Visitor Agreement.
Quick question. Could you help? Thanks.
03 LX V6 AT, 500 miles, 3 weeks new.
1. Shifts in low gear feels more jerk. After driving for a while, shifts more smoothly.
2. After stop-and-go traffic, car key is very warm.
Are these normal behavior? Other than these two, my first new car seems to be doing pretty well.
Thanks again for the help.
Don't know about the key? I've never noticed this on any 03 that I've driven so you might want to ask your dealer.
Greetings from sunny Miami.
Wow! Good advice. I couldn't have dreamt that one up without your assistance.
My car had only 5 miles when I first saw it. The label near the door jamb says it is made in 3/03 and dealer told me they got it on 03/19 and I bought it on 03/31. So I hope everything is fine.
I am quite scared by the recall of earlier models regarding the tranny problem. I was told once by a mechanic the ignition part was Honda's Achilles Heel. I do find out Honda has voluntary recalls on ignition switch for 1997 - 2000 models.
Thanks again.
And the transmission in '03s is completely different than the auto in '98-'02 Accords, so I don't think that should be cause for your concern.
Thanks a lot for the advice. I will ask Auburn about this.
My another car, which is Acura Vigor GS 1992, once stalled on the highway. Later I had the ignition stuff replaced and was told by the mechanic Honda's ignition stuff is not good. So I was very sensitive on this.
The funny thing is that I went out to buy a Toyota, but the dealership treats me bad and the result is I got a Honda.
Has anyone else experienced a problem of this magnitude with their new 03 Accord or any other Honda model? If so, how was it resolved or what options were you given.
A "rebuilt" transmission is one where they open up a failed transmission and replace the parts that failed, reusing most or all of the existing parts that didn't fail.
A "remanufactured" transmission is one where they open up a failed transmission, remove ALL of the parts and put all new components in the existing transmission housing. They do this because the transmission housing is one of the most expensive components in the transmission and can be used to house a new transmission as a cost saving measure. In other words, you're still getting a new transmission, just in an existing housing. That seemed reasonable to me.
Honda should buy back the car if this has happened over 5 weeks. Consult an attorney regarding the laws of your state regarding product defects.
I wouldn't be happy either if I was you!
Will check out with some more friends. This is my first new Honda, hopefully not the last one.
By the way, g35coupe, I prefer calling it a short-change not a short-block with unhappyinstl's 5-week new Accord. What a joke.
the metal part of my key does get warm, but the plastic part (where the transmiter is doesn't). i don't find it to be a concern...
I don't know what people think is "hot" but I haven't felt any that were more than mildly warm.
Thanks a lot for the reply.
I should correct myself. The key is very warm but not hot. (Maybe we will have to define what hot means like we need to define what sex means for Bill).
As emale said, the plastic part is not warm. The metal part is. So maybe it is normal.
Have a great day, guys.
Have you checked your cold tire pressure with an accurate gauge? Is it as specified on the doorframe label? (Good) Or, did somebody pump it up to the number molded into the tires? (VERY Bad)
were inflated to 38psi! The recommended inflation is 32psi front and 30psi rear. I lowered it to slightly above those levels and it made a huge difference! I told the sales guy about that. I will make sure it is closer to 32/30. It definitely is much better now. I guess they ship 38psi for some reason from the factory.
I would also let the Service Manager know about your dissatisfaction with the overinflation. Your new car should never have been delivered that way. They should have adjusted the pressures during their predelivery prep. Overinflation can cause skittish (read: dangerous) handling and excessive wear on the center of the tread of the affected tire(s).
Otherwise after 9months I get 30 mpg in my highway driving at 75 mph. I have had no problems other than strange tire problem that was solved by switching front and rear.
Overall, I think the steering/wheels is the weak link in this car.
Just found a dismal news at JD power:
initial mechanical quality rating:
03 Accord: 2/5
03 Camry: 4/5
even 03 Altima has 3/5.
As I said in the other thread, my 2003 EX V6 has been perfect so far (knock on wood), and JD Power never asked me for my rating.
The dealer told me that it takes time to break in the car and that my mileage will improve with time. Is this true? Is there anything i should check/fix?
the only problem that has bugged me about my '03 coupe is intermittent and various dash and headliner (sunroof?) rattles. i haven't had any mechanical issues to speak of, and really don't expect any. but i do find the on/off rattles irritating. and the outside temp sensor has issues, but once again not a big deal. i'm wondering if you guys that haven't noticed any rattles live in warmer climes??
City driving (avg 30 mph) about 26-27 mpg.
Highway driving (avg 45-50 mph)about 30 mpg.
Of course the city numbers include some highway driving and vice-versa but overall I think these numbers are pretty close to the EPA estimates and I am very satisfied.
Another question...
Does anyone know if any of the features on the new Accord are programable. For example, can the computer be programed to provide daytime running lights? How about to open the sunroof in response to the all windows-down feature from the remote or to have the sunroof close with the all windows-up when you turn and hold the key to the right in the driver's door lock?
I know you can change these type of features in the new Mini's.
03 Accord: 2/5
03 Camry: 4/5
I would think that the 2003 Accord has more quality concerns than expected. I guess buying a new model the first year it is out isn't sound for any new car.
My family has ownerd several new, first-year models over the years, including a 1988 Honda Prelude, 1990 Lexus LS 400, 1991 Acura Legend and 2002 Lexus ES 300. All were phenominal cars with no problems at all.
