Honda Accord Accessories
I made up my mine, I am taking the car to the Dealer for both the Mud guards and Door Edge Guard.
I just got a small ratchet and added an apex adapter and a #2 apex, which made for a "screwdriver" a little more than an inch shorter than the stubby. After I did that it was a SNAP to install. There's really nothing you can mess up while doing this so I suggest that everyone at least try it first. If you fumble or get exasperated, then yah, go to the dealer. --Leland
Anyone have any experience with this?
-Sean
My mechanic (of five years) who serviced our Camry will be doing the installation for me.
There is no charge involved and his Garage is well equipped for all sorts of Mechanical and Cosmetic work.
He works for Toyota.
Much nicer sound than FM Modulators.
I love that storage cubby and that's why I would never dream of adding additional audio components b/c I would have to give up that space.
I found a ground loop isolator that addressed the problem. See post 431 for details.
brian
IMO, the spoiler on the accord looks sharp. talk about useless, my wife wanted one on her mini-van...hey, why not, she drives it and I'm not going to keep her from the spoiler just because I don't like it. Actually I do though.
Accord:
http://www.pbase.com/image/20425960.jpg
Mazda:
http://www.pbase.com/image/19545251.jpg
"One perfect example-I had a Mazda Millennia and I bought the Moon Roof Visor for it-what a mistake, those Visors are just outright useless.
I thought it would have reduced wind noise but in reality it increased it."
So- no Spoiler for my honey, hope she does not read this or else its the sofa for me.:)
For whatever reason - if you want one, get it. If you don't - don't! Different strokes for different folks.
Don't take it the wrong way, I didn't mean to offend you. Besides, I may end up buying yours in 5-6 years.
Cheers!
Take Care
rear 6x9 normal depth. will probably need to pilot new holes, as the new holes do not line up exact.
Looking at yours kind of swayed me into getting the Spoiler for her.
I finally rolled up my sleeves and did the work myself.I installed the MudGuards and Door Edge Guards-very simple.I did not take off the rear wheels, I got a very small Phillipps and it did the job.
I think the next accessories are going to be the Fog Lights and the Spolier, I will let you guys know.
I did find that Bob Marley station-got some good soothing island music.
What I am trying to say is- if wanted to change a bulb for the brake lights, the socket is staring you right in the face.
Usually there is a liner there for you to remove.
Is that the way all the Accords are?
Had to look. there is a plastic flap on each side, looks like half a u.... probably rolling around, if not, ask the dealer.
The SNHond03 adapter from logjam electronics requires you to buy an additional audio harness from Honda and then splice it into the adapter (voiding the warrantee in the process) to make it work.
http://www.logjamelectronics.com/snhond3navinst.html
This seems overly complicated - there must be a simpler way. How well does an FM modulator work and is it difficult to install? I am interested in adding XM radio to an 03 Accord with navi. I would prefer not to have to pull apart my dash.
Matt
My next mods are set for mid December. Using the Greddy E-Manage to tune the Air/Fuel Settings and lower my vtec to 4600rpms. There's a local shop that will do the install, tuning and Dyno's before and after for $600. With my intake, total bump over stock is in the area of 25hp or so according to others they've done. I'm looking to add a nice down-pipe or J-Pipe as I call it to free up the exhuast a bit. Not interested in aftermarket sounding stuff. There are some quiet ones out there though. hmmmm...maybe.
More pics of mods here... http://www.pbase.com/pdqgp/my_cars
I'll have to get my Accord Specific Site up soon.
How much did those rims and tires run you?
I might upgrade next summer.
Also the HID, are those XENONS like the ones on the TLS- you know the blue color effect.
If so- give me the source for the bubls and the installation process.
Thanks anyway, when I go back to the dealer I will take a look at a model similar to mine.
Another quick boost which is relatively cheap is a fuel pressure regulator, B&M makes a decent one for about 60 or so with the gauge and the adjustable regulator... good for a few HP, especially with an intake and exhaust to let it breathe better... don't get too carried away though... =o)
Ordered the spoiler a week ago, so it should be in any day now.
1- Rear Deck Lid Spoiler $240
2- Rear Wing Spoiler $370
But I don't know which one looks better on my "Black" 4-Door Accord. I like the one that tlauro installed "Wing"
and I also like the smaller one attached directly to the trunk.
There is a big difference in Price that's for sure!
What are your thoughts?
A lot of dealers will have one of each installed on a showroom car, that you could view. If you can't find that, you'll have to decide from pictures. Good luck. I'll post some pics once I get mine installed.
2.Don't run the power and ground leads next to the input wires.
3. Get a powered high level input to RCA converter. Hook it up behind the head unit so you run RCA back to the amp. Remember, don't run the RCA cables anywhere near power cables or you'll still get that whine!
4. Last resort, Radio Shack sells a few different line conditioners that will reduce, but not eliminate, the noise.
Good luck
