Mazda Protege Accessories and Modifications
I find it very funny that they include direction for the mud guards, but not for the strut tower brace. I guarantee you that most techs at a Mazda dealer would need directions.
If I were getting one, I'd get a polished one from a company like Injen or AEM. The Injen website (www.injen.com) has a really cool picture of their cold-air intake in a Pro.
One last thing: Does anybody know the difference between cold-air and short ram air intakes (besides the location of the filter)? Is there a large power difference?
Thanks in advance all.
2. Undo screw at top of turn signal, save for later.
3. Gently wiggle turn signal out of place but not so far as to pull the wiring out.
4. Push in and turn the bulb socket gently counter-clockwise.
5. Remove clear turn signal bulb and replace with identical (except for color) orange turn signal bulb. (you will NOT use the gray plastic socket included with the Corksport J-Spec clear corners. Use the original that came with your factory orange corners. I had to buy new bulbs at the auto parts store. The J-Spec connector and our factory wiring harnesses are different shapes and incompatible. VERY simply fixed by using original socket which fits perfectly into back of clear corner.)
6. Insert original bulb socket with new orange bulb into clear corner, pressing inward lightly and turning clockwise.
7. Fit new clear corner into place carefully and screw into place with single screw removed in step #2.
8. Close hood and marvel at clean, complete look of your Protege sans ugly orange corner lamps!!!
You already have my number if needed yooper...call if this doesn't help.
Pete
Will also post seat-of-pant detection of improvements here...
As for the K&N drop-in, no drastic improvements like the strut bar, but there are some subtle things that did change for the better. The tach needle now jumps more freely now (ie engine revs up faster), was able to rev up to 3500 from standing maybe about 1/2 sec faster than before. Engine now gives a deeper, louder growl at redline, about the same noise level as before at normal rev range (2000-4000). The last thing I notice might purely be psychological, but the engine seems to rev more 'relaxed' at highway speed. In the O/D gear, the engine still runs at the same rpm at a particular mph, but now when press down on the gas pedal to go a bit faster, the car just accelerates flat out, without disengaging the torque lockup to rev up for acceleration.
I have to wait til I get my oem Dunlops back on before doing the strut tower brace. Might see if I can get a spray can of oem light sandalwood from the dealer and paint it before installing. Glad to hear you think it was a worthwhile upgrade.
How hard was the install?
oh yeah, have a 10mm hex socket handy, all the small bolts holding the bracket is that size.
The big bolts holding the struts are 9/16", and the bolts holding the bar itself is 1" IIRC...
And oh yeah, your hands will get dirty, but isn't that part of the fun ;-)
big h. If I understand you there's both metric and "American" sizes on our cars. Doesn't seem possible. What's 1" IIRC? Thanks.
-Larry
As a matter of fact it is mixed, I definitely remember the small bolts to be 10mm, because the 3/8" and the 7/16" doesn't fit right. The 9/16" and the 1" bolts also fit very well. My roommate has a tool set, and I tried out the sockets one by one until I found ones that give a nice tight fit over the bolts...
The bolts are probably all made to metric spec, which just happens to fit some english sizes...
So just when do you use the 16 and 18mm wrenches anyway?
more pics at http://groups.yahoo.com/group/mazdaprotege, under Photos section, in "Hank's Car."
According to protegetech.com, I am missing more than just the cruise control bracket. I am missing:
Mounting nuts 9994-01-003B (4 needed) I have 2
Vacuum sensor bracket FS8M-18-335; I have the wrong one FS8M-18-835
Bracket nut (3 needed): 9989-10-600
Cruise control bracket: BN5W-66-3AY
Rubber bushings for cruise control bracket mounts (2 needed): B6S7-13-349
Mounting guides for cruise control bracket mounts (2 needed): UE54-66-3A5
As an added bonus, the bar I received was all scratched up. Maybe that's why protegetech.com has this to say: "Sternly state that you want the tower bar wrapped up when the Mazda parts distribution center sends it to your dealer!"
WAY TO GO MAZDA! Geez, you'd think that you wouldn't have to deal with these kinds of things with factory backed aftermarket parts. And to think they've done this more than once. How ironic it is that I have had much better luck with non-factory aftermarket parts. They didn't even send directions and to make the install even easier, they didn't send the right parts!! If it wasn't for this website, I would have tried to install the strut tower bar and would have probably become so frusterated that I would have thrown the dang thing across the street. This POS part is going straight back to where it came from!!!
Newcar, sorry your kit is so botched.
They should send you a replacement kit, with apologies for the trouble.
Maybe I'll wait a little bit before ordering mine. Hopefully, their QC improves soon.
Make sure they return the credits back into your card....
I guess you can try the corksport bar later, once you've calmed down from all the frustrations this has caused you. The bar from corksport requires you to do some cutting of the regular cruise control bracket, but it comes as one piece, and you bolt it right on, so there won't be the problem of missing/wrong parts. Like you said, maybe you'll have better luck with aftermarket parts!
One question I have is whether the protegetech site has the parts count and p/n's right either. Can anyone elaborate on this? Otherwise I may send my so-called kit back as well.
the main pieces:
1. the strut bar.
2. the right strut bar bracket (driver side)
3. the left strut bar bracket (cruise control side). take a look in Meade's photo section, I have a couple close-up shots of what the left bracket looks like.
4. a cruise control bracket that's designed to 'hang' off of the left bar bracket, again look at my pics on Meade's site.
5. another smaller bracket that hangs off of the left bar bracket to hold another little sensor type of thing (look at pic)
The little stuff:
6. rubber bushings (I ended up using 5 total), remember you can take it off of the original brackets and re-use it.
7. small 10mm nuts, again I re-used ones that are already there, and ended up with couple leftovers.
8. four 1" nuts that will be used to mount the bar onto the brackets. They should be black in color.
9. a flat little metal piece that I used as a padding to prevent the new cruise control bracket from banging on the chassis. I mounted it under the cruise control bracket.
Mount the bar brackets using the nuts that are already there holding the struts. Remember to park your car on a flat surface before unscrewing those nuts.
www.protegeclub.com has an FAQ on parts needed to complete the installation, I didn't bother counting all the little 10mm nuts needed, since I more or less realized I'll have leftovers with what came with the kit and what's already being used. Just make sure you have all the big pieces and the 4 big mounting nuts for the strut bar.
You should be ok if you remember to reuse existing parts.
Take a look at my pics, sometimes pictures describes better than a thousand words, that's how I figured out how to put it together!
I'm considering getting the $30-40 strut bar advertised on ebay for older proteges. Its a little metal rod, with the right size brackets, and all the parts and instructions I'll need (according to a highly rated seller). Can't post a link, but should be easy to find - search for mazda protege strut, ipck the 88-98 protege link. btw, he posts another strut bar for sale every few days, so lets not bid against each other, OK!
Has anyone previously bought this from him, and is the quality comparable to OEM? Think it'll be worth the time and money to put this in my car, especiaolly considering the tire-wheel package I have?
-ashu
I went to tirerack and tried to figure it out using wheel upgrades. The weird thing is ...
1. upgrades for 95 DX, in sizes 15x6, 15x6.5 and 15x7 all will use 195/50/15 tires
2. upgrades for the 95 ES, on the other hand, same wheels as above (exact same list shows up fo 15") will use 195/55/15
Any clues as to the discrepancy in whee diameter? The 50 profile vs. 55 profile?
I'm not complaining, because it looks like I'll need 50 profile tires - but is something, somewhere screwed up?
or are the 95 (or 96/97/98) DX and ES sprung so differently that this is a valid size difference?
-ashu
http://www.miata.net/garage/tirecalc.html
Let's you mess with tire sizes and see how different sizes work compared to your current tires.
Working backwards from the 195/55-15 recommendation for the ES/LX, what is the size of the OEM tires on those? Is it 185/65-14?
So am I right in guessing that the dials and gauges (speed, rpm, odometer) are calibrated differently in the ES/LX from the DX for those years?
thanks.
I could keep doing this for months. I tried to put the bar on today and realized right away I was missing more parts. What happens next time when I get to a different step and realize I'm missing even more parts? Maltb, what should I do? I'm seriously considering sending it back and forgetting about the strut tower bar. It really isn't worth the hassle.
Since they published the Performance Enhancement products for Proteges in their last owners magazine, they should have the system more user-friendly. But, they can't improve it unless they know there are issues. Do you expect the dealerships and distribution centers to report these shortcomings? Well, they would, if they were diligent, but there are many ways for these things to escape notice (usually, employees or managers who want to brush problems under the carpet, as the saying goes).
On another note, has anyone gotten the Injen cold air intake or Borla exhaust for their Protege? The Borla is only for 2001 2.0L models.
check out www.protegeclub.com/forum, there are tons of people there that have the Injen CAI installed, as well as some Borla users.
I'll be happy to help with your question on purchasing new speakers for your 2001 Protégé. The rear door speaker locations in the 2001 and 2002 models are the same, but they are different in the 2000 model.
In the 2001 Protégé, there are rear door speaker grilles but no actual factory speakers. So, you will need to run new speaker wire from the radio to the speaker mounting locations. You can then install 6 1/2" speakers with a mounting height of 0.528" or less. This mounting height limitation restricts the choices to the following speaker models:
Infinity Kappa 62.1i
Kenwood KFC-1668S
Kicker 02K60
Pioneer TS-G1647
Polk EX602a
Rockford Fosgate FRC2206U
http://www.mazdadiscountparts.com/
I have never used them myself, and it takes them a while to quote prices (about 1 business day), but there prices are slightly cheaper than Mazdastuff.com. Shipping is free if you order more than $150. If anyone has tried to use them before, I would appreciate any comments concerning their service.
sure hope they'll get it right the second time around!
Question: I have some kind of a dark/black metallic bracket/gizmo attached bwteen the two windshield side bolts on the passenger side strut tower - whn I install the brace, shuold its brackets go under this or over this (respectively flush against the metal fram of the car, or flush against the bottom of the nuts?)?
Incidentally, I was unable to install it over the weekend as I did not have a deep enough socket to reach the nut - a large section of the bolt protrudes upwards!
TIA!
Guess you'll need to get a 'deep' socket eh?
check out the files section for eXcel sheet comparo
by Chikoo Feb 19, 2002
Nick, I got a couple of questions for you. My local B.J.'s Whole Sale Club is offering a $7.50 per tire discount on the BF Goodrich All-Season Touring T/A VR4 in stock. They are listed regular price of $73.99, not to bad.
My out the door price:
$73.99 per tire
-$7.50 discount
$66.49 x %6.0 PA sales tax= $70.48
$70.48 and $10.55 total install fee (mount, balance, new stems, and disposal of old tire)=$81.03
$81.03 total per tire
Ok, B.J.'s only carry this tire in the 205/55-15 size.
1.)How do your 205/55-15's tires fit?
2.)How do the 205/55-15's tires look?
3.)How did it fit on the OEM alloy wheel (rim fitment)?
4.)Any issue's with tire clearance in sharp turns or bouncing roads?
5.)What are your impressions of the 205/55/15 V-rated(BFG Touring T/A V4) tires, you purchased?
6.)Nick, any comments or tips would really be appreciated!
Your Friend,
Larry
*My out the door price:
$73.99 per tire
-$7.50 discount
*$81.03 total per tire
Excellent price...i paid $73.99 + 9.99 wheel deal + 6% tax....wish I had waited 3 months
Perfect fit
Check out the pictures link in Yahoo groups.
The look awesome, especially from the rear...FAT, PHAT....
Perfect. if u read the Tire fitment Handbook that u can find at the BJ's store, Michelin/BFG recommends this tires as "Plus 0" size for our car.
None whatsoever.
Overall good tires.
Reduced vibrations and noise on rough roads.
cuts through water puddles cleanly...used to feel a huge drag on the RE-92.
I maintain a 30 PSI pressure and the car now feels like a econo-luxo-sedan, especially in the passenger seat since u no longer feel the sharp bumps that make ur teeth grind.(I can now compare the ride,make that bump, quality with my friends Honda Accord 2001 EXV6.)
I have found that I can spin the tires If I lead foot at stop signs on wet roads....and also if I have to execute an immediate takeoff from a traffic signal into a left/right turn.
I never hydroplaned with the RE-92 poortenzas....nor with these.....never got the chance....always drove (still drive) carefully in wet, especially on descending ramps....maybe I don't have the courage to test tires at my expense
Best of luck!!
