Explorer on average, are near the top of their segment in reliability, and beat some comparable imports. But when something does go wrong, it's viewed as "the sky is falling"...While Honda has transmissions failing at high speeds, and Toyota has oil sludge/engine problems yet are easily forgiven. Something the media recently has been critisized over doing.
If a recall hasn't been issue, chances are it's affecting such a lower percentage of the vehicles population, and/or NHTSA hasn't found a need to require the manufacturer to initiate a recall.
As I've mentioned before, if a specific dealer hasn't been willing to fix your issue, you can try another, and/or try Ford's Customer support and document the issues till a resolution is made.
Many times the manufacturer has no idea there's an issue with the part, and goes ahead to install it. Us as consumers, will always run the risk of testing most of these parts, even if supposedly they have been used before-yet the formula changed a bit.
If you understand the structure of how dealerships work, you will understand that it's not Ford's fault directly how a dealership treats you. There's certain limitations overall, the dealership is seen as a service center, and outlet. Or for another example, it's like returning an item to your favorite dept. store...If one won't do it, you try the other, and the other.
You could contact the supplier and your own, and vent your frustration, although their contract with Ford doesn't require them to even read or respond to your letter. And because of the contract, it means Ford is bound to them till the contract expires. At that time, Ford will assess if they wish to continue the contract with a certain supplier. We all saw what happened with the Ford/Firestone marriage.
Now pertaining to the current issue, it only affected certain '04 vehicles, because that's when the supplier messed up. The problem was caught, and rectified promptly. In your case I would continue to press the issue till you reach a resolution.
I myself have been known to drive to 7 counties, to get a friends POS Passat fixed, over an A/C mold issue that dealer's didn't wish to touch. It was an "interpretation" case.... I SMELLED it, they didn't. Hence, no one wanted to bother. Found one dealership 190 miles away that did.... (4th time the charm though). But I'm annoyingly persistant that way, others might not be.
Well they did call (yes, a minor miracle IMHO) and about 2 days later the problem was truly fixed. I have not had any problems at all since then. I believe they (Ford) replaced the rear end gears,etc.. (minus the housing).
Patrick9 how many miles were on your 03 and I am assuming that it was under warranty. How many miles on truck post repair?
Had 97 Mountaineer. No mechanical problems in 24,000 miles.
Had 98 Mountaineer. No mechanical problems in 30,000 miles.
Had 02 Mountaineer - No mechanical problems in 35,000 miles.
Have 04 Mountaineer - No mechanical problems so far in 8,000 miles. Although transmission sometimes misses a shift. I'm not ready to quit buying Ford products because of it though, after this kind of track record, if the transmission does fail on this one, I'll get Ford to fix it. Plenty of time left on the warranty. If the truck turns out to disappoint me, I will turn it back in when the lease is up and get another one. After all of these great trucks, I'm probably due for one with a glitch, don't you think? Unlike some people, I don't expect perfection, because they're machines and machines sometimes break. I just expect it to be fixed as agreed, by the manufacturer's authorized dealer. And usually, they do that pretty well, I've found at my Lincoln/Mercury dealer here.
One other thing I should mention (see post just above). We also had an issue where it would feel like the transmission would 'slip' or 'shudder' when going around corners. For example, when making a right turn from a stop sign - you could feel a shudder or slip. I thought that problem was related to the rear-end whine issue, but it was not. This problem was fixed prior to the whine problem.
All of the above was corrected under warranty.
The changes are a bit more in depth than just styling. Other changes will take place engineering wise to improve the structure, ride, NVH, power, braking, fuel economy, response, etc.
Keep an eye out on the next round of auto shows in the next few weeks for more details. I'll also link as the information becomes public and I can mention more about it.
As for the ongoing domestic/import debate:
1. The main reason I bought the 2003 Explorer (I'm sure this is true for others as well) was $$ - 0% financing (72 month) + $2000 rebate + considerable discount off of the price (based on edmunds what people are paying). Try getting that deal on a Toyota.
And while the Toyota depreciation may be less over time, I think with a substantially lower initial price on the Explorer it 'all comes out in the wash' so to speak...
2. Although I do feel Toyota,etc...does make more reliable and generally higher quality vehicles vs. Ford, my gut feeling is that an Explorer is probably overall safer than a 4Runner or comparable import. The Explorer seems to be heavier - just bang on the sheet metal with your fist...the Toyota might need body work.
I had to move a bunch of RWD Explorers around our snow covered lot this past winter and they were able to move fine without getting stock.
Sure I had to See Saw fwd back fwd back to get through the berm in front of the truck that was about bumper high but it went through.
Incidently the 4x4 went through the snow like it wasn't even there.
As for Fuel Econ, its very easy to waste gas in either the Explorer or the V6 Escape when driving around town. There is so much power on tap that you will find yourself really getting on the trucks to get them moving away from stop lights if you are use to driving a car. These trucks can definitely move but you burn the fuel to do it if you aren't careful.
Mark
4 Runner 4300#
Pathfinder 4815#
Pilot 4431#
I realize that Ford often offers great finance/rebate incentives on the Exporers. However, and I learned this the hard way about Ford, you do get what you pay for.
My friend has a 4runner and he's had more issues with his 4runner than I've had with my Mountaineer, even though I have the rear-end whine.
The Mountaineer also feels much more planted in the bad stuff.
FWIW.
Can someone tell me if this would be a "plug and play" change or will I have to add any new wiring?
traveller, "Ford Explorer: Problems & Solutions" #2945, 18 Aug 2004 8:14 pm
Thanks again and happy holidays to you....happy motoring too!....
Ralph L
Take this example: on Honda Pilots, "HEAT BUILD-UP BETWEEN THE COUNTERSHAFT AND SECONDARY SHAFT SECOND GEARS IN THE AUTOMATIC TRANSMISSION EVENTUALLY LEADING TO GEAR TOOTH CHIPPING OR GEAR BREAKAGE Consequence of Defect: GEAR FAILURE COULD RESULT IN TRANSMISSION LOCKUP, WHICH COULD RESULT IN A CRASH." -that's off of a Honda recall notice!!! Failure? Result in a crash? At the least, you'll be stranded! And Toyota SUVs have that problem with the engine oil sludging and immediately destroying the motor. I'll take a whine or missed gear every now and then over a call to the wrecker!
My wife's '03 Explorer transmission problem does not appear to be the whine (at least not so far @ 14,000 miles). It is the jerking in reverse and at low speeds that is supposedly the transmission solenoid (which the dealer has already replaced). I have driven the vehicle since the solenoid was replaced and it happened to me one time. Due to the sporadic nature of the problem, it will never happen with a tech in the vehicle. We've been told to keep driving it, because no permanent damage will occur to the tranny (at least until my wife said, "Good, I guess that means if I do have transmission problems in the future (after the 36K warranty runs out), you (Ford) will be happy to repair it at no cost!" I guess the service manager has a crystal ball. What kind of idiot would make that statement without the ability to predict the future. He hasn't even felt the jerk that happens, especially when backing up. The first time it happened, my wife got out of the vehicle because she thought she had backed into something.
I do have to agree with the earlier post regarding Honda. When they have a known problem, they issue a recall and repair their vehicles. This is something the Big 3 need to learn (and practice).
What do I need watch for in this Explorer?
People with 4.6L V-8 engines.....On highway can you get 20mpg? Are you glad you got the V-8 over the V-6?
Thanks for your help.
Joe
Are you kidding??? There is a department called the Office of Defects Investigation at the National Highway Traffic Safety Administration that reviews consumer complaints, reports from NHTSA investigators, and manufacturers own TSBs. I'm willing to bet that the main reason manufacturers issue most recalls is not out of the kindness of their hearts, but because of findings from such boards and concern over potential litigation resulting from the defect.
Like I said before, I know a whole bunch of guys over at the State who all drive government-owned 2002, '03, '04, and '05 Explorers with anywhere from 20,000 to 70,000 miles on them, with NO complaints (except from the leadfoots who want their V8 Durangos back!) and there's at least 20 of these things. I've specifically asked if their trannies act up, any strange noises, "are any of your vehicles ever in the repair shop?" and they always think I'm crazy.
The ODI has investigated the Explorer and found it to be safe and reliable, as have Automotive Information Systems as well as Consumer Reports. If the NHTSA thought it needed to be recalled for any of these problems, it would be. That's that.
I'm not trying to say that one truck is better than the other. I'm just defending the Explorer against these posts which claim that it should be avoided. I bought my Explorer because it has real 4x4 with low range but if that wasn't important to me I could just have easily bought a Pilot. They are good trucks overall as well. Will an Explorer last as long? SURE! Go to eBay Motors, click on Ford Explorer, and sort by highest mileage. You'll see many original trucks with close to or over 200k, that still look and run great.
I just used the example of my Government buddies because they have the current generation. I have plenty others. My next door neighboor has a 1991 XLT 4x4 with 205,000 miles and it is his daily driver. He has had it years and hasn't had any major problems. My aunt has a 1997 with 180,000 miles. They drive it 300 miles on the highway to see family.
SECOND- As soon as I told my dealership what was going on with mine, they said it was no big deal as far as tranny life, etc. BUT were happy to order a kit- provided by Ford to fix the problem- which came in 4 days (they said it was perfectly fine to drive while waiting for the part) and was installed in two- all free of charge including a nice loaner. Problem solved! NOT time consuming OR costly, either. So how can you say the company doesn't acknowlede there was an error, and that they did not stand behind their product? The episodes here sound like crappy dealers to me. Find a dealer with good service- I know my dealer will handle whatever else comes up in the same manner.
So, again, in summary: IF there were serious problems with the Explorer, the NHTSA would not allow Ford to do nothing; and, Consumer Reports would not report improving reliability, as average overall- which they have. Sorry my posts are so long, but I like to back up my statements with verifiable facts and quotes/opinions of automotive experts.
One more reference for you to check:
Read Edmunds long-term test drive on the 02 Explorer. You will read at the end where they list problems they encountered. A Clunk in the transmission as well as a whine from the rear end. If these problems are so isolated it sure is odd that the 1 Explorer that Edmunds tested had these problems and so many thousands of others do not. As far as your experts you can't get much better than Edmunds! Good luck with your 04 let us know when she starts whining.
That is my counter point. I am not trying to say that every Explorer is perfect, or that every dealership will perform every fix available. But that's unrealistic for any vehicle from any manufacturer. That's why I used the Pilot as an example of a competitng vehicle from another reputable manufacturer that is giving owners headaches. Reading those forums it is evident that many of it's bugs took awhile to be worked out as well. It's a great comparison.
And yes, the experts at Edmunds noted in the 2002 long-term test of the Explorer that there was a whine in the rear end. And then in 2004, they awarded the Explorer the honor of "Most Wanted Midsize SUV under $35k," or a "vehicle we would most like to park in our own driveways." Which brings me back full-circle to my first post: the problems are minor.
So I do support the Blue Oval, for all future potential Explorer owners.
Also had a 97 Dodge Caravan LE that put 138K miles on it. Never had the dreaded transmission problem. It was a great Chrysler product.
I think Explorers are the best looking SUV's out there, and I know there are good ones and bad ones. I just hope the 03 V-8 I am looking at is one of the better ones.
Every manufacturer at some point has quality issues. How they go about 1)acknolwdeging it, and 2) fixing it, makes or breaks these guys.
With 400K a year Explorer production, it must be finanacial disaster for Ford to admit defective rear axle.
Toyota had oil sludge problem. First they blamed it on lack of customer understanding of oil changes!! Then when it got ugly, they said ..fine , we will replace the engines free up to 100K miles.
My 94 Accord had distorted windshield. Honda said it was normal. I went crazy over them telling me it was normal. At last, they changed it.
How bad is the rear axle whine? Do the V-8's have the same issue? or is it mainly V-6's? Did the 03 have the tranny selenoid problem too?
Joe
The tranny solenoid problem affects some of the 5r55-series transmissions used in several Ford products including the Lincoln LS V6 and V8. This tranny was used both with the V6 and the V8 in the Explorer as well.
Mine had a slight whine from the rear of the vehicle, starting at 15mph and fading at 20mph (in 1st or 2nd gear). My dealer said this was no big deal and was related to the delayed/harsh engagement. Sure enough, it went away when the solenoid job was done, for some reason.
Test drive the vehicle at various speeds in a quiet area with the stereo off and windows cracked. If you don't hear it, it's not there there; and, there is no reason to assume your vehicle will be affected in the future.
Mine also went away when the solenoid was replaced. I was very pleased. Then it resurfaced (same EXACT noise) in 3,000 miles......
Please see the Rules of the Road link above - it's ok to mention the dealer name, and that would make finding it easier.
(thanks Nvbanker).
First, the transmission fluid is a synthetic blend and some people are having alot of luck with simply changing the fluid (there is a rumor that the fluid mix being slightly off can affect how the tranny performs and cause soft, high-pitched whines). Notice that customers who have had flushes at around 30 to 50k are reporting extended mileage with no worries. When the solenoid job is done the mechanics have to take the pan off, but only the fluid that was in the pan at the time ends up getting changed. (FYI the solenoid is related to the flow and pressure of the fluid as well). I think this is why the noise seems to be related, and why changing only some of the fluid can have an effect (whether permanent or temporary). Let us know when you reach 30k, if a fluid change has an effect! (I don't think its necessary before 30-50k miles unless your noises/harsh shifting is really bad, where you think it might be wearing on the parts).
Second, the TSBs for the rear ends are saying something about improper fluid mixture, with a fix coming.
Wouldn't it be funny if all of this just came down to fluids?
Does anyone know if you can run full synthetic in these transmissions? My last car was a 626 ES-V6 with a 5-speed, and it started having some trouble shifting at about 60k. The service advisor stated some synthetic fluid would fix it. WOW, what a difference- I went from having to fight with the shifter to moving it with one finger, and it stayed that way for the other 40k I drove the car.
