Visitor Agreement.
Fleetwood-
maybe they don't stock them in certain areas. I have heard from others that at walmart..they can't find any supertech oil filters..but find plenty of the supertech oil. some never heard of the supertech oil filters. could be regional how they allocate the filters. the walmarts here don't carry chevron supreme but everyone on bob's board swear they get it there up north.
Are they any more places that stock WIX filters besides NAPA Gold and Carquest Filters?
Above is the place to go to ask WIX about availability. I presume they might reveal house brands they produce.
Walmart website is www.walmart.com
What is the prefered store bought filter?
The idea that filters do very little may be supported by the recommended change interval of some automakers - many automakers recommend replacing engine oil every x miles but filter every 2x miles.
I am also in agreement.
To me car companys giving long oil change intervals are crazy. 3k to 5k changes flush the junk suspended in the oil that filters let pass. I still change the filter every oil change just to be be safe.
>You've got to ask yourself if you are willing to trust that little, inexpensive valve in the filter to not slow the flow of oil to your very expensive engine. Most modern engines have some safe guards built in that favor keeping the oil flow up, and not allowing the secondary circuit of filtration to intercede in that volume per engine speed equation.<
Surprised he did not use his impact wrench to get it on "tite'
On one of my vehicles I actually have a torque value that is buried in the 3 volume 7 in thick specs.
The value is 22ft#'s.
While I have had good experience with the turn 3/4 past just seating procedure, (after 39 years of changing oil filters) I used the 22ft#'s after seeing a slight oil drip pool. The drips have not returned!
While each and every vehicle may or may not have its own spec. that part is more or less built the same as most any vehicle so I would have no trouble putting a 22ft# spec on my other vehicles.
Incidently I use a torque wrench to get the 22#ft. I also would agree that the gasket "seating" is the operative action. In that the AC Delco PF44 oil gasket looks and acts materially like almost any other.
So I am second guessing the OEM manual by saying that 22#ft is that value that takes your post into account.
Objectively 22#ft it is an easier and more positive number to achieve than the 3/4 turn past just seating will ever be.
I just did an oil change on a '91 Dodge Spirit RT. At idle the oil pressure would drop to almost zero (the engine has probably had a hard life!), but is within limits over 1000 rpms. I've always used larger filters when possible, but never saw this:
The oil pressure hasn't dropped since I changed to the larger filter (ST8 instead of the ST16 listed for the car). I did go to 10W40 oil, but that's from 10W30. Could the filter have done this? I like having the extra oil/filter in there, but the pressure is an added benefit!
Also the thread about filters doing precious little is interesting. Maybe will take on apart and see how what I can find in the filter element.
