Honda Civic Si / SiR 2005 and earlier
Maybe Koran's criminal law, closely followed by the Taliban in modern times, had the best solution for thievery. You steal first time, they chop off your left hand. Steal again, chop off your right hand. And, I think, it also involved branding "thief" on the forehead. This is how I felt when my car was violated the first time.
AndySanDiego
I'm interested in a new exhaust system for an ’04 EX sedan. Today, I went to the local Meineke Car Care Center. For about $300 I can get a new system. They’ll remove the stock resonator (a small muffler) which becomes straight-through 2” pipe, then a series 60 Flowmaster muffler (not Series 40 which would be too loud), and a chrome tip. The manager, said it will result in about 10% horsepower gain – enough that I will really feel. That would take it to 140 h.p., Miata territory.
My question is whether this will be too loud, and if it seems like a good idea in general. Any comments would be appreciated.
The 10% power gain would probably happen on a very restricitve stock system on a korean or other poorly designed vehicle. Don't you think Honda would have installed the most potent street legal system on your car to boast 140 hp from factory?
For four-stroke engines, reducing exhaust backpressure is accepted as a way to get more power. Racers of stock cars often replace street exhaust with system of less back pressure when at the track, and noise limits often are set to limit just how open they can be. You better bring ear protectors to a Formula One race.
Another example is most people who buy a new Harley change the exhaust as the first step (and rejet to take advantage of it). I have been there/done that with a new Harley, and you can definitely feel the difference.
I think backpressure tuning is an issue with two-stroke motorcycle engines.
It's worth it to me to spend $300 now for better sound, even if the horsepower gain should turn out to be modest. I'm tempted to spend $80 (times two)to dynomometer it before and after.
Did I kill my engine already?
After all, I got this wood or paper burning smell inside the car (maybe from the engine). Can anyone tell me if I damaged the engine badly?! I didn't notice anything unusual from the engine, but somehow I am a bit worrying...
(mine is '02 Si with 16k)
Any opinion will be appreciated.
This reminds me of a joke that was floating around a while back, it was called "Only in America"
Only in America you get double cheeseburger with supersized fries and a diet drink.
Only in America Pizza Hut guarantees 15 minute delivery but Ambulances can take up to 30 minutes.
Only in America.....
If you are after the noise, then I have a few solutions for you. One, burn a CD with exhaust noise from a 1983 Chevy Cavalier and listen to it. Second, drill a hole in your stock muffler, it will make it louder.
Manual is your friend, my friend.
I was running with a Mustang unless it was an auto mustang with a 4 or 6 cylinder, pick your fights wiseley.
elissa
Sorry for continuous questions. I just need to get it out of my mind.
You bounced off of the "rev limiter". Most cars have rev limiters for the engine's sake. I'm not sure what honda's method is but most rev limiters work like this:
When you pass red line by a couple hundred RPM the ECM :
1) Starts dropping cylinders one at a time until you cannot rev any higher.
2) Limits the fuel flow via the injectors to barely nothing.
3) If you completely ignore the above events the ECM (electronic control module) will try to shut the engine down.
As you can see the above events will make your tach go a little crazy.
As for the car, I did too reach the "red zone" when my car was 3 months old and racing. Engine went off but nothing afterwards.
The clutch issue, i had it twice, and got it checked by Honda, and after a day in the shop problem solved.
The one that concerns me the most is the steering wheel, a couple of weeks ago i was driving the car fairly loaded (more than i normally do, but under the maximum load) and noticed this creaking sound coming from the steering wheel, it kind of sounded like a friction problem from inside the car, not the engine area, dealer couldn't find a thing.
About the tires, back in May I changed the original Michelins for Bridgestone Potenza 950 (i think that's the model) and i love/hate them. I love the grip, but it feels weird, may be that sidewalls are too soft, but it doesn't corner like it did with MXV's, in the highway it get a little scary, when changing lanes rapidly, it kinds of sways.... Anybody had any of the problems listed????
Thanks and good seeing you guys again.
Apparently, there was a redesign for the steering components of the 03+ Ep. But lots of problems for 02 drivers.
I want to buy a complete A/C unit to fit it. New or used.
How can I find one ??
Dennis
When I bought my 87 Chevy Sprint Turbo I called the chevy dealer a couple months later for AC install. They gave me the name of the people they use and I went there. Cost was $700 then.
Solution: Clutch piston shaft lubricated. Problem not only solved, but the clutch pedal action much smoother than ever. Quick and simple. (Why on earth are dealers, as some report, replacing the hydraulic components?)
Problem #2: Creaking steering at slow speeds (aka “coffin creak” :-)
Solution: (Tentative) “Re-torque the damper shafts.” That’s Brit-speak for properly torquing the bolts securing the front struts/shocks. See further thoughts on this below.
Regarding #2 above, I found the creaking noise unlike anything I could think of that would require strut replacement as some dealers have done as instructed by one TSB, apparently. Our ’02 Si creaked at low speeds and large steering deflection, such as in parking maneuvers. Low speed sharp turns produced creaking towards the end of the steering travel. We had this for some time, but it went away. Haven’t heard it in awhile.
But we took the Si in for it’s first and only warranty service to correct a few problems that we accumulated over the first 33,000+ miles. We’ve subsequently learned that there have been a couple of TSBs that may address this problem. The first TSB recommended strut replacement, which at least one member here had done. I was skeptical that strut replacement was necessary. Apparently, the second TSB notes that at least one bolt securing the struts had not been properly torqued at the factory during assembly.
Now THAT makes sense to this man. The creaking comports with something not being quite tight enough. Not so loose as to “clunk,” but just barely not-quite-tight-enough to “creak.” Our mechanic, an ex-Trans-Am crew chief (very, very good, in other words), pursued our “complaint,” found the second TSB, checked the bolts, and found that “Yes!” one of the locking bolts (gold anodized, he said) was not tightened properly. He re-torqued them for each strut.
So, did that fix our problem? Can’t say, since the creaking had already gone away. All the same, he found “loose” bolts, and torqued them to spec.
I’ll be surprised if this problem recurs.
I love this mechanic; he’s a can-do, solution-oriented, honest professional. He’s the best, I trust him, and I’ll follow him to whatever dealership he goes to so long as he can work on our cars on the rare occasion they need attention beyond the work I can do.)
Naturally, those who had struts replaced (probably needlessly) also presumably had the new struts PROPERLY bolted in, which solved the problem, too, but it likely had nothing to do with the new struts -- just proper installation. The Brits don’t have a good reputation for bolting automobiles together.
I’d be interested in reading whether these solutions to these two troublesome problems work for the rest of you, too.
Let me know, won’t you, please?
I believe Honda corporation means well, but sometimes they need guidance, as do all of us owners out here who enjoy our fine cars and just want them to work, as I like to put it: as well as the design and materials permit. (Actually, that’s asking a great deal. I’m demanding. ;-)
Kauai (a satisfied Honda Si owner this evening :-)
I just purchased a mint 1993 Civic Coupe, but it did not come with A/C.
I do want to install air conditioning. Does anyone know where i could buy an after-market kit or a complete unit from salvage.
And who would be the best in the Maritime Procinces to install this besides a dealer ??
Please reply,
Dennis
Like I said earlier to check out JCWhitney, and they do infact have add on a/c system.
http://www.jcwhitney.com/autoparts/ProductDisplay/s-10101/storeId- - - -10101/makeId-1000117/p-1842/c-10101/catalogId-10101
You still need to find an installer, who will charge and arm and a leg for installation.
p.s. You should not expect people to do your legwork. Take a saturday and drive around in your neck of the woods, from one shop to another and ask if they would do it. Some may even charge you less with install than it is from JC Whitney.
If you have stock wheels and tires, the combo is very capable of mild to medium snow duties. If you are moving to Alaska or northern Minnessotta, then you should invest in a set of steel wheels and snow tires from http://www.tirerack.com
elissa
I drive a Forester now, but may buy a Si as a replacement. My last Civic was a 92 Si, it was one of my all time favorite cars that I've owned. That's why I lurk here.
http://www.nokiantires.com/newsite/tiresub.cfm?cid=1&sid=1
Chuck
elissa
And no, it's not easy to drop the S2000 engine in a Civic or RSX. It's been done, but it's not easy. It's meant to be mounted longitudinally...
First of all, if you are interested in the new Si, search for a site dedicated to the new Si. The new Si body code is EP and it is a Hatch search you shall find.
I think the Spoon Si is a hype. An F1 engine with 14,000 RPM redline would be completely useless in street application. I would suspect that you would have to run on high octane which is not available from your loacal "Gas mart".
Civic Type R (CTR) in its JDM rendition produces 220 hp, 200 for Europe. But some people in the US have transplanted a K24 from TSX into the Si with much better torque response than S2000 engine. The RSX and Si are twins and most parts are interchangeablem including a more potent mill from the RSX type S.
CTR is available in this country at $25,000 without A/c, radio nor sunroof. Are you willing to pay that much for a Civic? Most people won't, this is why CTR is not sold here. Most people who whine about the lack of CTR are not capable of footing a $25K car purchase, and people who can buy a $25K vehicle, would not buy a Civic. TSX is a pretty sensible alternative to me.
That site also presents the Mazda Ibuki concept as the next Miata, but that has been pretty well debunked in the media. So I'm not sure how up to date that site is.
Chuck
