Jeep Liberty: Problems & Solutions
13132343637
  • caribou1caribou1 Member Posts: 1,354
    A few decades ago a disk brake had to have a non planar behaviour to 'push away' the break pads when it was released and turning. Today we have multiple lips or waves on the receiver piston seal to retract the piston from the pad. This is not always sufficient to keep the brakes quiet and considering that some brake boosters don't completely let go their vacuum (Chrysler problem apparently), the pads stay where they are. I usually check for corrosion on the guiding of my pads when they start to be noisy. A brass brush fitted on a 'Dremel' tool usually serves the purpose. Now my disks are 27mm thick and I've driven 60,000 KM. It seems I will get at least twice this distance ~75,000 miles before I have to change them. :shades:
  • drydenkedrydenke Member Posts: 1
    I also have a 04 Liberty and having CD problems. The CDs won't eject out but the radio works fine. The dealership has replaced the CD player once but I am still having the same problem. How was your CD problem resolved?
  • My wife's 2005 Liberty Renegade Rocky Mtn Edition had the Low Tire Pressure Indicator light blinking in its instrument cluster. Due to the colder temperatures in SE Michigan lately, I filled each tire up to 33 psi. The light continued to blink right after starting it up and then it would stop. About 15-20 minutes of driving, it would then blink a few times again.
    Turned out I had forgotten to fill up the spare tire on the back. Once I did that, no more blinking light. Tire sensors apparently work just fine...as long as one remembers to check all the tires. :blush: Hey, I'm not used to having a full-size spare after so many years of having a small, emergency-type under the previous car's trunk floors.
    I wondered why her Liberty tire valve stems were so thick. Now I understand that they contain some sort of remote sensor that transmits to the vehicle control module the actual tire pressures. The last vehicle my wife had (Toyota Sienna) had tire pressure sensing but it used the ABS system to measure rotation speed of each wheel in relation to the others. I'm impressed the Liberty came with the remote tire pressure sensing capability.
  • I took my 2005 Liberty Renegade Rocky Mtn Edition in for 3,000 mile oil change and to have dealer address a noise my wife and I have heard coming from what seemed to be the brakes at low speeds. Dealer just called and said the rear brake pads looked damaged and since nothing but the rotors make contact with the pads, they replaced the pads and rotors.
    They've told me the brakes are covered by a 12-month, 12,000 mile warranty. They recommended I be sure to have the brakes checked again within that time to be sure they're wearing properly and if not, have them replaced for free under warranty again. Certainly, if I have to have those rear brakes replaced again within 12 months/12,000 miles, they'll have to agree that there must be some other underlying problem like a faulty automatic brake adjuster, emergency brake, or something like that.
    Dealer was very nice about it all and didn't sound like they knew of any known problems in this area. Unless of course, their statement to be sure I have the brakes checked again before the brake warranty expires means they have been down this path and know there's nothing that can be done except to regularly replace the brakes... :confuse:
  • john81john81 Member Posts: 60
    You're correct in your assumption that brake pads should have a longer life span than 12,000 miles. I would like to know, as on the front rotor, is it required that the rotor be ground down? If your pads were damaged, then the rotor might have suffered some surface damage or warrant a rotor change. Did they change the rotor?
    I do not know what information is allowed to passed on to the consumer in regards to parts replaced. There should be a full disclosure, atleast on paper to create a paper trail. Who knows, you might need to pass this information on to lawyer.
    You would be surprised how fast they start talking.
    John
  • bustervwbustervw Member Posts: 1
    I took my 05 Liberty Rocky Mountain Edition in for it's 5000 mile service a month ago. I also had them rotate the tires. Ever since then I have heard a grinding moaning noise from the rear wheels when I am starting up slowly. My tire pressure warning light has also started to come on periodically. The groaning happened while it was still warm, but the tire pressure warning just started when it turned cold in the last couple of days. Any advice?
  • Regarding your low tire pressure indicator light, see my post a couple items above (#1886?).
    I found I could induce the groan sound by slowly driving through the Jeep dealer lot using just the engine idle speed and then slowly pressing on the brake. I'd do this for about 2-5 minutes until the groan sound was consistent.
    The dealer verfied my concern by hearing the problem and they simply replaced the rear rotors and brake pads saying the pads looked damaged but they had no explaination. Certainly, I'm hoping the problem won't return but I figure my paper trail has begun with this first repair so I'll just be deligent to have them check the brakes for the next three 3,000-mile oil changes.
    Good luck to you and let's keep posting our experiences here so we can get a better idea of where this problem may be leading us.
  • chiefusnchiefusn Member Posts: 20
    Explain the difference between a Renegade and a 'Rocky Mt. Renegade. I thought it was one or the other.
    Your brakes are based on the hydraulic principle. Once the brakes are sufficiently "bleed", the calipers move the brake pads back and forth against the rotor from the movement of the brake pedal. Pretty fundamental. In automatic transmissions, while at rest, your foot is on the brake petal. For how long? How hot can the rotor be, if in stop and go traffic? Can brake pads get how too and begin to delaminate from the constant braking and release? All brake pads are not made the same, or made of the same material.
    I have a manual transmission and I rarely brake, instead I jack brake when coming to a stop. Jack braking, like in larger 18 wheelers, is the downshifting and letting the engine's decreasing RPM slow the vehicle. Most cities or towns prohibit jack braking because of the noise. Yes I do use brakes, but not as much as automatic transmissions.
    Need to monitor all brake problems like delaminated or separated brake pads. All rotors changed because of delaminated pads. All rotors changed because of warping. All axles changed from overheated rotors.
    In your master cylinder, I have heard that if a service station overfills the reservior (master cylinder) it will add additional pressure to the hydraulics causing the calipers to push the pads closer to the rotor more than if the reservior was filled to required specifications. Need to check for verification.
    Good on you for a paper trail!
    John
  • seabassseabass Member Posts: 2
    We have the same or similar problem w/ our '02. The dealer said it it is most likely related to the multi switch that controls the headlights, dome, etc. They have replaced several and the problem goes away. Parts and labor are about $200. :confuse:
  • I can speak for the 2005 Renegade Rocky Mt. Edition...The RME version of the Renegade has the same squared off front as the Renegade but without the tow-hooks or the fog lamps. The RME comes standard with power sunroof and "Jeep" embossed on the front seat backs. The RME does not have rock rails or pocket fenders like the regular Renegade. My wife wanted a Liberty but really liked the Renegade front-end grill better than the regular Liberty front grill design. However, she felt the Renegade looked too macho for her with fog lamps, tow hooks, aggressive pocket fenders, rock rails, and optional light bar along the top. The Rocky Mtn. Edition was perfect in her eyes. It gave her the front she liked without all the heavy offroad impressions you get with the regular Renegade. She's very happy with it. She loves knowing she looks a little different than the many Liberty's on the road.
    However, I'm wishing it at least had the tow hooks on front and I'm now looking to see if I can retro those in myself. So far, it looks like I'll need to cut into the lower facia to get tow hooks on her Renegade...I don't think she's going to let me touch her little beauty, though. :P
  • jayriderjayrider Member Posts: 3,602
    You can buy tow hooks at the dealer---they install without cutting into your bumper. Two in the front and one in the rear [if you don't have a hitch]. The after market hooks are generic--- I don't think you want them.
    Thanks Jim.I have an 05 Renegade (lt Khaki) that replaced an 03 Wrangler Sahara. It broke my heart letting go of the Sahara, but I had to, as my wife hauls elderly relatives here and there and it was real tough on them entering & exiting. I've since found that the Renegade will do everything I asked the wrangler to do....but much quieter and more comfortable. However...there will always be a special place in my heart for my 'Little Army Jeep.'
    Thanks again....Chief
  • lmdiagolmdiago Member Posts: 1
    We have a 2003 and absolutely love it. The other day was very cold and when my husband drove my son to school the electric windows would not go down. After taking him to school and then going home the window still wouldn't work but he smelled electrical burning smell. He couldn't find anything so he locked up and went into the house. A few hours later he went out ot go out and the inside of the car was charred. The driver panel was burned, melted, and so was the driver seat. The insurance guy said it was good that the car was air tight because it burned itself out of oxygen. The dealer said this is not a manufacturers problem and we must have been smoking. Anybody heard of anything like this?
    Lynn
    Thanks for the heads up. My wife and I both love our 03 Liberty and as of today, we will stop crushing out our cigarettes on the driver panel and front seats. It's a new years resolution 5 weeks early.
  • kwagner88kwagner88 Member Posts: 18
    Hello all,
    I recently started up my 02 liberty with 56K miles on it in cold weather (about 30F) and the engine trouble light came on, started blinking, then went solid. I couldn't find any problems and the engine sounded fine (I had the radio on so did not hear the inital problem, though). I made the 1 hour drive home with no problem and then found out how to get the trouble code using the key switch method and found it to be P0303 which is a cylinder #3 misfire.
    Question #1: Looking from the front of the vehicle, which one is cylinder #3? I cant find the markings.
    Question #2: Is there a way to turn the MIL off without having an ODBII tester?
    My plan is to turn this lamp off right now and if it comes back, change the plugs and reset it again. If it comes back again, change the spark plug module on top and if it fails again, I guess I'm stuck having to take it to a dealer. If anyone has experienced this and knows the best course of action, please let me know. Right now, I'm just interrested in getting the lamp off so I'll know for sure if #3 starts to misfire again because I doubt I'll know for sure unless I get this code erased and I don't want to wait the 40 cycles necessary for it to go our by itself. Like I said, right now everything appears to be fine.
    Thanks in advance!
    I should mention that is is a 3.7L V6, auto transmission and that I replaced the stock plugs at 30K with bosch platinum plugs.
    Also should mention for those that do not know, if your MIL lamp come on: With engine off, insert the key and fairly rapidly turn to ON-OFF-ON-OFF-ON (NOTE that ON is NOT start). . after a few seconds, the odometer will start reading off the codes and then display "done." If there are no codes, it will just say "done." Another key trick is to hold the trip button in while turn the key to ON and this will initate a self test of the dash board gauges.
    This has probably all been posted before, but thought I'd post it again.
  • juicyjeeperjuicyjeeper Member Posts: 3
    I have an 05 Liberty with the 3.7 v-6. My problem is the car will not get out of second gear and the engine light comes on. It's doesn't happen everytime, but it is happening more frequently. It's seen the dealer 3 (current being looked at) times and they claim to fix the "shortage in the wiring". The problem still remains. Anyone else have this problem or know what it is?
    05 Liberty with the 6-disc changer. It would not split the CD's back out and say CD ERROR. I took it in and they replaced the changer. Same thing 1 month later, so next changer is being put in. The dealer claims that it is cause by playing burned CD's, but all of my friend and family have no problems with their cars (not jeeps). Has anyone had this problem??? Is the Dealer right about the burned CD's BS?
  • arlettearlette Member Posts: 1
    I have a jeep liberty 2004 any time we do any long distance driving something electrical goes wrong...the first time was all the rear lights went out leaving me with no lights at all brake or turn or reg lights on a freeway coming home..the bulbs melted into the lenses. the dealer replaced them the 2nd time same thing coming home from long distance drive all rear lights do the same thing in the dark on the freeway both times and a semi truck almost hits us for he could not see us the dealer replaces the whole circuit board for the rear lights..the 3rd time the mapping sensor which is also electrical goes out again on the freeway after a long distance drive causing my jeep to stall at 70 mph on the freeway in the dark all three times and cars swerving around us again trying not to hit us...this is 3 major times something electrical has gone out on the freeway in the dark leaving us in dangerous positions and jeep says it does not fall under the category of replacing the truck under the lemon law but I state it does fall under the product lib. law of an unsafe auto..has anyone else experienced these problems?
    On face value, when a service tech says that he fixed some shorted wires, I have to ask the following questions: So, what subsequent damage did the shorted wires cause? Just because you fixed the wires, did you also fix any damage which the shorted wires cause?
    Lets look at what damage could have occured: the main Computer chip controlling the Automatic Tx was damaged. This is why an error signal is sent out after engaging 2nd gear. The transmission must have a receiving unit in which the main computer chip talks to, this was also damaged.
    Did the technician repair the break where the short occured, or did he replace the whole wiring harness?
    Obviously, if the gripe (problem) still remains, the technician did not continue troubleshooting once he repaired the wires. Obviously, the technician did not conduct a test drive to validate his repair job was complete.
    So, I would have some issues with the original service department, because now other service departments are having to back track and determine what was done, what troubleshooting procedures were taken and what was the repair sign-off.
    I would insist a complete wiring harness be changed, the computer chip changed, the transmission receiving unit changed, the dashboard changed and all associated electrical units changed. An electrical short goes EVERYWHERE, so everything needs to be changed at the same time.
    John
  • delaney1delaney1 Member Posts: 2
    Yesterday I picked up my 2003 Jeep Liberty from the dealership.It drove fine home. We went to the mall. When I came out I started the car, it was running kinda rough and the engine light started blinking.There was no owners manual but using the techniques I learned here I was able to troubleshoot. The codes are P 0300,P 0301,and P 0306.What do they mean?
    P0300 is random, multiple cylinder misfire
    the codes ending in 1 and 6 is cylinder #1 and #6 misfire.
    As long as you changed the plugs at 30K, just reset the check engine light (requires a tester) and wait for it to return. See MY post a few days ago about my P0303 code. Since that happened, it has not returned for me so I chalk it up to a random event.
    My 2006 3.7 liter 6 spd Liberty has under 1000 miles, but already getting 20 mpg in the city. Synthetic oil with Prolong and just put in synthetic gear oil for the manual tx and transfer case. Cold weather and regular gear oil aren't best of friends.
    Noticed how some people wash their cars. The wheels and tires usually receive a health dose of cleaners or other solvents just for appearance. Imagine if those same chemicals are getting their way into your calipers, brake pads or rotors. Imagine what heat can do to solvents whose base is petroleum in nature. A chemical "base" is alkaline and great for cleaners, but horrible if allowed to penetrate exposed materials. How often do you rinse the wheels after you shine them up? Do you rinse them at all?
    While the rotors are cold, have you noticed that black material coming from the wheel after spraying the high pressure hose. Give the calipers a good rinse to prevent solvent build-up and harmful brake pad powder. Brake pad powder and cleaner solvent, I'm sure aren't a good combination.
    My rotors are running cleaner and eliminate any unwanted friction to ruin gas milage.
    John
    Thank you very much. I took the car to the dealership and they said that while cleaning the engine the fuel injectors became wet as the car was not running as it should have been when it was cleaned. Does that make sense?
  • renegaderrenegader Member Posts: 73
    Your post impressed me, so I asked the dealer...
    They explained to me, there are battery powered remote sensors - transmitters, made by Siemens, in all 5 tires. It should be the same system which is in use on Mercedes cars for aprox. 4 years. Nice thing!
  • kubrick4277kubrick4277 Member Posts: 1
    I can't get my 2003 Liberty out of 4 wheel drive. I lost the manual. What should I do?
  • hcb56hcb56 Member Posts: 1
    I have the same car & CD-Changer. All I have ever put in it is burned CDs & it has never malfunctioned. Unless there is something seriously wrong with your CDs, the dealer is full of it.
  • giog99giog99 Member Posts: 2
    I have a 2004 Jeep Liberty with under 12K miles. Lately, while driving at low speeds, usually when car is cold or having sat for a while (a few hours, give or take) not driven, an odd moaning-like sound can be heard from the left rear wheel area as the car moves forward or in reverse. it's not a grinding sound or a screeching sound like bad brake pads. It sounds like it could be mechanical in nature but it only lasts a few 1-2 seconds and it can be very soft or loud depending I guess on the conditions. Once I increase speed, the sound goes away. Sometimes, if I drive at a slow speed, under 5 mph, and listen carefully, I can hear a rythmic sound that coincides with the wheels turning. It's the same sound but just softer cause I'm driving very slowly. anyone experience this?
  • Check my post #1887 and #1893. My past experience with brake pad/rotors/drum problems involved more of a screeching/grinding sound. However, I do think what you're hearing is something wrong with Liberty rear brake pads/rotors or as I suspect, brake adjusters. You may be able to induce the problem by slowly driving (at engine idle speed) through a parking lot while very gently touching the brakes. Once you hear the "groan" as I call it, try pulling up the emergency brake lever with the button depressed so you don't rachet-lock the parking brake. While holding the emergency brake release button you can pull and release just the rear brakes and see if the groan goes away while the emergency brake lever is being pulled up.
    I have a suspicion that there is a design problem in the Liberty brake adjusters. Have your rear brakes checked by the dealer before you go over 12K miles since according to my dealer, the brakes are covered for 12-months/12,000 miles.
    Let us know what you find since there have been other posts in here about strange "noises" coming from the drive-train or brakes in our Liberty vehicles. :confuse:
  • jo4lolajo4lola Member Posts: 1
    My radio died. Kerplunk .. dead ... I want to replace it, but the factory replacement is almost $400. I researched used ones or junkyards and couldn't find any. OI would like to replace with a satelite ready model. Doeas anyone know what size I need? Can I get 1.5 Din or 1 din .. or do I need 2?? I am so confused!!!
    jimlw2,
    thanks for that advice. Your description sounds pretty much like what I am going through. I hear the groan sound mainly at very slow speeds as when coming to a stop or stepping on accelerator. In slow moving traffic, with either stepping or not stepping on the brake or accelerator, the groan is there. Interesting note: with colder weather, the groan is less frequent. I've noticed it is more apparent in humid or warmer temperatures. I'm still going to get it checked out, though.
  • glhperformanceglhperformance Member Posts: 24
    I have replaced my factory cd player with a pioneer cd player with xm 1 din in size any retailer that carries aftermarket radios will have a mounting bracket and wiring harness to connect an aftermarket radio very simple to hook up or you can get an instaleer to do it for you anything else just ask, Its a Jeep thing
  • ldineenldineen Member Posts: 1
    This morning, the engine light started blinking and the Jeep started shaking. Over 30 mph caused it to shake. Then there's a tick-tick-tick under the hood. Dealership said it could be a cylidner misfire (???). I have two children and a traveling husband and am just sick over this. Does anyone know if this is covered by the powertrain warranty (41,000 miles) and how serious this problem could be? They did ask me when the last time I had an oil change, which was August. Your thoughts?
    just imagine taking out a spark plug and trying to run the car. In your case, the spark plug is in, but it sounds like the valves or the spark plug is hitting the top of the piston as the crank is turning over. Take out the spark plug to see if there is any damage to the electrode or if the electrode is missing. There could be several problems from a bad rocker arm, burnt or stuck valves or something broken in the lower block.
    The bottom line: I would get an estimate and let a mechanic determine the problem. Worse case situation is an engine change or perform a "head" job and hopefully repair the problem then. All it could be is a spark plug repair, but I'm not betting its that.
    I would be looking for any oil leaks from the head gaskets or oil pan gasket. Any antifreeze leaks into the oil (internal) itself.
    41,000 is almost a new engine. There are other factors which are at play here, which you may not have mentioned.
    I feel your pain when it comes to reliable cars and having your kids put in dangerous situations because of car trouble. Good Luck
    John
  • mikkidisneemikkidisnee Member Posts: 2
    I finally saved/scraped up the money to get the A/C compressor fixed. During this time, I did not drive the Jeep at all!! Luckily we had a spare vehicle! Anyway, I took it to the dealership and they said that the compressor had seized up and they had to replace the drive belt. That was on Thursday.....Saturday, the first time I had it out on the highway, it did the exact same thing when I slowed down for the speed limit change and down shifted!! It died, leaving me and my 6yoa daughter stranded in another town. I got the Liberty back home and to the dealership and just found out that actually the original problem was the Cranking?? Sensor which deals with timing. The service man said that although my Liberty wasn't displaying a check engine light, they hooked it up to the computer and got a code!! The real kicker of this whole mess, that probably won't be under warranty is....I had to take this Liberty in when it had under 12,000 miles on it because it was misfiring.....at that time I was told I had gotten a defective spark plug and they were all replaced....and they were replaced again 12,000 miles later and again about 12,000 miles after that.....after the last time the spark plugs went bad, I stopped handling it and let my father (the service department was much better dealing with a man than a female) At that time I was told that there was something wrong with the ignition which was causing the spark plugs to foul out. They replaced some part (sorry I don't know what it is called, but if you email me, I can get the service records from the dealership). However while being fixed, the electrical device that displays the "check engine light" was either broken/disconnected....so I had no way of knowing there was still a major problem with the Liberty. And from what I have been finding out, both of these problems are related and possibly could have caused the compressor to seize up!! All the dealership service department is telling though, is that I just had some defective parts......
    does anyone know where you can get a front bumper cover for an 05 liberty sport for cheap
  • jcarv76jcarv76 Member Posts: 4
    Yes that is covered by your 70000 or 7 year power train warranty. Check with the dealer for details. You'll be required to pay the $100 deductible though.
    Jeff
  • ree691ree691 Member Posts: 8
    Put your Jeep in Neutral then take it out of 4WD. It works for us. :)
  • rambo4rambo4 Member Posts: 1
    Here are my problems; I hope someone can respond. I bought a Liberty in May and have 6,000 miles on it. I have had the rear brakes replaced twice (once rotors and pads, second supposedly just pads) and now am told the emergency brake system is shot and has to be replaced. I also get horrible gas mileage. am researching how the brake systems work with each other.
    Any help will be appreciated!
    http://www.442.com/oldsfaq/ofbrk.htm indicates that parking or emergency brakes should be adjustable. In a few messages back, one person indicated that the maintenance technician said the Liberty's parking brake cable was not adjustable.
    According to the history of this gripe since 2002, you would think a modification would be designed in.
    You are doing good in keeping a paper trail of any maintenance actions. Keep an eye on the differencial outer seal, make sure it's not leaking. Rotors become very hot and this heat is transferred straight into the rear differential.
    I would quiz the maintenance person on what he would do to "really" fix the problem. I can't believe that some "on the ball" technician hasn't submitted a suggestion to Jeep on what can be changed to fix this problem.
    Also have the technician check the automatic transmission momemtum while at rest. When you press the brake petal, you are effectively "forcing" the automatic transmission not to move. I believe there is a clutch assembly (linkage) that may need adjustment. Heat can be generated through the brakes if the automatic transmission at rest is over-powering the brake's hydraulics.
    I have an manual transmission, and have not experienced any brake or parking brake issues.
    Chances are, the Liberty will be phased out in favor of the Dodge Nitro. So Jeep, isn't in any hurry to make any life threatening changes. That's why the post, "Why American's aren't buying American cars", so to complain about Jeep's design flaws.
    I would be interested in hearing what the service dept says.
    Pre-mature brake failure - Main suspect is heat. Heat warps. Warps are a consequence to the main suspect. Problem is why are the brakes overheating. Caliper alignment, Parking brake friction, improperly installed brake pads, hydraulic problem in brake system. That's all I can think of.
    Now, see what the tech says. . . .
    John
  • pennyosbypennyosby Member Posts: 2
    I have a similar problem, with my 2002 Jeep Liberty Sport; when I am driving with the headlights on, the headlights, will blink on and off several times then shut off, or if I use my signals with the headlights on it does the same thing, and my interior lights also come on on their own, although if I hold my signals arm forward it will keep the headlights on, and it is frustrating, I was told it is my headlight switch in the signal arm,is this a problem that my husband may be able to fix or is it a problem only a mechanic can fix?
    I have an '02 Jeep Liberty Sport, and I really love my Jeep, I wanted one when they first came out and were being given away by a soda company, I got my a year ago, and I have had very little problems except, for the headlight switch, my headlights blink of and on and then shut off, and I cannot use my signals when I have the headlights on, but that can be fixed, and sure the gas mileage sucks, but HELLO! it is not a compact, fuel efficient car, it is a suv and yes it uses more gas, but I think the gas mileage is not too bad, I love my Jeep, I will never own a car again, I baby my Jeep and have little or no problems with it. So if you don't like the Jeep don't buy one and if you own one and don't like it get rid of it, me I am going to keep my Jeep and simply drop a motor in if needed and a new tranny if needed, there seems to be more and more of them on the street and more and more people who love the Jeep so I guess there can't be much that makes it a bad purchase decision.
  • tninspectortninspector Member Posts: 2
    Thanks for the info John. But now I am having additional issues my ESP/BAS is messed up. I think somehow both issues are related. Loss of engine power & probelm with brake system. I can be going down the road and my brake system engages. It will all of a sudden apply brakes just for a second then release. This poses a huge problem when raining and on interstate at high rate of speed. Dealer states there are no tech bulletins out on this yet. But found on a yahoo group where someone else has same problem and dealer stated part to fix ESP/BAS has been on back order since 2006 Liberty was released. Any suggestions??
    Let me run this by you and see what you think. ESP/BAS system (ESP - Electronic Stability Program/BAS - Brake Assist System/TCS - Traction Control System.
    TCS monitors wheel spin and acts as an electronic Limited Slip Differential.
    ESP uses sensors in the vehicle to determine the vehicle's (slide) path. Corrections in the anticipated slide path brings the vehicle to the correct posture via the braking system.
    BAS measures the hydraulic pressure applied to each brake and adjusts this hydraulic pressure between all four calipers.
    Anytime someone mentions sensors, I think of "yaw" accelerometers to measure a 2 axis plane, forward-back and side to side. These sensors are connected to the main computer which apparently has total control of the braking system based on electro-hydraulic "pick-offs". To move hydraulics from greater pressure to lesser pressure to equalize the total braking system means several electronically controlled valves.
    I am trying to get a hold of a 2006 Liberty manual and see if these hydraulic systems really exist or not. I know that systems with stuck accelerometers can do real damage if not calibrated or operating properly. I may be reading too much into this, but, again I need the manual to be sure.
    Love them ball joints. I thought the Jeep Liberty was supposed to have this awesome front end suspension. Look for ball joint failure. I would look for bad grease fittings, cracking rubber seals, bushing and grease fittings near the rotor or engine block. Heat and rubber seals are not best of friends. Check all U-joints for freedom of movement. All stuck or sticking U-joints need to be replaced immediately. Usually a clicking sound indicates a stuck U-joint.
    Check for "dizzy". What I mean is, when you turn around in circles, your inner ear looses its reference and you fall down. So, take this and apply it the hydraulic brakes. Whe you press your brakes, the car does not want to go straight. It appears that the brakes are putting more pressure to one side, thinking its loosing control. One of the sensors is "fooling" the car that its in a spin or about to spin out of control. Try that logic and see what happens.
    Went on a 147 mile trip, used 5.29 gallons for a grand total of 27.78 miles per gallon. Since I have a manual transmission, I have not experienced any of these braking issues.
    I do not know if the automatic transmission enteracts with the braking system. A sudden RPM change, I would think that the computer would communicate to the automatic transmission that the engine was slowing down.
    Keep up the paper trail and encourage your technician to submit maintenance bulletins.
    John
  • rc1jeeprc1jeep Member Posts: 1
    Crazy thing going on with my Liberty. At the gas pump, you can fill up using full pump pressure, seems like an air block maybe, and when you turn off the jeep, you can hear air either blowing out or sucking in around the fuel tank area, you all every heard of this? :mad:
    What does "permanently" lubricated ball joints mean? If they are permanently lubricated, then they must not require further lubrication. So, they are permanently enclosed filled with grease. Compare this with the old CV joint. Once the CV boot (rubber outer protector) was compromised, then the whole assembly needed to be rebuilt. On my old Jeep Cherokee, I changed out all U-joints and reinstalled 1330 series U-joints with grease fitting points. I changed all ball joints (drilled out the old rivets holding on the ball joints) and installed new ball joints with bolts. This is how you tell that the ball joints have been changed, look for bolts. I changed my ball joints every 35,000 miles whether they needed it or not. Here I could also check all the bushings, seals, grease fittings and U-joints in the front suspension. Dodge and Chrysler products have a long history of front bearing problems, so here I repacked both bearings with Moly-B grease or synthetic lube grease. Also check the rotor, caliper and brake pads for wear and warping.
    I have always used synthetic oil in my engines. What happens is that some people go 6000 miles between oil changes. But what they miss are the lubrication "maintenance cycles" where all the fittings, knuckles, U-joints and what ever else are packed with a fresh squeeze of lubricant. This 3000 mile lubrication cycle is very important, and Jiffy Lube does a good job with this if you don't want to do it yourself.
    Drift in your front end alignment is the first tell-tale signs that something is wrong with the ball joints. Tire wear is not a tire problem, its a front end problem.
    I bought my Liberty, like my old Cherokee because they are easy to work on and there are plenty of spare parts around. Don't get me wrong, I'll get on Jeep for putting production quota's over quality. So press your maintenance people to initiate maintenance bulletins whenever possible. Believe it or not, the more bulletins means added pressure on quality assurance to do a better job on the factory floor, rather than at your dealership. This means an over all better product for Jeep.
    John
  • disgruntled6disgruntled6 Member Posts: 2
    A close friend was a salesman for jeep. He clued me into putting it in 4WD FT on wet roads, PT in snow. Makes a big difference. Even with "good" tires.
  • ronmacronmac Member Posts: 1
    We bought our 03 Liberty new in 8/03 and have had the same problem since we bought it. We took it in for a brake replacement and rotor adjustment in 1/04 at 3,500 miles. It has been in for brake replacement and rotor adjustments 4 times and 1 time for the emergency brake pad replacement. I don't know wht your symptoms are but ours has howling sounds from the rear end after it has been sitting awhile. I love my jeep, but I am concerned about resale since it is definitely hard to ignore. My husband called Chrysler today and they are supposed to be in touch with our dealer through the Star program. Our dealer told us the first time we took our Liberty in that the howling brakes was a known issue with Liberties. They have fixed 2 of 4 or 5 issues, but seriously, i don't know how. The time before last, they said they had "the" fix from Chrysler, but it made no difference. In fact after this most recent exchange, it might even be noisier.
    Wow!
    Mechanically here are your options:
    1. Sell it
    2. Trade it in (show paper trail of maintenance actions done by the dealership and their apparent lack of technical knowledge, because if they were on the ball, they would have fixed it the first time. Would I call it neglegence if the Service Dept. gave custody of the car to you knowing that it wasn't fixed or never test drove it to see if the repairs were good, Sounds legal to me.
    3. If Jeep indicated that a "fix" was either in the works for your Jeep was a test vehicle, then apparently the "fix did not work". The dealership needs to know this, so they can tell Jeep to keep trying. If Jeep is honestly trying to fix the problem, then my question is, why should you be paying for a potentially life threatening experiment?
    4. "Money Pits" have no sentimental value, atleast for mechanical cars (not necessarily for people).
    5. So Jeep did know about the brake problem, dispite their best efforts to ignore the problem, OR tell unsuspecting consumers that it was their imagination. Lemon Law anyone. I would get that technician's deposition about what he knows, then talk to a lawyer.
    Putting money into a lost cause goes against every logical decision. How much time and effort put in selling it against putting the money out and hopefully fixing it once and for all. I would take my Jeep in for a final time, have all previous maintenance actions presented to the dealership and have a lawyer present with you. Sound terrible, Oh Well.
    John
