Mazda Protege Accessories and Modifications
I just discovered this great site and wanted to join in the fun. I have a 2000 Protege ES with 35K miles on it. Excellent car, just change the oil, put gas in it and zoom.
Quick question, the driver's side power window switch has an auto down function. (Push the switch all the way down and the window goes down automatically) Does anyone know if the only difference is the switch, the housing, the button?
If the switch is the only difference, I would like to order a switch and install in the passenger door, so it will be auto down as well.
Anyone done this or know if all I have to do is change the switch?
told you this is out of nowhere, purely for my own curiosity I guess...
1.6l on 99-00 was derived from the miata 1.8l.
open the hood of a 626 and a miata and you will know what I am talking.
The guards went on real easy and look nice. Almost like a ground effect. It took me about 10 minutes to do all four wheels. Nicely molded and the look like they really belong there. It's nice having the real thing.
You have to drill two holes for the cargo net, but it, too, goes on easy as pie.
Last weekend I got one of those little convex mirrors that you stick onto the driver side mirror. It looks a little goofy but it's quite functional. I can see the entire lane beside me right up to where it comes into my field of vision. No blind spot.
I would not drive a car without one.
Mine's a small rectangular mirror in the lower right quadrant. I moved the main mirror in as tight as it would go, then stuck the convex on it "lightly" so there would be no interference with the main mirror's motion. I then moved the main mirror back to the regular position and made sure the convex was on straight. It was, so then I pushed it on nice and snug.
The round mirrors look OK, I saw one yesterday on newish Mustang but it did have an aftermarket look to it.
You know how the electro-lock rocker button on the driver's side is basically just a molded black oval with a bump on one end. I'm always fumbling around trying to find it, esp. at night.
I took a dayglo orange sticker, a hole puncher and punched out a dot. I stuck the dot onto the top center of the rocker button. The day-glo orange is easy to see, provides a target and is visible as long as there is any light available, such as courtesy light, ambient street lighting, etc. I did a nice clean punch and good centering. It's looks good and I find the button first time every time, now. It's also raised a little and I find the tactile feedback to be better.
If I pointed my mirrors way out like that, I'd have to put the convex mirror on facing inward so I could see my car.
eg. 205/55R15...any problems?
Fronts are either 5x7 or 6x8. Either should git without any modifications. I had the front driver's door apart the other day to finish stripping the tint off the front side windows and got a good look at the fronts. The rears are 6x9's without a doubt. Some people have mentioned putting speakers in the rear doors, and I'd guess they are also 5x7's or 6x8's like the front doors, but I'm not sure. I do know that there are no speakers in there right now though.
Pete
Now that the short intro is out of the way, I have a question: My dealer threw in some locking nuts for the wheels, but I'm wondering how they work... and I'd like to have some idea before I pick it up, rather than having to ask the dealer. Can anyone enlighten me?
Respectfully;
Larry
Pro'ers - has anyone with moonroof done a before / after with deflector installation? How much difference does it make to interior wind noise, how fast you can go, etc. Also how is the deflector installed?
Anyone esle get the new issue of Zoom Zoom Magazine? It had a survey asking what I'd like to see in future issues. I added 2 things... feature Protege Mods and a Mail order store for purchasing acessories (at discount).
-Larry
The Cargo net does require a little drilling. Read the instructions first and read them well. It's not complex, but it may save you some small trouble. I made a paper template based on the offset specs of the hole, lined the paper up on the trunk liner and drilled. Tools? A small flat head screwdriver to pry the pushed-in fasteners out (easy), an adjustable open end wrench or pliers to start the screws for the net hooks. I used an old glove to protect the plastic net hooks from the metal pliers. It was also a 10 minute job, once you round up the drill bit, drill and tools.
I would not mind getting an extra set of the upper hooks for the cargo net. There is a second set of holes in the panel and I'd like to be able to optionally hook the net there, giving it a little more flex when I want it.
My sis don't mind if i take her mud guards, so I'll get some soon
I installed the factory wind deflector on the sunroof on my '92 Protege. (I can only assume that these things haven't changed much -- they don't look like they have.) It made a HUGE difference. Without it, wind would enter the rear of the sunroof when it was open and buffet my hair, and anyone in the back seat, around. With it, no more wind entering the car. It made the ride much more quiet at speed, and I never had any problems with its fit even at speeds exceeding 80 mph. The front edge of the windshield/roof line seems to protect it from the full force of the wind, and it's aerodynamic anyway. Very easy to install and it never caused any leaks.
One other very nice feature about it was, since it was a smoked transparent plastic, it shielded the sun from my face and head much of the time. The moon looked awesome through it!!!
A sunroof was the only option I elected not to get on my 2000 ES -- not because I don't like them, but because I'm big and they cut about 1-1/2 inches of head room. But if I did have one, I'd get another one of those wind deflectors in a heartbeat. A very good investment!
Meade
Is it installed with double-sided tape? Is there any risk of long-term damage to paint?
Norcan
Question: Hi,
> currently my car has stock 15" al. alloys with Bridgestone potenza RE92
> 195/55-VR15 tires.
> I was wondering whether it would cause any interference in the wheel-well of
> my car if I upgraded to 205/55-R15 tires.
> Thanks in advance,
> Nick
> Year: 1999
> Model: Protege ES
these are good sites to see differences in tire size and speeds..
http://www.miata.net/garage/tirecalc.html
http://pw1.netcom.com/~sgalaba/tiresize.htm#ustires
with the 205/50, the tire height is 4.04" compared to 4.22" stock. the width is 8.07" to 7.67".
slightly wider, but lower.. go out and measure if there is enough space for the tire...
Chikoo, the best thing may be to find a shop or a freind that will swap wheels and/or tires to test fit.
No kidding.
Obviously, if it rubs when the car's standing still, you'll say forget it. I'm wondering how likely that it would when the new tire is 0.36" shorter (the whole tire) and 0.40" wider.
Going from 185/85-14 to 205/60-15? The new tire is a full 1.7" shorter and 6.4% smaller in circumference.
so if my tire at 1.7" shorter rubbed, what do you think a tire .22" shorter would do? I never said the closer the tire is to the wheel well, the more chance you will know if it will rub was a scientific way to guage rubbing did I? no.
you just like to try and nitpick numbers like the Civic volume..
visually, there is a huge gap between the tire and the wheel well.
205/55VR15 24.1"dia / 7.8" width
195/55VR15 23.5"dia / 7.7" width
difference 0.3" radially / 0.05" width
doesn't look as if it would rub if you put those numbers into your visual inspection.
But, would they?
best way is by swapping and testing and/or check with inside man of mazda
I took a look at a few tire size calculators. The 205/55R15's are 1/2" larger in diameter, resulting in the tires being 1/4" closer to the wheel well. The 205mm width works fine in mine with plenty of clearance, so I say the 205/55R15's would be just fine!!! Go for it!!
My question is how likely is it to detect rubbing by visual inspection while the car is standing still. Does the clearance, or lack of, increases or decreases as the car's suspension is compressed?
Regards and let me know,
Pete
