the doors
6. Come back after the car's warmed up (or cooled down, depending on climate) and unlock the doors with the remote
7. Call the spouse or the locksmith, or get the other key (you have a spare, no?) to unlock the doors because your toasty (or chilled) vehicle is inaccessible at this time! The remote is disabled while the vehicle is running.
(luckily I had the second key available!) :-o
Viper w/ remote start - now there's a nifty option to have!
Best of luck,
Dave
Problem I have is I'm in NJ and there's no tint allowed at all on the front windows. With that, what do you think about just tinting the "back 5"? (of course, the moonroof as well). I imagine it would contribute to the cooling effect you describe, albeit not as potent.
Thoughts, anyone?
Dave
In California it's illegal as well, but Jerry and many others take the chances that if they tint the back dark and the front much lighter, most officers won't notice. Worst case, you have to peel off the tint from the front, have it inspected and start over.
The remarks above are from police and sheriff deputies in the San Diego area. I don't know how other areas handle it. BTW, in California, it is now legal to have 85% tint on the front door windows. Of course, 85% is practically no tint at all. I have heard that the bronze non-reflective tint is also legal here, but I'm not sure on that one.
Fortunately, I have not had a speeding ticket in my Pro. Actually, I haven't had any tickets at all in the Pro (knock on wood). The only speeding ticket I've had was in a 4-cyl extended cab Ford Ranger. I don't know how I did that... that poor truck couldn't get out of its own way.
There's an Edmunds discussion on tinting and the same questions get asked over and over. Topics are metallic vs. dye, radio reception with metallic, state laws, installation problems, etc. etc.
I think I'll get the moonroof tinted but I'm not sure about the rest.
Borg, Kinda hard to drive and look at the stars at the same time.... what the heck are you up to?
Actually I have looked thru it while the wife was driving at night......kinda cool.
I'd hate to pay for a nice tint job only to wind up "breaking the law" by getting a ticket or failing inspection (though they did bump inspection up to every two years from one...) I'll see if I can do what the consesus here is: darker in the back, lighter (but uv protected) up front, may be acceptable.
(also, thanks for the tip on the other Edmunds tint discussion)
http://www.geocities.com/protegetech
You should see the featured car after you enter the site. Click on it for details. This site is also a great resource for Protege owners of all generations. Basically, he's added the Sport 20 front bumper:
and the side skirts:
And of course of bunch of other modifications.
All images above used with the permission of CorkSport. Visit them on the web at http://www.corksport.com
Now the question is will there be any Proteges at the junkyard, otherwise I'll have to buy them for $20 each, still a ripoff...
-Larry
Sparrow: I paid like $1000 for the moonroof installation. The dealer sent it to a shop and got it installed. The maker was called Hollendasia or something like that (don't know anymore, because I got rid of the car). But it was a spoiler-type roof (opened outside and not inside) and it also closed automatically when turning off the car. (That's one thing I miss about my DX.) You can also go to Ziebart (some locations) and have one installed for like $6-800 or something. In any case, make sure it's covered for the life of the car. Mine was, and the ones from Ziebart are as well.
H
