Acura MDX Accessories and Modifications
I've had other problems with my MDX (long story) due to dealer's error. They ended up replacing my X with completely new X, hence, I have to get the PPF reinstalled again. Once I have a month to drive it around, I can provide feedback.
The previuos X did get the PPF installed and you can hardly tell that it's there. That's all I know since I didn't get to drive it around much.
Try a different dealer and try a Honda dealer. The Pilot has a similar kit.
I did not buy the kit.
Does it reduce or increase wind noise? Does it really help in rain or snow?
Does it accumulate dust in the crevice that becomes harder to clean?
Firebird EOU, The Tailgate Deflector help to keep dust off the rear window. It doesn't do much to keep off rain or snow, and no noise differnce.
many thanks
There is a LOT of integration with the car including voice recog. that controls the nav. itself and rear view camera that comes w/nav.
If you look under the front passenger seat, the right floor wire harness comes out from under the carpet near the console, near the left rear of the passenger seat when the seat is in the full forward position.
If your car does not have this harness, adding it does not look like a big labor job.
Has anyone put in upgraded bulbs in the low/high beams? I have used Sylvania silverstar's in my other truck and think they are way better than the OEM lights.
In general I think the MDX lighting is pretty good. I was reading that a lot of people upgraded the Low beam bulbs?
I was considering upgrading all 4 bulbs, 2 9005s for the lows and 2 9006s for the highs. Thoughts? Opinions?
My MDX came with the headlight aim way down. Once corrected, the standard halogens did fine with respect to distance (better than the xenon TSX loaner I get when the MDX is in for service and better than my friend's xenon BMW 530i).
My aging eyes like the extra (white) light the Silverstar bulbs produce.
There are other bulbs, usually in the 80w power range, that are not legal for street use. These are very nice and do give added distance. They usually cost less than Silverstars too.
Around here there is so much traffic at any hour that high beam use is nill. If I was considering changing the high beam bulbs I'd lean toward the high power 80/100w bulbs.
BTW, the beam spread/pattern on my old Avalon is much better than on my MDX. I can see more even with OE halogens when driving the Avalon than I can with the Silverstar MDX.
Also, I've read a lot of references to hondaacuraworld.com but find the site to be worthless. Did it used to be different and actually offer accessories instead of simply links?
The best site for Acura accessories that I've been able to locate is handa-accessories.com - does anyone have any others to recommend?
Is it a whistle or just noise? Sometimes sunroof weather stripping can leak air...I have had other cars where when they whistle, I treat the weatherstripping with silicone lubricant on a paper towel, which eliminates the noise.
Thinking about opening it up all the way and powdering it or something. Other MDX cargo covers make noise or did I get a bum one? :-(
It's the only interior noise I have...
Ralph
I never had a problem with any of the 4 systems. Bought my MDX in Sept. but haven't gotten around to having it done, yet...
But it would be nice on long trips. Maybe I'll do what you did. Sounds like it works fine. But, how is the sound??? Just read a c/net review that said it wasn't that great, but that the factory battery was fantastic at minimum 5 hours. Do you have a cig lighter adaptor?
Ralph
The only thing the panasonic doesn't have is a carrying bag. I used the bag for my video recorder. The lv70 while only 7" fits right into the rectangular hole in the fold back top. I have a handy-bundler that I used to create a plastic tie to put over the player to hold it in place for hard stops, etc. Any plastic wire wrap would work...since the foldback top is triangular when you push it over it gets tighter and holds it in place well.
A few complaints...the volume control is manual, a dial on the side of the unit, a digital controller would make it easier to not turn it up too much or down too low. Second, after 2-3 years the screen has gotten a little digitized, but not really noticeable. Otherwise it is great. Read my review on Amazon about it. Check out epinions.com for the best pricing going.
So it has an audio out that you plug into one of those tape adaptors for car speaker sound?
And the AC adaptor goes into the middle console outlet and provides a 2 prong outlet?
Ralph
2. On long road trips I plug the outlet adapter into the dash outlet, put it on the passenger side floor and then plug the dvd player power cord into that. The adapter provides a 3 prong outlet.
The battery on the panasonic lv70 is great. We get at least 2 movies on a single charge. (4-5 hours usually)...however we use the power adapter to spare us from a movie ending while on the highway and having tired kids put on their own show.
I found no significant difference in distance with Silverstars, but the the higher color temp makes everything appear more white and easier to see, much like HID headlights.
If one factors in the bulb life, Silverstars are rather expensive. At about $40 per pair they will cost about $250 or so over the same life of the OE bulbs.
