Visitor Agreement.
There are some trucks running around picking up used motor oil-I also notice they have a special hazardous material warning sticker on the tank. Am told some of these collection companies charge to pick up the oil.
Just don't pour it down a storm drain or your toilet-that really screws up the works.
Can some one feed back?
http://www.autopridegroup.com/switch.html
Thought I had used them before with no problems..
Tried to remove it today, the cup wrench I have used before slipped and woud not remove it.
Had to use gant channel locks.
Has there been any dimensional change in the filters?
That solved the problem.
Thanks to them.
(filter had 15 flats on it vice 14)
There is like a adjustable wrench that can be used with a socket set extention and ratchet wrench that is a real winner! It can put a lot of torque on the filter (if needed) and cost app 7-9 bucks. In addition it does not mar or damage the filter upon installation or removal.
For example on one machine, I actually put a torque value of 22ft#'s, because one time another filter worked loose that was not torqued to 22 ft #'s and put on the old tried and true way of 1/4 to 1/2 extra turn once the seal presents resistance.
Here in this neck of the woods a Kragens, PEP Boys or even an Idependent. This wrench looks more rectangular, with like 4 metal fingers or extensions. It is NOT an adjustable strap wrench!
You are correct. I wrote a "typo." It should have read 3/4 to 1 turn. The 22 ft #'s on the AC Delco PF-44 filter comes from the vehicles service manual. This was the first time in 40 years of oil changing that it has EVER happened to me!! For that vehicle I very definitely go with the recommend torque values!
a better cap design would be a welded on socket area for the extension to press into
I stopped by a couple of Kmarts today, seeking Penske and Castrol filters for my latest vehicle. I am now 99.9% convinced that soon there will be only Fram available at Kmart. I read a sign at the second store that said "No returns on discontinued filters-- Penske and Castrol." They were on clearance prices, and the selection was poor. I found two filters I could use, and bought them. I will likely turn my attention in the future to Champion made filters at Walmart and Autozone-- Supertech, STP, and Bosch-- In that order.
BTW, in feb 87 issue of consumer reports the fram was far and away the best filter accross the board, and that is for both capacity AND minute filtration. Because of the consumer reports article, Ive used fram from then untill I started reading this thread. The exception was using genuine toyota in our 150k mile 4 cyl. camry. The dealer has the toyota filter cut open on display next to a {would you know it} FRAM!
As you can see you guys have changed my oil filter buying habits probably for life.
At $1.97 for a superior filter, I can live with that.
less super techs each year.
Fram may pressure the store, sorta like Kraft foods used to do on salad dressings and proctor and gamble on laundry detergent.
old cup wrenches dont fit on the frams with the grit material on the ends - are those frams supposed to come off without a wrench?
http://www.stant.com/brochure.cfm?brochure=622&location_id=193
It is ruggedly made and the extension allows you to remove or tighten filters that most other wrenches cannot reach.
The extension part of this wrench is parallel to the length of the filter, so only about an inch of clearance beyond diameter of the filter is required. If you have a proper fitting "cup" type wrench, use it. But, if not, this wrench works just fine and the price is right.
can someone post a pix or plews website?
Kmart AC PF20 243sqin std paper
Motorcraft FL300 293sqin Purolator clone
Penske Maxpro CM43 263sqin Wix clone
Nissan engine is the 2.4l 4cyl, I used Frams years ago, but stopped when I learned how they were causing valve noise until the oil warmed up.
see y'all
Rando
horizontal. Lot of good suggestions since I posted "Keeping oil off me". Someone told me if I let the truck sit an hour after parking it, the oil will drain out of the filter. I thought the filters are designed to keep a certain amount of oil in the filter so it gets to the engine as soon as possible after you start the engine.
Base stock is actually Exxon (probably). Some of the SuperTech production has been shifted to Warren Petroleum. Here are spec. sheets for the four PZ/QS brands. The ST is an old spec sheet for their SJ oil.
Super Tech filters are Champion Labs.
10W30 SuperTech Pennzoil Quaker St. Wolf's Head
Visc. 40c 73.2 67.0 69.1 65.3
Visc 100c 11.0 10.5 10.5 10.5
Visc. Indx 140 160 139 138
Flash-F 410 430 410 430
Pour-F -29 -33 -22 -17
Low Pumping-C -25 -30 -22 -30
good luck
Rando
the way the fram bled down because of the bad check valve, the only way to get an accurate oil check was right after turning off the engine before the oil had a chance to drain back. no more fram.
