Seller asking close to $3000
Maint records indicate transmission and clutch replaced approx 50,000 mi. ago, has small oil leak at valve cover and AC seems weak. Otherwise good condition. Any comments/advice out there?
Anyone have a similar experience?
My question is, do i have to replace the dryer component at the same time as the condenser?
I did find a dryer on ebay (screenshot here):
I can also get the condenser a lot cheaper online than from the dealer, but i've never bought car parts online before so was a little unsure where to go.
I found this website which seems to offer some varied options, with varying costs:
Auto Body Parts Go
My wife and I would really appreciate some advice on this matter, I have a friend who can help me fit the parts, and we can have the A/C topped up and tested for pretty cheap with a local mechanic, but I'd really like to try and save some money by fitting the new parts myself, and buying them online.
Thank you for taking the time to read my rather long post!
I did this repair about a month ago. I used a Haynes Auto manual when I did it to make sure I got it right. I had the same problem. The rotor seems stuck on where as you are expecting it to just pop off after the wheel comes off. There is actually a small hole on the rotor (I'm typing this from my job so I'm not looking at the manual) in which you have to screw a bolt into. Screwing the bolt (or screw?) into the rotor actually pushes the two surfaces apart and the rotor pops off. I'm sorry I cant remember where or what your supposed to screw in there but its mentioned plain as day in the manual and worked great. I would go buy the manual cause its the best money I spent in regards to maintenance for my vehicle. I have the 2000 I30 but they are practically identical in alot of aspects. Hope it helps and GL.
Also looks like the seat motors are a problem with the 2000. Has anyone repaired this problem themselves? If so, can the average "shadetree mechanic" do this?
When cold she starts if I push on the gas a little, keeps stalling until she's completely warmed up (about 5 minutes). When warmed up she starts beautifully. The problems are getting worse.
A technical Service Bulletin was issued for this:
Vehicle: 2001 Infiniti I30
Nature of Defect: SEATS:FRONT ASSEMBLY:POWER ADJUST
Bulletin Number: ITB00067B
Bulletin Date: Oct 2003
Summary: DRIVER'S SEAT WILL NOT MOVE FORWARD OR BACKWARD. (NHTSA ITEM NUMBER - 10003898 )
ive had a similiar problem, to the point where the clicks to turn my car went from 1 to freakin 5 clicks to none. at the point of no clicking, my starter short circuited along with my battery going to the point of no recharge. horrible experience, but my opinion, get it looked at before clicking it over too many times.
Could also be you Mass Airflow sensor incorrectly measuring the airflow and fuel mix causing the car to stall. The Mass Airflow Sensor can be removed and cleaned with Mass Airflow Cleaner. Not a hard task, just takes a little time.
Start with the free battery and alternator checks at most of the national automotive part store chains (autozone, etc..) . They also have the abiity to offer free computer diagnostic code analysis. If these two free tests don't yield any answers, I would suggest taking to a shop and have them look further into it.
Driving home from work late at night I notice when I'm depressing the brake at stop lights the car starts going into a spaztic convulsion, thudding and shaking the entire frame every several seconds (no warning lights are on my dash), so I immediately pull over, turn everything off, wait a few minutes and start up again - I notice, while in Park and/or Neutral the "convulsions" aren't very noticeable (quieter and more subtle), then when put into drive (1st, 2nd, and D) it repeats the madness. I went to see my mom and she thought it was the transmission failing (as do I), but here's the strange part... I checked my Trans Dipstick - smells sweet and is a nice rosey color, then checked in the morning for leaks where I had parked - nothing; finally, took for another ride around to see if I noticed any slipping/catching gears when accelerating or high rpm - again, nothing - has plenty of torque - and thus, we come to my question...
WHAT THE HELL IS WRONG WITH MY CAR ?!?!? :sick:
& Should I cut my losses and buy a Honda or Toyota? So puzzled and dismayed... help please!
Thanks for indulging me and my rantings.
-Amy
There can be many reasons for low engine idle, including, as witnessx suggests, some electrical issue. I don't think this is transmission related.
so yeah, check for vacuum leaks and test the battery and alternator first off.
It's also possible that cleaning the throttle body and MAF sensors might help.
Even a badly clogged up air filter might cause this.
My car is infiniti I 30 1997 model.
JP
