Toyota Tundra
I want to buy a Tundra but am concerned about pulling a 5000 pound travel trailer. Not a fifth wheel. We will do some mountain trips and do not want to lose speed on grades of 6% or so. Will it do it? Thanks.
http://www.trailerlife.com/test/0002tundra.cfm
In short - the Tundra is as capable as any other 1/2 ton to tow the load you are talking about.
People use small trucks to haul travel trailers all the time, so it's not a problem for the truck. It's just an issue of how comfortable you can be sharing the right lane with the older motor homes, getting the same fuel mileage also. Strong crosswinds are always a fact of life if you travel in the west. Stability of your combination is always a concern. Long wheelbases are more stable.
The seldom appreciated factor that makes hauling travel trailers uncomfortable for light trucks is wind resistance. People intuitively think because you can accelerate briskly, maybe even power up a hill, that it won't be straining all those other times when you're on level ground but facing a strong headwind for 100 miles, unable to exceed 50 mph, steering wheel cranked to the side, and your family riding with white knuckles and clenched teeth. Travel trailers punch huge holes in the wind, and have aerodynamic efficiency equal to towing a parachute behind you. A 5000 lb trailer, on level ground, can be just as hard to tow as a 7000 lb trailer when you face opposition from the wind.
I have lots of friends with travel trailers. And I myself have a 25 ft 12,500 GVWR motorhome with Ford 460 V8. They get mileage towing as bad as mine, with no significant speed advantage either. To a man, all of them who don't already have power stroke diesels, cummins, big blocks, V10's etc are constantly discussing the merits of getting one.
Just the most recent example, my friend Doug Linder bought a Toy Hauler travel trailer nearly identical in to the one in the trailer life article referred to above. He has a Ford F150. Now has the new trailer, now looking for a diesel.
The 5000 lb. trailer in question would be easily towed by the Tundra. Quad had to get the diesel Lemonado because of the weakness of his 1/2 ton Lemonado.
If you get a Tundra, you get a truck built to work. The lemonado is fine for towing a couple of bags of groceries - anything else it will break quick. They use those weak S10 drive trains.
Just wondering......
Bama- why the negative input towards quad? he's simply trying to point out the obvious to a perspective buyer. does "experience" even ring a bell in that negative attitude of yours?
you're still ticked off about being ripped off and it seems your only too happy to point more people in the wrong direction, instead of safety. hopefully there's only one of your kind.
Trailer Life magazine, who actually towed 6500 lb through the Sierra Nevada mountains in mid summer with the Tundra said:
"That said, the Toyota pulled as well as any of its Big Three counterparts and yet, when not in tow, the Tundra was nimble and veritably attacked the winding mountain roads. It handled and responded akin to a smaller version of its actual self. The steering was tight, the ride was distinctly not like any truck we've driven lately, and, pushed to its limits, the Tundra accelerates 0 to 60 mph in a rapid 8.1 seconds. It seems the Tundra is more than able to take on its intended half-ton-rated counterparts in the U.S. light-truck market." Emphasis added.
sorry meeker, but you should read bama's responses to other members in the "Tundra vs. big 3 topic". you'll see that this individual is here to simply annoy people.
red
Are you STILL on that "Mah Truck is bigger" illusion?
Let's see:
1) The Tundra has 3" more ground clearance. Even Chev admits this.
2) The Tundra LOADED with 1200 lb. stops quicker than the Chev EMPTY.
3) The Tundra hauls more.
4) The Chev is making Hyundai build quality look good.
5) GM sales have DECREASED 16% since last year. Toyota set sales records. Could this mean that the consumer has realized that Chev is selling expensive junk?
6) A comparably equipped Chev only has 400lb more towing capacity.
7) The Chev has those weak S10 drive components (they will be breaking quick).
go in the right topic and we'll talk.
don't even start on this 3' GC thing again, cause you know that's an out right lie.
-bottom line........tundra= bad possibilties when towing more than it can handle.
Are you saying that you need a 3/4 ton to tow anything over 5000lb? I would think that a lot of 1/2 ton truck owners would disagree with you.
I might admit that a Chev can't tow more than 5000lb, but a Toyota?
We have to talk credibility here. Trailerlife magazine actually tested a Tundra towing 6500 lb and posted the results. Quad or Red assumed a new identity and posted otherwise.
I am now off to enjoy a drive in my black tundra with my wife on a beautiful sunny day in Vancouver. Maybe go up one of the local ski mountains without anything in tow.JH
Everyone please have a lovely day
In trailer life they gave the truck high marks but indicated it got only 6.9 mpg when towing. Do any of you know if this is an isolated case or it is what I can expect when towing?
Thanks again.
The question I have, since you seem comfortable enough with the notion of a Tundra pulling a 5000 lb travel trailer, is why the concern for fuel economy while towing? Seems to me, the logic you are applying is that it will only be occasional. If it was a full time habit, I think you would be asking more pertinent questions.
In case I havent here goes.
The 4.3 V6 that you can get in both trucks was originally in the full size trucks, so its a Silverado drive train in the S10.
Read it slow and at least 4 times maybe then you will understand.
Harry
Now talk about real deal !!
You take care now
now start a topic about a REAL truck and there's bound to be some good conv.....
One thing you will want to research is that the Silverado you can get towing suspensions, all the trailer wiring already hooked up, a towing hitch for about 1/2 the price (If you were looking at the Tundra limited you can't even get a hitch), on the Tundra you are going to be closer to maxed out witha 5000 pound trailer than you would be with the Silverado (safety buffer), I'm not quite shure on this but can you even get a 4.10 rear end in a Tundra?
I would say 2500 would be the best choice, but it you don't want a 3/4 ton I wouldn't limit yourself to the Tundra the other three are awesome trucks.
Sorry Oby, not trying to bust you too much. And no, not the second-hand stuff either, just the idea part. We all know who is the culprit in denial... Won't mention names, let sleeping dogs lie...
" Towing -- Our test Tundra easily towed a Toyota Epic ski boat/trailer. In fact, we had to keep checking our mirrors because it didn't feel like we were towing anything. Even when throwing the Tundra through curves, the trailer tracked behind the truck like a train and the driver had full control. There was no "driving" of the truck by the tow vehicle."
"Performance wise, the 4.7 liter V-8 is world class. Jump on the pedal and get instantly rewarded with a solid launch and quick acceleration. Toyota's published 0-60 mph time for their 4x2 model is just 7.87 seconds a full 1.6 seconds faster than the Chevrolet Silverado, the quickest of the competition. Passing time is just as impressive. With a 6,500 lb. trailer attached, the Tundra clocked a 40 -60 mph passing time 14.73 seconds 4.37 seconds quicker than the F-150, the fastest of the competition in this category. When you are trying to get around a slow tractor/trailer combination or get around a vehicle on a hill, a difference of over four seconds between the Tundra and the next closest competitor makes a huge difference in the margin of safety."
These quotes are from Truckworld, someone who actually towed something with a Tundra. But we don't want to cloud this topic with facts. By the way - what breed is your "sleeping dog" expert?
You all take care now .. Truckrme - RIP
Ryona a bob ?
thanks bama for pointing out the tundra's deficiencies.
You can flush that crap right down the Toddy!
"You can flush that crap right down the Toddy!"
What the hell is a "Toddy"?
Does the fact that Quad's buddies post their email addresses make them more credible? Inqiuring minds would like to know!!!
