Visitor Agreement.
Years ago lived in SF and Porsche was the hot item there-friend had his stolen and the cops only kept them on their hot sheets for 2 weeks in SF. Yep it is a market driven society which includes the crooks.
Maybe our "resident expert" can enlighten us regarding this problem.
I keep reading little problems one right after another with the V-6. Such as pulling right, brake noise, and rear rattles.
Thinking I will talk to the local brake shop, and see what they say. Probably will end up pulling the pads and putting some brake quiet to see if it eliminates the problems.
My only experience with disc brake noise was with my VW van-the pads wore much more on one side and got wedge shaped-could only get 20K or so out of them before they started making a racket-had to get some high performance pads and for some reason they worked ok-no more squeaks or strange wear patterns.
Oh and thanks again for the advice on the emissions control problem I had.
You're going to hate this, mikegold, and I know you won't believe it either when I tell you that I haven't heard any brake noises.
And I keep trying to get a V-6 to pull to the right and that hasn't happened yet either.
That's not to say some cars may have these problems.
"The Accord has a firm yet absorbent ride that's steady and composed on highways, supple and controlled on bumpy roads. The cabins is very quiet, though road noise is not as well muffled as it is in the Camry or Passat. A taut suspension and responsive, communicative steering help the car feel agile, though its 40-foot is a bit wide."
"The well-finished and spacious interior has a high-quality look and feel and comfortable seats five adults"
"We expect much-better-than-average reliability"!
I think that this has been the best review of a new Honda Accord to date. Comments please!!!!!
this is what happens on mine, when the clutch starts engaging in a drive gear, I hear the front brakes click. When I come to a stop w/ the car out of gear, and come to the stop, same thing. I'm thinking that it may be the shims/pads because when you stop in an Auto, te engine is still trying to "pull" the car forward, while if you have the clutch out, the engine is fully disengaged and the car will usually "rock" a bit. Then again, maybe it's just my car... curious as to if it is repeatable on another car...
Two I'm getting an unbelievable amount of brake
dust especially on the front and with only 600
miles... is that common, what can i do if anything about that ???
back too. Even though it's minor that "sooty"
look to the wheels takes some luster away from owning a new car...
I hope it's not a long term thing. AT 1000 i have
my first scheduled oil change(free).... I'll check with service about the brakes then
Otherwise the car's pretty solid... I'm glad i bought it.. how bout you ???
http://pinnaclewax.com/leathercare.html
http://www.finishfirstpolish.com/
It has to do with the non-premium grade brake pad's they use on new vehicles. If you decide to, they make "dustless" brake pads that are supposed to practically eliminate this problem, supposed to have better braking power too... You can check into it if you like, should be roughly a 1hr job... depending on experience...
http://www.tirerack.com/brakes/ebc/greenpads.jsp
Tots $1 each time somebody
clicks on the Toys For Tots link on their homepage!
http://www.excedrin.com
Go here then click on the 'Toys For Tots' link- NO
CATCH. JUST DO IT... Pass
this on to all you know before Dec. 31
Happy Holidays!
1. Two serpentine belts need to be changed.$144
2.Distributor cap,rotor,wire system change $222
3. Break fluid replace,flush $52.
4. A/C to Heater turning knob(switch) is not working. To inspect, $134
When I check the web, serpenting belts cost $15 each. Distributor kit cost around $50 bucks, and break fluid is around $30. Is this guy trying to milk money from me? Not sure, what to do ? Thanks in advance for your valuable help.--Bill
I would contact your local AAA club to get a list of approved repair facilities in your area.
Take it to a dealer of an honest imdependent who knows Hondas!
Your guy sounds like a crook!
Rotor, distributor cap, wires, plugs and an oil change. That is a freebie if you have under 150K on the clock. Two serpentine belts to replace-must be the power steering pump, alternator and ac-way too much money for that. Have u had the timing belt changed-should be changed at 105 to 125K-then you can have the drive belts changed-never heard of anybody calling them serpentine-those things are found on FORDS.
Yeah don't go back to this guy-go to a junkyard and find a heater control assembly-pull it out and replace it yourself. or use google and find a honda parts source online.
Oh the extended warranty is useful as I am having problems with my emissions control system and honda paying for it all. I think my problem is a heated O2 sensor-they cost about $200 from honda.
As for the serpentine belt... uh... no. You need 3 belts. A/C, P/S, Alt. Many places will do a full tuneup for you for about 150-200 and change the belt, spark plugs, wires, rotor, cap, check your valve clearances, and even do an oil change... Check your local dealer... If you are over 90k on your vehicle, I would seriously consider having the timing belt changed... You can probably get it all done for about 6-800. And not have to worry about anything for 30k mi.
Never heard of a vehicle needing a brake fluid purge... that's a new one on me. Usually when you change the pads out and bleed the brakes you do a sort of purge...
Are you sure there is no serpentine belts for this car? In online websites, they sell belts for this model. I am taking the car to a friend's servicetech, to get his opinion. Thanks much.
Bill
no serpentine belts on a honda-at least on yours.
4wd???
Sometimes drive belts are all referred to as "serpentine belts" not sure why... just a generalization. A "Serpentine belt" will usually drive all the accessories such as A/C, P/S, Alternator, etc. Your Honda should have all separate belts for these pulleys.
Merry Christmas all...
This is regarding the service tech guy's remarks on my 97 Accord. I took it to another place, and this new guy inspected the belts in front of me, and said they are OK. I also checked them and they look sturdy. I have decided not to do it now.
I called Honda-USA directly and they say I dont have any warrenty now on this car. This new tech recommended doing the ditributor cap,rotor, wire change along with the timing belt change. Is that good or bad? The manual book does not recommend doing this at any specific mile/time.
I did a fuel injection service for $50 with this guy. He said, he does it throuh an automatic pipeline machine, which pushes the cleaning liquid and then sucks them out. Is this normal/correct? As usual, any advice is highly appreciated. thanks.
Bill
Why did u do a fuel injection cleaning-what problems were u having-a honda dealer a few months ago tried to sell me on a 3m fuel injection cleaning-looked the tech directly in the eye and said-"What's your spiff". we both laughed and that was that.
milage-what is it
