Can you just change the oil filter and not the oil?
the filter and adding oil would seem to be enough. All you need is the filter to clean out the impurities in the oil. The add a quart or two of new oil to top off the level.
I'm with ADC on this point: Motor Oil is super cheap. I don't understand the practicality or logic behind not changing it every 3K or so. Heck, I saw a TV commercial advertising Texaco Havoline for 79 cents/quart. Buy a top quality filter and you can change your oil for under $10.
By comparison, the iced venti nonfat mocha I just bought at Starbucks cost $3.90. The lemon pound cake slice was $1.70.
It's all about value, my friends.
Actually, your can go much further then 3000 with synthetic but I will not start that argument.
Didn't really want to take my drain pan and do an oil change in the hotel parking lot in the middle of December, so I just pulled the filter and replaced it, added a quart of new oil, and took my trip.
Did the "full" oil change 1000 miles "late" so I had 6K on the Mobil 1 instead of 5K.
But, I wouldn't recommend it as a regular practice.
Cheers,
TB
I run Amsoil synth, change the filter every 5k, and change the oil once a year. Sweet deal for us lazy people.
I need 5W-20 and from what I have heard Amsoil is the only synthetic so far. Amsoil is telling you to change at 7,500 or 6 months, whichever is sooner. The 5W-20 weight Amsoil is different then the other Amsoil synthetics. Why do they recommend 7,500 and not 25,000? Whats the difference.
Is Mobil coming out with a 5W-20 sythetic any time soon? Thanks.
The Amsoil 5 W 20 is the XL label which was designed for the quick lube
business where people are reluctant to go beyond 7,500 mile changes.(or 3000
for that matter) To capture that market they formulated the XL series of oil. The
additive package is not as good ( meaning not as durable for extended use) as
the other oils that are slated for 25,000.
It's actually that simple!
http://www.noria.com/boards/thread2.cfm?threadid=471&messages=18#3374
But, I dunno, the filters are cheap. To me, that would be like taking a shower and putting my dirty clothes back on.
I may be wrong, but the original question here seemed to be in regard to any oil. Extended drains always seems to confuse the general population in these forums.
Have you ever heard of anyone "ruining" their engine who was on a 25,000-35,000 mile drain interval with analysis? I haven't, but I have heard of people changing their oil within limits and because they used cheap oil or a cheap filter that let them down, they suffered poor engine performance and/or damage. So, my opinion would be that it is of much higher risk to change frequently if you are using oil and filters of unknown quality, or are not doing analysis.
If you do not see condensation on the tip of the dipstick in the winter you are probalby fine with once a year
What is proven about it? Many engines fail with regular maintenance. What are you accomplishing? If you can support the "proven" theory with hard facts that changing the oil at 3K intervals provides more protection than using a quality synthetic at extended drain intervals with analysis, then I will take back what I've said.
Later
Saw what on TV?
The disclaimer they forget to mention is that ALL of their oils are mandated to meet the same test criteria that the API approves a safe drain interval of 12,000 miles! They don't even have the integrity to say, "refer to your owner's manual for recommended intervals". Nope, 3,000 miles covers every make out there according to them. Same with the quicky-lube joints.
And just like slack-jawed, gullible rubes, the general masses believes this dribble. Hey, whatever... if you want to change your oil at 10 miles, go for it. Dump the used oil in your local stream, and throw the filter out your window as you drive home. Your car will last 100K miles, and that's what's important, right?
End of Rant.
Yeah, like SHE's an expert in tribology or mechanical engineering. :rolleyes: Words of caution about my ride from HER I don't need!
I switched to Redline synthetic and either use an OEM or (next) hastings filters and I'll be doing my changes about every 5 months. This works out to about 7,000 miles ...
... and I know even THAT is overkill ... even for an engine like mine that's somewhat over-worked and at high RPMs some times for hours on end.
--- Bror Jace
I guess I can't 'prove' anything in a chat type posting and neither can you or anyone else for that matter. But I have owned many vehicles that have gone over 100K miles with no problems from lubrication. I consistently use a name brand oil, filters and 4500 mile oil change intervals.
I give you credit for the rigorous oil analysis and maintenance routine you set up. But for most of us, reasonable oil change intervals works fine.
I have heard varying claims on the TP filter systems of old. They may have been rather effective. Thats a lot of square inches of filtering-- and really tough to fling out the window at speed without getting oil on the side of the car and suck-back onto the upholstery!
I have learned though over the years with many, many vehicles that those where the oil stays the cleanest seem to hold op the best and tend not to use oil as the engine gets older. On the other hand those engines in which the oil turns darker quicker use more oil and as the car ages and that oil usage generally (althought not always) goes up) Those engines struggle to make 100K. I've had two that did not make it.
What does this mean. To me it means that if the engine oil is clean-all is well. When the oil goes from dark honey color to black. A change is more than necessary.
I hasten to add that black oil is not necessaily bad. Oil analysis here have proved that and I also know that as a fact. But for me- I will have no black oil in my vehicles-thank you. The other reason why I don't do the analysis I guess is - if irons or silicons come back high what am I going to do about it? The answer is nothing. I have synthetic in it and its clean. Am I gonna' drain it and put new in- I don't think so. As I said, I wouldn't discourage anyone from testing. Oh yea-it can detect antifreeze-that one could be worth looking at-but again I monitor my antifreeze level and if its not visibly going down I don't pull the heads.
So, having used synthetic on about 7 different cars now I have yet to see black oil. The highest mileage that I have ever converted to synthetic at has been 57,000 miles.
Of the 7 or so still have 3 and going fine, others have been company cars which are sold at 60,000 miles. Longest I have on synthetic is 135,000 miles switched at 1000. On this car I had a 15,000 mile analysis and I did nto like the results but the oil was still amber, not black.
So, I just don't get it. Why do you continue? Why do so many not even follow their owner's manual and just change when the quicky-lube sticker says so? I'm open minded - if you convince me that there is a proven benefit to 3K oil changes, I promise I won't rant anymore!
Everytime I think about it I can't help chaning both oil and the filter.
But you have peeked my interest. Where can I find how to use oil analysis?
http://www.sae.org/servlets/productDetail?PROD_TYP=PAPER&PROD_CD=981448
I keep hearing the "baby" analogy in reference to oil and filter, so I'll use it for frequent oil changes. Changing your oil every 3,000 miles is like changing a baby's diaper every 5 minutes. The diaper doesn't always need to be changed, but you can guarantee that the baby will always have a clean diaper! Ok, that wasn't that good, but you get the picture.
If you have noticed, many car makers are now implementing some kind of "analysis" right into the electronics of the car. For example, Mercedes has the most sophisticated system where an electrical signal is passed through the oil. Based on the resulting "resistance", their analyzer can determine how much safe life is left in the oil. This is hopefully where all cars are heading in the next 5-10 years.
Other cars (GM products) have a less sophisticated system where an algorithm calculates oil life based on engine hours, temperature, speed, rpms, etc. This is a good start, but the problem is that the algorithm is based on "standard" oils and does not take into account the extended additive packages and longevity of synthetics. Still, it's a step in the right direction.
Again, I apologize for trying to condemn you or anyone else here. I tend to get annoyed with the "Marketing of America" where half-truths and outright lies are perpetuated by manufacturers for the sake of a few dollars more. It's unbelievable how far some will go - as is the case with products like Z-Max and fuel line magnets.
