Visitor Agreement.
on another note, what's your opinion of blackstone labs vs. dyson? which is more accurate? I see that dyson is cheaper at 10 dollars per anaylsis, but blackstone gives you free oil test kits. sorry if I'm way off topic, bob's board is down at the moment for routine maintence.
Now, on my 2002 4-cyl 2.0L Mazda Protégé engine the drain hole is again several inches below the oil filter. At my first oil change I waited about an hour after draining the oil, then removed the filter, and I was amazed that seemingly not a drop of oil leaked down from the filter mounting area. And the oil filter looked as if it had no oil inside it at all! Can anyone say if this is normal? Or, if not, what might make this happen? I’m stumped!
Since there is no leak back, the actual task time is shorter. While the oil is draining you can be wiping down the oil fittings and greasing or oiling the seal on the new filter and retorquing back on. Some folks go so far as to pre load the new oil filter with oil (usually if it is vertical, i.e., oil doesnt drain out when you go to reattach it.)
Inside the middle of the opening on the old ST2808, there was a small open-topped metal cylinder at the bottom (top?) of the filter - furthest away from the open end of the filter. Is this the anti-drainback valve or something? The newer ST2808 did not have any such thing in the middle of the opening. Isn't this a significant variation?
The newer ST2808 also seemed to have slightly larger and slightly fewer holes inside the filter.
I can never remember - is an anti-drainback unnecessary in a vertical filter application, or in a horizontal application, or neither?
I ended up buying the 2 old ones - figured I'd grab them just in case they're better than the newer ones, since the old ones seem pretty scarce.
Popular consensus seems to still have it that Champion Labs makes the Supertech house brand filters for Walmart.
BTW that 2808 would be the oversize filter I may use on my son-in-laws Nissan. I have been using the Mobil 1 but I'm done with that. I need to stop spending so much.
Next time I'm at Wal-Mart, I'll take another look.
seriously e mail ST
http://www.baldwinfilters.com/index.html
the spec on the filters are great.
odd that a b33 baldwin crosses to 13 toyota fiters?????
I have had the feeling for years that the real reason there are so many sizes is to create market pockets where they can charge a lot more money individually for essentially the same product. A 13-1 ratio really stands out. As they see that their strategy may or may not be working they reconsider consolidating.
To give you a for instance, my TLC oil filter (oem 3.25 ea) is crossed with a Fram PH8A oil filter (2.50 ea). Toyota has seen fit to change the stock # at least 3 times. At least one of those times they have decreased the size of the oil filter by app 1/3 to 1/2. Do you think the price of the latest stock # is priced higher or lower?The latest one is (4.86 ea) The money may not seem like a lot but the % in this case approaches 50% higher.
In some ways this is not rocket science. The task is to filter oil under pressure, though usually a synthetic filter media and if the media can't handle all the flow, provide an overflow valve so that oil can reach criticial areas with or without filtering. All filters have to pass some "J xxx" SAE test, but that fact is not commonly known or documented.
A small for example: It is widely know that a dual in tandem oil filter set up can literally keep engine oil clean for at least double the manufacturers recommended life. Why not commonly available? Well let us put it this way, the goal is not to sell LESS OIL. And the goal is not to prolong the life of "OLD" cars.
Another example is that 60% of engine wear is at start up!! There are preoil systems that can coat the moving parts before the engine starts. Don't like cold oil on the moving parts? There are engine oil heaters that can make oil toasty again before the engine turns over.
Yes, you have hit it on the head. There is no reason with current technology, that passenger cars can not go 500-700 k miles ie half to 3/4 of a million miles with minimum unscheduled maintenance. If we built our cars and light trucks as well as the trucking industry vehicles, it should easily out gun the 7 figure mark. At our normal consumption distributions (avg 12-15k miles per year)... Well I think it becomes cystal clear!?
check the specs
http://www.wixfilters.com/
Interesting - I looked up my filter for my 01 Sentra and in Baldwin the bypass was 14psi. The same filter is set at 8-11 psi in the WIX manual.
I'll take the 14 psi filter thank-you.
Still, it is not by fram.
