Oil Filters, whose is best, and Why?
1. after removing the old filter wipe off the area at the engine where the rubber seals against. Then take your finger and run it all around to feel for dirt. I know it can be hot.
2. If the filter is mounted vertically, which it probably isn't on the altima. Fill the filter with oil before installing.
3. Make sure your finger is clean and dip it in the new oi and run it around on the rubber gasket to lub it.
4. Make a mark (permanent Marker) on filter so you can tell that you get 3/4 to one turn after contact as was mentioned.
5. Your altima has a copper gasket at the drain plug-I assume. They are supposed to be replaced each time. You need to carefully pry them off with a small screwdriver, working your way around it. Sometimes its a [non-permissible content removed]. Its possible this gasket was used one time to many. They are usually good for several (at least) changes.
6. You really should invest in a "click" torque wrench and torque the plug to about 20 ft lbs. That number works on every plug I use.
7. You can screw off that filter if its leaking. You will lose a little oil plus whats in the filter. Total about a pint or less.
Oh-check filter for leaks by running at fast idle for about 30 seconds and feel around filter. Make sure filter has no oil on it before checking.
and thank you all for your advice... I will remember to also fill the oil filter with oil...duh!!??...i cant belive i forgot that part!
After turning 3/4 turn After Contact and marking it, do i use a wrench or my hands???because i read in this Haynes book that Do not use wrench to tighten the oil filter because over tightning causes...etc..
again thank you very much
This, changing the copper washer/gasket, is kind of weird b/c everytime i take it to a place to change my oil, they never change that piece...??!
I dont see any leaks...so i guess its ok...dont you think?
thank you
Later. We're to help any time.
Seems that Wal-Marts in my area are no longer carrying the low-end Frams; could this be because they're being phased out in favor of the TG, EG, and X2 filter lines?
Maybe they started reading stuff on the internet???
We can only hope!!!
"Boy, those Fram filters made by Honeywell suck."
"But not as bad as the ones made by Allied!"
According to the boxes for the X2 filters, they can go 7000+ miles on dino oil. I wouldn't trust it. Of course, they're sealed in a canister, and I'm not gonna pay $9.00 to cut one open and find out. I'd rather pay $9 for an OEM Nissan filter :-)
some of the filters I cut open have a lot of unused space in them
They look fine to me.
If a filter has a 'W' stamped on the metal on the open end of the filter, does that pretty much guarantee it's made by Wix? The Kia brand filter I installed on our Sedona minivan last weekend has a 'W.'
The white and the yellow are the same on the inside, the black uses thicker paper (says synthetic mix) and had slightly less sq inches..
The thicker paper still FILLED the cannister though.
Nothing wrong that I could see.
In the next month or two, I'll cut apart a Wix & Penske both, & compare filter material. May be interesting. ;^)
At 5 bucks, the Castrol MaxPro Plus (black box) seems like not a great bargain. For that price I can get a Purolator PureOne, which has been my filter of choice for a while. However, I'm starting to think any decent filter will do, since my change interval will be 3,000-4,000 miles with SL conventional oil.
Higher efficiency filters are better for normal shorter intervals. Standard efficency filters are better for extended intervals (they actually gain efficiency as they start filling up with contaminants). As the filter packs up with material, the efficiency goes up and the flowrate goes down.
Actually a little known fact is that AC Delco PF 44 have synthetic filtering media. I am at comfort buy on price (supertech, AC Delco) AC Delco PF-44's are the specified filter for the Corvette's up to 15,000 mile oil change or 12 mo. Also little known is that with this filter and oil, the statistical middle of 175,000 miles has been tested for.
High efficiency filtration is fine for someone who really has a thing for clean oil, but they should not expect those high efficiency filters to be used for extended drains. Any standard filter that is constructed well would be good for extended drains, it would gain efficiency anyway as it collects dirt through its service life.
As for the price, to me $4.99 is nothing for a filter. If I can keep the smallest particles out of the oil by changing the filter more often, using a filter that traps as much dirt as is practical and using a synthetic oil that can better handle the South Texas summer heat, saving a buck or two on a cheaper oil filter doesn't make sense. Using a good oil but a cheap filter that will let particles wear on the cylinder walls seems foolish to me. If you live in a dusty climate, such as a city with dirty air or drive on a lot of dirt or gravel roads, I would strongly recommend frequent oil and air filter changes along with a good PCV valve.
By the way, I cleared out the local K-Marts when they were closing of all the black-box Castrol filters that fit my truck and my wife's car.
PAman: Those filters you bought should be very good. They are made by Wix, which is a highly reputable company.
You mean about the filter or the durability of the engine using the synthetic oil GM4718 standard aka Mobil One synthetic and the AC Delco PF44 filter? "
The synthetic filter (AC DELCO PF-44) and synthetic oil meeting the GM 4718 standard, ( ie Mobil One etc,) given an up to 15,000 mile/ or 12mo oil change interval has been statistically tested and calculated to last 175,000 miles. 175k is the middle most point, so you would expect the normal distribution curve to occur. (8 SD's of app 12.5% per SD. Obviously there are many variables that would effect/affect this but with good care and systematic maintenance, which includes up to 15k mile oil change intervals given synthetic oil and synthetic filter ie AC DELCO PF-44, it should go the distance! So for example if distance is your concern, rev your engine no greater than 80% of the redline.
What i find interesting is that this is a "high performance" engine!
New oil and new filter, not much dirt in the oil yet. As the dirt starts accumulating in the oil the filter is its least efficient and the flow is the highest. As the filter starts filling up, the efficiency starts going up too, and the flow starts decreasing as well. Then you get to 5k miles and put in a new filter and top off oil and start over. It's the best way to use a high efficiency filter and get the most benefit from expensive synthetic oil.
Keep in mind though the AIR filter also filters the best when it is a little dirty as well (the dirt actually helps with the filtering..), usually best to leave it on until it is really dirty. I use water filters at my house (we have a well), I wait until I notice some reduced pressure before I change those filters, they are REALLY covered with clay and they are still flowing plenty of water, and that water is actually cleaner than with a new filter.
I have 2 Chevy trucks with the 4.3 motor, I use the Walmart filters and standard Havoline/Chevron oil and change it at 3 kmiles.
Keep on truckin!!!
Filtration is a cool science, it is amazing how a filter can perform even when it looks really bad.
In order to really tell when the filter needs changing you need a pressure gauge before and after the filter, and when the pressure drop across the filter spikes it is time to change the filter..that works for air/water/oil..whatever.
It's a judgement call for the individual user, do you want flow or really clean air...usually the flow is more impt for engines that run higher rpms, other engines don't rev high enough for the filter to usually be an issue,,enough air still gets through. Same with fuel filter, folks don't see a problem until they start noticing the high rpm is surging but lower rpm is fine..that lets you know the filter REALLY needs changing. More dirt actually goes through clean filters (any kind) than dirty ones though, its just a fact.
see ya
Rando
The main reason I use the K&N air filters is just that they can go longer between cleaning than the paper filters can go between replacing. As far as them having INCREASED air flow due to additional dirt in the filter, they can say whatever they want to...I don't believe it (extra dirt will help efficiency though). All I care about is they work good enough for my trucks,,any real high air flow benefits mainly help high rpm engines and my trucks aren't.
Have a good day
Rando
Also, I've always used Fram air filters (when I'm not using a K&N). Though their oil filters are crap, I've never heard anything bad about their air filters. Have any of you?
Now, on oil filters, yep. Many are better then OEM including Mobil 1, Hastings, Amsoil, K&N and Pure One
