Lexus IS 300 SportCross
Vivian - If you check out IS300.net, you should get a better idea in the General Discussion forum. I believe I read 1000 off MSRP is what people are getting.
I think it's more of a hatchback than a wagon due to the sloping rear hatch and the side rear windows sloping upward. Everyone who has seen it loves it.
You won't see a ton of them on the road like the Lexus 300GS or RX300. SportCross production is limited to 5,000 units for 2002.
I got around 18 mpg on my first tank of gas around town which is not great, but a significantly better than any SUV. Highway mileage is rated at 25 mpg.
Only things I would change are the busy chronograph dashboard styling along with the orange lighting. An all digital dash display would be more suitable I think.
There are some excellent deals right now and you can probably get a SportCross either at or below invoice pricing.
Overall, I'm extremely happy with mine.
Revka
Hatchbacks / Station Wagons / Women's Auto Center Boards
I noticed a momentary noise and small vibration through the brake pedal when rolling away from a stop after the car has been sitting for over 10 minutes and brought this up to the service tech when I brought the car in for a 30 day service. They reported that it was part of the ABS system doing some set up activity, so I still have the noise. I will ask to drive another SC during the 5000 mile service to see if they all do this.
I was also told by the service tech that Lexus will sell a factory turbocharger that, if installed by the dealer, will not void the warranty and will push the car to around 300hp. This will be availalble next summer. No pricing was given, but I did see a carbon fiber replacement grill without the big "L" for $800, so the Turbo won't be cheap. However the thought of an unbadged turbo charged SC is very enticing. I am also looking at some aftermarket suspension pieces that are said to lower the car about an inch, but reduce roll in hard cornering without affecting cruising comfort. This seems like a car that will enjoy being driven with spirit periodically.
Being 55 I don't fit the demographic for which this car seems intended but I'm real happy Lexus decided to sell it.
My main issues w/ the SC is the safety of driving in rainy/slick conditions (I've had a few bad experiences) w/ the RWD and no LSD/VSC available (w/ no nav). The VDC will be ideal for any harsh conditions and probably more practical in general (more room, better mpg, less costly? maintenance). The cars are difficult to compare since they are not really of the same class/category, but they are my top 2 picks.
Thanks, Andy
Also, about the comment about AWD not being good for handling, the AWD in the VDC and the Auto-WRX have a 45/55 power split all the time with 22% of the power going to the rear wheels thus giving a slight RWD driving feel - in normal driving. When more power is needed, front or back, the system redistributes torque/power rapidly and un-obstrusively, front/rear rear/front left/right right/left. The electronically controlled torque-sensing Planetary gear center differential which works along with a continuously variable multi-plate clutch pack, rapidly sends more torque (upto 90%) to the rear wheels, when needed (for instance when accelerating). When situations demand (like when the rear wheels are on a traction-less surface), the AWD rapidly sends more torque to the front (this is done through terrain sensing algorithms) before slip occurs . The LSD also transfers power side to side, which makes for superb handling, primarily because you have the appropriate amount of power on the correct set of wheels on the appropriate side of the car. The SUVs and 4WD pickups you mentioned use ancient, out-dated systems whose 4WD is designed more to go in a straight line and not for turning or handling. In the wrong hands, those are sure-fire recipes for disaster. Also, those ancient 4WD systems have to be separately engaged and ought to be disengaged when reaching dry pavement. They prevent any handling finesse and force the vehicle to turn like a semi-truck with a lot of under-steer. This bears absolutely no resemblance to the VTD-AWD (Variable torque distribution-AWD) of the VDC or the Auto-WRX.
Also, it needs to be mentioned that this advanced AWD of Subaru, is only available in the Auto-WRX and the VDC. It is not available in any other Subarus, including the manual-WRX. This is the exact same system (in a much lighter duty form) that are present in the World Rally Conquering Subaru Rally cars, where the brutal driving environments demand the very best in handling and reliability. The system present in the manual-WRX is not that sophisticated.
But it goes without saying that in-spite of such advanced AWD systems (like the Auto-WRX/VDC AWD) that enhance handling and safety, it is a very good idea to be aware of the "physics" of the situation and not try to push the envelope beyond a reasonable level. Anybody who grows over-confident and does stupid and unreasonably risky moves in such safe vehicles, do create scenarios where the vehicle is blamed for the stupidity of the person driving it.
Later...AH
Revka
Check out the above URL and you can see a rather spendy rack that you should be able to get some attachments for. You might be able to shop around on the web and find a better price for this rack if you are interested. is300.net has some postings which list most/all of the known IS300 aftermarket parts suppliers.
I also saw some form of Yakima rack on a SportCross at the local dealer that hooked under the lips of the upper door sills. I didn't like how the door seals were compressed around the brackets when the doors were closed though.
http://is300.net/forum/viewtopic.php?topic=13291265&forum=2&2
http://www.laautoshow.com/project.asp
Read the full story here: Spin Around Town: 2002 Lexus IS 300 SportCross, by Kim Liz. Let us know what do you think. Thanks for your comments.
Revka
Hatchbacks & Station Wagons Boards
There is some speculation that Lexus over reacted to 9/11 and cut back production too much. They are supposed to be building more cars now. No info on how many of them will be SportX.
Nissan's only hook is the HP. They show you pumped up commercials with FWD family haulers doing J-curves knowing people's eyes will get big - hoping the whole time they'll ignore the rest of the car for obvious reasons.
HP does not a car make.
It must be tough having a WRX and a SportX.
I'd be interesed in a few more comparisons between your WRX and IS300 Sportwagon.
Stephen
For me on an every day basis the SportX is a better car from a comfort and convience standpoint (as it should for the extra money) and it just rides and feels more solid to me than the WRX did.
For the additional money you get some things as standard equipemnet that are options on the WRX. In other cases there are some features that aren't available on the WRX. Some of the thing I like are climate control, electric seat adjustment, leather seats, heated seats ( our 1st car with them the wifes says they are now a must have), heated mirrors, sunroof (a must have for both of us), self level HIDs (we have both grown to love these), really nice 160 watt sound system, really smooth inline 6 engine (4 bangers just aren't as smooth), E-shift automatic (IMHO a lot better than the WRX auto), great handling, and superb steering feel. My wife also likes the security of brake assist and skid control but I don't care for the skid control (she had a near miss where the brake assist and skid control cut in; she was impressed). I am sure there are a few more things like longer warranty, a couple of free services, firstaid kit, tool kit, homelink, and etc that aren't really that big of a deal. To me it was all worth some extra money (Lexus dropped the price last month so I paid more than you would today).
I also like the unique styling of the SportX; I see WRXs every where but I have yet to see another SportX on the road.
Here's a pic of my second rate WRX wagon...tee hee!!
I was looking more for comfort than performance so I went for the the SportX. It seemed to fit my needs and price range better than some of the other cars I was looking at besides the WRX.
As far as manuals go I will take the E-shift. If the WRX had a similar gearbox and a sunroof I might have one in my garage instead. I think I have exceeded the quota for manual shifts during a lifetime. I really don't miss them. The future seems to be headed towards the manual-matic gear boxes. In the WRX rally car don't they only use the clutch from a dead stop?
Have you had your car on Pacific Raceway yet? Turn 3A can be a little hard on brakes but it is really a fun track. It is nice to see it being renovated. I hope to turns some laps there this year, but I will have to manually shift the race car.
Thanks for the compliment on the wheels. I actually removed the ski rack today and washed/waxed. Spring finally came to Seattle today. We had snow just 4 days ago...crazy!
No, I haven't been to Pacific Raceway but knew that it was being renovated. I think that's great and hope to visit soon.
Stephen
Any SportX owner with some insight into my upcoming decision-making process? Red with power/escaine pkg intrigues me most...
I believe the World Rally race-cars have a true clutch-less manual (clutches that the driver will never touch or feel but is available underneath), similar to the BMW SMG.
Later...AH
Note to self: check the "limited slip dif." box!
I stopped in at Magnussen Lexus in Fremont, CA today at lunch, but nary a SportX did I see. I looked at theIS interior, which I like quite a bit, though it seems a sticking point with critics.
As for the X-Type, it has a look that's hard to get over, but I love the utility and ease of a small wagon. And the SportX is the best looking wagon I've seen in a while. The fact that you can actually drive it means that I can get over my coupe fascination, and still have some fun to and from Home Depot; the long way...
My car came with a full sized spare alloy 17x7" wheel with 215-45-17 tire
So the only down side to having different size tires on the SportX is you can't rotate the front tires to the back (the tires are uni directional just as they are on the IS300 sedan, so you have left side tires and right side tires). A BMW 3 series with the sport tires and wheels is the same. The spare on the SportX can be used temporarily to replace any of the wheels.
Salesman tend to not be very technical and also not accurate in their forecasts of what Lexus or any other Mfgs is going to do; they want to sell what they have on the lot. I have seen nothing, in the Lexus boards, saying that the SportX will or won't be here in 2003. I am not really worried about it. I like the car and enjoy not seeing a SportX everywhere; 90% of the parts are the same as the IS300 sedan.
The sport wagon/hatchbacks are going to come back. Lexus might be a year early with the SportX but we will see a lot more cars like the SportX in the future. The hatch really makes the car a lot more practical on a day to day basis.
You got THAT right, they already have! All those "crossover" vehicles are essentially small wagons or hatches in varying shades of tall. One of the reasons I really like this car is that it offers all of the utility and more performance without that clumsy, ungainly look.
I admit, I am used to, and like, the ability to rotate paws. Not being able to means, at least for me, buying new front rubber in fairly short order. OTOH, I imagine I would be saving the difference on the rear treads, which should wear more slowly, I should think. Unless, of course, I decide to go donut a parking lot (not likely)!
Do you know anyone who has gone for the 16" rims? I can't imagine they're the popular way to equip, but I'd be curious to hear about handling deficits v. ride quality improvement.
Maybe boxerlover was suggesting that the different rubber sizes (front/back) would be discontinued in favor of 17x7s all around?
As far as tire wear goes I think the rears will wear out faster than the fronts. The reality is sport rubber on the sporty cars will last 15-20K miles. Less if you do track days and/or AutoX. The sport tires really improve the handling of the car wet and dry and to me it is worth the price of admission. In my previous hobby I would change tires on my racer based upon hours (try 3-4 hours) not miles. Tires for the SportX are a bargain in comparison.
