Visitor Agreement.
From this perspective, doesn't it seem that attention to engine tune and driving habits are much more significant to the environment than is the possible too-frequent oil change frequency? Indeed, frequent oil changes are a distinct factor in maintaining good fuel efficiency as the engine ages.
We know that the earth is in a warmup cycle and for it to happen so quickly really defies common sense. Both southern and northern ice caps melting and 9 out of the last summers the warmest on record. Warmups can happen, but not that fast. Naturally politicians follow the trail of money.
We'll worry about it when a piece of ice comes down to New York and scrapes a portion of Manhatten away.
And really the supply of oil is not the question. Few think to question that as CO2 increases oxygen is decreasing. That's the scary part.
Oh well-support terrorism-buy an SUV!!
get the idea? No one knows.
I have spread the word about Fram to everyone I know. I was a brand loyal customer of them until I found out about their cardboard construction and poorly functioning anti-drainback diaphragm.
Texas Trucker
the OEM filter for the 3.8 V6 is a tiny little thing not much bigger than a coffee cup. For a hard working supercharged engine I don't think much of GM's choice.
Al
I did [non-permissible content removed] enough that he gave me a card for a future free oil change. Free oil and $20 for the genuine Valvoline filter, maybe?
I will take in one of my PureOne 10111's and line it up against
the PL 24011 and see how it checks out.
The GM 3.8 V6's don't give you much room to get the filter in and out, but once you spin it on, there should be enough room for a bigger case. I love the design of the 'PureOne'..it looks like its built like a little blue bank vault.
That engines oil system has its own bypass filter built in, and the tiny 10111 is the special filter for that application...wonder if the bigger Pureones' , Amsoils, K&N's or other larger sized canisters mentioned, have the same internal specs' as AC's PF 47 ? And if not, does it really matter?
http://www.salemboysauto.com/faqs/faq-30.htm
TB
BTW, I am no longer a fan of the Pure One filters. After cutting a couple up and finding the wall thickness is only .010". Maybe not a big deal-but I'm uncomfortable.
Champion Lab Filters-(Mobil 1, K&N, and SuperTech) have a wall thickness of .017". Hastings and Bosch are .015".
The SuperTech (from WallyMart is an outstanding filter (its efficiencies are as good or better than Pure One. I have cut up one and they are very well made. The number here is ST 3980 . I just put one (oversize) on my son's Cav yesterday. Next time I get to Walmart I'm gouin go buy a half dozen so I have a reserve before they change suppliers. $1.97-unreal!!
Taking into account that one only sees the filter twice in its life span, a heavier canister buried down there out of sight, would be a plus, but at that price, it's sounds like the perfect compromise
of all the things us Paranoid Oilheads lose sleep over. I will check availability of the ST 3980 for the Park Ave..BTW is there a larger Super Tech filter for the Dodge Caravan 3.3. ltr as well? Sorry I don't have a 'Filter Book' and most of the pages in the one at the local Wall Mart have been ripped off/out
Later,
Al
the filter media was on the short side - that made me make the statement that wix was cheating you.
castrol max pro (wix) 64 sq inches
Super tect wal mart 70 sq inches
purolater 94 sq in
purolater has 50% more area than wixcastrol. cost is about the same, hence I think wix is shorting you
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
Here's what I have boiled this down to:
Use either K Mart or Walmart "two dollar" filters. We must be diligent about any change of suppliers, or negative change of specifications.
Filter MultiPass % SAE Test Micron Size
Mobil 1 96% (web site) ? 10-20
Mobil 1 95% (on box) J806 10-20
Pure 1 96% (box) J806 10-20
SuperTech 99% (box) J1857 ?
Fram EG 94% (box) J1857 ?
Fram TG 99% (box) J1857 >20
Bosch 93% (box) ? 15?(per 800 #)
K&N 90% (box,MP? or SP?)? 10-20
The single pass data also use different sources. SuperTech cites SAE HS806, Fram TG cites J806, Fram EG cites J1857, Mobil claims 98% with no SAE test identified, and I couldn't even find a SP % for Pure 1.
It gets even worse when you simply read the product literature on their web sites and else where. Purolator mentions that their Premium filter traps contaminate in the 10-20 micron size but offers no data to back it up. Dido for Fram, Nissan and some Motorcraft sites that mention 10-20 micron filtering ability, but no SAE data or reference test. And then there is Amsoil. They brag about HS806 numbers for "filter efficiency" and "filter capacity". Trouble is no one else cites those stats.
This is nuts! Almost enough to make one stick with the OEM filter. Maybe the manufacturer knows something the aftermarket guys don't want us to? Of course there is always a trusty dart.
Congrat's on all the leg work on those filter numbers. Too bad you didn't put in the store
prices on each . That's about the only REAL information left to us consumers, to make our final decision on filters AND oils. Weather we buy 'Leading Brand A, B or CYA'.. All the rest of those fancy graphs and info on the filter box is mostly marketing hype that goes this way.............
"Dazzelem with footwork and Baffelem with Bull"
The 'market place' will probably decide "who has the best Filter" and it will be the one with the studiest construction, excellent
multi pass' ratings, a large filter area, be readily available at the big Auto Parts Stores, AND, will cost under $2.00 ea.
bluedevils: Its almost certain, in my opinion that they are (SuperTech) all good. I forget the leter, but check acouple of filters and check the letter designation on the filter head, I think its a "Y". All should be the same (made by Champion Labs).
Later Guys.
Go for it.
2. The Mark Salem posting stating that Champion Labs made Valvoline filters talked about filtering media being tied to expected oil viscosity, i.e. a car needing 5W30 needed different filtering media than a car needing a heavier weight oil.
Salem's radio show is syndicated in St. Louis (actually it's StL specific even though his shop is in Phoenix) and he usually seems pretty knowledgable. He constantly calls for lighter weight oils comparing 10W40 with peanut butter. Is he right that too heavy an oil will defeat some of the filters out there?
3. The discussion (synthetic oil posts) of the post SL grade oil having less protective abilities (converter burnout is more important than engine longevity--get it past 100K, and then who cares) has me rethinking STP for cars other than beaters. Salem's warning about higher viscosities gives me pause on the whole subject.
Probably not much of an issue during summer though
Talking to my Infiniti Service Representative, he says to use the factory filter no matter what kind of car it is. He said that Infiniti's has a check valve and its better to be safe than sorry. I am sure there are others that have a check valve and probably some that are better than the factory. I just bought a 2002 QX4 in January want to treat it right from the outset to make it last a long time.
I'm purposely not defining my terms.
What I'm wondering is, how important do you folks think the filtering area is vs. the quality of the filtering?
I'm intrigued by the SuperTech filters, but if the ST for my vehicle is really small, I'm wondering if I'm better off with a bigger filter that's not quite as well-regarded.
Because the SuperTech filters are made by Champ, and given some of the previous comments about the filtering media Walmart uses in them by our resident filtering manufacturing guy, I'd say they are very worthy choices. But some are way too small! The Fram 7317 filter for a Nissan is the size of a small coffee mug. The SuperTech equivalent (6607 I think?) is the size of a large golf ball. So I'll pass on the SuperTech and go with other brands that I think have better area and quality. Some SuperTechs are comparable in size however, and I wouldn't be afraid to use them.
wain If you are using the M1-108, I believe the M1-110(longer) will work.
Al
adc100: Those K Mart WIX filters are a size I like... (:oÞ
Well...I'm off to cut open a WIX.
Later,
Al
whats that about?
