Can you just change the oil filter and not the oil?
24
  • wtd44wtd44 Member Posts: 1,208
    You could cut a piece out of the diaper every few hours and get it analyzed by an expert who could tell you when to change diapers...
  • rcarbonircarboni Member Posts: 290
    ...you could use your built-in analyser, a.k.a. your nose, to diagnose when to change the diaper. Now if you're hard of smelling, I guess you're stuck with the visual analyser...
    ...take the baby down to the quicky-diaper place and have them change it... but then you won't know if they actually wiped the baby and put some powder on... and who knows what brand of diaper you'll get...
  • brorjacebrorjace Member Posts: 588
    ... the baby will end up with the diaper improperly installed (completely covering his face instead of the other end) resulting in the baby's premature demise ... and the quicky place will tell you that it's not their fault.
    --- Bror Jace
  • bushonebushone Member Posts: 39
    throw the baby out with the bath oil.
    In 1997 I bought a new Geo Prizm from a local Chevrolet dealer. They had a policy of doing one free oil change for all of their new deliveries. I took them up on it, but when getting the car home, some four miles away, I just had to check the level. They had dumped five quarts in, instead of the three and a half required. This, from a franchise holder-- not your local quick oil joint. They managed to change the filter without further incident, so what should I expect?
  • spokanespokane Member Posts: 514
    Overfilling occurs in many instances. In my experience, it's even more common with automatic transmission fluid. We should all do exactly as you did ...check the level very soon after an oil or ATF change. This is advisable no matter who changed it - dealer, independent shop, or self. At the same time, one can verify that the oil is fresh and clean rather than the old oil having been left in the crankcase.
  • armtdmarmtdm Member Posts: 2,057
    Because it varies as to how much is drained each time even with the same car Oil chages are consistent, if you add back the same 4 quarts 20 ounces or whatever your engine requires you will always be in the ballpark. But tranny fluid differs and no one (except maybe myself) actually measures how much I drain out so that I can replace the same amount. Plus, tranny fluid must be checked when hot and few if any places are willing to spend the time to measure how much was drained or drive the car ten miles to heat it up properly befroe checking it. I have had overfills from dealers, independents etc. Really need to check it yourself.
  • eharri3eharri3 Member Posts: 640
    People trying to find reasons to cheap out on oil and filter changes...: "Can I just change the filter and not the oil?" "Can I go 7500 or 8000 miles instead of the recommended 5000?" Why spend 15k or more on a vehicle and then get irritated at spending 20-30 bucks every few months on a simple maintenance procedure that can greatly extend the vehicle's life? Do people who think this way generally change vehicles ever few years, so getting maximum mileage out of it is not a concern? Seems to me like 25 bucks 3-4 times year is aweful cheap insurance against premature engine wear.
    95 Ranger, 2.3, 5 speed. 74000 miles, Gets oil and flter changes every 5000 miles on the dot along with most other recommended maintenance. It needs to last at least another 50 thousand miles before replacement. I feel no need whatsoever to test my own personal theories on engine longevity and oil break-down. I figure 30 bucks every 5K is no big deal. So what if I could let it slide until 7500 miles or 10 thousand miles or whatever.
  • adc100adc100 Member Posts: 1,521
    Jiffy Lubes love you. Buts its OK to feel that you are getting the best out of your car by going that way. Experience has however demonstrated that syn oils give more protection and can take engines to 200K (15K oil changes.) Measured wear parts for the most part come up to specs for new parts. Jiffy Lubes survive on fear, tradition, and customers refusing to question things.
    On another subject. I was having problems with discrepancies on oil filter part numbers for my Sentra (2001) As it turns out between 2000 and 2001 Nissan switched all of their engines to the extremely small (Purolator # L14610) Obviously they put inventory ahead of the better filtering larger filters. So there's just another example eharri3 that sometimes it doesn't hurt to think outside the box. I went with a filter which is 1/3 larger. Of course I'm in trouble because the Autozone man said it wouldn't work.
    Some reading material for you:
    http://www.novaregion.org/arner/ra-uoctl.htm
    http://www.memagazine.org/backissues/may99/features/vitalsigns/vitalsigns.html
    How do you know your avoiding engine wear and getting better mileage by changing the oil sooner?
    I must confess that I am GIVING CONSIDERATION to stretching my 3K cycle out to 5K. I think there is evidence to support such a move. I am NOT ready, however, to go back to my old ways of using synthetics. I frankly became somewhat alarmed by the obfuscation going on at the supply side toward the consumer. And I see that many brands have made adjustments to formulas that are absolutely radical (e.g., changing from ester to PAO dominance in content percentage). This implies that I may have been lucky years ago to not have had serious troubles when I subscribed to the rantings of the industry and true believers. But when that dipstick looks murky, how can I not change the oil before the 5K...
    Who went from ester to PAO? Castrol went from full ester to group III hydro-cracked, not PAO. Is there another oil that you are refering to?
    BTW, Castrol claims no loss in protection or longevity from their previous formula. They made the change for obvious cost savings, but forgot to pass those savings along to the consumer!
    You seem to be overlooking the definition of, and alternate sources for, polyalphaolephins.
    Not clear on your response. Are you comparing group III hydro-cracked bases with group IV PAOs? Completely different catalysations here, but the claims can be similar, according to Castrol, when blended with esters. Their numbers don't reflect their claims however!
    Some reading material:
    http://www.guarding-our-earth.com/amsoil/basestocks.shtml
    I was taking into consideration a much simpler view-- not complicated at all. I was referring to the molecules of natural occurance and those of synthesis as being chemically very similar, when referring to non-esters.
    Since I usually do it myself, and the times when I do decide to take it in I'd let chimps work on it blindfolded before I'd go to a quickie place. I'd like the full 5 quarts of oil thank you very much, not 3, not 10, and no transmission fluid in my oil pan is also preferable. (That's what killed my x girlfriend's old car.)
    It's also nice when the nut and the filter are tightened sufficiently
    that they don't let my engine's life blood come gushing back out.
    You said "experience", not "evidence." Show me two identical cars under identical conditions, driven the same way, one on synthetic, one on dyno, with all other maintenance being the same, and one lasts significantly longer,and I'll be swayed in my opinion. To me, experience means you know of lots of people who had cars go 200k on synthetic. Thing is, 200K on the odometer is not that lofty of a goal nowadays no matter what oil you use.
    Also, there's also lots of evidence the synthetic thing is just like higher octane gas... many people swear it makes cars run longer and better but alot of it is a placebo effect. In fact, I remember reading a recent article somewhere that some synthetics arent really man made anymore. It does no harm, but I don't think it makes the huge difference everyone swears by. Maybe paying more for synthetic is just like me doing oil changes every 5k on the dot... I cannot show material evidece that my car runs better because of it but it makes me feel better.
    You may need to spell out for me where those links really raise significant evidence that 5000 miles is unnecessary. Unless I missed something when I skimmed them, the first is about disposal problems, which have nothing to do with what's best for my car. And the second mentions that driving style can also affect oil changing needs. I kind of agree with the second, in that driving style does affect the oil longevity, but I have no on board computer to nag me to go in for service and I don't trust senors and dummy lights anyway. A regular interval ensures that I don't fall off in my maintenance, and seeing as how my driving is mostly highway and various mechanics I've spoken to say 3000 miles is ideal for heavy duty service but 5k is OK for lighter highway driving, 5000 miles just seems right for me.
    Mobil repeated their 200K test with dino oil. I've seen pictures of the cams and cyl walls. I believe the pics are on the Mobil1.com page but the site is down. I have pics somewhere else though. I'll find 'em.
    I suspect though that changing oil at 5000 and syn might give the same results after extended driving tests though, to be honest. Syns two advantages are -to me- half as many oil changes. (I change oil on 8 family/extended family vehicles.) The other is that if bad things happen on the road like a loss of coolant, there is less chance of engine damage and the car can be run a few miles more to get to a location of safety. Important for my wife/daughter. Syns protect better under adverse conditions.
    I do agree with your blindfolded chimps though.
    The point of those links are:
    1. We are wasting incredible amounts of oil (a limited resource) due to the fact that we somehow believe that changing the oil more frequently reduces wear on the engine more than extended synthetic drains.
    2. Changing the oil more frequently does not protect you in any way, shape, or form from damage that occurs from foreign substances in the oil such as water and/or fuel, and has no credible evidence that it will reduce wear any more than extended drains.
    You have no proof that your oil changes are protecting your engine other than the fact that if your engine runs 150,000 miles, you'll swear it was the oil changes, even though some goober who changed his oil every 20,000 because he was lazy also ran 150,000 miles in his car.
    Changing at 5,000 "seems" OK to you, but how do you know if that is too long or too short? How do you know if the bearings are wearing prematurely because the engine might not be balanced quite right? How do you know if your air filter is providing sufficient filtration? How do you know if you have a small head gasket leak? How do you know if the additives in your oil are still preventing oxidation and your oil is lubricating to spec?
    I know these things on my engine because I do oil analysis with my extended drains of once a year. And guess what? It doesn't cost me anymore than your 5,000 mile changes! And, I'd rather have my on-board computer nag me than my engine nagging me when it dies!
    BTW, I commend you at least for changing the oil at 5K and not 3K which is totally ridiculous unless your running the Dakar rally everyday. If you are using recycled oil, then I applaud you even more.
    When you change oil on 8 vehicles that kind of puts things in perspectinve. I get the feeling if I suspected something would help me extend oil change intervals in th at sitation, I'd try it too. Hoever, it seem to me that if you pay more for synthetic anyway, you end up spending close to the same amount on less frequent oil changes as you would using regular oil mor frequently. Just out of curiosity, what's in the fleet?
    rcarboni: No, I don't have concrete proof that 5000 is the magic number except that I go by what I've heard from experiened mechanics. I also change my air filter and other wear and tear parts on a regular basis. Like I said, I cant say definitively that 5000 miles is perfect for me. But based on what mechanics and others who would know have said, it seems like a nice compromise to me between appropriate maintenance and conservation. I must admit, I wouldn't mind doing an oil alysis and would probly have it done at some point when I have the disposable income (impoverished college student here...every dollar counts) But it still wouldn't change my 5000 mile intervals unless it showed that I needed to do it even more often. If the oil came out clean, I would take that to mean I should change nothing. My first instinct would not be to stretch it any further between chages. Besides, many of the scenarios you cite seem not to have much to do with oil change frequency anyway. It would be usful to know such things, but I don't see how there is much you could do in the way of preventative maintenance to stop them from happening, other than the air filter thing.
    '96 (I think)Grand Prix, '00 Grand Am, '99 Quest., '94 Corsica '99 Quest (Bimbobox), '96 Cavalier, 94 Toyota 4WD, '92 Corsica (love those Corsicas), '01 Sentra. I change oil as Christmas/Birthday presents- saves money.
    And I agree 5000 is better than 3000.
    When I first started using synthetics I was the skeptic and began with the 3000 miles changes and analysis. I extended the drains over time and kept up with analysis as well. Fact is, there is no noticeable difference in my used oil at 3000 miles or 12,000 miles with the same vehicle as comparisons. In fact, having done this on multiple cars over the past 9 years I know for a fact that changing my oil in less then 7,500 miles is a true waste of money and time. Will my cars last longer, probably not, but are they protected better, yes, are they better in cold starts, yes, are they better in extreme heat, yes, nad do I save time/hassle and aggravation whether I do it myself or bring it to someone to do, yes, is there less chance of stupid errors (fewer episodes) during a change (plug/filter loose, ATF in lieu of oil, too littte/overfill etc) , yes.
    So now I don't even bother with manual recommendations on oil changes even if under warranty. I am so confident I just change it around one a year.
    I'm not criticizing you on your 5K changes. I think you have at least seen the light to extend to this point. My only complaint, as it were, is against anyone who says that changing the oil frequently is a benefit to your car. If your "experienced mechanics" know this, how did they gain that knowledge? Did they analyze the oil of every car at every change, and also measure the wear? Obviously not, so therefore they are just plain guessing. Ask them how many cars have failed with frequent oil changes vs. extended drains with high-quality synthetics.
    I consider myself an "experienced mechanic", and I'm telling you that 5K changes are meaningless. Now you have a new opinion. ;)
    If you are trying to stretch your budget, then you are a perfect candidate for extended oil changes and analysis! I pay $80 a year per vehicle with analysis. That's less than $7 a month, and here's the more important factor: I'm running the highest quality oil in my engines and not some dino sludge that barely meets the requirements of an oil. My oil (Amsoil) also guarantees it's protection and longevity - can you say that about your oil? If you're concerned about protection, what makes more sense?
    You kids these days! ;)
    you haven't changed my mind totally but it is something i'll take into consideration.
  • joq867joq867 Member Posts: 3
    I have read most of your posts, but I want to know what kind of driving conditions, and mileage you are operating under. I drive about 600 miles a week and use mobil 1, but these miles are in the Florida heat. 5k sounds good for an oil change but what would you suggest. I don't want to here about the other guy who went 500k and never changed his oil or any other legends, just some sound advice. I know about long term neglect I ran a truck for 50k before the first oil change and it lasted for a good 150k.
    whether you intend to do oil analysis. What your oil consumption is and your level of comfort there is no one right answer. The heat has no bearing on the situation with syn. Heat won't kill the oil as it does conventional oils. If its under warranty then you have to be careful, unless you want to use creative bookkeepin (cheat/lie). Under warranty-go to the max milage limit. If you are not under warranty you could easily go 10K with a filter at 5K. Thats about what I do. If you don't want to do an oil analysis. and are comfortable going further- change filter and oil a couple of K longer. I just keep the oil in until it begins to turn from dark honey to dark/dark honey.(knot-not very scientific) Use a top notch filter- Pure One Mobil 1, Amsoil.
    $80 per year per vehicle is a high price to pay, in my opinion. I pay about $15 per vehicle per year. Neither of us are spelling out the conditions that allow comparison. Let's talk price per 1K miles, or something.
    Ok. I put 20,000 miles on ~$80 worth of materials, and 1 change (my time is more valuable than the materials!) Here's the breakdown:
    6 quarts of Amsoil 0w-30 Series 2000 @ $8 = $48
    4 filters (usually between $4-5, sometimes lower on sale) = $20
    oil analysis = $18
    Total = $86
    Per 1000 miles = $4.30
    Obviously, the more miles you put on your car in a year, the more you save with extended drains.
    I promise to not cheat, having seen your costs posted before calculating mine:
    average volume per vehicle=4.5 qts ==> $4.50
    average filter cost ==> $3.80
    total per oil change ==> $8.30
    ridiculous, short 3K average change
    period converted to cost perK........................... ==> $2.77
    that does not include my $200 in labor...lol
    3k/3 months right? That works to be $33/yr, not $15, but no big deal. ;)
    You use oil that costs $1 a quart???!!!! You are a brave man my friend! You better change at 1k!
  • mrdetailermrdetailer Member Posts: 1,118
    Daaaang! 50,000 without a change. That was one tolerant engine. Definitely not a modern low emission overhead cam engine. Youd've burnt up long before.
    I've gone 6,000 on synthetic under severe conditions without any problem. And at least this time of the year the type of driving you do is definitely severe service on most cars. Extensive driving in the heat with the AC fits the bill.
    Go 5,000, analyze it and see how the oil is holding up. As long as you aren't under warranty, if it turns out good, you may want to try to extend it.
    I always change filters at 3,000 however.
    You can go the full time or milage even under severe driving conditions (that's 7500 miles for most cars)
    Even my twinturbo I don't change until 5000 miles after that one car is 7,500, one is 12,000 (filter at 6000) and two are once a year with a fitler at 6 months. Analysis has been fine.
    WRONG!
    We were getting realistic and comparing the costs per 1000 miles, not yearly expenses. Nice try. You lose again. Sorry. :^~
    I shop carefully and always stock my ample shelves in advance. I can buy the good name oil company brews for under a buck a jug all day long.
    And I do change at 1K on my Valkyrie motorcycle.
    92 Camry 4.5 quarts at $4.35/quart (Amsoil) = 19.58
    1 Amsoil Oil Filter 7.25
    Total $26.83 / 7,500 miles = $3.58/1000 miles driven
    My daughters car
    96 Mystique 4 cyl 4.5 quarts at $6.25/quart (Amsoil 0W30) =28.12
    1 Pure One Oil Filter (Amsoil did nto work for this car) = 5.99
    1 Pure One filter at 6 months 5.99
    1/2 quart of oil for fitler change 3.13
    Total $43.23/12,000=$3.60/1000 miles
    Opportunity cost of not getting under car (or driving to a quick lube) two more times (if I changed at 3000) hassle and time, well, one hour/change at $40/hour = $80.
    I'm confused with your responses. You said originally that it cost you $15 per year to change your oil. However, in your breakdown post, you said that each change costs $8.30. Combining the information would indicate to me that you only change your oil twice a year. Is this correct? If so, then you are extending your drains, but not my mileage, instead by time. Are you changing the filter at 6 month intervals as interpreted?
    I'm just trying to clarify your information. I would agree that anyone who only puts 6,000 miles on their car per year could probably save money over extended drains. However, I would argue that if this low mileage were in effect, then the vehicle is most likely making many short trips, and either the lower-quality oil should be changed at very short intervals anyway (3 months), or only a high-quality synthetic should be used.
    You can only compare cost per 1000 miles if you compare like protection. Don't you agree? Otherwise, I could say that I only put 3000 per year on my vehicle, change the oil once with the cheapest filter and oil, and it only cost me $8 ($2.67 per 1000). On the other hand, I could also say that I drove 35,000 miles per year using Amsoil and it cost me $80 (2.30 per 1000). Hmmm, the extended drain is now less expensive AND provides better protection. Ok, that wasn't my original thought, but I like this scenario better. ;)
    Ok, I've thought about this and decided that the cost per 1000 miles doesn't work as a fair comparison because miles per year is not a fixed variable with extended drains.
    Extended drains will be less expensive when more miles are recorded, but more expensive with less miles. It's just not a fair cost comparison against a fixed mileage schedule.
  • andre1969andre1969 Member Posts: 26,113
    ...about a car that only travels a few hundred miles a year. Say, my '57 DeSoto, for instance? I've been changing my oil about once a year, and it comes out the same color as when it went in. I know I don't have to worry about the oil wearing out, but at this rate I'm more worried about moisture accumulating in the oil.
    Any opinions? Should I change it more often? Or is even once a year just wasting oil? FWIW, I did change the oil but not the filter once. But anyone who's ever had to change those obnoxious drop-in cannister filters would understand ;-)
    We put about 6K per year on each of three vehicles, and put about 12K each on another two. I do not include the motorcycle, which is superlow miles annually. 3K with a filter is a very satisfactory interval to protect all these rigs. I really don't think one needs to do any more. And surely we all know that the old sop about every three months no matter what-- is a bag of horse feathers.
    Hey, do you run Delsey in the DeSoto, or use a drop in cartridge? Ain't them cannisters a mess? (:^{
    Now you're really confusing me! You think the 3 month change is a bag of horse feathers, but the 3K change is not overkill?
    I recognize the baiting, but what the hey!
    Rest assured that I understand acid development in crankcases that are chronically short hauled. Other than that, there is little cryptic in the goings on of storing oil in a crankcase versus storing it on a shelf. If you feel there is scientific factuality backing the idea of changing oil in not more than three months (in every case, regardless), I'll stand still to hear you out. The operant word is SCIENTIFIC. Horse feathers are not scientific, they are mythical. !^}
    I don't mind you thinking of 3K miles as overkill. That means I am not taking any risks of waiting too long, eh?
    Thanks. You used my exact argument against 3 month changes as I have used against 3,000 mile changes, i.e. there is no SCIENTIFIC proof that 3K changes are more beneficial to the longevity or protection of your engine. Yes, it was well baited! ;)
    Anyway, I don't believe in the 3 month change either. I don't use inferior dino oils, so time limits do not apply. Hey, was that another baiting? hehehe.
    I think maybe we just gave each other permission to not be identical in all belief systems, and with that permission hopefully comes tolerance. Let me just say that when I found the hiding of even very general formulation information to be the standard among most syn brewers, I waned. My enthusiasm for the products just slipped away.
    I honestly think that the SH, SJ, and SL(?) standards are such that not a lot is gained in engine protection by using today's most popular synthetics. For those that enjoy lubricant analysis and tracking, it may be worthwhile, as a challenging venture. For those of us that do the entire process in our own garages, dino is very satisfactory.
    I'd just change it and the filter once per year ... like I do with most of our power equipment. If you skip a year, though, I wouldn't worry about it. Just make sure, that when you start the car's engine and take it for a drive, you run it for at least 20 minutes or so at a time to get it up to temperature. The car's oil should be brought up to temp ... and the car should run with the choke off for at least 5 minutes before shutting it down again.
    Then, I use much of the relatively clean oil drained out of such vehicles/equipment to top off old beaters we have/had that go through oil like a quart+ each month or so. We have an old 1978 truck with a slow leak and my father's previous Grand Marquis had 130,000 on it that he took only moderate care of. The oil I was dumping into them was 99% better than the oil that was already in their crankcases.
    --- Bror Jace
    Probably protection means different things to different people. Protection for most people is the oil protecting the engine under normal conditions. Certainly everyone wants that. Protection to me means that if really bad things happen-usually the loss of coolant comes to mind. My engine will stand a much better chance of having no problems. Unfortunately not everyone watches the coolant gage all the time. And if you forget to scan it for a minute or two after its hit the roof-welcome to possible cracked heads/lubrication failure/cylinder damage. Every day driving under "normal" conditions. Mineral is fine (again if you like changing it).
    We ex-DeSoto owners understand and sympathize with the drop-in canister oil filter hassle, Andre. A cheap suction pump can be used to empty the canister and remove most, but not all, of the oil and hassle. Seriously, for a low-usage car such as yours, I would be comfortable with more than one year between changes. I agree that moisture accumulation is the question you face - but since virtually all of the moisture comes from combustion rather than being time-dependent, I would change primarily on the basis of number of times the engine was started. For example, if a year's driving consists of 100 trips of three miles each; perhaps change every eight to twelve months. Or, if a typical year's driving is three weekend trips of 100 miles each - I would be comfortable with changes at 30 months or so. From your comments a few months ago, I'm sure you do check the dipstick fairly often - a good idea. Brorjace makes an excellent point as to fully warming the engine whenever it is started; especially if the car will subsequently be parked for several weeks.
    SAE Technical Publication Series.(#181448). It indicated that in this test with 15W-50 syn oil the most optimal time to change considering cost of engine wear and cost of the oil was 7000 miles. Not sure I totally buy it but in this case that's what the numbers came out to. Since they only used one engine you could have a huge standard deviation.
  • lbthedoglbthedog Member Posts: 198
    Guess what? It's back. Doubt many/any of you have noticed that the GM 2.2 four has one. That is the 2.2 that's in the Saturn LS and now is becoming the base for Grand Am and Alero, upgrade for Sunfire and Cavalier. Reason for this? Well, GM believes (and it makes sense to me) that the canister style filter is never or rarely drained. Ever see a filter crusher at a Jiffy lube? So in this case all that is replaced is the filter element. You've got to wonder how many do it yourselvers are tossing a quart of used oil in the garbage via a Fram filter.
    from Saturn when they already have the more powerful Quad in the Cavalier now. Also I didn't think the GrandAm whould have such an underpowered engine. The present 3.4 V-6 is barely adequate???
