Jeep Liberty: Problems & Solutions
I'm just wondering what else will go wrong - and I think we'll get rid of the car as soon as we have it fixed.
Replacing the engine at 48000 miles as mentioned in previous posts is not something I want to wait for.
That's going to be my first *and* last time buying an american car!
I swear I must have visited the dealer like 4-5 times a year to get these kind of stupid problems fixed! :mad:
I'm a bit surprised since I made the appointment a week ago, and they had the car for a day last week which is when they found out exactly what was wrong and which parts they needed.
So the dealer asks if I can get a ride home from the office from someone, or if I want to come pick up the car and bring it back tomorrow. Finally he offers a rental car.
He calls back at 3pm to let me know that if I need the rental car I have to be there before 5:30 to pick it up, which means I have to leave work early. Also, it is possible there won't be any cars available when I get there, in which case they'll take me to another Enterprise location to pick up a car.
I already know that the whole thing will take at leaast an hour out of my day. Is this normal Jeep / Chrysler 5 star dealer service?
I was also wondering if there was anything I could do to have Chrysler give us a discount on the cost of the new A/C, since they really aren't supposed to break at 41000 miles. Any ideas? (Like contact corporate office or something?)
1. The Liberty uses a cv joint between the transfer case and propshaft. This is all good and well but if the car is taken on sand and sand gets into the cv boot the cv joint will be ruined and to top it all off Jeep in South Africa do not sell the cv as a unit meaning I had to buy an entire propshaft.
2. The front Differential and axle are made of aluninium. Recently I was driving over some rocks and the front differential hit the ground and the axle broke. Yes that's right the front axle broke.
To those of you looking to do some serious offroading in a liberty I have the following advice.
1. Bolt some bashplates to the bottom of the vehicle to protect the differential, transfer case and propshafts.
2. If possible fit a lift kit to the vehicle as ground clearance is an issue.
P.S. In South Africa a liberty is called a Cherokee and a Cherokee is called a Grand Cherokee.
The service manger didn't think it would help ?? My first tankful is 15.9 MPG vs 13.7 on the one before it. I think the people on this forum know more than the Jeep service people. I hope it gets even better as it breaks in. If anyone out there knows ways to get a few more MPG, please post it.
I had a similiar problem. I would be driving and my liberty's steering wheel would start to vibrate, If I applied the brakes the vibration would be amplified to the point the front end was vibrating back and forth. This problem was intermitent, but I was lucky it happened when the dealship had the car out for a test drive.
The problem turns out is the brakes would not release all the press so a brake would lightly rub and cause the vibration also when I applied the brakes it amplifies the situation.
They though it was the master cyclender so they changed it to no availe. Then the called the Jeep Tech line and it turns out they have a problem with some brake boosters not releasing all the pressure in the system. They are in the process of changing my brake booster so hopefully that fixes it.
1) At approximately 1800 to 2000 RPM I get a vibration/resonance from the engine bay, at higher or lower revs the resonance disappears. The noise is very loud when the engine is cold and dies off slightly when warmed up. The last visit to Jeep seemed to cure the problem for a couple of days but then reappeared.
2) When I am driving and I let off the throttle and ease it back on again I get a stutter, which resembles what I can only describe as like a sticky throttle. This problem also manifests itself if I am driving along a straight and ease off the throttle a bit for a bend or a roundabout I get a jolt as the engine drops the revs and then picks up almost instantly.
The car has now done 4000 miles and has been back to Jeep 4 times but they seem unable to fix the problems.
Has anyone else experienced these problems?
2) The throttle pedal pulls a cable that rotates a potentiometer that sits under the bonnet. Check that your pedal mount is well bolted to the firewall and that the cable+pot assembly doesn't stick.
I hope this helps.
Best,
TR
I went to nhtsa and only found one notice from 2003 regarding the control arm & lower ball joint.
Thanks-
Smell you later.
I seem to be very lucky with my truck. It stays clean inside, I've had no other problem in 2 years than the noisy fan clutch that was changed under warranty (but that could have been repaired). I keep the A/C ON all the time because it has practically no influence on my mileage and I don't give it time to "smell bad".
I checked for break wear last sunday: the disks are still 27.2mm thick instead of 28mm when new. I now have close to 52,000 KM (32,500 miles) and the pads still have 5/16" to go each side of the disks. The disks I have are made by Bosch, and I'm really surprised to read that some folks have problems at 15,000 miles ???
go off when you jiggle the lever. The radio shuts off (including the cd player) when it is supposed to be operating. It comes back on after a few seconds,long enough that the cd restarts. Does anyone have any idea what is causing this?
I had a small rock hit and & put 2 chips in it.
I also owned a 2002 Jeep Liberty & had the same problem with that windshield.
2. Cracked windshield(s) after small rock hits it
3. Broken ball joint
I owned a 2002 Liberty before this one and didn't have any problems. Now I have this one and am having these problems. I started doing research and came across this board and decided I needed to share this info. The dealer says there has been no complaints on any of this. I find it hard to believe after reading the forums. I will take printouts to them so they can read them. The ball joint concerns me after find out that over 400,00 2003 Liberty's were recalled. Oh - they didn't mention that to me either.
